fog and cornering light retrofit
Polobear6r
Drives: Polo
Post by Polobear6r »
My polo 6r doesn’t have fog lights. I don’t miss them that much but I really would like cornering lights. And if there is an extra benefit that I have fog lights as well that would be great
I have a 87 BCM with 'since yesterdag' a working Cruisecontrol Retrofit!!! thanks to u guys! (and a friend) The 87 BCM does support cornering lights, i hope?
I came across this picture with the 3 options.
1 Fog and Cornering lights and DRL
2 Fog and cornering
3 DRL
And someone pointed out this wiring loom
https://www.hz-design.eu/vw-polo-6r-6c- ... w_358_1292
I found some ‘not to expensive’ 2nd hand fog lights with plastic covers. Model 1. So fog, cornering and DRL.
I don’t really care about DRL. But is the wiring loom and the fog lights all that I need?
What else do I need if I (maybe in the future, or at the same time) want to get DRL also working?
https://nl.aliexpress.com/item/32837624 ... 4c4dh8SFmr
I like to use this light switch for automated lights. Is that going to work in combination with fog/cornering lights?
Does someone have a wireling diagram that i can use in my situation?
Re: fog and cornering light retrofit
Does your car have esp? Or a steering angle sensor?
Polobear6r
Drives: Polo
iichel wrote: Thu Feb 25, 2021 8:43 pm Does your car have esp? Or a steering angle sensor?
I dont know for sure. How can i check this? Does it show in a VCDS output?
I don't have a recent output but this was when i changed my BCM to an 87
Tuesday,09,June,2020,19:23:46:23303
VCDS Version: 20.4.1.0 (x64)
www.Ross-Tech.com
VIN: WVWZZZ6RZCXXXXXXX   License Plate:
Mileage: 235210km-146152mi   Repair Order:
Chassis Type: 6R-VW25 (6N0)
Scan: 01 03 04 08 09 15 17 19 25 44 56
VIN: WVWZZZ6RZCXXXXXXX   Mileage: 235210km-146152miles
56-Radio -- Status: Cannot be reached 1100
Address 01: Engine (J623-CGPB)       Labels:. 03E-906-019-CGP.clb
   Part No SW: 03E 906 019 M    HW: 03E 906 019 B
   Component: SIMOS11.1     H03 8949
   Revision: --------    Serial number:
   Coding: 00110016000400080000
   Shop #: WSC 00788 648 00255
   ASAM Dataset: EV_ECM12MPI02103E906019M 001007
   ROD: EV_ECM12MPI02103E906019A.rod
   VCID: 2E57F709714C42F6A9-807A
2 Faults Found:
6093 - Catalyst System; Bank 1
          P0420 00 [101] - Efficiency Below Threshold
                    Fault Status: 00000001
                    Fault Priority: 2
                    Fault Frequency: 1
                    Mileage: 0 km
                    Date: 2000.00.00
                    Time: 00:00:00
                    Engine speed: 0.00 /min
                    Normed load value: 0.0 %
                    Vehicle speed: 0 km/h
                    Coolant temperature: -40 °C
                    Intake air temperature: -40 °C
                    Ambient air pressure: 0 mbar
                    Voltage terminal 30: 0.000 V
                    Test of catalytic converter: measured value-EFF_CAT_DIAG_OBD[1]: 0.000000
                    Cat. temperature: bank 1: -273.14999 °C
                    Engine speed: 0 /min
                    Air mass: actual value:-MAF: 0.00 mg/stroke
10964 - Bank 1: CMP Sensor (G40) / Engine Speed Sensor (G28)
          P0016 00 [096] - Incorrect Correlation
          Intermittent - Not Confirmed - Tested Since Memory Clear
                    Fault Priority: 2
                    Fault Frequency: 1
                    Mileage: 235141 km
                    Date: 2020.06.04
                    Time: 18:37:21
                    Engine speed: 924.00 /min
                    Normed load value: 22.7 %
                    Coolant temperature: 80 °C
                    Intake air temperature: 38 °C
                    Ambient air pressure: 990 mbar
                    Voltage terminal 30: 12.085 V
                    Unlearning counter according OBD: 36
                    Time since engine start: 3 s
                    Engine torque: 25.87500 Nm
                    Accelerator pedal travel-Accelerator position: 0.00 %
                    Ignition angle of current cylinder: actual value-Ignition angle: actual: -3.000 °
Readiness: 0000 0000
Address 03: ABS Brakes (J104)       Labels:. 6R0-907-37x-ESP82.clb
   Part No SW: 6R0 907 379 AK    HW: 6R0 907 379 AF
   Revision: --------
   Coding: 210224E3217000B6842924EB84DA00401100
   VCID: 071962ADB27633BE4A-8052
Address 08: Auto HVAC (J301)       Labels: 6R0-820-045-9AB.clb
   Part No SW: 6R0 820 045 F    HW: 6R0 820 045 F
   Component: Man AC         02 0101
   Revision: 0002S 02
   VCID: 316DEC7568725D0EB4-8064
   Part No SW: 6R0 937 087 H    HW: 6R0 937 087
   Component: BCM PQ25 H+4  H46 0230
   Revision: BF046001    Serial number: 0394 035110798
   Coding: 62B02BBF08A10048002008002D2B0C900040410F60060000200000000000
   Shop #: WSC 124697 483 00190
   VCID: 428FB3B9DDD4D6965D-8016
   Subsystem 1 - Part No SW: 6R0 959 801 AB    HW: 6R0 959 801 AB  Labels: 6R0-959-801.CLB
   Component: J386__TSG_FT  008 1611
   Serial number: KU0KU014061100014122
   Coding: 18BC30
   Subsystem 2 - Part No SW: 6R0 959 802 AD    HW: 6R0 959 802 AD  Labels: 6R0-959-802.CLB
   Component: J387__TSG_BT  008 1611
   Serial number: KU0KU016061100013956
   Coding: 08BC30
7 Faults Found:
00901 - Back-Up Lamps
            011 - Open Circuit
                    Fault Status: 01101011
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 104
                    Mileage: 235217 km
                    Time Indication: 0
                    Date: 2014.10.31
                    Time: 00:00:02
03080 - Activation for interior lights
            006 - Short to Plus - Intermittent
                    Fault Status: 00100110
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 144
                    Time Indication: 0
00920 - Heated Outside Mirrors; Driver Side (Z4) / Passenger Side (Z5)
            011 - Open Circuit
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 104
                    Time Indication: 0
01334 - Door Control Module; Rear Right (J389)
            004 - No Signal/Communication
                    Fault Status: 01100100
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 104
                    Time Indication: 0
01333 - Door Control Module; Rear Left (J388)
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 104
                    Time Indication: 0
01332 - Door Control Module; Passenger Side (J387)
                    Fault Status: 00100100
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 144
                    Time Indication: 0
01331 - Door Control Module; Driver Side (J386)
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 144
                    Time Indication: 0
   Component: VW10Airbag022 H09 0020
   Revision: --------    Serial number: 003GX00PVUS.
   Coding: 003232
   ROD: EV_AirbaVW10BPAVW250.rod
   VCID: 4A9F9B99EDE40ED695-801E
   Serial number: 3575HRB404V0JR9KC0K6
   Serial number: 3585HRB40570ISD6CGHU
   Serial number: 3515RRB40530L9U4H1JK
   Serial number: 3525RRB405D0L2V2C8FL
   Part No SW: 6R0 920 860 G    HW: 6R0 920 860 G
   Component: KOMBI         H03 0505
   Coding: 140200
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04113
   VCID: 387BD15183088C46F3-806C
   Part No SW: 6N0 909 901     HW: 6R0 937 087
   Component: GW-K-CAN TP20 0230
   Coding: 002200
   VCID: 70EB2971A3F81406FB-8024
5 Faults Found:
            000 - - - Intermittent
                    Fault Status: 00100000
                    Fault Priority: 2
                    Fault Frequency: 5
                    Reset counter: 255
                    Time Indication: 0
01315 - Transmission Control Module
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 104
                    Mileage: 235217 km
                    Time Indication: 0
                    Date: 2014.10.31
                    Time: 00:01:40
01304 - Radio
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 104
                    Time Indication: 0
02078 - Media Player Position 3 (R120)
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 104
                    Mileage: 125373 km
                    Time Indication: 0
                    Date: 2015.01.24
                    Time: 03:30:16
03075 - Parallel Parking Assistance Control Module (J791)
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 104
                    Mileage: 235217 km
                    Time Indication: 0
                    Date: 2014.10.31
                    Time: 00:01:41
   Component: IMMO          H03 0505
   Serial number:
   Shop #: WSC 00000 000 00000
   VCID: 6ADF3B198D24EED6B5-803E
   Part No: 6R0 423 156 B
   Coding: 11250
   Shop #: WSC 00788
   VCID: 2F69EA0DEA464BFEA2-807A
Address 56: Radio
Cannot be reached
End-------------------------(Elapsed Time: 02:17)--------------------------
It does say:
Component: LenkhilfeTRW V277
Coding: 11250
Shop #: WSC 00788
Wiki says: https://en.wikipedia.org/wiki/Volkswagen_Polo_Mk5 that all european models exept french and turkish have ESP by default. So i guess yes i have it.
Check adress 03 ;)
Polobear6r
Drives: Polo
Haha i see, thanks! :D
I see you also completed your cruise control. Good job
FFA76
Drives: Polo 6R BlueGT
Post by FFA76 »
Am I not duidelijk enough?
Polobear6r
Drives: Polo
FFA76 wrote: Fri Feb 26, 2021 10:40 pm Am I not duidelijk enough?
I always post questions on multiple fora and base my opinions on that. Everything i learn here i can share on other forums and visa versa.
Of course your help is greatly apriciated. But my german is not that great and i was looking for an wiring diagram.
Thanks to iichel and ciclo i manged to install cruisecontrol and im verry thankful for that.
Just send him to erwin for the wiring diagram. it only costs a couple of euros and it's the most recent version you can find.
Don't spend too much energy and time on people that just ask without introduction or addition to the forum.
Polobear6r
Drives: Polo
Thanks, u are such a nice guy.
He send a wiring manual from kufatec that is in english. So im sure that will be fine.
FFA76
Post by FFA76 »
What a nice guy.
Hope this manual answers all your questions.
Polobear6r
Drives: Polo
Well i installed the fog/cornering lights last saturday. Everything went well but the automatic light switch I got from aliexpress does not seem to work well.
I looks like the cornering lights do work however so I'm happy with that.
Can someone tell what VCDS coding needs to be done to enable fog lights ? When I turn on the front fog switch no light turns on on the dashboard. While there is a dashboard light when I turn on the rear foglight. So that makes me think I missed something in VCDS ?
Also this happens after driving in auto light mode and i turn off the engine.... That seems a big problem :cry:
https://drive.google.com/file/d/1tf7nzg ... sp=sharing
Not sure if Google drive video's work so i uploaded it to youtube.
Please show a current scan of the car
Polobear6r
Drives: Polo
This is the latest
Sunday,14,March,2021,15:02:02:23303
VCDS Version: 21.3.0.0 (x64)
Data version: 20210226 DS325.0
www.Ross-Tech.com
VIN: WVWZZZ6RZCXXXXXXX   License Plate: XX-XX-XX
Mileage: 246190km-152975mi   Repair Order:
VIN: WVWZZZ6RZCXXXXXXX   Mileage: 246190km-152975miles
   Coding: 00110016002400080000
   VCID: 2E57F709714C42FB61-807A
Readiness: 0110 0101
   Revision: --------
   VCID: 071962ADB27633B382-8052
   Revision: 0002S 02
   VCID: 316DEC7568725D037C-8064
Address 09: Cent. Elect. (J519)       Labels: 6R0-937-08x-09.clb
   Component: BCM PQ25 H+4  H46 BCM PQ25 H+4  H46 02300230
   Coding: 7BB02BBF08A10048002008006D2B0C9000C0410F60060000200000000000
   VCID: 428FB3B9DDD4D69B95-8016
   Coding: 18BC30
   Subsystem 2 - Part No: 6R0 959 802 AD  Labels: 6R0-959-802.CLB
   Coding: 08BC30
No Faults Found
  or DTCs not supported by controller
  or a communication error occurred
   Coding: 003232
   VCID: 4A9F9B99EDE40EDB5D-801E
   Coding: 140A00
   VCID: 387BD15183088C4B3B-806C
   Coding: 002200
   VCID: 70EB2971A3F8140B33-8024
   Serial number:
   VCID: 6ADF3B198D24EEDB7D-803E
   Coding: 11220
   Shop #: WSC 00788
   VCID: 2F69EA0DEA464BF36A-807A
End-------------------------(Elapsed Time: 02:12)--------------------------
   Revision: --------
   Revision: 0002S 02
   Coding: 18BC30
   Coding: 08BC30
1 Fault Found:
00907 - Intervention load Management
            000 - -
                    Fault Status: 01100000
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 232
                    Mileage: 246195 km
                    Time Indication: 0
                    Date: 2015.08.05
                    Time: 02:23:60
   Coding: 003232
   Serial number: 357
   Coding: 140A00
   Coding: 002200
   Serial number:
   Coding: 11220
   Shop #: WSC 00788
End-------------------------(Elapsed Time: 01:57)--------------------------
Enable byte 21 bit 7 please in the bcm
