Well I found put what was the klunking noise when I realease the gas pedal, it isnt the clutch plate center piece, it was the input shaft bearing.
Unfortunatly for me, it seems that in my case the differential bearings are dead ( how and why this early i'm not sure).
I was driving recently then i got a strange noise from right side of the car ( like when a piece of rock falls between rotor and pad) - scratching metallic sound.
It lasted till first parking lot where i inspected the brakes and gave a look under the bonet.
It seems in most cases it's not possible to replace those bearings ( since some part of the differential becomes pitted
My question since these transmissions are MQ250 02 family....
Can I pick a transmission from fabia mk1, polo 9n3, ibiza mk2 1.9TDI .... since my KFK transmission is double the price?
