UPGRADING BCM 6R
patil
Re: UPGRADING BCM 6R
Post by patil »
govindsharma wrote: Fri Sep 06, 2019 3:54 pm Ciclo Sir ESP installed successfully video attached
Sharmaji congratulations. :D
Sir i had also installed shark fin antenna in my car but here one following error occurs in VCDS that is under please tell me how can i rectify it.
Thank you.
That error is due to installation of 2nd FM ( diversity antenna)
Your RCD 330+ is using 2nd FM signal input for radio and hence 1st antenna is short to ground. I think it is normal.
I may be wrong also :mrgreen:
About the question you ask me by email related to the CC Emulator. :arrow: viewtopic.php?f=56&t=58703&start=4725#p564515
If your current buttons are these: (your last Autoscan posted here)
Subsystem 4 - Part No SW: 6C0 959 442 HW: 6C0 959 442
Serial number: 0111607164000748AB2B
Coding: 240000
The sport buttons on the link to aliexpress you show me (they are no longer for sale) do not fit in your steering wheel: https://es.aliexpress.com/item/32979883 ... 723bZOTwkc
You should get 6C0959442A buttons or similar. (aliexpress, ebay, vw dealer, etc...)
Please get in touch with Slavik, he will tell you everything you need to know to install the CC Emulator. Thank you! :wink:
adityagttsi
Drives: Polo GT 1.2 TSI
Post by adityagttsi »
govindsharma wrote: Thu Jan 25, 2018 2:36 pm Dear sir autoscan of car
Chassis Type: 60 (7E0)
Scan: 01 03 04 08 09 10 15 17 19 20 25 44 56 65 0B
VIN: MEXD16603GOVIND
56-Radio -- Status: OK 0000
Address 01: Engine (J623-CJLA)       Labels: None
   Part No SW: 03E 906 019 AQ    HW: 03E 906 019 AQ
   Component: SIMOS11.2     H04 1968
   Revision: --H04---    Serial number:
   Coding: 00110016032400000000
   Shop #: WSC 01234 785 00200
   ASAM Dataset: EV_ECM12MPI02103E906019AQ 001001
   ROD: N/A
   VCID: 73E5B5AADA7402DAAD-8026
No ASAM data for: "EV_ECM12MPI02103E906019AQ" (VW25)
Readiness: 0000 0100
Address 03: ABS Brakes (J104)       Labels: Redir Fail!
   Part No SW: 6R0 907 379 BP    HW: 6R0 907 379 AQ
   Component: ABS9.0 front  H01 0003
   Serial number: --------------
   Coding: 60DD2763212B18C20618E46B845818000000
   Shop #: WSC 00000 000 08192
   ASAM Dataset: EV_Brake1ABS90BOSCH 003017
   ROD: EV_Brake1ABS90BOSCH_VW25.rod
   VCID: 0D11C352DC90742ADB-8058
Address 04: Steering Angle (G085)       Labels: 6R0-959-654.clb
   Component: LENKW.SENSOR  H06 0060
   Serial number: 090465LEA0003X
   Coding: 01
   Shop #: WSC 00000 000 00000
   ROD: EV_LWSKLOVW25X.rod
   VCID: 7EF3949EE1365FB2D2-802A
   Part No SW: 6R0 907 044 Q    HW: 6R0 907 044 Q
   Component: Climatronic   H12 0615
   Revision: V0000000
   VCID: 41892F62D848E04AEF-8014
Address 09: Cent. Elect. (J519)       Labels: 7E0-937-BCM-V1.clb
   Part No SW: 7E0 937 090 B    HW: 7E0 937 090
   Component: BCM PQ25 Max4 H81 0744
   Revision: B9081001    Serial number: 0982 352161207
   Coding: 3AB02BBF48A3000001380FB07E8B9E905FC0616F60AC20C0200000030800
   Shop #: WSC 12345 123 12345
   VCID: 2A5B68CE453E0312DE-807E
   Subsystem 1 - Part No: 5K7 955 559 B
   Component: RLS 311215 03  37  0059
   Coding: 0728DD
   Subsystem 2 - Part No SW: 6R0 959 802 BH    HW: 6R0 959 802 BH  Labels: 6R0-959-802.CLB
   Component: J386__TSG_FT  003 8612
   Serial number: KU0KU021021440523980
   Coding: [b][color=#FF0000]1400B1[/color][/b]
   Subsystem 3 - Part No SW: 6R0 959 801 BC    HW: 6R0 959 801 BC  Labels: 6R0-959-801.CLB
   Component: J387__TSG_BT  003 8611
   Serial number: KU0KU004101300011381
   Coding:[b][color=#FF0000] 0400B3[/color][/b]
   Coding: 240000
   Subsystem 5 - Part No SW: 6R0 959 811 S    HW: 6R0 959 811 S
   Component: J388__TSG_HL  019 1552
   Serial number: 13102728160108150857
   Subsystem 6 - Part No SW: 6R0 959 812 S    HW: 6R0 959 812 S
   Component: J389__TSG_HR  019 1552
   Serial number: 13202729160111111032
Address 10: Park/Steer Assist (J446)       Labels: 7E0-919-475.clb
   Part No SW: 7E0 919 475 K    HW: 1Q0 919 475
   Component: PARKHILFE 4K  H03 0106
   Revision: --------    Serial number: 35821404004439
   Coding: 308001
   ASAM Dataset: EV_VW75XParkAssis4K 001004
   ROD: EV_VW75XParkAssis4K.rod
   VCID: 3A7B588EBD9EB392AE-806E
   Revision: --------    Serial number: 003GW013KE03
   Coding: 003036
   VCID: 49993742E878280A37-801C
   Part No SW: 6RD 920 870 A    HW: 6RD 920 870 A
   Component: KOMBI         H03 0805
   Coding: 140801
   Shop #: WSC 17218 938 12345
   ROD: EV_Kombi_UDS_VDD_RM09_VW25.rod
   VCID: 479D317AFE6CDE7A21-8012
   Component: GW-K-CAN TP20 H81 0744
   Revision: B9081001
   Coding: 002300
   VCID: 68DFD2C69BB2F10208-803C
Address 20: High Beam Assist. (J844)       Labels: 8S0-857-511.clb
   Revision: AA001001
   Coding: 040401E200000000000000
   VCID: 2E5364DE71D66F3202-807A
   Component: IMMO          H03 0805
   VCID: 6ADBA8CE8DBEC3121E-803E
Address 44: Steering Assist (J500)       Labels: 1Sx-909-144-44.clb
   Part No SW: 1S2 909 144 P    HW: 1S2 909 144 P
   Component: EPS_ECU       H61 1702
   Coding: 0001000001000000
   ROD: EV_SteerAssisNSK_VW12.rod
   VCID: 41892F62D048E04AEF-8014
Address 56: Radio (J503)       Labels: User\6RD-035-187.lbl
   Part No SW: 6RD 035 187 A    HW: 6RD 035 187 A
   Component: MIB2-S-R-CN   025 0210
   Revision: -----001    Serial number: 12765GD0082357
   Coding: 00000440000000
   Shop #: WSC 00081 790 00184
   VCID: 45813B72CC60CC6AD3-8010
   Serial number: 30000000060895
   ROD: EV_RDKBERU30_VW36.rod
   VCID: 377D41BA8E8CAEFA51-8062
End-------------------------(Elapsed Time: 03:06)--------------------------
Coding: 1400B1
Coding: 0400B3
Hello guys, new to this forum. Did try the above coding from auto folding function but it does not work in my car. Any solutions??.
The code gets accepted but the folding function doesnt work and upon that front window switch functions have been inter changed.
Need help guys. Thanks in advance
govindsharma
Drives: polo 1.2 petrol HighLine
Post by govindsharma »
can you post latest autoscan of your here.
adityagttsi
govindsharma wrote: Sun Feb 02, 2020 2:18 pm can you post latest autoscan of your here.
Part No SW: 6RU 937 087 S HW: 6RU 937 087 S
Component: BCM IM H+4 H43 0471
Revision: BZ043001 Serial number: 4201 256190258
Coding: 3AB02BFF48B30000013806007CEF9690B0C0600F608E0100220000000A00
Shop #: WSC 124697 483 00190
VCID: 72EB6FCFADAF28DF9F-8026
Subsystem 1 - Part No: 5K7 955 559 C Labels: 5K7-955-559.CLB
Component: RLS 180619 05 50 0106
Coding: 066800
Subsystem 2 - Part No SW: 6R0 959 802 EF HW: 6R0 959 802 EF Labels: 6R0-959-802.CLB
Component: J386__TSG_FT 023 2551
Serial number: 13202848190716085938
Coding: 140000
Subsystem 3 - Part No SW: 6R0 959 801 ED HW: 6R0 959 801 ED Labels: 6R0-959-801.CLB
Component: J387__TSG_BT 023 2551
Serial number: 13102849190711213513
Coding: 040000
Serial number: 1961915005001392AB2B
Coding: 240000
Component: J388__TSG_HL 022 1552
Serial number: 13102728190711175909
Component: J389__TSG_HR 022 1552
Serial number: 13102729190711052611
I tried the codes but the B3/B1 part doesnt get accepted and instead shows 00
Your WRMs software does not support the automatic fold-in function.
Coding: 140000
Coding: 040000
adityagttsi
ciclo wrote: Sun Feb 02, 2020 6:02 pm Your WRMs software does not support the automatic fold-in function.
Coding: 140000
Coding: 040000
So what do i have to do for automatic fold-in function? Get new WRMs?
One more thing from 2019 according to the new traffic rules the MFD gets locked at 80kmph speed warning no matter what speed i am till the time its above 80kmph. Anyway i can disable this so can view the actual digital speed or MFD functions?
patil
Post by patil »
adityagttsi wrote: Sun Feb 02, 2020 6:46 pm
Hello adityagttsi yes, you need to buy new/used WRM's for RHD with part numbers in picture below.
You just need to replace the existing WRM's with these on front driver and passenger side doors. After installing motors, change the coding as mentioned in Govind Sharma's previous post.
Reset the comfort window function after coding change and you are good to go.
With this you will have all existing functions plus mirror autofold(long press keyfob) and unfold with ignition ON
These WRM are a rarity, difficult to get. you try on eBay, and RHD markets like UK, Malaysia, southafrica, etc..
Good luck :lol:
We all must be grateful to Master ciclo for this superb discovery :)
govindsharma
Hello Friends today GRA High Is activated in my car with the help of Ciclo Sir and Patil ji .Pictures attached .Ciclo sir advice me to activate this feature a long time ago but i have not proper tool for it but suddenly Patil ji made me call and told me to send my ECU and IC with Keyfob and Patil ji finally activated GRA high and illumination niddle in my car IC.Ciclo sir edited my ECU file and Patil ji flashed this file in my car ECU .Thank you to CIclo Ji and PAtil ji for your help.Patill ji please discribe all process here if possible.
Thank you.
Hi Govind.
Enjoy it! 🎉
Very good job Patil!👌
My intervention was totally free for these great colleagues who have accompanied me during these years. Thanks!
patil
Post by patil »
govindsharma wrote: Mon Sep 19, 2022 2:23 pm Hello Friends today GRA High Is activated in my car with the help of Ciclo Sir and Patil
It's a small favour in return for many selfless helps you did for my little 6R. :wink:
ciclo wrote: Mon Sep 19, 2022 7:21 pm
Thank you Master, it wouldn't have been possible without your magical touch.🤘
patil
Post by patil »
GRA High activation in Polo6R MPI 1.2 ( CJLA)Simos 11.2 ECU.
On behalf of dear friend Govind and with his kind permission I post here the details.
Simos 11.2 ECU was a hard nut to crack!!
Flashing through OBD was out of question as car was 2500+ km away, so requested Govind to send the ECU, IC and the key. On bench mode I could able to read and save the dump. The modified dump with GRA High activated was sent by Master ciclo. Now the real problem began, the same FLEX ecu programming tool which read the ecu, refused to flash saying " parameters not correct for writing, vehicle speed is not 0" write failed! ... what the..😁
Tried to read and write with another powerful tool KESS3, but again same result. :?
I decided to arrange a similar MPI 1.2 engine and connect our ecu, IC and try flashing through OBD, but unfortunately I couldn't find a similar Polo. May be in-vehicle flash would have been successful, but we can never know now, couldn't get a change to try.
Now left with only remaining option is "Boot mode" that means open heart surgery 😁 for which Govind was unwilling initially, but I persuaded him to agree. In boot
mode too I faced an issue, the ecu still refused to accept the edited dump saying.. "maps incomplete.. write failed" Here ecu tuner told me that I edit the complete dump( flash+immo data) and reflash again. I edited the complete dump to activate GRA High( used hex cmp software) .. here again thanks to master ciclo for sharing the pictures of necessary byte to be edited in previous emails which came handy at the time of flashing. 👌
Finally after much tormenting, the ECU let us write successfully.😅😎
Few pictures of the process:
The tormentor 😁
ECU opened for boot mode.. can you see worms on the PCB?😂
PCB connection points for programmer.
Connected to ECU: For a moment I felt like an expert😁
Writing started:
Finally... 😍
I thank Govind for having patience, I thank Master ciclo for editing the flash and finally I thank my friend ECU expert for all the help. I got to learn something new entirely in the process.. the knowledge gained was priceless.🤓
ag69
Drives: 1.2TSi 77Kw 7DSG
Post by ag69 »
no words to express ...
finally nut cracked and we got to see these mods
beautiful work patil and ciclo
