How do i check if the sortware and sat nav info is up to date
Alboyuk
Drives: R Line
Post by Alboyuk »
Hi
I have a 2023 Polo R line and wondered how i check if the cars and the Satnav software is up to date, as i am getting speed restrictions slowing me down when the speed restrictions have been lifted a long time ago
If they are out of date how do i get it updated to the latest versions.
Many thanks for any replies
Maarten
Re: How do i check if the sortware and sat nav info is up to date
Post by Maarten »
Go to MENU then settings, scroll down to system info
Should say 25.1
But the car will not slow down on satnav data.
Only on roadsigns.
Just turn it of in the IQ drive settings
Alboyuk
Drives: R Line
Post by Alboyuk »
How does the car know where it is if it is not using the satnav info in the background also the road signs have been taken down but the car slows down as if they are still in place
Maarten
Post by Maarten »
You could also disable roadsignrecognition.
But the car does not make up speeds.
If it sees a speedlimit is will ajust.
You can stop this in the IQ drive menu
Maarten
Post by Maarten »
Go to IQDRIVE settings
Select ACC
Decheck this box (predict speedlimit)
ACC (1).JPG (948.01 KiB) Viewed 4755 times
Alboyuk
Drives: R Line
Post by Alboyuk »
My screen does not seem to be the same as the one above
Maarten
Post by Maarten »
So what do you see when pressing on ACC?
