- Drives: Transporter
Ciclo!
Again brilliant, I followed the procedure again, this time no faults other that terminal 30 left and right open circuit, I know why that is so once I completely finish this part and I'm back I will post saying where I'm up to with an up to date scan,
thanks,
Darren
thanks,
Darren
- Drives: Transporter T5GP
Ciclo,
Just dropping a final line to say thanks for your help, had some difficulty sourcing another windscreen and everything took a bit longer than expected so had to improvise....
But finally we are all there now!... just need to source one of the 6c switches but that’s just for aesthetics!
Wednesday,08,August,2018,11:27:16:00006
VCDS Version: 17.8.0.1
Data version: 20170721 DS276.2
www.Ross-Tech.com
VIN: *** License Plate:
Mileage: 129900km-80716mi Repair Order:
Chassis Type: 7H-VN75 (7E0)
Scan: 01 03 04 08 09 10 15 17 19 25 56 0B
VIN: *** Mileage: 129900km-80716miles
56-Radio -- Status: OK 0000
Address 01: Engine (J623-CFCA) Labels:. 03L-906-022-CFC.clb
Part No SW: 03L 906 019 GN HW: 03L 907 309 L
Component: R4 2,0L EDC H38 5606
Revision: 22H38--- Serial number: 00000000000000
Coding: 01194012232400080000
Shop #: WSC 02736 790 50316
ASAM Dataset: EV_ECM20BTD01103L906019GN 003004
ROD: EV_ECM20BTD01103L906019GK_003.rod
VCID: 7DF14FF6ECF168AEE1-8028
Readiness: 0 0 0 0 1
Address 03: ABS Brakes (-----) Labels:. 7E0-907-37x-MK25AXT.clb
Part No SW: 7E0 907 379 K HW: 7E0 907 379 E
Component: ESP MK25A XT H43 0110
Revision: 00H43001
Coding: 508724AD89A50A9824AA9177A96210
Shop #: WSC 02736 790 49152
VCID: 3A7B84EAB55F9F9684-806E
Address 08: Auto HVAC (J301) Labels:| 7E5-907-047.clb
Part No SW: 7E5 907 047 BN HW: 7E5 907 047 BN
Component: Climatic-T5 H20 0506
Revision: 00001012
Coding: 0000000002
ROD: EV_ClimaT5Basis.rod
VCID: 7CF742F2F7EB61A6D6-8028
Part No SW: 7E0 937 090 HW: 7E0 937 090
Revision: B9080001 Serial number: 0771 092160713
Coding: B8A030BA4A73243193284EF06EEB9E54F28063FF608C64C1320000030000
Shop #: WSC 18752 008 00032
VCID: 68DF0EA29B73DD0622-803C
Subsystem 1 - Part No: 1K0 955 559 AF Labels: 1K0-955-559-AF.CLB
Component: RLS 020608 04 46 0204
Coding: 0F30AD
Subsystem 2 - Part No SW: 7E0 959 801 B HW: 7E0 959 801 B Labels: 7E0-959-80X-V1.CLB
Component: J386__TSG_FT 002 3313
Coding: 010000
Subsystem 3 - Part No SW: 7E0 959 802 B HW: 7E0 959 802 B Labels: 7E0-959-80X-V1.CLB
Component: J387__TSG_BT 002 3313
Subsystem 4 - Part No: 7E1 951 172
Component: DWA-Sensor 00 001 0104
Component: LIN BACKUP HO H05 1501
Subsystem 6 - Part No: 7E1 951 172
Address 10: Park/Steer Assist (J446) Labels:| 7E0-919-475.clb
Part No SW: 7E0 919 475 K HW: 1Q0 919 475
Component: PARKHILFE 4K H03 0106
Revision: -------- Serial number: 32931312600211
Coding: 108001
ASAM Dataset: EV_VW75XParkAssis4K 001004
ROD: EV_VW75XParkAssis4K_001.rod
VCID: 3A7B84EABD5F9F9684-806E
Part No SW: 7E0 959 655 B HW: 7E0 959 655 B
Component: VW10Airbag009 H07 0013
Revision: -------- Serial number: 003HL00J7H86
Coding: 000000000000000000000000000000003039
Shop #: WSC 02734 790 50316
ROD: EV_AirbaVW10BPAVN750.rod
VCID: 356197D6944170EE69-8060
Address 17: Instruments (J285) Labels:| 5K0-920-xxx-17.clb
Part No SW: 7E0 920 970 J HW: 7E0 920 970 J
Component: KOMBI H04 0710
Coding: 160A01
ROD: EV_Kombi_UDS_VDD_RM09_004_VN35.rod
VCID: 3169A3C660295CCE35-8064
Part No SW: 7E0 909 901 HW: 7E0 937 090
Revision: B9080001
Coding: 002300
Component: IMMO H04 0710
Serial number:
Shop #: WSC 00000 000 00000
VCID: 6ADB74AA8D7FEF1634-803E
Part No SW: 6RD 035 187 B HW: 6RD 035 187 B
Component: Radio 541 5314
Revision: -------- Serial number: VWZZZ4J6228373
Coding: 16000200020014
Shop #: WSC 127395 840 08317
VCID: 4683E01AF1A7EB76F0-8012
End-------------------------(Elapsed Time: 03:04)--------------------------
Thanks again
Thank you very much for the final report. This is what everyone should do (autoscan).
Please, check again that all the lights work correctly in all positions of the light switch, stalks, buttons, etc ...
Sincerely, Fernando.
Thanks to you!
Thanks to you!
Hello to every one.Dazzyboy81 wrote: ↑Thu Aug 02, 2018 5:31 pm Ciclo!
thanks,
Darren
Hi Dazzyboy81 are you going to take out your dash or no? I'm wondering how long time it will take?
Dear. Ciclo i need your help please. I start next month working on my t5 to add rls, xenon and solve the issues with terminal 30l and r. But i want to retrofit in one time with all of this things my powerwindow, folding mirror. And pdc frond and rear. Looms in the door i have them but under the dash not. Can you help me? PLEASE?
I have changed my windshild already. Light swich and some of the conector i got them last week from dealer. But diagram of the oem Windows can't find.
Beste regards from Belgium to all vag freaks
And i hope all of you had agood summer this year.
Sorry just saw this!
See bellow the photos, just need to get the better light switch you had now as this one looks a bit rubbish but will do for now, I also want to get some better headlights but again will wait a while!
Please excuse how dirty the van is!
Hi bizmo, are you using oem vw lights swich or aliexpress rubbish? I hade the same issue 5weeks ago with my gti.
It’s an OEM switch from the Mk5/mk6 golf
I’ve used Ciclos wiring so should be, everything seems to work. Maybe one of our switches has a function the other doesn’t?
Any ideas ciclo?
I'd say it's normal for the light switch not to be illuminated in the 0 setting, only the light bulb on the rotating part is illuminated on mine.
Same on mine, just the bulb part on the switch is illuminated
Hi guys this is what i was talking about here the pic of illumin. https://imgur.com/a/4RVarNG
I’d say it wasn’t supposed to be like that, probably a wiring error
Without the auto switch that does the DRL so maybe it’s because of the power going to the lights?
Adam i was by vw and they told me some of the vw cars are oem. I have done nothing. Only retrofited c.c and mfsw. In november i will paint my t5 and i will take my dash out. And in one time i will upgrade my rls and xenon and pdc. With help of ciclo and bizmo. I hope so.
Bizmo my h4 drl works perfect i have only made adaptation my c.h. and. l.h. i
btw bizmo have your t5 oem xenon? Or retrofited? I made my self adapters it looks like by golf6 but i have still probs with 3 cables. And i dont have elsawin dunno where to download. Thx alot.
