Hi all ,
We have replaced the abs module on our vw polo 6r 1.2 2010. Although we know the fault has cleared ,we do not have a long code for it.
Can we re fit the old unit and obtain a code to rewrite to the replacement module although don’t fancy stripping it down again or is it lost forever?
That being the case can anyone who has the knowledge provide a code for the module.
My vin is WVWZZZ6RZAU01****
Engine CGPB
ESP8.2i
POLO 6r ABS MODULE CODE HELP
Mad car guy
- Drives: 2010 v5 polo 1.2
Re: POLO 6r ABS MODULE CODE HELP
I know you have a vcds interface so I'm going to need a full and unedited scan including the vin to calculate your coding. Otherwise the abs and esp system will not work.
Mad car guy
Thanks, my problem is I only have the printed version now, I could email it to you. Otherwise I will have to get it scanned again.
My question is ,
If we refit the original module to the connector without refitting the brake lines and scan it again, will the code reappear ?
My question is ,
Mad car guy
Don’t know if this helps
See photos
See photos
- 259F435F-2D8E-423C-98F2-B382772A458A.jpeg (3.91 MiB) Viewed 20326 times
- 8916D726-BE1A-4726-A8C1-643FC4D5BE29.jpeg (3.34 MiB) Viewed 20326 times
- B93BA181-5B63-4D4B-BF72-21EDBE830248.jpeg (3.49 MiB) Viewed 20326 times
- B4641D89-ACBB-4456-9C92-33B683EC0CFD.jpeg (3.77 MiB) Viewed 20326 times
- 8CBD89A7-8687-452D-BC9B-77CBC0CEE3BB.jpeg (4.25 MiB) Viewed 20326 times
Best is to mail it to me. its my username @online.nl
Mad car guy
I have sent this to --
Is this correct?
Is this correct?
