Polo 6R GTi Footwell Lights
RooshevN
Drives: 6R GTi
Post by RooshevN »
Hi all
I swapped out the oem footwell light for red led's. Now as standard the operation is as follows:
1. Footwells come on when car unlocked.
2. Footwells come on when door is open.
3. Footwells go off when driving or car is locked.
How do i keep them on while driving? I have an Obdeleven device but unable to find any address relating to footwell lights in the bcm. Was anyone able to code this successfully using the oem lights. I know many have retrofitted footwell lights but mine came with it. Any help will be appreciated.
Re: Polo 6R GTi Footwell Lights
What is the coding for Footwells come on when car unlocked
RooshevN
Drives: 6R GTi
Post by RooshevN »
amer6R wrote: Sat Sep 25, 2021 6:02 pm Hi,
Sorry mate not sure. The car came like that from factory. I am unable to find any coding in obdeleven. There are bytes and bits that have no labels so maybe it's one of them.
ag69
Drives: 1.2TSi 77Kw 7DSG
Post by ag69 »
If you want then take power from headlight switch - which is on/illuminated -- which could solve your problem.
There is no coding involved in the footwell lights. they behave in the same way as the dome lights when set to the middle position.
A different approach should be taken in case you want ambient lighting on your 6R GTI while driving (at night).
RooshevN
Drives: 6R GTi
Post by RooshevN »
ciclo wrote: Sun Oct 03, 2021 7:03 am A different approach should be taken in case you want ambient lighting on your 6R GTI while driving (at night).
Like doing a retrofit?
mirceaculita
Drives: 6R 1.2TDI 75hp
Post by mirceaculita »
My car didn't come with footwell lights so I installed this kinda kit
I hooked up the power to the light switch so they only turn on when I have my headlights on. The state they were in last time gets saved so I don't have to set the color/brightness every time I turn them on.
I am really happy with them. I placed the signal box above the fuse compartment, under the steering wheel column so it's easily accessible for changing the colors.
I have no visible wires and everything looks as OEM as it gets(unless you poke your head under the seats and see the light strips)
RooshevN wrote: Mon Oct 04, 2021 9:08 pm
Yes, leaving the installation of the footwell lights as it is from the factory.
In all the interior switches that have backlighting there is a blue/gray wire (or gray, in the last models), it is a positive signal named '58', ... if you have a factory dimmer it is named '58d'. Use this signal/wire to connect the positive of the new LED Ambient lights to this wire, the negative you must connect it directly to earth/ground/chassis.
If you take the positive signal from the light switch, it must be from the T17/17 wire.
RooshevN
Drives: 6R GTi
Post by RooshevN »
ciclo wrote: Tue Oct 05, 2021 3:55 am
Thanks Ciclo. So glad i joined this forum with such knowledgeable people.
