Polo 6R ABS CODING
legendaryzz
Drives: 6r
Re: Polo 6R ABS CODING
Post by legendaryzz »
iichel wrote: Sun Sep 20, 2020 1:18 pm
legendaryzz wrote: Sun Sep 20, 2020 1:16 pm
iichel wrote: Sun Sep 20, 2020 12:09 pm is your VCDS original or clone?
How can i see that? I have borrowed it from a friend.
uhm... ask him?
Its original. It also douse accept the original code.
But not when I make changes to 288 brakes.
Strange. I believe your updated coding should be:
210248E3216F00B3842712E984D100401300
Perhaps type it manually or only change byte 2 & 10?
By_soner
Drives: Polo 1.2 tsi 6c
Post by By_soner »
Hı lichel koyunu takip ediyorum bana yardımcı olur musun? Polo 1.2 tsi 6c vcds ile abs kodlama yapmak istiyorum esp sport asr off menü için help stok olarak multimedya üzerinde aktif değil ve Manuel tuș yok
By_soner wrote: Sun Sep 20, 2020 1:59 pm Hı lichel koyunu takip ediyorum bana yardımcı olur musun? Polo 1.2 tsi 6c vcds ile abs kodlama yapmak istiyorum esp sport asr off menü için help stok olarak multimedya üzerinde aktif değil ve Manuel tuș yok
Please write in English
By_soner
Post by By_soner »
I'm following this thread I want to do abs coding with Polo 1.2 tsi 6c 2014 vcds esp sport asr off menu help is not active on multimedia as stock and there is no manual key. code is stok:21DD2885492C33C80918106C0053841492CC90080005C7090C00
ESP Sport, ASR On --> 21DD2885492C33C80918106C0053841492CC90080005EB090C00
By_soner
Post by By_soner »
Coding rejected error31:request out of range The error appears securty Accses 40168 log in to
You can try these values for byte 22:
C7
CB all ON/ASR OFF
EB ASR OFF/ESP Sport
DB ESP Sport/ESP OFF
E0
E3
CA
C9
legendaryzz
Drives: 6r
iichel wrote: Sun Sep 20, 2020 1:36 pm Strange. I believe your updated coding should be:
Both ways it gives error 22. Conditions not correct or request sequence error.
I also tried with 02 instead of 00 (for gti model)
Only the 28 byte 2 / 14 byte 10 is accepted. Very strange.
legendaryzz wrote: Sun Sep 20, 2020 4:41 pm
This is indeed unusual.
By_soner
Post by By_soner »
CB
DB
Activeted thx :)
Is it necessary to add menus for multimedia?
By_soner wrote: Sun Sep 20, 2020 5:00 pm CB
DB
Activeted thx :)
I don't know, sorry. What radio do you have?
By_soner
Post by By_soner »
5F I found these ref to the brake:
Car_Function_Adaptations_Gen2:
menu_display_Brake_Function: activated
menu_display_Brake_Function_clamp_15_off: Not activated
menu_display_Brake_Function_over_threshold_high: activated
menu_display_Brake_Function_standstill: Not activated
menu_display_Brake_Function_after_disclaimer: Not activated
Car_Function_List_BAP_Gen2:
Brake_0x26: activated
Brake_0x26_msg_bus: Databus drivetrain
---^>Tried, Negative not active
22byte E7 ASR OFF/ESP SPORT Enjoyable ride
I believe, you can solve it. You helped me a lot. Can we please solve the activation menu?
Multimedya my car
Multimedya my car
Reset the radio by holding the power button for 10 seconds
By_soner
Post by By_soner »
Tried negative result,The menu is empty Is there another way?
