Help fitting Reverse Camera with RCD330 - Canbus
Mocro
Drives: Polo 6C 1.4TDI 105HP
Re: Help fitting Reverse Camera with RCD330 - Canbus
Post by Mocro »
patil wrote: Sat Jan 23, 2021 3:28 pm
Mocro wrote: Sat Jan 23, 2021 12:01 am
I checked the camera @ vw specalist and they told me the camera is dead.
The usual suspect, that's why I was telling you to test the output of T12/6 &12 to check if camera is working.
Anyway, thanks for informing us.
To find the +30 signal in fuse box, visually inspect the fuse box for presence of terminal inside any of empty fuse slots. If you find any then use multimeter or 12v tester to find out the type of signal present.
Thanks.
Mocro
Post by Mocro »
iichel wrote: Sat Jan 23, 2021 4:41 pm Can I just say that I'm a bit shocked by the way you're running this red wire to a fuse. Come on man, you're better than this
Iknow that this is not ok, if my OEM flip camera is deliverd i will do it the correct wise. But know nothing is working and my OPS also i opened a new topic.
Maybe you guys know this problem, thanks patil i saw your reaction i will try it.
Damon
Drives: 2010 Polo Moda 64
Post by Damon »
Mocro wrote: Mon Jan 04, 2021 5:02 pm
Damon wrote: Sun Dec 27, 2020 5:42 pm Okay got it working at front of car.
However I’ve put the bracket with the camera in the registration light but how do feed the cable off the camera into the boot from the bracket?
I push the cable through but can’t seee where it’s coming out?
Remove this
You will see a round rubber thing with wiring remove the rubber
Put a cable in the license plate light holder
You will see the cable is coming to the rubber whole, its little bit difficult but the cable is coming to the rubber whole
Yeah I managed to feed it through.
I just need to make small hole to feed the cable through the rubber at the moment I’ve just got it hanging out.
So what’s your current issue so I understand
Do you see a video image then it goes off? Or not at all?
Mine did that it could come on once then go off, didn’t show lines but camera showed. Had to restart car to get camera to work again for a few seconds.
For me it was because I hadn’t connected the camera can cables for the existing can once done it wokeee fine.
Mocro
Post by Mocro »
Damon wrote: Sat Jan 30, 2021 9:28 am
Remove this
No i see only black screen and then it turn off withe message ''Parkpilot is not available'', but i remove it. I will install OEM flip camera in it, I still waiting voor the harness.
Mocro
Post by Mocro »
I install OEM golf 7 camera logo on my polo without any issues thanks everybody for the previous problem
patil
Post by patil »
Mocro wrote: Fri Feb 26, 2021 9:38 pm I install OEM golf 7 camera logo on my polo without any issues thanks everybody for the previous problem
Hello Mocro.. good job👍
I hope you did proper wiring this time))
Mocro
Post by Mocro »
Yes i soldering it on the quadlock +30.
patil
Post by patil »
Mocro wrote: Sun Feb 28, 2021 8:50 pm Yes i soldering it on the quadlock +30.
Ok make sure you've insulated the joint properly. Add a inline fuse 5A to protect the wiring and camera.
Mocro
Post by Mocro »
Thanks i will do it.
