Dazzyboy81
Drives: Transporter
Post by Dazzyboy81 »
Ciclo!
Again brilliant, I followed the procedure again, this time no faults other that terminal 30 left and right open circuit, I know why that is :wink: so once I completely finish this part and I'm back I will post saying where I'm up to with an up to date scan,
thanks,
Darren 8)
Bizmo
Drives: Transporter T5GP
Post by Bizmo »
ciclo wrote: Wed Jul 25, 2018 3:15 am
By other side, right now I'm on vacation. (Meditation time ... Image, Image, Image, ...)
Ciclo,
Just dropping a final line to say thanks for your help, had some difficulty sourcing another windscreen and everything took a bit longer than expected so had to improvise....
But finally we are all there now!... just need to source one of the 6c switches but that’s just for aesthetics!
Wednesday,08,August,2018,11:27:16:00006
VCDS Version: 17.8.0.1
Data version: 20170721 DS276.2
www.Ross-Tech.com
VIN: ***   License Plate:
Mileage: 129900km-80716mi   Repair Order:
Chassis Type: 7H-VN75 (7E0)
Scan: 01 03 04 08 09 10 15 17 19 25 56 0B
VIN: ***   Mileage: 129900km-80716miles
56-Radio -- Status: OK 0000
Address 01: Engine (J623-CFCA)       Labels:. 03L-906-022-CFC.clb
  Part No SW: 03L 906 019 GN    HW: 03L 907 309 L
  Component: R4 2,0L EDC   H38 5606
  Revision: 22H38---    Serial number: 00000000000000
  Coding: 01194012232400080000
  Shop #: WSC 02736 790 50316
  ASAM Dataset: EV_ECM20BTD01103L906019GN 003004
  ROD: EV_ECM20BTD01103L906019GK_003.rod
  VCID: 7DF14FF6ECF168AEE1-8028
Readiness: 0 0 0 0 1
Address 03: ABS Brakes (-----)       Labels:. 7E0-907-37x-MK25AXT.clb
  Part No SW: 7E0 907 379 K    HW: 7E0 907 379 E
  Component: ESP MK25A XT  H43 0110
  Revision: 00H43001
  Coding: 508724AD89A50A9824AA9177A96210
  Shop #: WSC 02736 790 49152
  VCID: 3A7B84EAB55F9F9684-806E
  Part No SW: 7E5 907 047 BN    HW: 7E5 907 047 BN
  Component: Climatic-T5   H20 0506
  Revision: 00001012
  Coding: 0000000002
  ROD: EV_ClimaT5Basis.rod
  VCID: 7CF742F2F7EB61A6D6-8028
  Revision: B9080001    Serial number: 0771 092160713
  Coding: B8A030BA4A73243193284EF06EEB9E54F28063FF608C64C1320000030000
  Shop #: WSC 18752 008 00032
  VCID: 68DF0EA29B73DD0622-803C
  Subsystem 1 - Part No: 1K0 955 559 AF  Labels: 1K0-955-559-AF.CLB
  Component: RLS 020608 04  46  0204
  Coding: 0F30AD
  Subsystem 2 - Part No SW: 7E0 959 801 B    HW: 7E0 959 801 B  Labels: 7E0-959-80X-V1.CLB
  Component: J386__TSG_FT  002 3313
  Coding: 010000
  Subsystem 3 - Part No SW: 7E0 959 802 B    HW: 7E0 959 802 B  Labels: 7E0-959-80X-V1.CLB
  Component: J387__TSG_BT  002 3313
  Subsystem 4 - Part No: 7E1 951 172
  Component: DWA-Sensor 00  001 0104
  Subsystem 6 - Part No: 7E1 951 172
  Part No SW: 7E0 919 475 K    HW: 1Q0 919 475
  Component: PARKHILFE 4K  H03 0106
  Revision: --------    Serial number: 32931312600211
  Coding: 108001
  ASAM Dataset: EV_VW75XParkAssis4K 001004
  ROD: EV_VW75XParkAssis4K_001.rod
  VCID: 3A7B84EABD5F9F9684-806E
  Part No SW: 7E0 959 655 B    HW: 7E0 959 655 B
  Component: VW10Airbag009 H07 0013
  Revision: --------    Serial number: 003HL00J7H86
  Coding: 000000000000000000000000000000003039
  Shop #: WSC 02734 790 50316
  ROD: EV_AirbaVW10BPAVN750.rod
  VCID: 356197D6944170EE69-8060
Address 17: Instruments (J285)       Labels:| 5K0-920-xxx-17.clb
  Part No SW: 7E0 920 970 J    HW: 7E0 920 970 J
  Component: KOMBI         H04 0710
  Coding: 160A01
  ROD: EV_Kombi_UDS_VDD_RM09_004_VN35.rod
  VCID: 3169A3C660295CCE35-8064
  Revision: B9080001
  Coding: 002300
  Component: IMMO          H04 0710
  Serial number:
  Shop #: WSC 00000 000 00000
  VCID: 6ADB74AA8D7FEF1634-803E
  Component: Radio         541 5314
  Revision: --------    Serial number: VWZZZ4J6228373
  Coding: 16000200020014
  Shop #: WSC 127395 840 08317
  VCID: 4683E01AF1A7EB76F0-8012
End-------------------------(Elapsed Time: 03:04)--------------------------
Thanks again
Thank you very much for the final report. This is what everyone should do (autoscan).
Please, check again that all the lights work correctly in all positions of the light switch, stalks, buttons, etc ...
Sincerely, Fernando.
Thanks to you!
El Boss
Drives: Vw T5GP LWB
Post by El Boss »
Dazzyboy81 wrote: Thu Aug 02, 2018 5:31 pm Ciclo!
thanks,
Darren 8)
Hello to every one.
Hi Dazzyboy81 are you going to take out your dash or no? I'm wondering how long time it will take?
Dear. Ciclo i need your help please. I start next month working on my t5 to add rls, xenon and solve the issues with terminal 30l and r. But i want to retrofit in one time with all of this things my powerwindow, folding mirror. And pdc frond and rear. Looms in the door i have them but under the dash not. Can you help me? PLEASE?
I have changed my windshild already. Light swich and some of the conector i got them last week from dealer. But diagram of the oem Windows can't find.
Beste regards from Belgium to all vag freaks 😁
And i hope all of you had agood summer this year.
Bizmo
Post by Bizmo »
ciclo wrote: Thu Aug 09, 2018 6:01 am Thank you very much for the final report. This is what everyone should do (autoscan).
Thanks to you!
Sorry just saw this!
See bellow the photos, just need to get the better light switch you had now as this one looks a bit rubbish but will do for now, I also want to get some better headlights but again will wait a while!
Please excuse how dirty the van is!
El Boss
Drives: Vw T5GP LWB
Post by El Boss »
Bizmo wrote: Sun Sep 02, 2018 6:45 pm
Thanks to you!
Hi bizmo, are you using oem vw lights swich or aliexpress rubbish? I hade the same issue 5weeks ago with my gti.
Bizmo
Post by Bizmo »
It’s an OEM switch from the Mk5/mk6 golf
El Boss
Drives: Vw T5GP LWB
Post by El Boss »
Bizmo wrote: Mon Sep 03, 2018 7:51 pm It’s an OEM switch from the Mk5/mk6 golf
Hey bizmo on my t5 and gti when i put on 0 it lightning red. But on your t5 not. Are you sure thate wiring is correct??? Juist asking.
Bizmo
Post by Bizmo »
El Boss wrote: Wed Sep 05, 2018 7:51 pm
I’ve used Ciclos wiring so should be, everything seems to work. Maybe one of our switches has a function the other doesn’t?
Any ideas ciclo?
I'd say it's normal for the light switch not to be illuminated in the 0 setting, only the light bulb on the rotating part is illuminated on mine.
Adam87
Drives: T5.2
Post by Adam87 »
Same on mine, just the bulb part on the switch is illuminated
El Boss
Drives: Vw T5GP LWB
Post by El Boss »
Hi guys this is what i was talking about here the pic of illumin. https://imgur.com/a/4RVarNG
Adam87
Drives: T5.2
Post by Adam87 »
I’d say it wasn’t supposed to be like that, probably a wiring error
Bizmo
Post by Bizmo »
Without the auto switch that does the DRL so maybe it’s because of the power going to the lights?
El Boss
Drives: Vw T5GP LWB
Post by El Boss »
Bizmo wrote: Thu Sep 13, 2018 6:50 pm Without the auto switch that does the DRL so maybe it’s because of the power going to the lights?
Adam i was by vw and they told me some of the vw cars are oem. I have done nothing. Only retrofited c.c and mfsw. In november i will paint my t5 and i will take my dash out. And in one time i will upgrade my rls and xenon and pdc. With help of ciclo and bizmo. I hope so. 😂
Bizmo my h4 drl works perfect i have only made adaptation my c.h. and. l.h. i
btw bizmo have your t5 oem xenon? Or retrofited? I made my self adapters it looks like by golf6 but i have still probs with 3 cables. And i dont have elsawin dunno where to download. Thx alot.
