POLO 6R. HEATED SEATS. OEM.
Re: POLO 6R. HEATED SEATS. OEM.
I think for <200 eur you could source OEM installation except the pads from a used car.
Easily. I have a new harness and used OEM buttons + module for Polo 6R for sale for 145.
2022-06-01 17.39.00.jpg (811.26 KiB) Viewed 5826 times
Thanos
Drives: Polo 6R 1.2 TDI BM
Post by Thanos »
mirceaculita wrote: Wed Jun 15, 2022 2:54 pm
Thanos wrote: Wed Jun 15, 2022 11:42 am Ive had these aliexpress mats kit for longer than a year now. No issues. All parts seem like oem parts.
Did they provide everything needed for the install? Also do you still have the link from who you bought it?
Yes, everything is provided with the kit. I have bought it from the same store you have linked.
ukpolodriver
Drives: Polo 6C 2017
Post by ukpolodriver »
did the aliexpress kit require coding of any sort or was a plug and play please ?
Thanos
Post by Thanos »
This is what I recieved almost 2 years ago.
I installed the week i got it, I haven't had issues so far. :D
You might need to code your BCM, otherwise adding the female end for the fuse is the trickiest bit.
I believe the pads (made by Gentherm the same OEM as the 6R0 pads) are from a China/east asia only model, the Santana.
Imgur album: https://imgur.com/a/nJYRkMm
CMacD7
Drives: Polo 6C GTI 2015
Post by CMacD7 »
CANDYMAN wrote: Fri Dec 03, 2021 3:51 pm Sorry for re-igniting this post could someone tell me what these plugs are. I’m guessing the yellow is airbag, Green seat sensor for seatbelt warning? But what are the 2 white ones. Are they both for the heated seat. If so which is the Base and which is the Backrest. If looking from the front of the seat. My heated seat has packed up so I’m looking for help on how to determine which pad has failed. If I turn the seat heat on with 2 lights it shuts down after around 30 seconds. If I turn them on with one light it stays on. HEEEEEEeeeelp :shock:
Did you ever have any luck?
Anyone else able to comment?
Aquavalver
Drives: 2013 Polo Blue GT
Post by Aquavalver »
Thanos wrote: Wed Sep 21, 2022 11:52 am This is what I recieved almost 2 years ago.
Where does the burgundy seat heating pad plug go to? Do you need to change the connector to match up with the one on the loom? I take it the blue one in my photos is the seat occupancy one?
unnamed (2).png (2.03 MiB) Viewed 4981 times
unnamed (1).png (1.74 MiB) Viewed 4981 times
Thanos
Post by Thanos »
The burgundy connector connects to the wiring loom.
Mine is not linked to the seat it just dangles underneath the seat.
Aquavalver
Thanos wrote: Wed Sep 06, 2023 9:11 am The burgundy connector connects to the wiring loom.
The Kufatec wiring loom doesn't have a burgundy matching connector like that-it has a male 1J0972923 -it's the same as the photo that iichel posted
Aquavalver
Zun89
Drives: Seat Ibiza 6J SC
Post by Zun89 »
Hi Guys :)
i drive a Seat Ibiza 6J SC 2015
Buyed a 6R0959772A Modul and also buyed the kufatec cable kit.
6J0927137AP as switch - 6R0937087R as bcm
I have wired everything correctly - I have plugged in the fuse.
After that i coded byte 15 bit 4 to 1.
I have about 10v at the plug.
When i press the button - nothing happend.
The seat mats are still on the way - i cant test it with the mats on :/
When i want to access "channel 63" -> it says "The channel is not available"
Is everything OK so far?
Thank you for your help :)
br Zun
is the engine running when you test?
Zun89
Post by Zun89 »
No the engine wasnt running.
The key was on "Ignition" position.
then the seat heating will not turn on, engine must be running of you let the BCM control it.
Zun89
Post by Zun89 »
When I started the engine - there is 11.8v at the plug.
When the engine is running - 12.7v at the plug - the switch does not light.
Did he need the 2.4 ohm resistance from the seat heating to illuminate control leds?
