Polo 6c Composition touch possible rear camera retrofit
Discuss In Car Entertainment
giannis20vt
Post by giannis20vt »
hello,
i have this unit to my 6C MY2016
I wonder if I can install a rear camera. Not the original, any aftermarket camera.
For example this one.
https://www.aliexpress.com/item/4001362 ... 5450119_12
Anyone have any idea ?
Re: Polo 6c Composition touch possible rear camera retrofit
No you need a colour screen to show camera images
giannis20vt
iichel wrote: Mon Apr 17, 2023 9:57 am No you need a colour screen to show camera images
very useful information, thank you.
So i have to retrofit another unit before procced with this installation.
Image Image
Those are the choices from the ETKA, composition COLOR and composition MEDIA
The PR code KA0 is without rear camera system and the KA1 is with rear camera system. I don't know if the unit with PR Code KA0 is capable to manage rear camera.
If I install one of these, will I be able to fit a regular (non VW) cam afterwards and what would I need? (perhaps some signal converter, etc.)
Most of the aftermarket camera systems will have a cinch tulip connector, those will work with an oem mib head unit yes. I think it's pal 50hz for the signal but I'm nog 100% sure.
giannis20vt
iichel wrote: Mon Apr 17, 2023 9:28 pm Most of the aftermarket camera systems will have a cinch tulip connector, those will work with an oem mib head unit yes. I think it's pal 50hz for the signal but I'm nog 100% sure.
Thank you, i appreciate this. The connector is not going to be a problem, I didn't know if any device was needed to connect the camera to the Head Unit.
To summarize, I'm going to upgrade to a unit with color screen, buy a camera with an RCA connector and install it. Of course it will require some programming of the Head Unit to make it work.
I will search about the type of signal, i think is NTSC.
giannis20vt
So far i discover that it is possible to retrofit any camera to the Composition Color :cry:
This is the 1rst link that says about that.
https://www.advanced-incar.co.uk/produc ... -retrofit/
Maarten
Drives: AW R-line Facelift MY2022 Vibrant Violet
Post by Maarten »
This is probably after market unit
That's about the composition colour for the T6 (PQ25) anyway, not for your MQB Polo 6C.
giannis20vt
iichel wrote: Tue Apr 18, 2023 12:57 pm That's about the composition colour for the T6 (PQ25) anyway, not for your MQB Polo 6C.
Okay, so this is good news. I'm seriously considering going with a used composition color unit. And the only reason is because I want to install a rear camera.
Just like this https://allegro.pl/oferta/radio-vw-polo ... 3422791945
giannis20vt
I am willing to buy this one.
The Pr Code KA1 is for Rear View Camera (type1)
For sure this unit can have rear camera.
What Type1 is ? I mean what kind of camera i should buy ?
This is the original code
I'm not sure what type 1 means. In my experience, a most of aftermarket camera's with a 2-wire signal will work. I haven't seen one that didn't so far.
giannis20vt
As i mentioned the camera VW code is 6C0980121
The camera described as Low Line
I can't find any other information about resolution and the TV system type ( i think it is NTSC).
Anyone has any other information about that ? I am willing to buy something like that :
https://www.aliexpress.com/item/1005005 ... 4122154_15
giannis20vt
iichel wrote: Wed Apr 19, 2023 8:54 am I'm not sure what type 1 means. In my experience, a most of aftermarket camera's with a 2-wire signal will work. I haven't seen one that didn't so far.
Maybe something like that
https://www.aliexpress.com/item/1005003 ... 04200253_9
I installed this camera to a few MIB units, it was ok
giannis20vt
iichel wrote: Wed Apr 19, 2023 11:53 am I installed this camera to a few MIB units, it was ok
:D
Would you suggest a better one?
