POLO 6r ABS MODULE CODE HELP
Post FORUM SPECIFIC questions here: Such as, "HELP, I can't keep logged in for more than one session" etc... Not general help questions such as "my car won't start". You get the idea?
Mad car guy
Drives: 2010 v5 polo 1.2
Post by Mad car guy »
Hi all ,
We have replaced the abs module on our vw polo 6r 1.2 2010. Although we know the fault has cleared ,we do not have a long code for it.
Can we re fit the old unit and obtain a code to rewrite to the replacement module although don’t fancy stripping it down again or is it lost forever?
That being the case can anyone who has the knowledge provide a code for the module.
My vin is WVWZZZ6RZAU01****
Engine CGPB
ESP8.2i
Re: POLO 6r ABS MODULE CODE HELP
I know you have a vcds interface so I'm going to need a full and unedited scan including the vin to calculate your coding. Otherwise the abs and esp system will not work.
Mad car guy
Thanks, my problem is I only have the printed version now, I could email it to you. Otherwise I will have to get it scanned again.
My question is ,
If we refit the original module to the connector without refitting the brake lines and scan it again, will the code reappear ?
Mad car guy
Don’t know if this helps
See photos
Best is to mail it to me. its my username @online.nl
Mad car guy
I have sent this to --
Is this correct?
