retrofitting kessy to the Polo 6R
Re: retrofitting kessy to the Polo 6R
shanny wrote: Sun Nov 10, 2019 12:28 pm Nope =(
I always got "Forbidden. Contains contacts. Message seems to be spam. " Error. But it is the same content like in the picture.
Try it by deleting the ross-tech web address from the autoscan text file, then copy and paste the autoscan text.
ag69
Drives: 1.2TSi 77Kw 7DSG
Post by ag69 »
pardon me to ask such basic question here.
could you please help me with pin for start stop button (illumination)
This is how button is :
This is the connector:
It has 4 pins.
1 is GND
2 is the illumination
3 and 4 are the starter signals to the ELV
ag69
Post by ag69 »
Thank you iichel.
My illumination project unlike you (all greats full fledged system) is on ;)
shanny
Drives: VW UP
Post by shanny »
ciclo wrote: Sun Nov 10, 2019 6:08 pm
Now it works, I had nothing changed.
Adresse 01: Motorelektronik (J623-CHYA) Labeldatei:. 04C-906-020-CHY.clb
Teilenummer SW: 04C 906 020 D HW: 04C 907 309 A
Bauteil: 1.0l R3 MPI H01 6464
Revision: U8H01--- Seriennummer:
Codierung: 00110012022401000000
Betriebsnr.: WSC 84227 123 22067
ASAM Datensatz: EV_ECM10MPI01104C906020D 001011
ROD: EV_ECM10MPI01104C906020D.rod
VCID: 1C31EEC817A8A8AA21-8048
Kein(e) Fehlercode(s) gefunden.
Adresse 05: Zugangs-/Startber. (J518) Labeldatei:| DRV\5K0-959-434.clb
Teilenummer SW: 5K0 959 434 A HW: 5K0 959 434 A
Bauteil: VWKESSYPQ35GP 085 0802
Revision: 00085000 Seriennummer: 0145973523
Codierung: 030C0C
ASAM Datensatz: EV_KESSY_PQ35GP A01018
ROD: EV_KESSY_PQ35GP.rod
VCID: 3326CBF79A871BD754-8066
Adresse 09: Zentralelektrik (J519) Labeldatei:. DRV\7E0-937-BCM-V1.clb
Teilenummer SW: 7E0 937 090 A HW: 7E0 937 090
Bauteil: BCM PQ25 Max4 H80 0736
Revision: B9080001 Seriennummer: 0771 251150512
Codierung: 64B8293868E1060093280FF42EE806E177C4606E60012CC020B400420940
VCID: 291A299F404B5107EE-807C
Subsystem 1 - Teilenummer: 5K7 955 559 B Labeldatei: DRV\5K7-955-559.CLB
Bauteil: RLS 060416 03 37 0059
Codierung: 0228DD
Subsystem 2 - Teilenummer SW: 6R0 959 802 CH HW: 6R0 959 802 CH Labeldatei: 6R0-959-802.CLB
Bauteil: J386__TSG_FT 003 9610
Seriennummer: KU0KU016061441670503
Codierung: 0200A1
Subsystem 3 - Teilenummer SW: 6R0 959 801 CF HW: 6R0 959 801 CF Labeldatei: 6R0-959-801.CLB
Bauteil: J387__TSG_BT 003 9610
Seriennummer: KU0KU013061441648403
Codierung: 1200A1
Subsystem 4 - Teilenummer: 1K8 951 171 A
Bauteil: DWA-Sensor 00 001 0103
Codierung: 000000
Subsystem 5 - Teilenummer: 1K8 951 171 A
Codierung: 000000
Adresse 17: Schalttafeleinsatz (J285) Labeldatei:| DRV\5K0-920-xxx-17.clb-SRI1
Teilenummer SW: 5C5 920 870 HW: 5C5 920 870
Bauteil: KOMBI H08 0014
Revision: X0008003 Seriennummer:
Codierung: 110A21
ASAM Datensatz: EV_KombiUDSMM9RM10 A04305
ROD: EV_KombiUDSMM9RM10_A04_VW12.rod
VCID: 679E6FA79EDFA77738-8032
Adresse 19: Diagnoseinterface (J533) Labeldatei:. DRV\7E0-909-901.clb
Teilenummer SW: 7E0 909 901 HW: 7E0 937 090
Bauteil: GW-K-CAN TP20 H80 0736
Revision: B9080001
Codierung: 502003
VCID: 689C6C9B9BC1A80F31-803C
Adresse 25: Wegfahrsperre (J334) Labeldatei:| DRV\5K0-920-xxx-25.clb
Teilenummer SW: 5K0 953 234 HW: 5C5 920 870
Bauteil: IMMO H08 0014
Codierung: 000007
Betriebsnr.: WSC 00066 000 00150
ASAM Datensatz: EV_ImmoUDSMM9RM10 A01301
ROD: EV_ImmoUDSMM9RM10_VW12.rod
VCID: 6A9816938DCD9A1F27-803E
Adresse 2B: Lenksäulenverrieg. (J764) Labeldatei:* DRV\5K0-905-861.clb
Teilenummer SW: 5K0 905 861 A HW: 5K0 905 861 A
Bauteil: ELV-PQ35 H20 0230
Revision: 00000000 Seriennummer: 11000086925002
Codierung: 4100000000000000
ASAM Datensatz: EV_ELVMarquMPVW36X A01001
ROD: EV_ELVMarquMPVW36X.rod
VCID: 2E10DA8371A5363F3B-807A
vento2013
Drives: 6R Polo(Vento)1.6TDi, Skoda Fabia 1.2MPi
Post by vento2013 »
Hi, iichel,
Will you please post some pictures of Start button with Scirocco trim: 1K8 858 599 A
and steering column switch VW Up 1S0 959 503 x
after KESSY installation
I'm sorry but I cannot provide since the 1S0 stalks are no longer in there. I have the 2Q0 stalks from the new Polo with 6C0 slip ring (without G85).
vento2013
Post by vento2013 »
iichel wrote: Wed Nov 27, 2019 1:27 am I'm sorry but I cannot provide since the 1S0 stalks are no longer in there. I have the 2Q0 stalks from the new Polo with 6C0 slip ring (without G85).
:D
Ok. will you please share picture with Polo stalk. just wanted to see how it looks!
Earlier you said you have to install 1S0 stalk so asked! :)
vento2013
Post by vento2013 »
also wanted to see how you managed height and reach adjust lever
vento2013
Post by vento2013 »
Hi, iichel,
found full kit of KESSY, seller says full kit is new, he also has used ELV and KESSY module everything else new as an option for less price. attaching picture too.
Kessy module 5K0959434E
Electronic steering lock 5K0905861C
Full wiring kit
found a guy who has VVDI and ODIS with some experience.
So wanted to know PQ 35 wiring kit can be used?
Please guide!
Yes, the wiring is identical between PQ25 and PQ35 for the antenna and ELV and Kessy module.
You need to improvise in how to connect relays (+15, +75, converter box).
vento2013
Post by vento2013 »
Ok.
What is converter box?
Apart from above image what are the other parts I need. Please let me know. So I can source them too.
Robbo770
Drives: Polo SEL 1.4 tdi 2014
Post by Robbo770 »
Hi iichel,
Is this upgrade able on a 6C, or completely different due to bcm?
vento2013
Post by vento2013 »
vento2013 wrote: Fri Jun 05, 2020 7:17 pm
BUMP :|
vento2013 wrote: Thu Jun 11, 2020 1:41 pm
BUMP :|
I don't have the time to look into this in detail. I'll share my google drive folder with all the information i found:
https://drive.google.com/drive/folders/ ... sp=sharing
I hope you can find whatever you need in this.
Robbo770 wrote: Sat Jun 06, 2020 6:42 pm Hi iichel,
It's completely different from a 6R. I know kessy is available in the 6C-based Fabia. But I don't know how to do this for the Polo 6C.
