Polo Cross 2017 seats in a 6R
mirceaculita
Drives: 6R 1.2TDI 75hp
Post by mirceaculita »
Hi I found this nice interior from a 2017 Cross and I wonder if it will fit the 6R. I know there are some compatibility issues between 6R and 6C occupancy sensor. Would this be a problem?
I've attached a photo of the wiring under the seats for reference.
Also do they have heating? I can't figure it out from the wiring
Re: Polo Cross 2017 seats in a 6R
swap the sensor and you'll be fine
mirceaculita
That implies taking the covers off the seat right?
Maarten
Post by Maarten »
Green connector is for seatheating
Yellow one for airbag
mirceaculita
oh nice so it's got seat heating. I may go for it. It's 200 euro for front/rear seats + doors cards with the white panel and chrome trim
No these seats do not have seat heating! The green connector is seat belt, yellow is airbag and blue will be passenger detection.
I think you'll get away with removing only a part of the seat upholstery at the front or the rear. No need to remove it all.
You probably will have to remove at least one of the longitudinal wires holding down the fabric and then you can slide the sensor in between.
Ideally you must remove all to properly glue down the pad, but if placed correctly, friction only will keep it in place allright.
Maarten
Post by Maarten »
My bad.
On the 9N3 was it as follows
Yellow: Airbag
Green: Seat heating
Red: Seatbelt (only drivers side, French polo's were optional equipped)
:oops:
That's alright. At least yellow was correct :D
Maarten
Post by Maarten »
:lol: :lol:
mirceaculita
Was going to order them regardless but got sold lmao
