BCM Max Transporter 2013
Shadow109
Drives: Vw t5.1 2013
Re: BCM Max Transporter 2013
Post by Shadow109 »
Finally, I’ve got all parts for TPMS
I have connected all wires :-
Canbus high/low
+30
Ground
My BCM version is H80, I didn’t find tire pressure in Can getaway installation list (address 65), I think I need another BCM with H81
Ciclo can you confirm ??
Yes.
I have had all the 7E0 937 090 (434 Mhz) installed in my 6R (7E0 ... / B / C / D / E) and from 7E0937090 B you already have address 65 available in the GW installation list.
However, the availability of the 65 address is more dependent on the BCM manufacturing date than on the BCM reference, being possible that there are current BCMs Max without an index and have the 65 address available.
To be sure, get a C, D, or E.
Contact firegrafik to get a new one. :wink:
I see there are also new BCM floating around aliexpress around 100 eur
Shadow109
Post by Shadow109 »
I’ll check if he have, But maybe I’ll get a new BCM, any recommendation ?
My last option is always Aliexpress for many reasons ... too bad it often has to be the only option.
Aliexpress sells massively copied products, it does not usually provide any type of technical support due to total ignorance of what is sold...
The BCM's from firegrafik are made in Germany, the same or similar price.
TheKeymeister
Drives: Caravelle T5.1
Post by TheKeymeister »
Shadow109 wrote: Fri Mar 19, 2021 4:26 pm Finally, I’ve got all parts for TPMS
Canbus high/low
+30
Ground
Hey, could you possibly confirm which canbus pins the TPMS needs connecting to for Transporter? Just to save me trawling through everything :D I plan to connect mine tomorrow assuming my foglights come to life.
Shadow109
Post by Shadow109 »
Sure, this will help you
TheKeymeister
Thanks, that's a big help, I had assumed it would be on the CAN convenience network (of which my towing module is connected to, and was conveniently located under the front seat :) ) but alas, further wires to run to the BCM :D fortunately it's all still in pieces.
Shadow109
Post by Shadow109 »
New BCM on the way
So according to some resources H81 adds TPMS and electric tailgate
I don’t know what H82 adds, but definitely its better :|
RobertVW
Drives: T6
Post by RobertVW »
@Shadow109 did you try your new TPMS unit on your existing H80 BCM?
I would expect it to work even though 65 is not present on CAN Gateway INSTALLATION LIST.
By the way you can get second hand 7E0937090 Max BCMs from Poland for approximately €60 :wink:
There are only two possible CAN BUS to connect RDKS in the PQ25, ... or in powertrain CAN lines, or in the new dashboard/instrument cluster CAN lines, in no case in the convenience CAN lines.
The recommended one, and according to diagramas for Amarok, is the powertrain CAN.
The cheapest way to get a good 7E0 937 090 BCM Max with the latest SW (E_0772) is to properly flash it with the proper file. Price = 0.
e.g.
However, the last one I installed I got thanks to firegrafik.
viewtopic.php?p=562228#p562228
Of the BCMs D and E I did not take good images.🤭
Shadow109
Post by Shadow109 »
RobertVW wrote: Sat Mar 20, 2021 9:23 pm @Shadow109 did you try your new TPMS unit on your existing H80 BCM?
Yes, All the wires are connected, I have coded the TPMS in the Cluster, but nothing showed up
I have already ordered a new bcm, but thanks anyway
ciclo wrote: Sun Mar 21, 2021 5:42 am There are only two possible CAN BUS to connect RDKS in the PQ25, ... or in powertrain CAN lines, or in the new dashboard/instrument cluster CAN lines, in no case in the convenience CAN lines.
e.g.
I will try to update the new bcm when I get it
Shadow109
Post by Shadow109 »
I have received the new bcm 8)
I have noticed that T73/b-63 Pinout is missing :!: :?:
I have coded it., (I didn't forget to code channel 54 for HBA)
Last H80 Scan :-
Tuesday,30,March,2021,11:53:34:00009
VCDS Version: 20.4.1.0
www.Ross-Tech.com
VIN: WV1ZZZ7HZDH036544   License Plate:
Chassis Type: 7H-VN75 (7E0)
Scan: 01 03 04 08 09 10 15 17 19 20 25 37 5F 77 0B
VIN: WV1ZZZ7HZDH036544   Mileage: 216730km-134669miles
08-Auto HVAC -- Status: Not registered 0001
77-Telephone -- Status: Not registered 0001
Address 01: Engine (J623-CAAA)       Labels:. 03L-906-022-CAA.clb
   Part No SW: 03L 906 019 GF    HW: 03L 907 309 M
   Component: R4 2,0L EDC   H44 3312
   Revision: 26H44---    Serial number: 00000000000000
   Coding: 01114012232400080000
   Shop #: WSC 02736 790 50316
   ASAM Dataset: EV_ECM20TDI01103L906019GF 003002
   ROD: EV_ECM20TDI01103L906019FG_003.rod
   VCID: 75E154D3D4C13F2E28-8020
Readiness: 0 0 0 0 1
Address 03: ABS Brakes (-----)       Labels: 7E0-907-37x-MK25AXT.clb
   Part No SW: 7E0 907 379 K    HW: 7E0 907 379 E
   Component: ESP MK25A XT  H43 0110
   Revision: 00H43001
   Coding: 508724AD89A70A9B24A79175796210
   Shop #: WSC 02736 790 49152
   VCID: 3A7B87EFB55F905605-806E
   Serial number: 11031913470358
   Coding: 01
   Shop #: WSC 00000 000 00000
   ROD: EV_LWSKLOVW25X.rod
   VCID: 7EF34BFFE1F77C7679-802A
   Part No SW: 7E5 907 047 BM    HW: 7E5 907 047 BM
   Component: Climatic-T5   H20 0505
   Revision: 00001010
   Coding: 0000000002
   ROD: EV_ClimaT5Basis.rod
   VCID: 7BF542EBF2E5695E5E-802E
   Revision: B9080001    Serial number: 0771 351150194
   Coding: A8A0393E4E21201201280ED06EAB9ED4F08063FF608C2040320000020800
   Shop #: WSC 54707 002 104857
   VCID: 68DF0DA79B73D2C6A3-803C
   Subsystem 1 - Part No: 5K7 955 559 B  Labels: 5K7-955-559.CLB
   Component: RLS 230916 03  37  0059
   Coding: 0228DD
   Subsystem 2 - Part No SW: 7E0 959 801     HW: 7E0 959 801   Labels: 7E0-959-80X-V1.CLB
   Component: J386__TSG_FT  002 3313
   Subsystem 3 - Part No SW: 7E0 959 802     HW: 7E0 959 802   Labels: 7E0-959-80X-V1.CLB
   Component: J387__TSG_BT  002 3313
2 Faults Found:
00329 - Control Circuit for Unlocking Rear Lid
            011 - Open Circuit - Intermittent
                    Fault Status: 00101011
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 54
                    Mileage: 216732 km
                    Time Indication: 0
                    Date: 2021.03.30
                    Time: 21:49:49
01504 - Bulb for License-Plate Light (X)
            010 - Open or Short to Plus
                    Fault Status: 01101010
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 14
                    Mileage: 216732 km
                    Time Indication: 0
                    Date: 2021.03.30
                    Time: 21:49:10
   Part No SW: 7E0 919 475 AA    HW: 7N0 919 475
   Component: PARKHILFE 8K  H06 0212
   Revision: --------    Serial number: 28261631000160
   Coding: 108001
   Shop #: WSC 02737 790 50316
   ASAM Dataset: EV_VW75XParkAssis8K 001012
   VCID: 71E960C3A0A9130EF4-8024
   Part No SW: 7E0 959 655 B    HW: 7E0 959 655 B
   Component: VW10Airbag003 H07 0013
   Revision: --------    Serial number: 003HL00DDD0.
   Coding: 000000000000000000000000000000003033
   Shop #: WSC 02734 790 50316
   ROD: EV_AirbaVW10BPAVN750.rod
   VCID: 356194D394417F2EE8-8060
   Part No SW: 7E0 920 970 N    HW: 7E0 920 970 N
   Component: KOMBI         H04 0805
   Coding: 160A01
   Revision: B9080001
   Coding: 042200
1 Fault Found:
            000 - -
                    Fault Status: 01100000
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 216732 km
                    Time Indication: 0
                    Date: 2021.03.30
                    Time: 21:43:05
   Part No SW: 7E0 857 511 F    HW: 7E0 857 511 C
   Revision: AA001001
   Coding: 010100E200000100000000
   Shop #: WSC 12345 123 12345
   VCID: 2D51BCB37C1137EE90-8078
   Component: IMMO          H04 0805
   Serial number:
   ROD: EV_Immo_UDS_VDD_RM09_VW31.rod
   VCID: 6ADB77AF8D7FE0D6B5-803E
Address 37: Navigation
Cannot be reached
   Component: MU-S-ND-ER    H41 0478
   Serial number: VWZAZ2U1668085
   Coding: 0645000FBE00000011110001010D08001F0303C401200100CE
   Shop #: WSC 00046 123 12345
   ROD: EV_MUStd4CTSAT_VW32.rod
   VCID: 2541449324E10FAE58-8070
   Data medium:
   Subsystem 1 - Part No SW: 5NA 919 866 AL    HW: -----------
   Component: MRM1 2020/21  --- 1420
3 Faults Found:
          U1101 00 [009] - Active
                    Fault Status: 00000001
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 14
                    Mileage: 216732 km
                    Date: 2021.03.30
                    Time: 21:43:03
                    Voltage terminal 30: 12.0 V
7194 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 14
                    Mileage: 216732 km
                    Date: 2021.03.30
                    Time: 21:43:06
                    BAP-BAP_Function_ID: 02
0001 - Antenna 1 for Radio
          B1119 13 [009] - Open Circuit
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 14
                    Mileage: 216732 km
                    Date: 2021.03.30
                    Time: 21:43:04
                    Status of antenna 1 for radio-Antenna current: 0 mA
                    Status of antenna 1 for radio-Connection between radio and antenna amplifier: Open circuit
                    Status of antenna 1 for radio-Connection between antenna amplifier and antenna: Not available
                    Status of antenna 1 for radio-Reception level antenna 1: 0 dBµV
Address 77: Telephone
Cannot be reached
End-------------------------(Elapsed Time: 02:55)--------------------------
new H82 scan :-
Tuesday,30,March,2021,12:18:34:00009
www.Ross-Tech.com
Scan: 01 03 04 08 09 10 15 17 19 20 25 37 5F 65 77 0B
37-Navigation -- Status: Not registered 0001
61-Battery Regul. -- Status: Malfunction 0010
   Revision: 00H43001
   Coding: 01
   Revision: 00001010
   Coding: 0000000002
   Part No SW: 7E0 937 090 C    HW: 7E0 937 090 C
   Revision: B9082001    Serial number: 4000 295170714
   Shop #: WSC 31414 790 00001
   VCID: 2B55B2AB4A0539DE8E-807E
   Coding: 0228DD
   Coding: 108001
   Coding: 160A01
1 Fault Found:
10486016 - Control module
          B2001 00 [009] - Incorrect software version
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 5
                    Mileage: 216732 km
                    Date: 2021.03.30
                    Time: 22:15:19
   Part No SW: 7E0 909 901     HW: 7E0 937 090 C
   Revision: B9082001
   Coding: 042200
1 Fault Found:
            000 - -
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 216732 km
                    Time Indication: 0
                    Date: 2021.03.30
                    Time: 22:14:36
   Revision: AA001001
   Serial number:
Cannot be reached
   Data medium:
3 Faults Found:
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 5
                    Mileage: 216732 km
                    Date: 2021.03.30
                    Time: 22:14:35
                    Voltage terminal 30: 11.9 V
          U1111 00 [009] - -
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 5
                    Mileage: 216732 km
                    Date: 2021.03.30
                    Time: 22:14:38
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 5
                    Mileage: 216732 km
                    Date: 2021.03.30
                    Time: 22:14:35
   Part No SW: 3AA 907 273 H    HW: 5Q0 907 273
   Component: RDKBERU30     H04 0012
   Serial number: 30000000047437
   ROD: EV_RDKBERU30_005.rod
   VCID: 397998E3B8599B4E0C-806C
Cannot be reached
End-------------------------(Elapsed Time: 03:00)--------------------------
Issues:-
HBA isn't working
new Instruments fault
TPMS didn't show anything on. the MFD
edit : I have noticed that the TPMS Controller (3AA 907 273 H) is ending with H Not F
Have you coded BCM channel 53 also to '1'?
For Direct TPMS to work on PQ25 it must be:
Address 65: Tire Pressure (J502) Labels: 3AA-907-273.clb
Part No SW: 3AA 907 273 F HW: 5Q0 907 273
Component: RDKBERU30 H04 0011
'H' it is for other platforms, doesn't work for PQ25, ... accidentally tested. :)
You need to flash that TPMS unit with the correct firmware, ... then you must load the zdc file with the parameters of the tire pressures that you have chosen.
Hi Shadow109, please ask all questions of general interest in your threads, not by private messages. Thanks a lot!.
It's better for everyone (especially for me), so I don't have to answer the same question a million times.🤗
In response to your private message:
Shadow109 wrote: Thu Apr 01, 2021 8:16 pm Hello Fernando
Can you explain to me more about flashing TPMS unit
What tools/program I need ?
Example:
:arrow: viewtopic.php?p=529334#p529334
The 'Warning TEST' I made up (a spontaneous occurrence) is not copyrighted. 😂
Flash file.
