Retrofit mib2 3Q0035846A problem
Homer51
Drives: Polo 6C
Post by Homer51 »
I retrofited RCD330 Carplay (Ali) to a mib2 3Q0035846A on my Polo 6c 2015.
All works like expected except park assist and rear camera (static in rear logo). I can have in same time OPS PDC and rear camera.
I made a test with a mib1 and same coding and it works, (except screen resolution for sure ..)
My question is, does the mib2 3Q0035846A is able to show in same time pdc incrusted and camera ?
Thanks !
OPS OK.jpg (1.68 MiB) Viewed 16789 times
cam ali.JPG (368.74 KiB) Viewed 16789 times
Homer51
Drives: Polo 6C
Re: Retrofit mib2 3Q0035846A problem
Post by Homer51 »
here is my log any idea ?
unit defective ?
park 10
IDE00001-Production mode,Deactivating ,3
IDE01165-Park assist activation tone,On ,1
IDE01169-Audio lowering request,On ,1
IDE02332-Deactivate production mode,0 ,3
IDE03782-Switch-off speed for parking assist,15 km/h,1
MAS01426-Rear parking aid buzzer: volume,Stage 4 ,1
MAS01427-Speaker frequency for rear park assist,Stage 4 ,1
Homer51
Drives: Polo 6C
Post by Homer51 »
5F
IDE00001-Production mode,00 00 00 ,3
IDE00346-Summertime-automatic,Europe ,1
IDE00758-Base volume of telephone,50 %,1
IDE00759-Base volume of speech output,50 %,1
IDE00760-Microphone sensitivity,0 dB,1
IDE00769-Call number 1 for info call,5E 05 A1 30 32 37 77 69 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,23
IDE00770-Number 1 for roadside assistance,5E 05 A1 80 00 22 04 00 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,23
IDE00820-ENG117828-Activating and deactivating all development messages-Infotainment_CAN_Messages,OFF ,1
IDE00820-ENG117829-Activating and deactivating all development messages-MIB_CAN_Messages,OFF ,1
IDE00845-Wheel circumference,0 mm,2
IDE02121-CD eject button,Enabled ,1
IDE02122-Developer mode,activated ,1
IDE02330-Call number 2 for info call,5E 06 91 33 23 73 73 97 F6 FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,23
IDE02331-Number 2 for roadside assistance,5E 06 91 33 24 26 89 77 F0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,23
IDE02476-MAS03001-Electrical test of speakers-Mode,automatic ,49
IDE02476-ENG117360-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_1_Test_Frequency,19000 Hz,49
IDE02476-ENG117361-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_1_Test_Volume,36 ,49
IDE02476-ENG117378-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_10_Test_Frequency,19000 Hz,49
IDE02476-ENG117379-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_10_Test_Volume,36 ,49
IDE02476-ENG117380-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_11_Test_Frequency,19000 Hz,49
IDE02476-ENG117381-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_11_Test_Volume,36 ,49
IDE02476-ENG117382-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_12_Test_Frequency,19000 Hz,49
IDE02476-ENG117383-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_12_Test_Volume,36 ,49
IDE02476-ENG117384-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_13_Test_Frequency,19000 Hz,49
IDE02476-ENG117385-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_13_Test_Volume,36 ,49
IDE02476-ENG117386-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_14_Test_Frequency,19000 Hz,49
IDE02476-ENG117387-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_14_Test_Volume,36 ,49
IDE02476-ENG117388-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_15_Test_Frequency,19000 Hz,49
IDE02476-ENG117389-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_15_Test_Volume,36 ,49
IDE02476-ENG117390-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_16_Test_Frequency,19000 Hz,49
IDE02476-ENG117391-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_16_Test_Volume,36 ,49
IDE02476-ENG117362-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_2_Test_Frequency,19000 Hz,49
IDE02476-ENG117363-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_2_Test_Volume,36 ,49
IDE02476-ENG117364-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_3_Test_Frequency,19000 Hz,49
IDE02476-ENG117365-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_3_Test_Volume,36 ,49
IDE02476-ENG117366-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_4_Test_Frequency,19000 Hz,49
IDE02476-ENG117367-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_4_Test_Volume,36 ,49
IDE02476-ENG117368-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_5_Test_Frequency,19000 Hz,49
IDE02476-ENG117369-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_5_Test_Volume,36 ,49
IDE02476-ENG117370-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_6_Test_Frequency,19000 Hz,49
IDE02476-ENG117371-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_6_Test_Volume,36 ,49
IDE02476-ENG117372-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_7_Test_Frequency,19000 Hz,49
IDE02476-ENG117373-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_7_Test_Volume,36 ,49
IDE02476-ENG117374-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_8_Test_Frequency,19000 Hz,49
IDE02476-ENG117375-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_8_Test_Volume,36 ,49
IDE02476-ENG117376-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_9_Test_Frequency,19000 Hz,49
IDE02476-ENG117377-Electrical test of speakers-Parameter_AC-Diagnostics_Channel_9_Test_Volume,36 ,49
IDE02502-Confirmation of installation change,C6 69 ,2
IDE02607-Wheel pulse,0 ,2
IDE02699-Number 1 for roadside assistance,5E 02 A1 11 F2 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,23
IDE02701-Number 1 (roaming) for roadside assistance,5E 02 A1 11 F2 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,23
IDE04331-Selection of release codes for a SWaP function,FF FF FF FF ,4
IDE04550-Bluetooth: Sniff mode,OFF ,1
IDE05111-Fee-based traffic information (TMC),32771 ,2
IDE05113-Infotainment Recorder,activated ,1
IDE06425-Dynamometer mode: functional,not activated ,1
IDE08814-IDE04033-Navigation receiver GNSS configuration-Compass,OFF ,1
IDE08814-MAS01570-Navigation receiver GNSS configuration-Default,On ,1
IDE08814-MAS02614-Navigation receiver GNSS configuration-GPS,OFF ,1
IDE08814-MAS07828-Navigation receiver GNSS configuration-Galileo,OFF ,1
IDE08814-MAS07829-Navigation receiver GNSS configuration-Glonass,OFF ,1
IDE08814-ENG142047-Navigation receiver GNSS configuration-external_gps_1,OFF ,1
IDE08814-ENG142048-Navigation receiver GNSS configuration-external_gps_2,OFF ,1
IDE10221-MAS00839-Audio Management Input Gain Generation 2-TV Tuner,-128 ,40
IDE10221-MAS00846-Audio Management Input Gain Generation 2-Satellite radio,5 ,40
IDE10221-MAS01984-Audio Management Input Gain Generation 2-Radio (FM),-128 ,40
IDE10221-MAS01985-Audio Management Input Gain Generation 2-Radio (AM),-128 ,40
IDE10221-MAS01986-Audio Management Input Gain Generation 2-Digital radio (DAB),-128 ,40
IDE10221-ENG125854-Audio Management Input Gain Generation 2-Exbox_DMB,-128 ,40
IDE10221-ENG117430-Audio Management Input Gain Generation 2-HFP,-128 ,40
IDE10221-ENG125846-Audio Management Input Gain Generation 2-Media_Airplay,-128 ,40
IDE10221-ENG125837-Audio Management Input Gain Generation 2-Media_AUX_Adapter,-128 ,40
IDE10221-ENG125836-Audio Management Input Gain Generation 2-Media_AUXIN,-128 ,40
IDE10221-ENG125843-Audio Management Input Gain Generation 2-Media_Bluray,-128 ,40
IDE10221-ENG125841-Audio Management Input Gain Generation 2-Media_BTDevice,-128 ,40
IDE10221-ENG125838-Audio Management Input Gain Generation 2-Media_CDA,-128 ,40
IDE10221-ENG125848-Audio Management Input Gain Generation 2-Media_Cloud,-128 ,40
IDE10221-ENG125839-Audio Management Input Gain Generation 2-Media_DVD,-128 ,40
IDE10221-ENG125844-Audio Management Input Gain Generation 2-Media_HDMI,-128 ,40
IDE10221-ENG125840-Audio Management Input Gain Generation 2-Media_MFP,-128 ,40
IDE10221-ENG125847-Audio Management Input Gain Generation 2-Media_UPNP,-128 ,40
IDE10221-ENG125855-Audio Management Input Gain Generation 2-Mirrorlink,-128 ,40
IDE10221-ENG125859-Audio Management Input Gain Generation 2-Phone_Ringer_MFP,-128 ,40
IDE10221-ENG125860-Audio Management Input Gain Generation 2-Phone_Ringer_OB,-3 ,40
IDE10221-ENG125858-Audio Management Input Gain Generation 2-Phone_Voice,-128 ,40
IDE10221-ENG125842-Audio Management Input Gain Generation 2-TA_Tuner_FM,-128 ,40
IDE10221-ENG125850-Audio Management Input Gain Generation 2-Tone_Beep,-128 ,40
IDE10221-ENG125853-Audio Management Input Gain Generation 2-Tone_Messaging,-128 ,40
IDE10221-ENG125852-Audio Management Input Gain Generation 2-Tone_Touchscreen,6 ,40
IDE10221-ENG125851-Audio Management Input Gain Generation 2-Tone_Warning,-128 ,40
IDE10221-ENG125856-Audio Management Input Gain Generation 2-TTS_Nav,-128 ,40
IDE10221-ENG125857-Audio Management Input Gain Generation 2-TTS_SDS,-128 ,40
IDE10221-ENG125845-Audio Management Input Gain Generation 2-Tuner_Online,-128 ,40
IDE10221-ENG125849-Audio Management Input Gain Generation 2-Tuner_Personal,-128 ,40
IDE10221-ENG125835-Audio Management Input Gain Generation 2-Tuner_TI,-128 ,40
IDE10221-ENG125861-Audio Management Input Gain Generation 2-TV_AV_IN,-128 ,40
IDE10480-MAS10741-Interface for external media: activation-Connection 1,not activated ,4
IDE10480-MAS10742-Interface for external media: activation-Connection 2,not activated ,4
IDE10480-MAS10743-Interface for external media: activation-Connection 3,not activated ,4
IDE10480-MAS10744-Interface for external media: activation-Connection 4,not activated ,4
IDE10604-Menu entries for mobile online services,activated ,1
IDE11122-Country identification: country of sale HMI,FR ,2
IDE11502-ENG127601-Locked menu contents-FB_CAR_0,non_blocked ,21
IDE11502-ENG127602-Locked menu contents-FB_CAR_1,non_blocked ,21
IDE11502-ENG127611-Locked menu contents-FB_CAR_10,non_blocked ,21
IDE11502-ENG127612-Locked menu contents-FB_CAR_11,non_blocked ,21
IDE11502-ENG127613-Locked menu contents-FB_CAR_12,non_blocked ,21
IDE11502-ENG127614-Locked menu contents-FB_CAR_13,non_blocked ,21
IDE11502-ENG127615-Locked menu contents-FB_CAR_14,non_blocked ,21
IDE11502-ENG127616-Locked menu contents-FB_CAR_15,non_blocked ,21
IDE11502-ENG127617-Locked menu contents-FB_CAR_16,non_blocked ,21
IDE11502-ENG127618-Locked menu contents-FB_CAR_17,non_blocked ,21
IDE11502-ENG127619-Locked menu contents-FB_CAR_18,non_blocked ,21
IDE11502-ENG127620-Locked menu contents-FB_CAR_19,non_blocked ,21
IDE11502-ENG127603-Locked menu contents-FB_CAR_2,non_blocked ,21
IDE11502-ENG127621-Locked menu contents-FB_CAR_20,non_blocked ,21
IDE11502-ENG127622-Locked menu contents-FB_CAR_21,non_blocked ,21
IDE11502-ENG127623-Locked menu contents-FB_CAR_22,non_blocked ,21
IDE11502-ENG127624-Locked menu contents-FB_CAR_23,non_blocked ,21
IDE11502-ENG127604-Locked menu contents-FB_CAR_3,non_blocked ,21
IDE11502-ENG127605-Locked menu contents-FB_CAR_4,non_blocked ,21
IDE11502-ENG127606-Locked menu contents-FB_CAR_5,non_blocked ,21
IDE11502-ENG127607-Locked menu contents-FB_CAR_6,non_blocked ,21
IDE11502-ENG127608-Locked menu contents-FB_CAR_7,non_blocked ,21
IDE11502-ENG127609-Locked menu contents-FB_CAR_8,non_blocked ,21
IDE11502-ENG127610-Locked menu contents-FB_CAR_9,non_blocked ,21
IDE11502-ENG127521-Locked menu contents-FB_MEDIA_0,non_blocked ,21
IDE11502-ENG127522-Locked menu contents-FB_MEDIA_1,non_blocked ,21
IDE11502-ENG127531-Locked menu contents-FB_MEDIA_10,non_blocked ,21
IDE11502-ENG127532-Locked menu contents-FB_MEDIA_11,non_blocked ,21
IDE11502-ENG127533-Locked menu contents-FB_MEDIA_12,non_blocked ,21
IDE11502-ENG127534-Locked menu contents-FB_MEDIA_13,non_blocked ,21
IDE11502-ENG127535-Locked menu contents-FB_MEDIA_14,non_blocked ,21
IDE11502-ENG127536-Locked menu contents-FB_MEDIA_15,non_blocked ,21
IDE11502-ENG127537-Locked menu contents-FB_MEDIA_16,non_blocked ,21
IDE11502-ENG127538-Locked menu contents-FB_MEDIA_17,non_blocked ,21
IDE11502-ENG127539-Locked menu contents-FB_MEDIA_18,non_blocked ,21
IDE11502-ENG127540-Locked menu contents-FB_MEDIA_19,non_blocked ,21
IDE11502-ENG127523-Locked menu contents-FB_MEDIA_2,non_blocked ,21
IDE11502-ENG127541-Locked menu contents-FB_MEDIA_20,non_blocked ,21
IDE11502-ENG127542-Locked menu contents-FB_MEDIA_21,non_blocked ,21
IDE11502-ENG127543-Locked menu contents-FB_MEDIA_22,non_blocked ,21
IDE11502-ENG127544-Locked menu contents-FB_MEDIA_23,non_blocked ,21
IDE11502-ENG127524-Locked menu contents-FB_MEDIA_3,non_blocked ,21
IDE11502-ENG127525-Locked menu contents-FB_MEDIA_4,non_blocked ,21
IDE11502-ENG127526-Locked menu contents-FB_MEDIA_5,non_blocked ,21
IDE11502-ENG127527-Locked menu contents-FB_MEDIA_6,non_blocked ,21
IDE11502-ENG127528-Locked menu contents-FB_MEDIA_7,non_blocked ,21
IDE11502-ENG127529-Locked menu contents-FB_MEDIA_8,non_blocked ,21
IDE11502-ENG127530-Locked menu contents-FB_MEDIA_9,non_blocked ,21
CUT FOR MESSSAGE PLACE
MAS00951-Bluetooth,On ,1
MAS02809-MAS02870-Check tone frequency-High note frequency range,4000 Hz,6
MAS02809-MAS02871-Check tone frequency-Medium note frequency range,1000 Hz,6
MAS02809-MAS02872-Check tone frequency-Low note frequency range,100 Hz,6
MAS03782-WLAN,On ,1
ENG117917-BAP_Debug_Mode_Release,not_released ,1
ENG104140-Bluetooth_Phonebook_Access_Profile,PBAP ,1
ENG122227-ENG125811-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization,not activated ,60
ENG122227-ENG125814-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization_after_disclaimer,not activated ,60
ENG122227-ENG126995-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization_clamp_15_off,not activated ,60
ENG122227-ENG125812-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization_over_threshold_high,not activated ,60
ENG122227-ENG125813-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization_standstill,not activated ,60
ENG122227-ENG152538-Car_Function_Adaptations_Gen2-menu_auxiliary_ventilation,not activated ,60
ENG122227-ENG152539-Car_Function_Adaptations_Gen2-menu_auxiliary_ventilation_after_disclaimer,not activated ,60
ENG122227-ENG152540-Car_Function_Adaptations_Gen2-menu_auxiliary_ventilation_clamp_15_off,not activated ,60
ENG122227-ENG152541-Car_Function_Adaptations_Gen2-menu_auxiliary_ventilation_over_threshold_high,not activated ,60
ENG122227-ENG152542-Car_Function_Adaptations_Gen2-menu_auxiliary_ventilation_standstill,not activated ,60
ENG122227-ENG152543-Car_Function_Adaptations_Gen2-menu_crossroad_assistent,not activated ,60
ENG122227-ENG152544-Car_Function_Adaptations_Gen2-menu_crossroad_assistent_after_disclaimer,not activated ,60
ENG122227-ENG152545-Car_Function_Adaptations_Gen2-menu_crossroad_assistent_clamp_15_off,not activated ,60
ENG122227-ENG152546-Car_Function_Adaptations_Gen2-menu_crossroad_assistent_over_threshold_high,not activated ,60
ENG122227-ENG152547-Car_Function_Adaptations_Gen2-menu_crossroad_assistent_standstill,not activated ,60
ENG122227-ENG117486-Car_Function_Adaptations_Gen2-menu_display_ACC,not activated ,60
ENG122227-ENG117490-Car_Function_Adaptations_Gen2-menu_display_ACC_after_disclaimer,not activated ,60
ENG122227-ENG117487-Car_Function_Adaptations_Gen2-menu_display_ACC_operation_clamp_15_off,not activated ,60
ENG122227-ENG117488-Car_Function_Adaptations_Gen2-menu_display_ACC_over_threshold_high,not activated ,60
ENG122227-ENG117489-Car_Function_Adaptations_Gen2-menu_display_ACC_standstill,not activated ,60
ENG122227-ENG117646-Car_Function_Adaptations_Gen2-menu_display_adaptive_key,not activated ,60
ENG122227-ENG117650-Car_Function_Adaptations_Gen2-menu_display_adaptive_key_after_disclaimer,not activated ,60
ENG122227-ENG117647-Car_Function_Adaptations_Gen2-menu_display_adaptive_key_clamp_15_off,not activated ,60
ENG122227-ENG117648-Car_Function_Adaptations_Gen2-menu_display_adaptive_key_over_threshold_high,not activated ,60
ENG122227-ENG117649-Car_Function_Adaptations_Gen2-menu_display_adaptive_key_standstill,not activated ,60
ENG122227-ENG126152-Car_Function_Adaptations_Gen2-menu_display_Adblue,not activated ,60
ENG122227-ENG126155-Car_Function_Adaptations_Gen2-menu_display_Adblue_after_disclaimer,not activated ,60
ENG122227-ENG127002-Car_Function_Adaptations_Gen2-menu_display_Adblue_clamp_15_off,not activated ,60
ENG122227-ENG126153-Car_Function_Adaptations_Gen2-menu_display_Adblue_over_threshold_high,not activated ,60
ENG122227-ENG126154-Car_Function_Adaptations_Gen2-menu_display_Adblue_standstill,not activated ,60
ENG122227-ENG117591-Car_Function_Adaptations_Gen2-menu_display_air_damper,not activated ,60
ENG122227-ENG117595-Car_Function_Adaptations_Gen2-menu_display_air_damper_after_disclaimer,not activated ,60
ENG122227-ENG117592-Car_Function_Adaptations_Gen2-menu_display_air_damper_clamp_15_off,not activated ,60
ENG122227-ENG117593-Car_Function_Adaptations_Gen2-menu_display_air_damper_over_threshold_high,not activated ,60
ENG122227-ENG117594-Car_Function_Adaptations_Gen2-menu_display_air_damper_standstill,not activated ,60
ENG122227-ENG117491-Car_Function_Adaptations_Gen2-menu_display_ambient_illumination,activated ,60
ENG122227-ENG117495-Car_Function_Adaptations_Gen2-menu_display_ambient_illumination_after_disclaimer,not activated ,60
ENG122227-ENG117492-Car_Function_Adaptations_Gen2-menu_display_ambient_illumination_clamp_15_off,not activated ,60
ENG122227-ENG117493-Car_Function_Adaptations_Gen2-menu_display_ambient_illumination_over_threshold_high,activated ,60
ENG122227-ENG117494-Car_Function_Adaptations_Gen2-menu_display_ambient_illumination_standstill,not activated ,60
ENG122227-ENG122296-Car_Function_Adaptations_Gen2-menu_display_angle_of_slope,not activated ,60
ENG122227-ENG122300-Car_Function_Adaptations_Gen2-menu_display_angle_of_slope_after_disclaimer,not activated ,60
ENG122227-ENG122297-Car_Function_Adaptations_Gen2-menu_display_angle_of_slope_clamp_15_off,not activated ,60
ENG122227-ENG122298-Car_Function_Adaptations_Gen2-menu_display_angle_of_slope_over_threshold_high,not activated ,60
ENG122227-ENG122299-Car_Function_Adaptations_Gen2-menu_display_angle_of_slope_standstill,not activated ,60
ENG122227-ENG117641-Car_Function_Adaptations_Gen2-menu_display_attention_identification,not activated ,60
ENG122227-ENG117645-Car_Function_Adaptations_Gen2-menu_display_attention_identification_after_disclaimer,not activated ,60
ENG122227-ENG117642-Car_Function_Adaptations_Gen2-menu_display_attention_identification_clamp_15_off,not activated ,60
ENG122227-ENG117643-Car_Function_Adaptations_Gen2-menu_display_attention_identification_over_threshold_high,not activated ,60
ENG122227-ENG117644-Car_Function_Adaptations_Gen2-menu_display_attention_identification_standstill,not activated ,60
ENG122227-ENG117531-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating,not activated ,60
ENG122227-ENG117535-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating_after_disclaimer,not activated ,60
ENG122227-ENG117532-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating_clamp_15_off,not activated ,60
ENG122227-ENG117533-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating_over_threshold_high,not activated ,60
ENG122227-ENG117534-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating_standstill,not activated ,60
ENG122227-ENG117501-Car_Function_Adaptations_Gen2-menu_display_awv,not activated ,60
ENG122227-ENG117505-Car_Function_Adaptations_Gen2-menu_display_awv_after_disclaimer,not activated ,60
ENG122227-ENG117502-Car_Function_Adaptations_Gen2-menu_display_awv_clamp_15_off,not activated ,60
ENG122227-ENG117503-Car_Function_Adaptations_Gen2-menu_display_awv_over_threshold_high,not activated ,60
ENG122227-ENG117504-Car_Function_Adaptations_Gen2-menu_display_awv_standstill,not activated ,60
ENG122227-ENG122301-Car_Function_Adaptations_Gen2-menu_display_battery_management,not activated ,60
ENG122227-ENG122305-Car_Function_Adaptations_Gen2-menu_display_battery_management_after_disclaimer,not activated ,60
ENG122227-ENG122302-Car_Function_Adaptations_Gen2-menu_display_battery_management_clamp_15_off,not activated ,60
ENG122227-ENG122303-Car_Function_Adaptations_Gen2-menu_display_battery_management_over_threshold_high,not activated ,60
ENG122227-ENG122304-Car_Function_Adaptations_Gen2-menu_display_battery_management_standstill,not activated ,60
ENG122227-ENG117666-Car_Function_Adaptations_Gen2-menu_display_BCmE,not activated ,60
ENG122227-ENG117670-Car_Function_Adaptations_Gen2-menu_display_BCmE_after_disclaimer,not activated ,60
ENG122227-ENG117667-Car_Function_Adaptations_Gen2-menu_display_BCmE_clamp_15_off,not activated ,60
ENG122227-ENG117668-Car_Function_Adaptations_Gen2-menu_display_BCmE_over_threshold_high,not activated ,60
ENG122227-ENG117669-Car_Function_Adaptations_Gen2-menu_display_BCmE_standstill,not activated ,60
ENG122227-ENG117536-Car_Function_Adaptations_Gen2-menu_display_board_computer,activated ,60
ENG122227-ENG117540-Car_Function_Adaptations_Gen2-menu_display_board_computer_after_disclaimer,not activated ,60
ENG122227-ENG117537-Car_Function_Adaptations_Gen2-menu_display_board_computer_clamp_15_off,not activated ,60
ENG122227-ENG117538-Car_Function_Adaptations_Gen2-menu_display_board_computer_over_threshold_high,activated ,60
ENG122227-ENG117539-Car_Function_Adaptations_Gen2-menu_display_board_computer_standstill,not activated ,60
ENG122227-ENG117671-Car_Function_Adaptations_Gen2-menu_display_Brake_Function,activated ,60
ENG122227-ENG117675-Car_Function_Adaptations_Gen2-menu_display_Brake_Function_after_disclaimer,not activated ,60
ENG122227-ENG117672-Car_Function_Adaptations_Gen2-menu_display_Brake_Function_clamp_15_off,not activated ,60
ENG122227-ENG117673-Car_Function_Adaptations_Gen2-menu_display_Brake_Function_over_threshold_high,activated ,60
ENG122227-ENG117674-Car_Function_Adaptations_Gen2-menu_display_Brake_Function_standstill,not activated ,60
ENG122227-ENG117651-Car_Function_Adaptations_Gen2-menu_display_car_mirror,activated ,60
ENG122227-ENG117655-Car_Function_Adaptations_Gen2-menu_display_car_mirror_after_disclaimer,not activated ,60
ENG122227-ENG117652-Car_Function_Adaptations_Gen2-menu_display_car_mirror_clamp_15_off,not activated ,60
ENG122227-ENG117653-Car_Function_Adaptations_Gen2-menu_display_car_mirror_over_threshold_high,activated ,60
ENG122227-ENG117654-Car_Function_Adaptations_Gen2-menu_display_car_mirror_standstill,not activated ,60
ENG122227-ENG117561-Car_Function_Adaptations_Gen2-menu_display_central_locking,activated ,60
ENG122227-ENG117565-Car_Function_Adaptations_Gen2-menu_display_central_locking_after_disclaimer,not activated ,60
ENG122227-ENG117562-Car_Function_Adaptations_Gen2-menu_display_central_locking_clamp_15_off,not activated ,60
ENG122227-ENG117563-Car_Function_Adaptations_Gen2-menu_display_central_locking_over_threshold_high,activated ,60
ENG122227-ENG117564-Car_Function_Adaptations_Gen2-menu_display_central_locking_standstill,not activated ,60
ENG122227-ENG117601-Car_Function_Adaptations_Gen2-menu_display_central_unit_master,activated ,60
ENG122227-ENG117605-Car_Function_Adaptations_Gen2-menu_display_central_unit_master_after_disclaimer,not activated ,60
ENG122227-ENG117602-Car_Function_Adaptations_Gen2-menu_display_central_unit_master_clamp_15_off,not activated ,60
ENG122227-ENG117603-Car_Function_Adaptations_Gen2-menu_display_central_unit_master_over_threshold_high,activated ,60
ENG122227-ENG117604-Car_Function_Adaptations_Gen2-menu_display_central_unit_master_standstill,not activated ,60
ENG122227-ENG117571-Car_Function_Adaptations_Gen2-menu_display_charisma,not activated ,60
ENG122227-ENG117575-Car_Function_Adaptations_Gen2-menu_display_charisma_after_disclaimer,not activated ,60
ENG122227-ENG117572-Car_Function_Adaptations_Gen2-menu_display_charisma_clamp_15_off,not activated ,60
ENG122227-ENG117573-Car_Function_Adaptations_Gen2-menu_display_charisma_over_threshold_high,not activated ,60
ENG122227-ENG117574-Car_Function_Adaptations_Gen2-menu_display_charisma_standstill,not activated ,60
ENG122227-ENG117526-Car_Function_Adaptations_Gen2-menu_display_clima_configuration,not activated ,60
ENG122227-ENG117530-Car_Function_Adaptations_Gen2-menu_display_clima_configuration_after_disclaimer,not activated ,60
ENG122227-ENG117527-Car_Function_Adaptations_Gen2-menu_display_clima_configuration_clamp_15_off,not activated ,60
ENG122227-ENG117528-Car_Function_Adaptations_Gen2-menu_display_clima_configuration_over_threshold_high,not activated ,60
ENG122227-ENG117529-Car_Function_Adaptations_Gen2-menu_display_clima_configuration_standstill,not activated ,60
ENG122227-ENG117586-Car_Function_Adaptations_Gen2-menu_display_clock,activated ,60
ENG122227-ENG117590-Car_Function_Adaptations_Gen2-menu_display_clock_after_disclaimer,not activated ,60
ENG122227-ENG117587-Car_Function_Adaptations_Gen2-menu_display_clock_clamp_15_off,not activated ,60
ENG122227-ENG117588-Car_Function_Adaptations_Gen2-menu_display_clock_over_threshold_high,activated ,60
ENG122227-ENG117589-Car_Function_Adaptations_Gen2-menu_display_clock_standstill,not activated ,60
ENG122227-ENG117566-Car_Function_Adaptations_Gen2-menu_display_compass,not activated ,60
ENG122227-ENG117570-Car_Function_Adaptations_Gen2-menu_display_compass_after_disclaimer,not activated ,60
ENG122227-ENG117567-Car_Function_Adaptations_Gen2-menu_display_compass_clamp_15_off,not activated ,60
ENG122227-ENG117568-Car_Function_Adaptations_Gen2-menu_display_compass_over_threshold_high,not activated ,60
ENG122227-ENG117569-Car_Function_Adaptations_Gen2-menu_display_compass_standstill,not activated ,60
ENG122227-ENG125823-Car_Function_Adaptations_Gen2-menu_display_Curve_Assist,not activated ,60
ENG122227-ENG125826-Car_Function_Adaptations_Gen2-menu_display_Curve_Assist_after_disclaimer,not activated ,60
ENG122227-ENG126998-Car_Function_Adaptations_Gen2-menu_display_Curve_Assist_clamp_15_off,not activated ,60
ENG122227-ENG125824-Car_Function_Adaptations_Gen2-menu_display_Curve_Assist_over_threshold_high,not activated ,60
ENG122227-ENG125825-Car_Function_Adaptations_Gen2-menu_display_Curve_Assist_standstill,not activated ,60
ENG122227-ENG142087-Car_Function_Adaptations_Gen2-menu_display_Display_Configuration,not activated ,60
ENG122227-ENG142091-Car_Function_Adaptations_Gen2-menu_display_Display_Configuration_after_disclaimer,not activated ,60
ENG122227-ENG142088-Car_Function_Adaptations_Gen2-menu_display_Display_Configuration_clamp_15_off,not activated ,60
ENG122227-ENG142089-Car_Function_Adaptations_Gen2-menu_display_Display_Configuration_over_threshold_high,not activated ,60
ENG122227-ENG142090-Car_Function_Adaptations_Gen2-menu_display_Display_Configuration_standstill,not activated ,60
ENG122227-ENG117656-Car_Function_Adaptations_Gen2-menu_display_driving_school,not activated ,60
ENG122227-ENG117660-Car_Function_Adaptations_Gen2-menu_display_driving_school_after_disclaimer,not activated ,60
ENG122227-ENG117657-Car_Function_Adaptations_Gen2-menu_display_driving_school_clamp_15_off,not activated ,60
ENG122227-ENG117658-Car_Function_Adaptations_Gen2-menu_display_driving_school_over_threshold_high,not activated ,60
ENG122227-ENG117659-Car_Function_Adaptations_Gen2-menu_display_driving_school_standstill,not activated ,60
ENG122227-ENG125034-Car_Function_Adaptations_Gen2-menu_display_Ecall,not activated ,60
ENG122227-ENG125038-Car_Function_Adaptations_Gen2-menu_display_Ecall_after_disclaimer,not activated ,60
ENG122227-ENG126999-Car_Function_Adaptations_Gen2-menu_display_eCall_clamp_15_off,not activated ,60
ENG122227-ENG125036-Car_Function_Adaptations_Gen2-menu_display_Ecall_over_threshold_high,not activated ,60
ENG122227-ENG125037-Car_Function_Adaptations_Gen2-menu_display_Ecall_standstill,not activated ,60
ENG122227-ENG126160-Car_Function_Adaptations_Gen2-menu_display_Efficiency_Assist,not activated ,60
ENG122227-ENG126163-Car_Function_Adaptations_Gen2-menu_display_Efficiency_Assist_after_disclaimer,not activated ,60
ENG122227-ENG127004-Car_Function_Adaptations_Gen2-menu_display_Efficiency_Assist_clamp_15_off,not activated ,60
ENG122227-ENG126161-Car_Function_Adaptations_Gen2-menu_display_Efficiency_Assist_over_threshold_high,not activated ,60
ENG122227-ENG126162-Car_Function_Adaptations_Gen2-menu_display_Efficiency_Assist_standstill,not activated ,60
ENG122227-ENG126144-Car_Function_Adaptations_Gen2-menu_display_ENI,not activated ,60
ENG122227-ENG126147-Car_Function_Adaptations_Gen2-menu_display_ENI_after_disclaimer,not activated ,60
ENG122227-ENG127000-Car_Function_Adaptations_Gen2-menu_display_ENI_clamp_15_off,not activated ,60
ENG122227-ENG126145-Car_Function_Adaptations_Gen2-menu_display_ENI_over_threshold_high,not activated ,60
ENG122227-ENG126146-Car_Function_Adaptations_Gen2-menu_display_ENI_standstill,not activated ,60
ENG122227-ENG117516-Car_Function_Adaptations_Gen2-menu_display_exterior_illumination,activated ,60
ENG122227-ENG117520-Car_Function_Adaptations_Gen2-menu_display_exterior_illumination_after_disclaimer,not activated ,60
ENG122227-ENG117517-Car_Function_Adaptations_Gen2-menu_display_exterior_illumination_clamp_15_off,not activated ,60
ENG122227-ENG117518-Car_Function_Adaptations_Gen2-menu_display_exterior_illumination_over_threshold_high,activated ,60
ENG122227-ENG117519-Car_Function_Adaptations_Gen2-menu_display_exterior_illumination_standstill,not activated ,60
ENG122227-ENG117596-Car_Function_Adaptations_Gen2-menu_display_headup_display,not activated ,60
ENG122227-ENG117600-Car_Function_Adaptations_Gen2-menu_display_headup_display_after_disclaimer,not activated ,60
ENG122227-ENG117597-Car_Function_Adaptations_Gen2-menu_display_headup_display_clamp_15_off,not activated ,60
ENG122227-ENG117598-Car_Function_Adaptations_Gen2-menu_display_headup_display_over_threshold_high,not activated ,60
ENG122227-ENG117599-Car_Function_Adaptations_Gen2-menu_display_headup_display_standstill,not activated ,60
ENG122227-ENG117606-Car_Function_Adaptations_Gen2-menu_display_hybrid,not activated ,60
ENG122227-ENG117610-Car_Function_Adaptations_Gen2-menu_display_hybrid_after_disclaimer,not activated ,60
ENG122227-ENG117607-Car_Function_Adaptations_Gen2-menu_display_hybrid_clamp_15_off,not activated ,60
ENG122227-ENG117608-Car_Function_Adaptations_Gen2-menu_display_hybrid_over_threshold_high,not activated ,60
ENG122227-ENG117609-Car_Function_Adaptations_Gen2-menu_display_hybrid_standstill,not activated ,60
ENG122227-ENG125805-Car_Function_Adaptations_Gen2-menu_display_lane_assistant,not activated ,60
ENG122227-ENG125809-Car_Function_Adaptations_Gen2-menu_display_lane_assistant_after_disclaimer,not activated ,60
ENG122227-ENG125806-Car_Function_Adaptations_Gen2-menu_display_lane_assistant_clamp_15_off,not activated ,60
ENG122227-ENG125807-Car_Function_Adaptations_Gen2-menu_display_lane_assistant_over_threshold_high,not activated ,60
ENG122227-ENG125808-Car_Function_Adaptations_Gen2-menu_display_lane_assistant_standstill,not activated ,60
ENG122227-ENG117506-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning,not activated ,60
ENG122227-ENG117510-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning_after_disclaimer,not activated ,60
ENG122227-ENG117507-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning_clamp_15_off,not activated ,60
ENG122227-ENG117508-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning_over_threshold_high,not activated ,60
ENG122227-ENG117509-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning_standstill,not activated ,60
ENG122227-ENG117631-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker,not activated ,60
ENG122227-ENG117635-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker_after_disclaimer,not activated ,60
ENG122227-ENG117632-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker_clamp_15_off,not activated ,60
ENG122227-ENG117633-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker_over_threshold_high,not activated ,60
ENG122227-ENG117634-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker_standstill,not activated ,60
ENG122227-ENG117616-Car_Function_Adaptations_Gen2-menu_display_night_vision,not activated ,60
ENG122227-ENG117620-Car_Function_Adaptations_Gen2-menu_display_night_vision_after_disclaimer,not activated ,60
ENG122227-ENG117617-Car_Function_Adaptations_Gen2-menu_display_night_vision_clamp_15_off,not activated ,60
ENG122227-ENG117618-Car_Function_Adaptations_Gen2-menu_display_night_vision_over_threshold_high,not activated ,60
ENG122227-ENG117619-Car_Function_Adaptations_Gen2-menu_display_night_vision_standstill,not activated ,60
ENG122227-ENG117576-Car_Function_Adaptations_Gen2-menu_display_oil_level,not activated ,60
ENG122227-ENG117580-Car_Function_Adaptations_Gen2-menu_display_oil_level_after_disclaimer,not activated ,60
ENG122227-ENG117577-Car_Function_Adaptations_Gen2-menu_display_oil_level_clamp_15_off,not activated ,60
ENG122227-ENG117578-Car_Function_Adaptations_Gen2-menu_display_oil_level_over_threshold_high,not activated ,60
ENG122227-ENG117579-Car_Function_Adaptations_Gen2-menu_display_oil_level_standstill,not activated ,60
ENG122227-ENG117496-Car_Function_Adaptations_Gen2-menu_display_pdc,activated ,60
ENG122227-ENG117500-Car_Function_Adaptations_Gen2-menu_display_pdc_after_disclaimer,not activated ,60
ENG122227-ENG117497-Car_Function_Adaptations_Gen2-menu_display_pdc_clamp_15_off,not activated ,60
ENG122227-ENG117498-Car_Function_Adaptations_Gen2-menu_display_pdc_over_threshold_high,activated ,60
ENG122227-ENG117499-Car_Function_Adaptations_Gen2-menu_display_pdc_standstill,not activated ,60
ENG122227-ENG125815-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist,not activated ,60
ENG122227-ENG125818-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist_after_disclaimer,not activated ,60
ENG122227-ENG126996-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist_clamp_15_off,not activated ,60
ENG122227-ENG125816-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist_over_threshold_high,not activated ,60
ENG122227-ENG125817-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist_standstill,not activated ,60
ENG122227-ENG117541-Car_Function_Adaptations_Gen2-menu_display_rdk,activated ,60
ENG122227-ENG117545-Car_Function_Adaptations_Gen2-menu_display_rdk_after_disclaimer,not activated ,60
ENG122227-ENG117542-Car_Function_Adaptations_Gen2-menu_display_rdk_clamp_15_off,not activated ,60
ENG122227-ENG117543-Car_Function_Adaptations_Gen2-menu_display_rdk_over_threshold_high,activated ,60
ENG122227-ENG117544-Car_Function_Adaptations_Gen2-menu_display_rdk_standstill,not activated ,60
ENG122227-ENG122306-Car_Function_Adaptations_Gen2-menu_display_RearSeatEntertainment,not activated ,60
ENG122227-ENG122310-Car_Function_Adaptations_Gen2-menu_display_RearSeatEntertainment_after_disclaimer,not activated ,60
ENG122227-ENG122307-Car_Function_Adaptations_Gen2-menu_display_RearSeatEntertainment_clamp_15_off,not activated ,60
ENG122227-ENG122308-Car_Function_Adaptations_Gen2-menu_display_RearSeatEntertainment_over_threshold_high,not activated ,60
ENG122227-ENG122309-Car_Function_Adaptations_Gen2-menu_display_RearSeatEntertainment_standstill,not activated ,60
ENG122227-ENG117626-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load,not activated ,60
ENG122227-ENG117630-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load_after_disclaimer,not activated ,60
ENG122227-ENG117627-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load_clamp_15_off,not activated ,60
ENG122227-ENG117628-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load_over_threshold_high,not activated ,60
ENG122227-ENG117629-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load_standstill,not activated ,60
ENG122227-ENG117636-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification,not activated ,60
ENG122227-ENG117640-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification_after_disclaimer,not activated ,60
ENG122227-ENG117637-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification_clamp_15_off,not activated ,60
ENG122227-ENG117638-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification_over_threshold_high,not activated ,60
ENG122227-ENG117639-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification_standstill,not activated ,60
ENG122227-ENG117556-Car_Function_Adaptations_Gen2-menu_display_seat_configuration,not activated ,60
ENG122227-ENG117560-Car_Function_Adaptations_Gen2-menu_display_seat_configuration_after_disclaimer,not activated ,60
ENG122227-ENG117557-Car_Function_Adaptations_Gen2-menu_display_seat_configuration_clamp_15_off,not activated ,60
ENG122227-ENG117558-Car_Function_Adaptations_Gen2-menu_display_seat_configuration_over_threshold_high,not activated ,60
ENG122227-ENG117559-Car_Function_Adaptations_Gen2-menu_display_seat_configuration_standstill,not activated ,60
ENG122227-ENG125819-Car_Function_Adaptations_Gen2-menu_display_Seat_Pneumatic,not activated ,60
ENG122227-ENG125822-Car_Function_Adaptations_Gen2-menu_display_Seat_Pneumatic_after_disclaimer,not activated ,60
ENG122227-ENG126997-Car_Function_Adaptations_Gen2-menu_display_Seat_Pneumatic_clamp_15_off,not activated ,60
ENG122227-ENG125820-Car_Function_Adaptations_Gen2-menu_display_Seat_Pneumatic_over_threshold_high,not activated ,60
ENG122227-ENG125821-Car_Function_Adaptations_Gen2-menu_display_Seat_Pneumatic_standstill,not activated ,60
ENG122227-ENG117551-Car_Function_Adaptations_Gen2-menu_display_sia,activated ,60
ENG122227-ENG117555-Car_Function_Adaptations_Gen2-menu_display_sia_after_disclaimer,not activated ,60
ENG122227-ENG117552-Car_Function_Adaptations_Gen2-menu_display_sia_clamp_15_off,not activated ,60
ENG122227-ENG117553-Car_Function_Adaptations_Gen2-menu_display_sia_over_threshold_high,activated ,60
ENG122227-ENG117554-Car_Function_Adaptations_Gen2-menu_display_sia_standstill,not activated ,60
ENG122227-ENG117621-Car_Function_Adaptations_Gen2-menu_display_side_view,not activated ,60
ENG122227-ENG117625-Car_Function_Adaptations_Gen2-menu_display_side_view_after_disclaimer,not activated ,60
ENG122227-ENG117622-Car_Function_Adaptations_Gen2-menu_display_side_view_clamp_15_off,not activated ,60
ENG122227-ENG117623-Car_Function_Adaptations_Gen2-menu_display_side_view_over_threshold_high,not activated ,60
ENG122227-ENG117624-Car_Function_Adaptations_Gen2-menu_display_side_view_standstill,not activated ,60
ENG122227-ENG122311-Car_Function_Adaptations_Gen2-menu_display_special_functions,not activated ,60
ENG122227-ENG122314-Car_Function_Adaptations_Gen2-menu_display_special_functions_after_disclaimer,not activated ,60
ENG122227-ENG125810-Car_Function_Adaptations_Gen2-menu_display_special_functions_clamp_15_off,not activated ,60
ENG122227-ENG122312-Car_Function_Adaptations_Gen2-menu_display_special_functions_over_threshold_high,not activated ,60
ENG122227-ENG122313-Car_Function_Adaptations_Gen2-menu_display_special_functions_standstill,not activated ,60
ENG122227-ENG142082-Car_Function_Adaptations_Gen2-menu_display_Spoiler,not activated ,60
ENG122227-ENG142086-Car_Function_Adaptations_Gen2-menu_display_Spoiler_after_disclaimer,not activated ,60
ENG122227-ENG142083-Car_Function_Adaptations_Gen2-menu_display_Spoiler_clamp_15_off,not activated ,60
ENG122227-ENG142084-Car_Function_Adaptations_Gen2-menu_display_Spoiler_over_threshold_high,not activated ,60
ENG122227-ENG142085-Car_Function_Adaptations_Gen2-menu_display_Spoiler_standstill,not activated ,60
ENG122227-ENG126148-Car_Function_Adaptations_Gen2-menu_display_SportHMI,not activated ,60
ENG122227-ENG126151-Car_Function_Adaptations_Gen2-menu_display_SportHMI_after_disclaimer,not activated ,60
ENG122227-ENG127001-Car_Function_Adaptations_Gen2-menu_display_SportHMI_clamp_15_off,not activated ,60
ENG122227-ENG126149-Car_Function_Adaptations_Gen2-menu_display_SportHMI_over_threshold_high,not activated ,60
ENG122227-ENG126150-Car_Function_Adaptations_Gen2-menu_display_SportHMI_standstill,not activated ,60
ENG122227-ENG117676-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons,activated ,60
ENG122227-ENG117680-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons_after_disclaimer,not activated ,60
ENG122227-ENG117677-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons_clamp_15_off,not activated ,60
ENG122227-ENG117678-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons_over_threshold_high,activated ,60
ENG122227-ENG117679-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons_standstill,not activated ,60
ENG122227-ENG122315-Car_Function_Adaptations_Gen2-menu_display_trailer_assistant,not activated ,60
ENG122227-ENG122319-Car_Function_Adaptations_Gen2-menu_display_trailer_assistant_after_disclaimer,not activated ,60
ENG122227-ENG122316-Car_Function_Adaptations_Gen2-menu_display_trailer_assistant_clamp_15_off,not activated ,60
ENG122227-ENG122317-Car_Function_Adaptations_Gen2-menu_display_trailer_assistant_over_threshold_high,not activated ,60
ENG122227-ENG122318-Car_Function_Adaptations_Gen2-menu_display_trailer_assistant_standstill,not activated ,60
ENG122227-ENG122320-Car_Function_Adaptations_Gen2-menu_display_TV_tuner,not activated ,60
ENG122227-ENG122324-Car_Function_Adaptations_Gen2-menu_display_TV_tuner_after_disclaimer,not activated ,60
ENG122227-ENG122321-Car_Function_Adaptations_Gen2-menu_display_TV_tuner_clamp_15_off,not activated ,60
ENG122227-ENG122322-Car_Function_Adaptations_Gen2-menu_display_TV_tuner_over_threshold_high,not activated ,60
ENG122227-ENG122323-Car_Function_Adaptations_Gen2-menu_display_TV_tuner_standstill,not activated ,60
ENG122227-ENG117611-Car_Function_Adaptations_Gen2-menu_display_ugdo,not activated ,60
ENG122227-ENG117615-Car_Function_Adaptations_Gen2-menu_display_ugdo_after_disclaimer,not activated ,60
ENG122227-ENG117612-Car_Function_Adaptations_Gen2-menu_display_ugdo_clamp_15_off,not activated ,60
ENG122227-ENG117613-Car_Function_Adaptations_Gen2-menu_display_ugdo_over_threshold_high,not activated ,60
ENG122227-ENG117614-Car_Function_Adaptations_Gen2-menu_display_ugdo_standstill,not activated ,60
ENG122227-ENG122291-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating,activated ,60
ENG122227-ENG122295-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating_after_disclaimer,not activated ,60
ENG122227-ENG122292-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating_clamp_15_off,not activated ,60
ENG122227-ENG122293-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating_over_threshold_high,activated ,60
ENG122227-ENG122294-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating_standstill,not activated ,60
ENG122227-ENG117581-Car_Function_Adaptations_Gen2-menu_display_vin,activated ,60
ENG122227-ENG117585-Car_Function_Adaptations_Gen2-menu_display_vin_after_disclaimer,not activated ,60
ENG122227-ENG117582-Car_Function_Adaptations_Gen2-menu_display_vin_clamp_15_off,not activated ,60
ENG122227-ENG117583-Car_Function_Adaptations_Gen2-menu_display_vin_over_threshold_high,activated ,60
ENG122227-ENG117584-Car_Function_Adaptations_Gen2-menu_display_vin_standstill,not activated ,60
ENG122227-ENG117661-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition,activated ,60
ENG122227-ENG117665-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition_after_disclaimer,not activated ,60
ENG122227-ENG117662-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition_clamp_15_off,not activated ,60
ENG122227-ENG117663-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition_over_threshold_high,activated ,60
ENG122227-ENG117664-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition_standstill,not activated ,60
ENG122227-ENG117521-Car_Function_Adaptations_Gen2-menu_display_windows,activated ,60
ENG122227-ENG117525-Car_Function_Adaptations_Gen2-menu_display_windows_after_disclaimer,not activated ,60
ENG122227-ENG117522-Car_Function_Adaptations_Gen2-menu_display_windows_clamp_15_off,not activated ,60
ENG122227-ENG117523-Car_Function_Adaptations_Gen2-menu_display_windows_over_threshold_high,activated ,60
ENG122227-ENG117524-Car_Function_Adaptations_Gen2-menu_display_windows_standstill,not activated ,60
Homer51
Drives: Polo 6C
Post by Homer51 »
ENG122227-ENG117546-Car_Function_Adaptations_Gen2-menu_display_wiper,activated ,60
ENG122227-ENG117550-Car_Function_Adaptations_Gen2-menu_display_wiper_after_disclaimer,not activated ,60
ENG122227-ENG117547-Car_Function_Adaptations_Gen2-menu_display_wiper_clamp_15_off,not activated ,60
ENG122227-ENG117548-Car_Function_Adaptations_Gen2-menu_display_wiper_over_threshold_high,activated ,60
ENG122227-ENG117549-Car_Function_Adaptations_Gen2-menu_display_wiper_standstill,not activated ,60
ENG122227-ENG142092-Car_Function_Adaptations_Gen2-menu_soundcontrol,not activated ,60
ENG122227-ENG142096-Car_Function_Adaptations_Gen2-menu_soundcontrol_after_disclaimer,not activated ,60
ENG122227-ENG142093-Car_Function_Adaptations_Gen2-menu_soundcontrol_clamp_15_off,not activated ,60
ENG122227-ENG142094-Car_Function_Adaptations_Gen2-menu_soundcontrol_over_threshold_high,not activated ,60
ENG122227-ENG142095-Car_Function_Adaptations_Gen2-menu_soundcontrol_standstill,not activated ,60
ENG122229-ENG117700-Car_Function_List_BAP_Gen2-ACC_0x05,not activated ,64
ENG122229-ENG117701-Car_Function_List_BAP_Gen2-ACC_0x05_msg_bus,Terminal 15 ,64
ENG122229-ENG117702-Car_Function_List_BAP_Gen2-air_suspension_0x06,not activated ,64
ENG122229-ENG117703-Car_Function_List_BAP_Gen2-air_suspension_0x06_msg_bus,Suspension data bus ,64
ENG122229-ENG117764-Car_Function_List_BAP_Gen2-Amplifier_0x2D,not activated ,64
ENG122229-ENG117765-Car_Function_List_BAP_Gen2-Amplifier_0x2D_msg_bus,Comfort data bus ,64
ENG122229-ENG122334-Car_Function_List_BAP_Gen2-Angle_Of_Slope_0x24,not activated ,64
ENG122229-ENG122335-Car_Function_List_BAP_Gen2-Angle_Of_Slope_0x24_msg_bus,not activated ,64
ENG122229-ENG117696-Car_Function_List_BAP_Gen2-auxilary_heating_0x03,not activated ,64
ENG122229-ENG117697-Car_Function_List_BAP_Gen2-auxilary_heating_0x03_msg_bus,Comfort data bus ,64
ENG122229-ENG117744-Car_Function_List_BAP_Gen2-AWV_0x1B,not activated ,64
ENG122229-ENG117745-Car_Function_List_BAP_Gen2-AWV_0x1B_msg_bus,Terminal 15 ,64
ENG122229-ENG122336-Car_Function_List_BAP_Gen2-Battery_Management_0x25,not activated ,64
ENG122229-ENG122337-Car_Function_List_BAP_Gen2-Battery_Management_0x25_msg_bus,Powertrain data bus ,64
ENG122229-ENG117758-Car_Function_List_BAP_Gen2-BCmE_0x23,not activated ,64
ENG122229-ENG117759-Car_Function_List_BAP_Gen2-BCmE_0x23_msg_bus,Comfort data bus ,64
ENG122229-ENG117760-Car_Function_List_BAP_Gen2-Brake_0x26,activated ,64
ENG122229-ENG117761-Car_Function_List_BAP_Gen2-Brake_0x26_msg_bus,Powertrain data bus ,64
ENG122229-ENG117717-Car_Function_List_BAP_Gen2-central_locking_0x0D,activated ,64
ENG122229-ENG117716-Car_Function_List_BAP_Gen2-central_locking_0x0D_msg_bus,Comfort data bus ,64
ENG122229-ENG117736-Car_Function_List_BAP_Gen2-charisma_0x17,not activated ,64
ENG122229-ENG117737-Car_Function_List_BAP_Gen2-charisma_0x17_msg_bus,Comfort data bus ,64
ENG122229-ENG117734-Car_Function_List_BAP_Gen2-clima_slave_2_0x16,not activated ,64
ENG122229-ENG117735-Car_Function_List_BAP_Gen2-clima_slave_2_0x16_msg_bus,Comfort data bus ,64
ENG122229-ENG117692-Car_Function_List_BAP_Gen2-climatic_master_0x01,not activated ,64
ENG122229-ENG117693-Car_Function_List_BAP_Gen2-climatic_master_0x01_msg_bus,Comfort data bus ,64
ENG122229-ENG117694-Car_Function_List_BAP_Gen2-climatic_slave_0x02,not activated ,64
ENG122229-ENG117695-Car_Function_List_BAP_Gen2-climatic_slave_0x02_msg_bus,Comfort data bus ,64
ENG122229-ENG117724-Car_Function_List_BAP_Gen2-clock_0x11,activated ,64
ENG122229-ENG117725-Car_Function_List_BAP_Gen2-clock_0x11_msg_bus,Comfort data bus ,64
ENG122229-ENG117732-Car_Function_List_BAP_Gen2-compass_0x15,not activated ,64
ENG122229-ENG117733-Car_Function_List_BAP_Gen2-compass_0x15_msg_bus,not activated ,64
ENG122229-ENG117722-Car_Function_List_BAP_Gen2-driver_seat_0x10,not activated ,64
ENG122229-ENG117723-Car_Function_List_BAP_Gen2-driver_seat_0x10_msg_bus,Comfort data bus ,64
ENG122229-ENG125039-Car_Function_List_BAP_Gen2-Ecall_0x33,not activated ,64
ENG122229-ENG125828-Car_Function_List_BAP_Gen2-eCall_0x33_msg_bus,Comfort data bus ,64
ENG122229-ENG127500-Car_Function_List_BAP_Gen2-efficiency_assis_msg_bus_0x3C,Comfort data bus ,64
ENG122229-ENG127499-Car_Function_List_BAP_Gen2-efficiency_assist_0x3C,not activated ,64
ENG122229-ENG125829-Car_Function_List_BAP_Gen2-ENI_0x37,not activated ,64
ENG122229-ENG125830-Car_Function_List_BAP_Gen2-ENI_0x37_msg_bus,Comfort data bus ,64
ENG122229-ENG152531-Car_Function_List_BAP_Gen2-ExBoxM2_0x38,not activated ,64
ENG122229-ENG152532-Car_Function_List_BAP_Gen2-ExBoxM2_0x38_msg_bus,Comfort data bus ,64
ENG122229-ENG117708-Car_Function_List_BAP_Gen2-exterieur_light_0x09,activated ,64
ENG122229-ENG117709-Car_Function_List_BAP_Gen2-exterieur_light_0x09_msg_bus,Comfort data bus ,64
ENG122229-ENG117698-Car_Function_List_BAP_Gen2-headup_displ_0x04,not activated ,64
ENG122229-ENG117699-Car_Function_List_BAP_Gen2-headup_displ_0x04_msg_bus,Comfort data bus ,64
ENG122229-ENG117746-Car_Function_List_BAP_Gen2-Hybrid_0x1D,not activated ,64
ENG122229-ENG117747-Car_Function_List_BAP_Gen2-Hybrid_0x1D_msg_bus,Powertrain data bus ,64
ENG122229-ENG117706-Car_Function_List_BAP_Gen2-interieur_light_0x08,activated ,64
ENG122229-ENG117707-Car_Function_List_BAP_Gen2-interieur_light_0x08_msg_bus,Comfort data bus ,64
ENG122229-ENG117740-Car_Function_List_BAP_Gen2-LDW_HCA_0x19,not activated ,64
ENG122229-ENG117741-Car_Function_List_BAP_Gen2-LDW_HCA_0x19_msg_bus,Extended data bus ,64
ENG122229-ENG117720-Car_Function_List_BAP_Gen2-MFA_0x0F,activated ,64
ENG122229-ENG117721-Car_Function_List_BAP_Gen2-MFA_0x0F_msg_bus,Comfort data bus ,64
ENG122229-ENG117767-Car_Function_List_BAP_Gen2-MFL_Jocker_0x34,not activated ,64
ENG122229-ENG117766-Car_Function_List_BAP_Gen2-MFL_Jocker_msg_bus_0x34,Comfort data bus ,64
ENG122229-ENG117719-Car_Function_List_BAP_Gen2-mirror_0x0E,activated ,64
ENG122229-ENG117718-Car_Function_List_BAP_Gen2-mirror_0x0E_msg_bus,Comfort data bus ,64
ENG122229-ENG117738-Car_Function_List_BAP_Gen2-Night_Vision_0x18,not activated ,64
ENG122229-ENG117739-Car_Function_List_BAP_Gen2-Night_Vision_0x18_msg_bus,not activated ,64
ENG122229-ENG117710-Car_Function_List_BAP_Gen2-parking_assist_0x0A,activated ,64
ENG122229-ENG117711-Car_Function_List_BAP_Gen2-parking_assist_0x0A_msg_bus,Terminal 15 ,64
ENG122229-ENG117752-Car_Function_List_BAP_Gen2-Passenger_Seat_0x20,not activated ,64
ENG122229-ENG117753-Car_Function_List_BAP_Gen2-Passenger_Seat_0x20_msg_bus,Comfort data bus ,64
ENG122229-ENG125831-Car_Function_List_BAP_Gen2-Pedestrian_Assist_0x3A,not activated ,64
ENG122229-ENG125832-Car_Function_List_BAP_Gen2-Pedestrian_Assist_msg_bus_0x3A,Extended data bus ,64
ENG122229-ENG122333-Car_Function_List_BAP_Gen2-Range_Data_0x39,not activated ,64
ENG122229-ENG125827-Car_Function_List_BAP_Gen2-Range_Data_msg_bus_0x39,Comfort data bus ,64
ENG122229-ENG122327-Car_Function_List_BAP_Gen2-RearSeatEntertainment_0x2E,not activated ,64
ENG122229-ENG122328-Car_Function_List_BAP_Gen2-RearSeatEntertainment_0x2E_msg_bus,Comfort data bus ,64
ENG122229-ENG117750-Car_Function_List_BAP_Gen2-Reversible_Seat_Belt_Tightener_0x1F,not activated ,64
ENG122229-ENG117751-Car_Function_List_BAP_Gen2-Reversible_Seat_Belt_Tightener_0x1F_msg_bus,Powertrain data bus ,64
ENG122229-ENG125833-Car_Function_List_BAP_Gen2-Seat_Pneumatic_0x3B,not activated ,64
ENG122229-ENG125834-Car_Function_List_BAP_Gen2-Seat_Pneumatic_msg_bus_0x3B,Comfort data bus ,64
ENG122229-ENG139200-Car_Function_List_BAP_Gen2-Seatmemory_codriver_rear_0x3F,not activated ,64
ENG122229-ENG139201-Car_Function_List_BAP_Gen2-Seatmemory_codriver_rear_msg_bus_0x3F,Comfort data bus ,64
ENG122229-ENG139198-Car_Function_List_BAP_Gen2-Seatmemory_driver_rear_0x3E,not activated ,64
ENG122229-ENG139199-Car_Function_List_BAP_Gen2-Seatmemory_driver_rear_msg_bus_0x3E,Comfort data bus ,64
ENG122229-ENG117726-Car_Function_List_BAP_Gen2-service_interval_display_0x12,activated ,64
ENG122229-ENG117727-Car_Function_List_BAP_Gen2-service_interval_display_0x12_msg_bus,Comfort data bus ,64
ENG122229-ENG117748-Car_Function_List_BAP_Gen2-SideView_0x1E,not activated ,64
ENG122229-ENG117749-Car_Function_List_BAP_Gen2-SideView_0x1E_msg_bus,not activated ,64
ENG122229-ENG122329-Car_Function_List_BAP_Gen2-Special_Functions_0x35,not activated ,64
ENG122229-ENG122330-Car_Function_List_BAP_Gen2-Special_Functions_msg_bus_0x35,Comfort data bus ,64
ENG122229-ENG117762-Car_Function_List_BAP_Gen2-Start_Stop_reasons_0x27,activated ,64
ENG122229-ENG117763-Car_Function_List_BAP_Gen2-Start_Stop_reasons_0x27_msg_bus,Comfort data bus ,64
ENG122229-ENG117742-Car_Function_List_BAP_Gen2-SWA_0x1A,not activated ,64
ENG122229-ENG117743-Car_Function_List_BAP_Gen2-SWA_0x1A_msg_bus,Extended data bus ,64
ENG122229-ENG117704-Car_Function_List_BAP_Gen2-tire_pressure_system_0x07,activated ,64
ENG122229-ENG117705-Car_Function_List_BAP_Gen2-tire_pressure_system_0x07_msg_bus,Powertrain data bus ,64
ENG122229-ENG117754-Car_Function_List_BAP_Gen2-traffic_sign_recognition_0x21,not activated ,64
ENG122229-ENG117755-Car_Function_List_BAP_Gen2-traffic_sign_recognition_0x21_msg_bus,Extended data bus ,64
ENG122229-ENG122331-Car_Function_List_BAP_Gen2-Trailer_Assistant_0x36,not activated ,64
ENG122229-ENG122332-Car_Function_List_BAP_Gen2-Trailer_Assistant_msg_bus_0x36,Comfort data bus ,64
ENG122229-ENG122325-Car_Function_List_BAP_Gen2-TV_tuner_0x2C,not activated ,64
ENG122229-ENG122326-Car_Function_List_BAP_Gen2-TV_tuner_0x2C_msg_bus,Comfort data bus ,64
ENG122229-ENG117730-Car_Function_List_BAP_Gen2-UGDO_0x14,not activated ,64
ENG122229-ENG117731-Car_Function_List_BAP_Gen2-UGDO_0x14_msg_bus,Terminal 15 ,64
ENG122229-ENG117728-Car_Function_List_BAP_Gen2-unit_master_0x13,activated ,64
ENG122229-ENG117729-Car_Function_List_BAP_Gen2-unit_master_0x13_msg_bus,Comfort data bus ,64
ENG122229-ENG117712-Car_Function_List_BAP_Gen2-VPS_0x0B,not activated ,64
ENG122229-ENG117713-Car_Function_List_BAP_Gen2-VPS_0x0B_msg_bus,Comfort data bus ,64
ENG122229-ENG117756-Car_Function_List_BAP_Gen2-weariness_rcognition_0x22,activated ,64
ENG122229-ENG117757-Car_Function_List_BAP_Gen2-weariness_rcognition_0x22_msg_bus,Comfort data bus ,64
ENG122229-ENG117714-Car_Function_List_BAP_Gen2-wiper_comfort_0x0C,activated ,64
ENG122229-ENG117715-Car_Function_List_BAP_Gen2-wiper_comfort_0x0C_msg_bus,Comfort data bus ,64
ENG122228-ENG127498-Car_Function_List_CAN_Gen2-Adaptive_key,Not available ,8
ENG122228-ENG117690-Car_Function_List_CAN_Gen2-Adaptive_key_msg_bus,Comfort data bus ,8
ENG122228-ENG117688-Car_Function_List_CAN_Gen2-Driving_school,Not available ,8
ENG122228-ENG117689-Car_Function_List_CAN_Gen2-Driving_school_msg_bus,Comfort data bus ,8
ENG122228-ENG107608-Car_Function_List_CAN_Gen2-MFL,available. ,8
ENG122228-ENG117681-Car_Function_List_CAN_Gen2-MFL_msg_bus,Comfort data bus ,8
ENG122228-ENG117683-Car_Function_List_CAN_Gen2-Oil_level,Not available ,8
ENG122228-ENG117684-Car_Function_List_CAN_Gen2-Oil_level_msg_bus,Powertrain data bus ,8
ENG122228-ENG117685-Car_Function_List_CAN_Gen2-PDC_audio_lowering,available. ,8
ENG122228-ENG117686-Car_Function_List_CAN_Gen2-PDC_audio_lowering_msg_bus,Suspension data bus ,8
ENG122228-ENG98891-Car_Function_List_CAN_Gen2-Reserved,Not available ,8
ENG122228-ENG101416-Car_Function_List_CAN_Gen2-Reserved_1,Comfort data bus ,8
ENG122228-ENG99458-Car_Function_List_CAN_Gen2-Reserved_2,Comfort data bus ,8
ENG122228-ENG99668-Car_Function_List_CAN_Gen2-Reserved_3,Not available ,8
ENG122228-ENG99892-Car_Function_List_CAN_Gen2-VIN,available. ,8
ENG122228-ENG117687-Car_Function_List_CAN_Gen2-VIN_msg_bus,Comfort data bus ,8
ENG117913-ENG101574-Dimming_Ambient_Illumination_Information_Control_Unit-X1,0 ,6
ENG117913-ENG99557-Dimming_Ambient_Illumination_Information_Control_Unit-X2,50 ,6
ENG117913-ENG102140-Dimming_Ambient_Illumination_Information_Control_Unit-X3,100 ,6
ENG117913-ENG99777-Dimming_Ambient_Illumination_Information_Control_Unit-Y1,0 ,6
ENG117913-ENG100480-Dimming_Ambient_Illumination_Information_Control_Unit-Y2,50 ,6
ENG117913-ENG100773-Dimming_Ambient_Illumination_Information_Control_Unit-Y3,100 ,6
ENG117914-ENG101574-Dimming_Ambient_Illumination_Operating_and_Display_Unit-X1,0 ,6
ENG117914-ENG99557-Dimming_Ambient_Illumination_Operating_and_Display_Unit-X2,50 ,6
ENG117914-ENG102140-Dimming_Ambient_Illumination_Operating_and_Display_Unit-X3,100 ,6
ENG117914-ENG99777-Dimming_Ambient_Illumination_Operating_and_Display_Unit-Y1,0 ,6
ENG117914-ENG100480-Dimming_Ambient_Illumination_Operating_and_Display_Unit-Y2,50 ,6
ENG117914-ENG100773-Dimming_Ambient_Illumination_Operating_and_Display_Unit-Y3,100 ,6
ENG117916-ENG101574-Dimming_Illumination_for_Display_Unit-X1,0 ,12
ENG117916-ENG99557-Dimming_Illumination_for_Display_Unit-X2,10 ,12
ENG117916-ENG102140-Dimming_Illumination_for_Display_Unit-X3,100 ,12
ENG117916-ENG102936-Dimming_Illumination_for_Display_Unit-X4,150 ,12
ENG117916-ENG103548-Dimming_Illumination_for_Display_Unit-X5,220 ,12
ENG117916-ENG113992-Dimming_Illumination_for_Display_Unit-X6,253 ,12
ENG117916-ENG99777-Dimming_Illumination_for_Display_Unit-Y1,1 %,12
ENG117916-ENG100480-Dimming_Illumination_for_Display_Unit-Y2,1 %,12
ENG117916-ENG100773-Dimming_Illumination_for_Display_Unit-Y3,8 %,12
ENG117916-ENG100631-Dimming_Illumination_for_Display_Unit-Y4,20 %,12
ENG117916-ENG102174-Dimming_Illumination_for_Display_Unit-Y5,60 %,12
ENG117916-ENG113993-Dimming_Illumination_for_Display_Unit-Y6,100 %,12
ENG141636-ENG142049-Key_code_monitoring-monitoring_keycode_0x00_0x07,FF ,32
ENG141636-ENG142050-Key_code_monitoring-monitoring_keycode_0x08_0x0F,FF ,32
ENG141636-ENG142051-Key_code_monitoring-monitoring_keycode_0x10_0x17,FF ,32
ENG141636-ENG142052-Key_code_monitoring-monitoring_keycode_0x18_0x1F,FF ,32
ENG141636-ENG142053-Key_code_monitoring-monitoring_keycode_0x20_0x27,FF ,32
ENG141636-ENG142054-Key_code_monitoring-monitoring_keycode_0x28_0x2F,FF ,32
ENG141636-ENG142055-Key_code_monitoring-monitoring_keycode_0x30_0x37,FF ,32
ENG141636-ENG142056-Key_code_monitoring-monitoring_keycode_0x38_0x3F,FF ,32
ENG141636-ENG142057-Key_code_monitoring-monitoring_keycode_0x40_0x47,FF ,32
ENG141636-ENG142058-Key_code_monitoring-monitoring_keycode_0x48_0x4F,FF ,32
ENG141636-ENG142059-Key_code_monitoring-monitoring_keycode_0x50_0x57,FF ,32
ENG141636-ENG142060-Key_code_monitoring-monitoring_keycode_0x58_0x5F,FF ,32
ENG141636-ENG142061-Key_code_monitoring-monitoring_keycode_0x60_0x67,FF ,32
ENG141636-ENG142062-Key_code_monitoring-monitoring_keycode_0x68_0x6F,FF ,32
ENG141636-ENG142063-Key_code_monitoring-monitoring_keycode_0x70_0x77,FF ,32
ENG141636-ENG142064-Key_code_monitoring-monitoring_keycode_0x78_0x7F,FF ,32
ENG141636-ENG142065-Key_code_monitoring-monitoring_keycode_0x80_0x87,FF ,32
ENG141636-ENG142066-Key_code_monitoring-monitoring_keycode_0x88_0x8F,FF ,32
ENG141636-ENG142067-Key_code_monitoring-monitoring_keycode_0x90_0x97,FF ,32
ENG141636-ENG142068-Key_code_monitoring-monitoring_keycode_0x98_0x9F,FF ,32
ENG141636-ENG142069-Key_code_monitoring-monitoring_keycode_0xA0_0xA7,FF ,32
ENG141636-ENG142070-Key_code_monitoring-monitoring_keycode_0xA8_0xAF,FF ,32
ENG141636-ENG142071-Key_code_monitoring-monitoring_keycode_0xB0_0xB7,FF ,32
ENG141636-ENG142072-Key_code_monitoring-monitoring_keycode_0xB8_0xBF,FF ,32
ENG141636-ENG142073-Key_code_monitoring-monitoring_keycode_0xC0_0xC7,FF ,32
ENG141636-ENG142074-Key_code_monitoring-monitoring_keycode_0xC8_0xCF,FF ,32
ENG141636-ENG142075-Key_code_monitoring-monitoring_keycode_0xD0_0xD7,FF ,32
ENG141636-ENG142076-Key_code_monitoring-monitoring_keycode_0xD8_0xDF,FF ,32
ENG141636-ENG142077-Key_code_monitoring-monitoring_keycode_0xE0_0xE7,FF ,32
ENG141636-ENG142078-Key_code_monitoring-monitoring_keycode_0xE8_0xEF,FF ,32
ENG141636-ENG142079-Key_code_monitoring-monitoring_keycode_0xF0_0xF7,FF ,32
ENG141636-ENG142080-Key_code_monitoring-monitoring_keycode_0xF8_0xFF,FF ,32
ENG117921-Operating_and_Display_Unit_1_Proximity_Sensor_Basic_Adaptation,04 01 52 04 52 10 52 40 52 32 00 64 00 96 00 A4 01 C8 00 82 00 14 00 14 00 14 00 14 00 FF FF FF FF FF FF FF FF 01 00 05 ,40
ENG117809-p_damping_Display,5 ms,1
ENG117808-p_HMI_Display,13 %,1
ENG122219-ENG122287-Radio_Level_Quality_Offsets-Set_AM_Quality_Level_Offset,0 ,2
ENG122219-ENG122288-Radio_Level_Quality_Offsets-Set_FM_Quality_Level_Offset,0 ,2
ENG117910-Set_Remote_Test_Channel_Scanning,Conditions not correct or request sequence error,2
ENG117908-Shift_Remote_Test_Frequency_AM,Conditions not correct or request sequence error,2
ENG117907-Shift_Remote_Test_Frequency_FM,Conditions not correct or request sequence error,2
ENG117906-Shift_Remote_Test_Volume,Conditions not correct or request sequence error,2
ENG117919-Startup_Screen_Sticker_HMI,00 00 ,2
ENG109862-ENG117847-Vehicle_configuration-advanced_range_display,OFF ,30
ENG109862-ENG249824-Vehicle_configuration-AliBox,OFF ,30
ENG109862-ENG142146-Vehicle_configuration-allow_message_editing,OFF ,30
ENG109862-ENG130249-Vehicle_configuration-Apple_DIO,On ,30
ENG109862-ENG185764-Vehicle_configuration-Apple_DIO_Wireless,OFF ,30
ENG109862-ENG152525-Vehicle_configuration-Baidu_Car_Life,OFF ,30
ENG109862-ENG152559-Vehicle_configuration-Baidu_Car_Life_ios,OFF ,30
ENG109862-ENG185765-Vehicle_configuration-Baidu_Car_Life_ios_Wireless,OFF ,30
ENG109862-ENG185766-Vehicle_configuration-Baidu_Car_Life_Wireless,OFF ,30
ENG109862-ENG152560-Vehicle_configuration-block_hmi_function_p_epb,locked ,30
ENG109862-ENG142151-Vehicle_configuration-conditioning_variant,0 ,30
ENG109862-ENG263540-Vehicle_configuration-correction_e_mileage,0 ,30
ENG109862-ENG125043-Vehicle_configuration-Dtmf_without_active_call,On ,30
ENG109862-ENG142145-Vehicle_configuration-esim_data_only_sms_support,OFF ,30
ENG109862-ENG185778-Vehicle_configuration-FoD,SWaP ,30
ENG109862-ENG130248-Vehicle_configuration-Google_GAL,On ,30
ENG109862-ENG185779-Vehicle_configuration-Google_GAL_Wireless,OFF ,30
ENG109862-ENG117850-Vehicle_configuration-gracenote_local_coverarts,OFF ,30
ENG109862-ENG117851-Vehicle_configuration-gracenote_local_other,OFF ,30
ENG109862-ENG117848-Vehicle_configuration-gracenote_online_coverarts,OFF ,30
ENG109862-ENG117849-Vehicle_configuration-gracenote_online_other,OFF ,30
ENG109862-ENG152533-Vehicle_configuration-Hybrid_Radio_additional_online_data,not activated ,30
ENG109862-ENG152534-Vehicle_configuration-Hybrid_Radio_Range_Extender,Deactivated ,30
ENG109862-ENG261211-Vehicle_configuration-internet_over_WLAN_default_setting,OFF ,30
ENG109862-ENG125049-Vehicle_configuration-Joker_button_1,not installed ,30
ENG109862-ENG125050-Vehicle_configuration-Joker_button_2,not installed ,30
ENG109862-ENG127492-Vehicle_configuration-LGI,OFF ,30
ENG109862-ENG130246-Vehicle_configuration-LTE_modul,activated ,30
ENG109862-ENG142142-Vehicle_configuration-map_email_support,OFF ,30
ENG109862-ENG142143-Vehicle_configuration-map_instant_messaging_support,OFF ,30
ENG109862-ENG142141-Vehicle_configuration-map_sms_support,OFF ,30
ENG109862-ENG142152-Vehicle_configuration-Map_Style,0 ,30
ENG109862-ENG152537-Vehicle_configuration-media_control,not activated ,30
ENG109862-ENG138662-Vehicle_configuration-Mirror_link,On ,30
ENG109862-ENG142148-Vehicle_configuration-MirrorLink_Country_Code,MIB_EU ,30
ENG109862-ENG142150-Vehicle_configuration-MirrorLink_RGB_Preference,RGB565 ,30
ENG109862-ENG117843-Vehicle_configuration-my_audi,OFF ,30
ENG109862-ENG117845-Vehicle_configuration-online_dictation,OFF ,30
ENG109862-ENG127495-Vehicle_configuration-online_media,OFF ,30
ENG109862-ENG117840-Vehicle_configuration-online_navigation,OFF ,30
ENG109862-ENG117837-Vehicle_configuration-online_POI,OFF ,30
ENG109862-ENG117838-Vehicle_configuration-online_POI_voice,OFF ,30
ENG109862-ENG117839-Vehicle_configuration-online_portal_browser_services,OFF ,30
ENG109862-ENG152553-Vehicle_configuration-online_radio,Deactivated ,30
ENG109862-ENG117841-Vehicle_configuration-online_street_view,OFF ,30
ENG109862-ENG125048-Vehicle_configuration-OPS_display_in_dash_board_display_unit,OFF ,30
ENG109862-ENG167521-Vehicle_configuration-perso_v_threshold,00 ,30
ENG109862-ENG167522-Vehicle_configuration-perso_v_threshold_hysteresis,00 ,30
ENG109862-ENG152554-Vehicle_configuration-Phone_HMI_Privacy,0 ,30
ENG109862-ENG125046-Vehicle_configuration-Phone_module_operation_mode,Data & language service active ,30
ENG109862-ENG117844-Vehicle_configuration-picture_navi,On ,30
ENG109862-ENG167523-Vehicle_configuration-Pilot_Parking,not activated ,30
ENG109862-ENG167525-Vehicle_configuration-Popup_if_GPS_services_in_use,not activated ,30
ENG109862-ENG152555-Vehicle_configuration-Privacy_WithPINRequest,0 ,30
ENG109862-ENG127496-Vehicle_configuration-ProbeCar_lgi,OFF ,30
ENG109862-ENG137646-Vehicle_configuration-ProbeCar_vzo,OFF ,30
ENG109862-ENG125047-Vehicle_configuration-PSD_Protocol_Version,PSD_1.5 ,30
ENG109862-ENG117846-Vehicle_configuration-remote_HMI,OFF ,30
ENG109862-ENG138661-Vehicle_configuration-RSE_software_component,activated ,30
ENG109862-ENG245031-Vehicle_configuration-rvc_low_black_screen_trunk_open,not activated ,30
ENG109862-ENG244966-Vehicle_configuration-rvc_low_black_screen_velocity_threshold,not activated ,30
ENG109862-ENG245015-Vehicle_configuration-rvc_low_failsafe,not activated ,30
ENG109862-ENG126143-Vehicle_configuration-RVC_video_input,FBAS ,30
ENG109862-ENG152556-Vehicle_configuration-scon_telephony,not activated ,30
ENG109862-ENG142081-Vehicle_configuration-sd_slot_deactivation,no restriction ,30
ENG109862-ENG138660-Vehicle_configuration-SDS_Region_Flag,no_region ,30
ENG109862-ENG152557-Vehicle_configuration-show_volte_hmi_switch,not activated ,30
ENG109862-ENG125045-Vehicle_configuration-Sim_card_mode_switch,not installed ,30
ENG109862-ENG142144-Vehicle_configuration-sim_data_only_sms_support,OFF ,30
ENG109862-ENG138663-Vehicle_configuration-Smartphone_interface_for_rhmi,activated ,30
ENG109862-ENG126993-Vehicle_configuration-Station_Logo_DB_Mode,1 ,30
ENG109862-ENG125044-Vehicle_configuration-Support_for_response_and_hold,OFF ,30
ENG109862-ENG125042-Vehicle_configuration-Support_of_threeway_calling,OFF ,30
ENG109862-ENG130247-Vehicle_configuration-Support_second_phone,On ,30
ENG109862-ENG167531-Vehicle_configuration-Tencent_myCar_canceling_share_location,OFF ,30
ENG109862-ENG126994-Vehicle_configuration-TPEG_availability,OFF ,30
ENG109862-ENG152571-Vehicle_configuration-unblock_functions_while_piloted_driving,locked ,30
ENG109862-ENG137647-Vehicle_configuration-UOTA,OFF ,30
ENG109862-ENG167532-Vehicle_configuration-UOTA_2,OFF ,30
ENG109862-ENG117852-Vehicle_configuration-UPnP,On ,30
ENG109862-ENG142149-Vehicle_configuration-vehicle_leaving_sound,not activated ,30
ENG109862-ENG142147-Vehicle_configuration-vehicle_readiness_sound,not activated ,30
ENG109862-ENG152558-Vehicle_configuration-voice_over_lte,not activated ,30
ENG109862-ENG117836-Vehicle_configuration-VZAPro,OFF ,30
ENG109862-ENG127494-Vehicle_configuration-VZO,OFF ,30
ENG109862-ENG137648-Vehicle_configuration-WiFi_Client_HMI,OFF ,30
ENG109862-ENG117842-Vehicle_configuration-WIFI_Hotspot,On ,30
ENG109862-ENG152572-Vehicle_configuration-wlan_5ghz_switch,not activated ,30
Elapsed Time: 00:44
Re: Retrofit mib2 3Q0035846A problem
Is your Pdc module compatible with mib2?
Homer51
Drives: Polo 6C
Post by Homer51 »
iichel wrote: Sat Jun 17, 2023 7:19 pm Is your Pdc module compatible with mib2?
Hi !
Ha ? You think it could be not compatible ?
Works with mib1 ir’s true ..
But i suspected a defective mib2 unit (only for park)
I bought the kit here it’a 5Q0919283F
https://www.carsystems.eu/new-vw-polo-6 ... d1248.html
maybe i can buy another one ? If you have a good ref that must works (8k i would update from 4k)
