Audible Alert on Door Lock
Grumpyolman
Drives: 2017 Polo 1.0 TSI SEL
Post by Grumpyolman »
Hi Folks,
I have just bought a 2020 GTI and I am searching for the coding to enable audible confirmation of door locking.
Searching using VCDS but cannot find where the option is hiding. Anyone help?
Even better if someone knows how to enable feature in the MFD, example here, but they missed the how to bit…!
https://youtu.be/yLNaxwbcA6g?si=gegqWDTItSDvXOPT
Re: Audible Alert on Door Lock
Seem to remember reading on some forums that in the UK, audible locking / unlocking confirmation is illegal - only visual confirmation is permitted. That might possibly be why you’re unable to find the coding.
Grumpyolman
SRGTD wrote: Sat Sep 09, 2023 5:23 pm Seem to remember reading on some forums that in the UK, audible locking / unlocking confirmation is illegal - only visual confirmation is permitted. That might possibly be why you’re unable to find the coding.
Hi SRGTD,
I realise this, it might not be legal, but I have always enabled this on my VAG cars for the last 20 years. It’s handy feature to have enabled, saves you rubbernecking to check you have locked the car.
Definitely can be enabled, just need to find the right path using VCDS to enable this feature. Managed no problem in my previous 6C Polo.
Maarten
Post by Maarten »
Dauer should be set to short.
All should be set to active {akustische ruckmeldung)
Menuesteuering active.
Possible need to reset the radio to factory settings
GTI 2020 should display a box to check under open and close menu
Grumpyolman
Maarten wrote: Sat Sep 09, 2023 6:42 pm received_1280826459325920.jpeg
Hi Marten,
Thanks. I’ll have a look and have a play about.
Appreciate the screen grab. My German isn’t great 😂
Maarten
Post by Maarten »
Akustische ruckmeldung = audible comfirmation
Dauer = lenght
Menuesteuering = check box in radio menu
Entriegeln = opening
Verriegeln = closing
Grumpyolman
Maarten wrote: Sat Sep 09, 2023 7:08 pm Akustische ruckmeldung = audible comfirmation
Dauer = lenght
Vielen Dank Maarten,
I will give it a go tomorrow and let you know how I get on.
Really appreciate the help.
Maarten
Post by Maarten »
Good luck.
Worked in my FL AW 2022
https://youtu.be/6kDx2XKlv8k?feature=shared
grazuncle2
Drives: Polo 1.0 TSI SE 2019
Post by grazuncle2 »
There is an OCA (One Click App) on my OBDEleven option for this so it can definitely be done..
Grumpyolman
Grumpyolman wrote: Sat Sep 09, 2023 8:05 pm
Dauer = lenght
Maarten, thank you for taking the time to clearly explain.
Everything working 👌🏼. Even managed to leave open/Entriegeln switched off as I just wanted the close option enabled. Having the ability to control through the MFD means I can disable when parking late at night.
Really appreciate your help. I am sure others reading this will too.
Andy
Maarten
Post by Maarten »
Hello Andy,
You are very welcome.
Thanks for the feedback
Glad I could be helpfull.
For future reverence, the checkbox only appears in the pre FL models of the AW.
From modelyear 2022 (new front and tail) there is no longer a check box under open & close in the radio module, so for them it is either on or off via VCDS/OBD11
funkyg
Drives: 2020 Polo GTI+
Post by funkyg »
That’s surprising, it was a standard feature on my Megane.
Maarten
Post by Maarten »
Also illegal in Germany.
Fortunately not illegal in the Netherlands :mrgreen:
