Why does the Polo GTI have a 6 speed DSG?
TElwoody
Drives: VW Polo 2018
Post by TElwoody »
I've always wondered this. Why does the Polo GTI have a 6 speed DSG? Is it one of these two things?
1) It's too expensive
2) It wouldn't fit
Would you expect the facelift Polo GTI in 2021-2022 to have the 7 speed DSG?
giannis159
Drives: polo aw Rline 1.0 115ps
Re: Why does the Polo GTI have a 6 speed DSG?
Post by giannis159 »
Dsg7 sucks thats why. Is has problems all these years. So in higher performance best dsg.
Multiple possibilities.
1. Finite manufacturing capacity so that only so many of each of the 6 and 7 speed wet clutch variants can be manufactured. Some cars get priority for the 7 speed variant e.g Golf 7.5 and 8 performance variants.
2. Cost. I would imagine the 7 speed units comes at a higher price, although when you could still get manual variant of 7.5 Golf R, the price differential between manual and DSG was £1450, same as it was for Golf GTI where the 6 speed DSG was still an option.
3. No real economy gain. 7.5 Golf GTI and R variants have a taller 7th gear for economy gains. They have extra torque over the Polo GTI - taller gearing without the torque to handle it won't give you better economy.
The Golf GTD only had access to the 6 speed wet clutch DSG. Tall gearing on that already due to the torque available, likely no decent gains in having that 7th cog.
The Polo GTI has quite tall gearing - at 80mph, the Polo is doing 2400rpm in 6th, the Golf GTD 6th at 80 is about 2200rpm, my old Golf R manual was 3100rpm in 6th at 80 (same as old 6 speed DSG), but the new 7 speed DSG R is about 2700rpm in 7th at 80. Gains to be had with the R, but not the Polo. The 7 speed R's fuel economy is quite a bit better than the 6 speed DSG R.
All comments above relate to the wet clutch variants of the 6 (DQ250) and 7 speed DSG box, not the dry clutch 7 speed box (DQ200) that VAG currently fit to models under 170ps.
