bropasiek
Drives: Caravelle T5.1
Post by bropasiek »
I did isolate original T73a/45 wire, I forgot to mention that, T73a/45 is a new wire and it goes together with old T17/16 and T73b/7 - is that correct ?
Just to be sure I have not messed up with wires, according to schemes T6 plug for dimmer should have 58d signal on pin5 and it is the same signal that goes to T10/10 ( old T17/17) - checked by multimeter
Maybe I miss understood your scheme
My invention with that relay was only way to make van legal and drivable :cry:
Another thing I noticed with T73b/7 when main beam is off there is no current on that wire, but ince I will switch on main beam there is 12v and after switching them off again its not going to 0v, there is all the time 12v untill battery goes flat or untill I disconnect battery myself
Should it be like that ?
At least T6 dashboard and all rewiring went smooth
There is a TIP for someone who wants to do the same:
T5.1 instrument cluster and T6 are the same, just different housing, so if you have highline cluster just get a T6 housing and swap interior - save you some money
bropasiek
Post by bropasiek »
It is what you should have done from the beginning, otherwise you bypass the license plate lights diagnostics.
I didnt quite get this one, so should I leave it going through relay or direct to number plate light ?
Shadow109
Drives: Vw t5.1 2013
Post by Shadow109 »
Hello ciclo, I have a t5.1 2013, with a 87 bcm, i am intending to max bcm, do you recommend me to buy the bcm in the pic ?
bropasiek wrote: Sun Sep 27, 2020 10:10 am Hi,
I did isolate original T73a/45 wire, I forgot to mention that, T73a/45 is a new wire and it goes together with old T17/16 and T73b/7 - is that correct ? Yes.
Just to be sure I have not messed up with wires, according to schemes T6 plug for dimmer should have 58d signal on pin5 and it is the same signal that goes to T10/10 ( old T17/17) - checked by multimeter Yes.
My invention with that relay was only way to make van legal and drivable :cry: Ah, OK!👍
Another thing I noticed with T73b/7 when main beam is off there is no current on that wire, but ince I will switch on main beam there is 12v and after switching them off again its not going to 0v, there is all the time 12v ..................... untill battery goes flat or untill I disconnect battery myself
Yes and No.
It depends on the new position of the light switch after turning off the main lights, on the duration of the 'Coming Home' function (if new position is AUTO) and on removing (taking out) the remote key from the ignition switch. (behavior dependent on BCM coding)
That is, if you turn off the main lights by turning the light switch to position 0, the voltage in T73b/7 should be 0v.
Shadow109 wrote: Mon Sep 28, 2020 10:17 pm Hello ciclo, I have a t5.1 2013, with a 87 bcm, i am intending to max bcm, do you recommend me to buy the bcm in the pic ?
The reference number is correct, but I always recommend buying brand new BCMs because they have totally virgin coding and adaptations.
The usual thing is that everything goes well with the BCM that you show us in the image.👍
bropasiek wrote: Mon Sep 28, 2020 12:39 am
...direct to number plate light.
bropasiek
Post by bropasiek »
Hi Ciclo,
With number plate lights connected directly to T73b/7 everything works spot all, so all the issues are sorted now
Many thanks
Shadow109
Post by Shadow109 »
ciclo wrote: Tue Sep 29, 2020 3:53 am
Can you make a loom for me before I get the bcm ?
bropasiek wrote: Wed Sep 30, 2020 7:56 pm Hi Ciclo,
Many thanks
Hi bropasiek. Perfect! 8)
Shadow109 wrote: Wed Sep 30, 2020 9:17 pm
I spent years manufacturing them, but I stopped making this type of wiring and I don't have the materials to make them, I'm really sorry.🙏 Thank you very much.
It's not difficult to do these wiring looms ... and it's definitely worth it.
bropasiek
Post by bropasiek »
Hi Shadow109,
If you need some help with wiring and you are not far from Leicester I can help you out, you just need to get some automotive wires and pins
With Ciclo help I manage to get everything working
There were some difficulties, but luckly managed to go through them
I belive early T5.1 wiring is slightly different to later ones and it is were problems came from
Next week I will post some photos
Shadow109
Post by Shadow109 »
bropasiek wrote: Thu Oct 01, 2020 7:03 am Hi Shadow109,
Thanks alote, I live in palestine/israel, my T5 is December 2012
I am preparing parts and tools to upgrade bcm max with rian/light sensor and HBA
I would love to see some photos
reido80
Drives: VW t5.1 GP bitdi 4motion
Post by reido80 »
Ok, so I have ran the wiring for the rear xenon level sensor.
Goes from the Xenon level control module under dash/BCM area - up drivers A pillar, follows wiring loom along the roof line - at D pillar it drops down and follows wiring loom for Rear speed sensor, through a grommet with a helpfully spare way in it, behind the rear wheel arch plastic. - Pops out at the level sensor. I have photos which I will upload shortly. Kufatec look to have supplied the wrong plug for the xenon level sensor though which I am well peed off about! Both at them, for apparently suppling the wrong parts and disappointed with my self for not checking earlier! It is either the wrong plug or there are some updated xenon level sensors with different connections or something. photos to follow...
Fun and games....
reido80
Post by reido80 »
Ordered the correct plugs, part number 4B0973712A
Hi reido80,
According to ETKA it is 4H0973712A
...although it seems identical to 4B0 ... ... A
Thank you very much for the explanation and images.👌
bropasiek
Post by bropasiek »
Is anybody here who can speak Russian ?
I need some help buying cruise control adapter from this website
https://www.drive2.ru/l/546511156148177688/
Lucas
