I still have some time to install the A5 camera, the decisive thing is the calibration.
I will have to install the 8IU LED headlights and wait some time with the current camera for HBA.
Between the pandemic and half the world fighting like little children, I want to go to Australia as soon as possible...
ciclo wrote: Thu Feb 11, 2021 1:58 pm
Today I installed the wiring harness for the a5 camera Remaining camera for calibration:)
Glass replaced,Now I have to check if it works
ciclo wrote: Sat Feb 13, 2021 6:35 pm
Great, it looks good.
Any special tips to fully remove the A-pillar trim?
snow on the roof?
I had a problem getting him out
They hold the three hooks firmly from the top, it is more difficult to put it back on
,It is now a cold winter in Poland
Do I have to calibrate the A5 camera first to code the options? I wanted to change the encoding but it pops up Coding rejected, Error 31: Request out of range I also wanted to change the paramatrization, erorr pops up
Thank you
dcgumis wrote: Sat Feb 13, 2021 9:38 pm
Thank you
I don't know what is happening, I have not done this process yet, it is best if you ask Slavik.
Please post here what was the issue you had. Thanks.
Address A5: Frt Sens. Drv. Assist Labels: 3Q0-980-65X-A5.clb
Control Module Part Number: 3Q0 980 654 H HW: 3Q0 980 654 A
Component and/or Version: MQB_B_MFK H09 0272
Software Coding: 0002070600000401002200448150A90084000E000000
Work Shop Code: WSC 00020 999 00000
ASAM Dataset: EV_MFKBoschMQBB 001001 (VW37)
ROD: EV_MFKBoschMQBB_001_VW36.rod
VCID: 3C2131DD76E9587B6FA-8068
10 Faults Found:
0768 - No Basic Setting
B2010 00 [008] - -
[Calibration_VIN_mismatch]
0646 - Control Module Incorrectly Coded
U1014 00 [008] - -
0788 - Camera Interference
C1104 00 [008] - -
0789 - Camera Interference
C1104 00 [008] - -
1134 - Camera Interference
C1104 00 [008] - -
1295 - Camera Interference
C1104 00 [008] - -
0659 - Steering
C10AC F2 [009] - Lane-Holding Assistance Not Coded
1347 - Camera Interference
C1104 00 [008] - -
0635 - Camera Interference
C1104 00 [008] - -
0415 - Camera Interference
C1104 00 [008] - -
I also bought mine on eBay, but when I buy units of some relevance I have the habit of buying them from Germany (a little more expensive at times), mine according to the seller comes from a Golf 7.5, I hope to be lucky in this regard.
ciclo wrote: Sat Feb 20, 2021 1:00 pm
DLA wants to too, but a little later I have to buy headlights first, but I wonder if my current lamp modules will fit for DLA, or are they different for DLA.I have a 7P5 941 572A(AV0,AV1) A module Because I can change right-hand or left-hand traffic on the radio.In PR headlamps: 8IU There is no pr code in module 7P5 941 572 A
TJA Likewise, I thought that only for dsg.
ciclo wrote: Sat Feb 27, 2021 9:55 am
The control units of your current LED headlights are correct, they should only be flashed for Matrix headlights when you install 8IU LED headlights.
OK Thank you for the information
Steering wheel 5G0419091HQ
