Auto door lock - disable?
Simonz
Drives: 2023 Life TSI
Post by Simonz »
Hi
I recently swapped my 2018 SE for a new Match 70 plate. Some improvements on the old model and drives nicer, however I noticed that when driving the auto door lock activates at 10mph and then when you turn off the ignition it unlocks the doors. On the old model I could de-activate this on a menu in the display but I can't find anything on this new one. I wondered if they have updated the software - has anyone else noticed this on 70 plate Polos? It's annoying I preferred it turned off instead of that clunk noise every time you set off.
Thanks.
Re: Auto door lock - disable?
I’ve not checked the car settings in my car to see if it can be deactivated. In other VW’s I’ve had with this feature, you’ve always needed to activate it (default position was auto lock ‘off’). On the basis it has also auto locked on my current car from day one without me needing to set it, I assumed either a) auto lock was now the default or b) it was no longer possible to change it in the car settings menus, unless it could be coded out with something like VCDS or OBD11.
Personally, I prefer it auto locking for safety reasons and can’t say I really notice the locking sound, although now you’ve mentioned it, I’ll probably notice it every time! 😀.
ho8882000
Drives: 2019 (AW)
Post by ho8882000 »
Simonz wrote: Mon Oct 19, 2020 9:13 am Hi
Thanks.
Hello Simonz,
You can disable the "Auto Door Lock at Speed" using VCDS:
1. Select "09 - Central Elect" control module
2. Select "Security Access - 16" from the "Open Controller" screen
3. Enter the magic number 31347 and return to the "Open Controller" screen
4. Select "Adaptation - 10" from the "Open Controller" screen
5. Go to this Channel: "ENG141654-ENG149210-ZV Autolock-Automatisches_Verriegeln_bei_Geschwindigkeit"
6. Change setting to "not active".
This works on my MY20 Polo 1.6 Conceptline.
ho8882000
Drives: 2019 (AW)
Post by ho8882000 »
Thanks.
On the other hand, if you want to disable "Auto Door Unlock when Remove Key", follow the instruction below using VCDS:
Simonz
Post by Simonz »
Thanks for the replies, it seems it is default on newer models. My options seem to be live with the auto locking or invest in the coding kit and alter the setting - https://www.ilexa.co.uk/shop/VCDS-HEX-V2-Ent3VIN
ho8882000
Drives: 2019 (AW)
Post by ho8882000 »
Simonz wrote: Mon Oct 19, 2020 4:00 pm Thanks for the replies, it seems it is default on newer models. My options seem to be live with the auto locking or invest in the coding kit and alter the setting - https://www.ilexa.co.uk/shop/VCDS-HEX-V2-Ent3VIN
My Polo build in August 2019 at South Africa.
It comes with both "Door Auto Lock at Speed" & "Door Auto Unlock when Remove Key", I think this is standard on all Polo AW.
Due to my Polo being a Conceptline, the only thing that my Polo is a bit different from the other Polo AW, is it come standard with "Auto Start-Stop" disabled. :D
Alan_p71
Drives: 2019 Gti+
Post by Alan_p71 »
Hi all, our polo gti+ locks the doors at about 10mph and stays locked till you either use the handle to open door or press the lock/unlock button on door. Our previous Golf allowed auto lock to be disabled via the menus but there is no option for this on the polo, at least not on our one. The manual does mention that when you put the gear box in p the doors unlock, I think that works on other VW models but does not work on the polo either.
Don’t have any VCDS gubbins, so will just have to leave car as is which suits me fine 😀
Alan_p71 wrote: Mon Oct 19, 2020 6:36 pm Hi all, our polo gti+ locks the doors at about 10mph and stays locked till you either use the handle to open door or press the lock/unlock button on door. Our previous Golf allowed auto lock to be disabled via the menus but there is no option for this on the polo, at least not on our one. The manual does mention that when you put the gear box in p the doors unlock, I think that works on other VW models but does not work on the polo either.
Mine works the same. I checked the car settings menus earlier today and as you’ve said, there isn’t an option to disable the auto lock function.
The way it’s been set up to work suits me fine too. I don’t know how desirable the Polo GTI+ is to would-be car jackers but if it is, then the auto locking function helps minimise the risk of it happening.
redgti
Drives: 2020 Polo GTI+
Post by redgti »
I've been trying to do this on a 2020 GTI+ using the above with VCDS.
The setting takes but the car just seems to ignore it and the doors still lock when you hit ~10MPH.
I changed the ENG141654-ENG149210-ZV Autolock-Automatisches_Verriegeln_bei_Geschwindigkeit to not active
Can anyone shed some light?
Maarten
Post by Maarten »
I can adjust this in the radio menu in my car, it's under locking and opening
Maarten wrote: Fri Apr 12, 2024 12:15 pm I can adjust this in the radio menu in my car, it's under locking and opening
That option doesn’t exist on my pre-facelift 2020 GTI+. I had a T-Roc as a courtesy car in 2019 and that car did have the option to enable / disable auto locking in the car settings via the infotainment screen.
Not being able to disable it has never bothered me. If the enable / disable option was there, then I’d have enabled it anyway 🙂.
Maarten
Post by Maarten »
Probably only the MIB3 models then?
Not sure, both my Polo and my T-Cross (2021) have this option.
redgti
Post by redgti »
Found the solution!
Changed
ENG141654-ENG149214-ZV Autolock-Menuesteuerung ZV Autolock-Unlock
I can't remember what the option was called, something like optional or similar. It's obvious anyway.
That puts the item in the menu, where it should have been in the first place, IMO.
This is on a 2020 GTI+ keyless. I love VCDS!
Maarten
Post by Maarten »
That's the one I have too.
Glad you found it!
redgti
Post by redgti »
Thanks!
My Mum is very happy not to have her car 'locking her in' anymore.
(Tried explaining that it doesn't do that but hey!)
