Check that the pins of the new CAN lines are correctly inserted in the connectors.KamilPL wrote: Wed Aug 25, 2021 2:48 pm Original cables T32 / 28, T32 / 29 removed and individually insulated, something wrong is my ibiza resistant to modification?![]()
Check that the pins are not damaged.
Check that the two wires are not damaged at any point.
Use a multimeter.
Most of the faults diagnosed on the Autoscan are due to a lack of communication with the IC (J285).
If these CAN line wires were installed for the BCM 7H0 on the Ibiza FR they should work on your Ibiza 6J1.
