Hamster
Drives: VW T5
Post by Hamster »
I took a picture of the original BCM encoding before starting work.
A0A0303A0E612433802848102C2B8C550090430F60040000300000000000
https://drive.google.com/file/d/12fYUeo ... sp=sharing
I don't have any LED lighting, only original VW head lamps.
Later, I will check all the lighting and let you know how it works.
Perfect, waiting for that report.
Another question, does your T5 currently have front fog lights installed?
Hamster
Drives: VW T5
Post by Hamster »
no no, my T5 doesn't have front fog lights
ok, just to understand some inconsistencies in the BCM coding when you went from BCM High to Max.
Do not forget to check with VCDS if there are faults detected once you physically verify the operation of all the lights.
DRL/TFL lights...
Plate lights...
Position/Parking/Side lights...
One side Parking lights (P" on left lever)...
Low/Dipped Beam...
High/Main Beam...
High Beam flash...
Blinkers...
Hazard light...
Reverse light...
Rear Fog...
Interior light...
Dimmer...
Any other light...
Hamster
Drives: VW T5
Post by Hamster »
OK Ciclo.
I did a output test with the VCDS today.
All lights are working properly.
The indicator light on the counter appears when the rear right (passenger's side) position light comes on.
I have one more question. is it possible to do so that the low beam lights do not turn on when I want to blink the high beam lights. Of course, on the day when the dipped headlights are turned off. This will extend the life of the xenon lamps. I guess that's how I had the encoding set up before.
Ok, so everything is perfect the way it is.👌
Hmm... remove that tail light and do a general cleaning of the internal circuit with appropriate products, a light sanding may be necessary to remove possible oxidation from the contacts with the bulbs. Surely you already knew this.
You should not worry at all about the duration of the xenon bulbs, they should last the life of the vehicle even in the worst conditions (to infinity and beyond :lol: ).
Use them on demand with total confidence.👍
Did you know that they emit even whiter light as they age? ... (just like me 😁)
It is absolutely not possible that the low beams will not turn on when you use the flash/blink of the high beams in any external light conditions.
It is not related to pre or post coding, it is the way your new original xenon headlights work due to their internal construction. It's perfect that way!
T73a/62 keeps your low beams on when you activate your high beams, which is how it should be.
Byte18 46 HEX, is the perfect BCM coding for your T5 with bi-xenon headlights but 'no auto lights'.
Hamster
Drives: VW T5
Post by Hamster »
ok.
I unscrewed the right rear lamp, it looks like it left the factory yesterday. I put in a new bulb.
I turn on the VCDS and do the output test again.
The indicator light :idea: will be on when I turn on the rear left and right side light :(
I do not know why I saw only the right one yesterday, maybe fatigue.
The fault is probably not in the rear lights, only the electrical system.
Any more ideas?
Some ideas:
When installing Bixenon headlights, the 4 parking/side lights are powered individually, but you already did this according to your comments, link...?
The original wires in the front for these lights with Halogen headlights need to be isolated (T10) - check insulation - ...and install the two new ones from the BCM to the headlights (T14).
You may have forgotten to install the J431 headlight range control unit (55 Adres). :)
Try enabling and disabling the last 4 Bits of Byte11, maybe you'll have luck with this.
4 and 5 should be enabled based on the new light settings.
6 and 7 is the diagnosis.
BlackT51
Drives: No polos
Post by BlackT51 »
Yo!! Hello guys, i am new here, i read all 39 pages and i probably miss somewhere i have problem with xenon lights, i buy headlights and there was already made wiring from D3S xenon to H7, so i use H7 leds now... so the problem is when i use hibeam lowbeam stops working, i know that this lights should work together on hibeam. Before was h4 halogen lights. Maybe somewhere i need to do some extra wiring i dont understand..
Maybe someone can help me.. Thank you
Hi BlackT51, please post some picture of your current headlights and if you have diagnostic tool a reading of Address 09: Cent. Elect. (J519 BCM).
BlackT51
Drives: No polos
Post by BlackT51 »
Hello!
You means this?
And this is my lights
Please post a VCDS Autoscan.
BlackT51
Drives: No polos
Post by BlackT51 »
Thursday,15,September,2022,19:29:38:00009
VCDS Version: 21.9.0.1
Data version: 20210824 DS330.0
www.Ross-Tech.com
VIN: WV1ZZZ7HZBH081515 License Plate:
Mileage: 289880km-180123mi Repair Order:
Chassis Type: 7H-VN75 (6N0)
Scan: 01 03 04 08 09 15 17 18 19 25 56 69
VIN: WV1ZZZ7HZBH081515 Mileage: 289880km-180123miles
04-Steering Angle -- Status: Cannot be reached 1100
18-Aux. Heat -- Status: OK 0000
69-Trailer -- Status: Cannot be reached 1100
Address 01: Engine (J623-CAAB) Labels:. 03L-906-022-CAA.clb
Part No SW: 03L 906 022 CD HW: 03L 907 309 K
Component: R4 2,0L EDC X41 8732
Revision: 26X41--- Serial number: 00000000000000 CVN: F783C549
Coding: 0111401A232400080000
Shop #: WSC 00000 790 00000
ASAM Dataset: EV_ECM20TDI01103L906022CD 002012
ROD: EV_ECM20TDI01103L906019AM_002.rod
VCID: 69D908A38879EBC1F5-803C
VINID: 9E606AAAA1D8A9260020114114D4563869
Readiness: 0 0 0 0 X
Address 03: ABS Brakes (-----) Labels: 7E0-907-37x-MK25AXT.clb
Part No SW: 7E0 907 379 G HW: 7E0 907 379 E
Component: ESP MK25A XT H43 0105
Revision: 00H43001
Coding: 508724AD89AC0A9624A79172696310
Shop #: WSC 02736 790 49152
VCID: 366393DF81477439A8-8062
1 Fault Found:
00778 - Steering Angle Sensor (G85)
004 - No Signal/Communication
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 170
Mileage: 289577 km
Time Indication: 0
Date: 2017.02.05
Time: 00:49:46
Count: 128
Count: 785
Count: 8214
Count: 252
Address 08: Auto HVAC (J301) Labels:| 7E5-907-047.clb
Part No SW: 7E5 907 047 AG HW: 7E5 907 047 AG
Component: Climatic-T5 H11 0203
Revision: 00005001
Coding: 0000000002
Shop #: WSC 02737 790 50316
ROD: EV_ClimaT5Basis.rod
VCID: 74E769D7DFBB262956-8020
2 Faults Found:
13701376 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 78
Reset counter: 224
Mileage: 289577 km
Date: 2022.09.15
Time: 00:04:55
9481200 - Refrigerant Pressure
B10AB F0 [009] - Too Low
Fault Priority: 2
Fault Frequency: 1
Reset counter: 56
Mileage: 282678 km
Date: 2022.09.15
Time: 01:27:43
Address 09: Cent. Elect. (J519) Labels:. 7H0-937-08x-09.clb
Part No SW: 7H0 937 087 D HW: 7H0 937 087
Component: BCM T5GP H+4 H47 0221
Revision: BO047001 Serial number: 0347 176100917
Coding: A0A0303A2E212033002808102C2B8CD40080430F60060000300000000000
Shop #: WSC 02734 790 12345
VCID: 356194D39C417F21A1-8060
Subsystem 1 - Part No SW: 7E0 959 801 HW: 7E0 959 801 Labels: 7E0-959-80X-V1.CLB
Component: J386__TSG_FT 002 3311
Subsystem 2 - Part No SW: 7E0 959 802 HW: 7E0 959 802 Labels: 7E0-959-80X-V1.CLB
Component: J387__TSG_BT 002 3311
Subsystem 3 - Part No SW: 3C8 959 537 B HW: 3C8 959 537 B Labels: 3C8-959-537.CLB
Component: E221__MFL-TAP H4ÿ 0021
Serial number: 00000000000000146528
Coding: E20000
Part No SW: 7E0 959 655 B HW: 7E0 959 655 B
Component: VW10Airbag003 H06 0013
Revision: -------- Serial number: 003HL0035R3-
Coding: 000000000000000000000000000000003033
Shop #: WSC 02734 790 50316
ROD: EV_AirbaVW10BPAVN750.rod
VCID: 356194D394417F21A1-8060
Part No SW: 7E0 920 860 C HW: 7E0 920 860 C
Component: KOMBI H04 0204
Coding: 160A00
Shop #: WSC 02736 790 50316
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04086
ROD: EV_Kombi_UDS_VDD_RM09_004_VW36.rod
VCID: 285F4DA753F312C92A-807C
Address 18: Aux. Heat Labels: 7E0-815-071.clb
Part No: 7E0 815 071 A
Component: J737__Standheizung 0404
Revision: 00085000 Serial number: 09019275D00000
Coding: 0000031
Shop #: WSC 02757 790 00000
VCID: 23455A8BE2D5F1917F-8076
Address 19: CAN Gateway (J533) Labels:. 6N0-909-901-6R.clb
Part No SW: 6N0 909 901 HW: 7H0 937 087
Component: GW-K-CAN TP20 0221
Coding: 042200
VCID: 70EF65C7A3A31A09B2-8024
3 Faults Found:
01312 - Powertrain Data Bus
Fault Status: 00100100
Fault Priority: 1
Fault Frequency: 1
Reset counter: 212
Time Indication: 0
Fault Priority: 2
Fault Frequency: 1
Reset counter: 170
Mileage: 289577 km
Time Indication: 0
Date: 2017.02.05
Time: 00:00:36
01517 - Control Module for Trailer/Towing Sensor (J345)
Fault Priority: 2
Fault Frequency: 1
Reset counter: 56
Mileage: 282678 km
Time Indication: 0
Date: 2017.02.05
Time: 02:28:59
Component: IMMO H04 0204
Serial number:
Coding: 000002
Shop #: WSC 12345 123 12345
VCID: 6ADB77AF8D7FE0D9FC-803E
Part No SW: 5M0 035 186 AA HW: 5M0 035 186 AA
Component: Radio RCD310 016 0049
Revision: 01000000 Serial number: VWZ1Z2K8582832
Coding: 0500020002
Shop #: WSC 02734 790 00000
VCID: 6BD572AB8A85F9D187-803E
4 Faults Found:
00446 - Function Limitation due to Under-Voltage
002 - Lower Limit Exceeded - Intermittent
Fault Status: 00100010
Fault Priority: 3
Fault Frequency: 1
Reset counter: 210
Mileage: 289579 km
Time Indication: 0
Date: 2017.02.05
Time: 00:00:05
00856 - Radio Antenna
011 - Open Circuit
Fault Status: 01101011
Fault Priority: 5
Fault Frequency: 1
Reset counter: 56
Mileage: 282678 km
Time Indication: 0
Date: 2017.02.05
Time: 02:29:11
00821 - Antenna 2 for Radio (R93)
011 - Open Circuit
Fault Priority: 5
Fault Frequency: 1
Reset counter: 56
Mileage: 282678 km
Time Indication: 0
Date: 2017.02.05
Time: 02:29:11
03138 - Input AUX IN
011 - Open Circuit
Fault Priority: 5
Fault Frequency: 1
Reset counter: 56
Mileage: 282678 km
Time Indication: 0
Date: 2017.02.05
Time: 02:29:07
Address 69: Trailer
Cannot be reached
End-------------------------(Elapsed Time: 02:57)--------------------------
You probably have a low beam relay that operates the low beam. It is not controlled by your BCM.
This is an image that ciclo made for the Polo 6R with J331 low beam relay.
I suspect it works the same on your Transporter T5.1, perhaps the colours are different. I think this installation will solve (part of) your problem.
If you flash your high beam, will it illuminate a separate high beam light or will it 'click' the bixenon lens?
T17 7 mod.png (36.64 KiB) Viewed 3986 times
BlackT51
Drives: No polos
Post by BlackT51 »
When i flash with hibeam, lowbeam stops working
