Big Red - Wiper error *stuck on*
- red6n2
Big Red - VCDS error codes *misfire*
So today I have changed my coil pack HT leads and will change my sparks in a hour when I borrow a deep enough socket. It's running better but still misfiring slightly it's idling ok but when you put your foot down there's a slight rock in the engine. If sparks don't solve it other than the timing belt I'm at a loss anyone hit any suggestions ?!.
- red6n2
Sparks changed coilpack changed ht leads changed... Drives like a fookin dream.
I'm happy once again
Re: Big Red - VCDS error codes *misfire*
Happy days
- red6n2
One of the spark plugs was black and coated so I know that fuel overload most likely due to my lambda sensor being out so it running rich to compensate so next month I will change that. But yeah went for a drive earlier and it's never driven so well.
Running rich will not only blacken and stuff your plugs, it will also wash your bores and over time accelerate ring bore and engine wear and thin your oil.red6n2 wrote:One of the spark plugs was black and coated so I know that fuel overload most likely due to my lambda sensor being out so it running rich to compensate so next month I will change that. But yeah went for a drive earlier and it's never driven so well.
- red6n2
If I could afford to change it this month I would but its going to have to wait till november unfortunately the lambda sensors are just so expensive.
TriggerFish
- Location: Aylesbury, Bucks Drives: Polo GTi, 330d 'M-Sport'
If you can find out if the GTI uses the same sensors, I've got a pair here I got off eBay to replace mine, but the whole engine has since failed so I'm almost certainly going to swap the engine and put ITB's on mine when it's replaced, so have no need for the sensors. . .
- red6n2
Sweet il ring VW tomorrow and find out then if so il take off your hands. I think the gti has a much higher fuel usage so not sure of the comparability
Thanks dude.
Thanks dude.
- red6n2
So just picked up a new amp for my car it's just some cheap 800w 4 channel amp and its only to power my front speakers. And my current 4 channel amp will run twin 10" subs. And il just Velcro the amps to the back of the sub. Will probably fit it all this weekend.
- red6n2
Been a while had a crazy few months pretty much neglected the car but a few probs have cropped up like Brett sure the bracket in the exhaust has gone and my windscreen wipers as of today won't turn off and it's starting to duck me off big time anyone know what's up ?!.
- Piers0930
Re: Big Red - Wiper error *stuck on*
nice polo mate, did you die the carpet?
- red6n2
Thanks, no I didn't mate its how it came, these polos came with two different interior carpet colours a light beige colour and this dark grey.
. I'm in the midst of fixing it up again to its former glory, few weeks it will be back to where it was
