How do I get the ignition key lock off?
dazz
Drives: Polo 6R Comfort Line 2010
Post by dazz »
Hi
I have the VW broken ignition lock problem with the stuck key.
I am trying to remove the plastic coverings between the steering wheel and the instrument cluster.
The top half is flapping around, but held in place by the instrument cluster.
I can't figure out how to release the bottom half. I have found the Torx screw.
Any tips would be appreciated.
Re: How do I get the ignition key lock off?
you pull the part that is in the instrument cluster towards your self. Its just clipped in.
Then you will see torx bolts near the slip ring viewed from top ( birds eye persoective), and on the bottom trim underside there is an torx bolt
Le_Combattant
Post by Le_Combattant »
dazz wrote: Fri Feb 20, 2026 7:21 am Hi
The top half can stay in place, with the cluster
The lower half is installed with one torx screw. When removed, you can gently pull toward the bottom the part to remove it from the steering column assy.
dazz
Post by dazz »
Hi
OK thanks for the info. That will make it easier to work on the break-off bolts. I can't turn them to loosen them off. I am using a cold chisel to try and turn them. I may have to drill them out.
