Hı lichel koyunu takip ediyorum bana yardımcı olur musun? Polo 1.2 tsi 6c vcds ile abs kodlama yapmak istiyorum esp sport asr off menü için help stok olarak multimedya üzerinde aktif değil ve Manuel tuș yok
By_soner wrote: Sun Sep 20, 2020 1:59 pm
I'm following this thread I want to do abs coding with Polo 1.2 tsi 6c 2014 vcds esp sport asr off menu help is not active on multimedia as stock and there is no manual key. code is stok:21DD2885492C33C80918106C0053841492CC90080005C7090C00
5F I found these ref to the brake:
Car_Function_Adaptations_Gen2:
menu_display_Brake_Function: activated
menu_display_Brake_Function_clamp_15_off: Not activated
menu_display_Brake_Function_over_threshold_high: activated
menu_display_Brake_Function_standstill: Not activated
menu_display_Brake_Function_after_disclaimer: Not activated
Car_Function_List_BAP_Gen2:
Brake_0x26: activated
Brake_0x26_msg_bus: Databus drivetrain
---^>Tried, Negative not active
22byte E7 ASR OFF/ESP SPORT Enjoyable ride
I believe, you can solve it. You helped me a lot. Can we please solve the activation menu?
Multimedya my car
