hi
Can anyone give me some guidance on clutch cable adjustment on a 1.2. Have recently had this car passed on for my daughter to learn on. Clutch seems to bite quite high, not a problem for me but seems to make it harder for a learner. Not sure if this is normal or whether I need to make adjustments or is it is self adjusting?
Can anyone advise?
thanks
Clutch adjustment
Re: Clutch adjustment
I'd think that all 9N Polos have a hydraulic clutch, so no adjustment provided.
Correct, not adjustable
Thanks for your comments.
You are correct - what i thought was the clutch cable with an adjuster was, when i got my daughter to press the clutch, was the gear linkage!!
Oops! Feel a bit of a fool now!
GJ
GJ
