I have put this coding into BCM just now, many thanks for this, it is like a different van
Fault scan below
Current state of affairs-
Relay fitted, which is supposed to be a direct replacement for genuine VW 646 relay - Bosch 0332201107 - which I think is an 30/10 Amp, this is all I could get today after being messed about by another supplier. It works though.
ALWR wired in, apart from the sensors which are on order. Seems like my suspicions were correct, I think It is either the wrong one or I need to re code it somehow. (It was a gamble anyway). It wont accept the coding for VW t5 if I try to change it.
Left headlamp will be tested tomorrow, I may as well plug the loom in before I fit it to the bumper.
RLS, mirror etc not wired in, the wiring for this will be getting started tomorrow. I have decided to fit the good old W8 light mod which I wish I had planned for before I started but never mind.
It will be another week or so before any of this is sorted, I'm still trying to sort out windscreen and a few other bits.
At least I now have confidence the wiring I have carried out seems to be correct, I have varied it slightly from your standard Plug and play set up as I have started with a messed up/bodged standard loom and no kufatec T10-T14 conversion harness so I was worried I might mess it up. There is no way I could have achieved any of this without yourself and this forum and for that I thank you and everyone else in this topic that has contributed. Especially as I am gatecrashing this forum, and someone else's topic for that matter
I hope to post later with some more info on what I have changed in the loom and put some pictures up etc.
I was messing about with some of the coding before you gave me the bcm code, so I might have to change some more to get rid of some of these fault codes.
Chassis Type: 7H-VN75 (6N0)
Scan: 01 03 04 08 09 10 15 17 18 19 22 25 55 69 0B
VIN: WV2ZZZ7HZDH0 Mileage: 130870km-81318miles
18-Aux. Heat -- Status: OK 0000
22-AWD -- Status: OK 0000
55-Headlight Range -- Status: Malfunction 0010
69-Trailer -- Status: Cannot be reached 1100
Address 01: Engine (J623-CFCA) Labels:. 03L-906-022-CFC.clb
Part No SW: 03L 906 019 GK HW: 03L 907 309 L
Component: R4 2,0L EDC H37 3566
Revision: 22H37--- Serial number: 00000000000000
Coding: 0119401A233600080000
Shop #: WSC 02756 790 50316
ASAM Dataset: EV_ECM20BTD01103L906019GK 003003
ROD: EV_ECM20BTD01103L906019GK_003.rod
VCID: 7AADF0A04C5F927B1C7-802E
3 Faults Found:
5568 - Sensor for Ambient Air Temperature (G17)
P0073 00 [039] - Signal too High
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 1
Mileage: 130877 km
Date: 2020.08.21
Time: 00:05:05
Engine speed: 0.00 /min
Normed load value: 0.0 %
Vehicle speed: 0 km/h
Coolant temperature: 16 °C
Intake air temperature: 18 °C
Ambient air pressure: 970 mbar
Voltage terminal 30: 12.320 V
Exh.gas temp.sen 1: 20.0 °C
Exh.gas temp.sen 2: -0.0 °C
Exh.gas temp.sen 3: 21.9 °C
Exh.gas temp.sen 4: 20.0 °C
Shut-off timer: last engine shut-off time: 312 s
10065 - Mass Air Flow Sensor (G70)
P0104 00 [167] - Intermittent
MIL ON - Not Confirmed - Tested Since Memory Clear
Fault Priority: 2
Fault Frequency: 1
Mileage: 130877 km
Date: 2020.08.21
Time: 00:05:05
Air mass: actual value (mg/stroke): 0.0 mg/stroke
Standardized airflow ratio: filtered: 3.9999
EGR Solen.val.: actual value: 100.01 %
Throttle valve adapter: actual value: 104.35 %
Charge air pressure specified value: 1020 hPa
Charge air pressure: actual value: 986.0 hPa
Mean injection quantity: 0.00 mg/stroke
9531 - Manifold / Barometric Pressure Sensor (G71) / (F96)
P0105 00 [039] - Malfunction
Fault Priority: 2
Fault Frequency: 1
Mileage: 130877 km
Date: 2020.08.21
Time: 00:05:05
Charge air pressure: actual value: 977.4 hPa
Intake air pressure sensor after air cleaner: raw value: 1150 hPa
Sensor for charge pressure between turbochargers: raw value: 980.6 hPa
Engine status: COENG_READY
Engine status-Test_Program_Co Eng st COMPU VERB UBYTE: 1
Readiness: 0 0 0 0 1
Address 03: ABS Brakes (-----) Labels: 7E0-907-37x-MK25AXT.clb
Part No SW: 7E0 907 379 J HW: 7E0 907 379 E
Component: ESP MK25A XT H43 0109
Revision: 00H43001
Coding: 108764AD19A6089626A99878AA6610
Shop #: WSC 02756 790 49152
VCID: 392F2FAC0959596355D-806C
Address 08: Auto HVAC (J301) Labels:| 7E5-907-047.clb
Part No SW: 7E5 907 047 BG HW: 7E5 907 047 BG
Component: Climatic-T5 H20 0505
Revision: 00001010
Coding: 0000000002
ROD: EV_ClimaT5Basis.rod
VCID: 75B7E39C6541FD03715-8020
2 Faults Found:
13701936 - Function Restriction due to Faults in Other Modules
U1113 00 [008] - -
[Steuergerät für Bordnetz - bitte Fehlerspeicher auslesen]
Fault Priority: 6
Fault Frequency: 7
Reset counter: 17
Mileage: 130877 km
Date: 2020.08.21
Time: 00:12:48
13701968 - Function Restriction due to Faults in Other Modules
U1113 00 [009] - -
[Steuergerät im Schalttafeleinsatz - bitte Fehlerspeicher auslesen]
Fault Priority: 6
Fault Frequency: 9
Reset counter: 232
Mileage: 130877 km
Date: 2020.08.21
Time: 00:05:02
Address 09: Cent. Elect. (J519) Labels:. 7H0-937-08x-09.clb
Part No SW: 7H0 937 090 D HW: 7H0 937 090
Component: BCM PQ25 Max4 H74 0725
Revision: B9074001 Serial number: 0671 186141457
Coding: B8B079B80E61241193284E716EEB97554280662F60857841320000020000
Shop #: WSC 02739 790 12345
VCID: 2F3B11F4C71D87D3FB9-807A
Subsystem 1 - Part No SW: 7E0 959 801 C HW: 7E0 959 801 C Labels: 7E0-959-80X-V1.CLB
Component: J386__TSG_FT 003 3313
Coding: 050000
Subsystem 2 - Part No SW: 7E0 959 802 C HW: 7E0 959 802 C Labels: 7E0-959-80X-V1.CLB
Component: J387__TSG_BT 003 3313
Coding: 050000
Subsystem 3 - Part No: 7E1 951 172
Component: DWA-Sensor 00 001 0104
Subsystem 4 - Part No: 1K0 951 605 C
Component: LIN BACKUP HO H05 1501
Subsystem 5 - Part No: 7E1 951 172
Subsystem 6 - Part No SW: 5K0 959 542 A HW: 5K0 959 542 A
Component: E221__MFL-TAS H09 0013
Serial number: 0390005
Coding: 820000
8 Faults Found:
03591 - Control Circuit for Horn
011 - Open Circuit
Fault Status: 01101011
Fault Priority: 3
Fault Frequency: 1
Reset counter: 232
Mileage: 130877 km
Time Indication: 0
Date: 2015.01.12
Time: 00:17:23
02745 - Bulb for Daytime Running Light; Left
010 - Open or Short to Plus
Fault Status: 01101010
Fault Priority: 3
Fault Frequency: 1
Reset counter: 232
Mileage: 130877 km
Time Indication: 0
Date: 2015.01.12
Time: 00:20:56
02746 - Bulb for Daytime Running Light; Right
010 - Open or Short to Plus - Intermittent
Fault Status: 00101010
Fault Priority: 3
Fault Frequency: 1
Reset counter: 16
Mileage: 130877 km
Time Indication: 0
Date: 2015.01.12
Time: 00:20:56
00978 - Lamp for Low Beam; Left (M29)
Fault Priority: 3
Fault Frequency: 1
Reset counter: 232
Mileage: 130877 km
Time Indication: 0
Date: 2015.01.12
Time: 00:22:37
01495 - Bulb for High-Beams; Left (M30)
Fault Priority: 3
Fault Frequency: 1
Reset counter: 232
Mileage: 130877 km
Time Indication: 0
Date: 2015.01.12
Time: 01:14:35
01499 - Bulb for High-Beams; Right (M32)
Fault Priority: 3
Fault Frequency: 1
Reset counter: 232
Mileage: 130877 km
Time Indication: 0
Date: 2015.01.12
Time: 01:14:35
03906 - Control Circuit for High Beam Relay
Fault Priority: 3
Fault Frequency: 1
Reset counter: 16
Mileage: 130877 km
Time Indication: 0
Date: 2015.01.12
Time: 00:21:49
02195 - Dimmer Switch Instrument Panel & Switch Lighting (E20)
Fault Status: 00101000
Fault Priority: 3
Fault Frequency: 7
Reset counter: 16
Mileage: 130877 km
Time Indication: 0
Date: 2015.01.12
Time: 00:21:49
Address 10: Park/Steer Assist (J446) Labels:| 7E0-919-475.clb
Part No SW: 7E0 919 475 J HW: 7N0 919 475
Component: PARKHILFE 8K H06 0105
Revision: -------- Serial number: 28261217200384
Coding: 118001
VCID: 392F2FAC09D9596355D-806C
1 Fault Found:
13632256 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
[Steuergerät für Anhängererkennung-J345 - kein Signal/keine Kommunikation]
Fault Priority: 6
Fault Frequency: 6
Reset counter: 232
Mileage: 130877 km
Date: 2020.08.21
Time: 03:28:55
Part No SW: 7E0 959 655 B HW: 7E0 959 655 B
Component: VW10Airbag009 H07 0013
Revision: -------- Serial number: 003HL00CRH9K
Coding: 000000000000000000000000000000003039
Shop #: WSC 02754 790 50316
ROD: EV_AirbaVW10BPAVN750.rod
VCID: 3537239C25C1BD03B15-8060
1 Fault Found:
9442836 - Front Passenger's Airbag Disabled Indicator Lamp
B1016 14 [137] - Open or Short to Ground
Fault Priority: 2
Fault Frequency: 1
Mileage: 130877 km
Date: 2020.08.21
Time: 00:05:05
Part No SW: 7E0 920 970 G HW: 7E0 920 970 G
Component: KOMBI H06 0605
Coding: 160E00
VCID: 2E050CF0C0978EDBF0F-807A
1 Fault Found:
9453330 - Outside temperature sensor
B103F 1B [009] - Resistance Too High
Fault Priority: 2
Fault Frequency: 1
Reset counter: 232
Mileage: 130877 km
Date: 2020.08.21
Time: 00:05:03
Address 18: Aux. Heat Labels: None
Part No: 7E0 815 071 B
Component: J737__Standheizung 0605
Revision: 00085000 Serial number: 09019275F00000
Coding: 0000031
Shop #: WSC 02757 790 00000
VCID: 2411EED892DB348B16B-8070
Address 19: CAN Gateway (J533) Labels:. 6N0-909-901-6R.clb
Part No SW: 6N0 909 901 HW: 7H0 937 090
Component: GW-K-CAN TP20 H74 0725
Revision: B9074001
Coding: 042300
VCID: 70B9D2881AA3D82BA23-8024
1 Fault Found:
01517 - Control Module for Trailer/Towing Sensor (J345)
004 - No Signal/Communication
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 232
Mileage: 130877 km
Time Indication: 0
Date: 2015.01.12
Time: 00:05:07
Address 22: AWD Labels: 0AY-907-554-V1.clb
Part No SW: 09N 907 554 B HW: 09N 907 554 B
Component: Haldex 4Motion 6008
Coding: 0000007
Shop #: WSC 02756 790 00000
VCID: 372B2994334D4F13A39-8062
Component: IMMO H06 0605
Serial number:
Shop #: WSC 12345 123 12345
ROD: EV_Immo_UDS_VDD_RM09_VW31.rod
VCID: 6A8DC0E03CFF22FBEC7-803E
Address 55: Headlight Range (J431) Labels:. 6R0-907-357.clb
Part No SW: 6R0 907 357 HW: 6R0 907 357
Component: LWR-ECU H02 0070
Revision: -------- Serial number: --------------
Coding: 0312000001000000
Shop #: WSC 00066 000 00000
VCID: 77ABE9947F4D8F13639-8022
2 Faults Found:
5256725 - Rear Vehicle Height/Level Sensor
C114E 15 [137] - Open or Short to Plus
Fault Priority: 2
Fault Frequency: 4
Reset counter: 232
Mileage: 130877 km
Date: 2020.08.21
Time: 00:06:13
5276949 - Positioning Motor for Headlight Range Left
C1085 15 [137] - Open or Short to Plus
Fault Priority: 2
Fault Frequency: 1
Reset counter: 232
Mileage: 130877 km
Date: 2020.08.21
Time: 00:06:13
Address 69: Trailer
Cannot be reached
End----------(Elapsed Time: 02:07, VBatt start/end: 12.2V/12.2V)-----------
