https://youtu.be/i9VlboxHDcY/youtube
So you have installed pq26 bi-xenon headlights, right?.... or are these bi-xenon headlights you've installed used on both platforms?
on pq26 this bixenon work perfect, on my pq25 only after wire/ bcm 090 and so on
Have you installed another two new wires for the front parking/side lights (POS)? Your factory wires for the parking lights is front and rear on the same side with the same wire, with bi-xenon headlights the front and rear wires should be separate and coming from different pins from the BCM.
Bixenon, LED Headlights:
Front parking lights.
T73b/5 ---> Left headlight.
T73b/6 ---> Right headlight.
Rear parking lights.
T73a/41 ---> Left taillight.
T73a/40 ---> Right taillight.
Based on your headlights (W diagrams), you should know the correct pin/slot on the headlight/taillight connectors.
Note: This allows you to code or parameterize the output value of the front parking lights.
Halogen H4/H7 Headlights:
Front and rear parking lights.
T73a/41 ---> Left side.
T73a/40 ---> Right side.
First i can say my taillight from new model and have led, i didnt remember what i touch in vcds but back tail led work in 3 position of switch no problem, as a drl+parking+light!
Everything that concerns to parking lights from the front, they do not interest me. Do you think this unfinished work prevents the strip from working with the main light and drl?
Have you changed the input signal on T16c/9?
In the original installation it is a 56 signal coming from the T17/7 light switch, but now it should be a +15 signal coming from the SB27 (5A) fuse.viewtopic.php?p=598020#p598020
you sure about that? not a SB36?
originally i did it the first time like this
- Screenshot 2023-05-20 at 13.35.14.png (47.08 KiB) Viewed 5261 times
but since the Steering column switch did not turn on the light proper Or I did not do this code
bit 28 bait 3 at that moment, i change connection of this wire direct ,
T16/7 to T73B/8, T16/8 to T73A/62 and not from SB location.
+15 as i understand come from
T17/7
Or am I wrong? but it basically Steering column work proper now. in the sense that turning on the high beam works in two modes when the low beam is on.
Or and due to this ( maybe incorrect connection) flashing with Hibeam not possible in the absence of lo beam
