all side lights and tail lights out
dwlawson
Drives: 2010 Polo 1.2tsi
Post by dwlawson »
Lighting fault indicator came on this morning. Got out to check: both side lights out and both tail lights out. Number plate lights working. Also what sounds like a relay clicking below the steering wheel. Where do I start? Fuse?
dwlawson
Re: all side lights and tail lights out
Post by dwlawson »
Just noticed interior lights are not coming on either. Weird.
Have a look at the fuses
dwlawson
Post by dwlawson »
Thanks iichel, that was it. Lights are controlled by a module fed by one fuse. If that blows you lose half your lights. Replaced it and cleared fault codes and all is good. Although, having said that, a 10A fuse doesn't blow for no reason.
That is the next question. Did you install any LEDs? Water ingress?
dwlawson
Post by dwlawson »
No LEDs. No water ingress. One of the rear interior festoons had failed. Would that cause it? Surely not.
Sounds unlikely but then again, might be a smoking gun.
