Polo 6r GTI - Bi-Xenon installation Issues
Rapid
Drives: Rapid 2013
Re: Polo 6r GTI - Bi-Xenon installation Issues
Post by Rapid »
some owner of polo, jetta and my rapid mention that only if I FIX eeprom it can help in my situation and only with VCP or Odis.
Do u know something about that?
PWM Value with POS/TFL lights and activated Pos-lights
Well, in that case (low and high wired from BCM to headlights), you should modify and install more wires in E4 for Low and High beam.
E4 is T16/16Steering column switch
I make this wire connection to :!: T16/7 to T73B/8, T16/8 to T73A/62
and coding for it bit 28 bait 3
There is no representation of an LED module that controls the DRLs and side/parking lights on the same LED strip
becouse this diagram i think for old bcm pq25, and skoda never installed this headlamp for this model year. then made for new model from 2015 on pq26.
video tomorrow :!:
So you have installed pq26 bi-xenon headlights, right?.... or are these bi-xenon headlights you've installed used on both platforms?
Have you installed another two new wires for the front parking/side lights (POS)? Your factory wires for the parking lights is front and rear on the same side with the same wire, with bi-xenon headlights the front and rear wires should be separate and coming from different pins from the BCM.
Bixenon, LED Headlights:
Front parking lights.
T73b/5 ---> Left headlight.
T73b/6 ---> Right headlight.
Rear parking lights.
T73a/41 ---> Left taillight.
T73a/40 ---> Right taillight.
Based on your headlights (W diagrams), you should know the correct pin/slot on the headlight/taillight connectors.
Note: This allows you to code or parameterize the output value of the front parking lights.
Halogen H4/H7 Headlights:
Front and rear parking lights.
T73a/41 ---> Left side.
T73a/40 ---> Right side.
0.5mm2
Rapid wrote: Fri May 19, 2023 10:27 pm some owner of polo, jetta and my rapid mention that only if I FIX eeprom it can help in my situation and only with VCP or Odis.
Yes, we know about it, here in the forum it has happened with several VW models (T5, Amarok, Polo), but sometimes it depends on how the BCM 7E0 of the donor car is parameterized.
More information here: https://www.drive2.ru/l/489696641561919499/
Rapid wrote: Fri May 19, 2023 10:27 pm I make this wire connection to :!: T16/7 to T73B/8, T16/8 to T73A/62
Have you changed the input signal on T16c/9?
In the original installation it is a 56 signal coming from the T17/7 light switch, but now it should be a +15 signal coming from the SB27 (5A) fuse.viewtopic.php?p=598020#p598020
New BCM coding: (third test, AFTER you fix the wiring)
6C980F2000210400000808303E4B0CC00F40600F600338C0020000064800
Rapid
Drives: Rapid 2013
Post by Rapid »
https://youtu.be/i9VlboxHDcY/youtube
on pq26 this bixenon work perfect, on my pq25 only after wire/ bcm 090 and so on
First i can say my taillight from new model and have led, i didnt remember what i touch in vcds but back tail led work in 3 position of switch no problem, as a drl+parking+light!
Everything that concerns to parking lights from the front, they do not interest me. Do you think this unfinished work prevents the strip from working with the main light and drl?
you sure about that? not a SB36?
originally i did it the first time like this
Screenshot 2023-05-20 at 13.35.14.png (47.08 KiB) Viewed 5250 times
but since the Steering column switch did not turn on the light proper Or I did not do this code bit 28 bait 3 at that moment, i change connection of this wire direct ,
T16/7 to T73B/8, T16/8 to T73A/62 and not from SB location.
+15 as i understand come from T17/7
Or am I wrong? but it basically Steering column work proper now. in the sense that turning on the high beam works in two modes when the low beam is on.
Or and due to this ( maybe incorrect connection) flashing with Hibeam not possible in the absence of lo beam
Thank you very much for the video, now I understand everything perfectly.👌
Interesting that you comment now that you installed LED taillights and you will code for permanent Parking lights (old Scandinavian lights). Now called rear DRL (completely unnecessary IMHO, ... I'm not going to argue with anyone that if visibility isn't good enough the other lights bla bla bla....).
Regardless of the legal issues of the circulation of vehicles, you can do or prefer what suits you best, I will deeply respect it, I don't know if other drivers will find it good or bad.
I am not sure of absolutely anything, I live to learn.
I live in Magiclands, as indicated on my avatar.
- 1% of the time in the highlands.💎
- 9% of the time in the midlands.🤗
- 90% of the time in Orcolands with monsters, dragons, dwarves, trolls, and evil wizards... :lol:
Exterior lighting , (7L3),(K8B),(8K9),(9C2)
From May 2014
Now you can compare it with the diagrams of your original installation (with BCM High, not MAX).
It all depends on the type of BCM you have installed, and you have a 7E0 MAX (which can work exactly the same as a 7H0 MAX and much more).
Rapid
Drives: Rapid 2013
Post by Rapid »
It have stop signal😂 if you about that;)
Fog and reverse
https://youtube.com/shorts/aCIDcBhg20k?feature=share
And i don’t really understand the diagram, t 16/ 8 is not correct and i need t16 / 9 to T73A\62?
I think T16/9 connected to T17/7 , or it connected to fuse and from fuse to T17/7?
phote before T16/8 installed
Easy.
👍 ... this modification is correct.
Front parking lights are absolutely necessary, I meant that about what you are interested in, nothing regarding your new taillights.
It was just a comment.😊
Rapid
Drives: Rapid 2013
Post by Rapid »
i se that this wire For example on Skoda Fabia
T17a/7 (output) "56x" To the contact T41a/41 of the steering column switch, power is taken from it for high beam.
I think it's overkill but I'll try T16/9 to T17/7
i think i repair same wire which is now installed already by default :mrgreen:
Rapid
Drives: Rapid 2013
Post by Rapid »
Nothing , same same wire i just reconnect new one :mrgreen:
When i disconnect one side for test , options to turn long hibeam lost, so my new wire reproduced same wire
You have to connect T16/9 to a +15 signal NEW wire coming from the fuse box, which you seem to have a hard time understanding.
- A +30 signal is a signal direct from the battery.
- A +15 signal is when you turn the ignition switch.
You can check it in the fuse box with a multimeter.
The BCM is not stupid and does not expect to receive a 75x signal passed to 56x by the light switch and then to 56 on the STALKS. The BCM waits for that +15 signal.
You should have the low beam and high beam on individual wires from the BCM to the headlights.
You should have the DRL (TFL) and Parking Lights (POS) on individual wires from the BCM to the headlights.
Before editing/changing/parameterizing the BCM parameter values for TFL or POS, the wires must be well connected and the coding must be correct. Otherwise you will not have the results you expect.
Does anyone know what the correct values for those headlights are? I'm afraid not, whoever will test it, 40 here, 20 there to see if it works.
Enter the last BCM coding (third test) that I posted earlier, although this does not give the results you expect. Post here a new Autoscan with this coding.
Do not be impatient, and wait to solve the problems step by step.🤷‍♂️
hahaha... I'm not Darth Vader or your father.😅
https://www.youtube.com/watch?v=8ZWimzSyWbs
Rapid
Drives: Rapid 2013
Post by Rapid »
i try!
In short about rest
Hibeam already connected L T73a/1 R T73b/1 , DRL already connected L T73b/3 R T73a/5 +wire from T73b/29 to t17/3, this is correct?
28 drl :roll:
https://www.youtube.com/watch?v=AcBTkjvyLNg
Rapid wrote: Sat May 20, 2023 9:11 pm
yes 👍
28 drl :roll:
These are the values with which Alexander💎🤗 correctly operated the LED modules in his Polo Sedan pq25 (6R/6C LED headlights).
For example, for T5.1 or Amarok (pq25) they are not the same.
Rapid
Drives: Rapid 2013
Post by Rapid »
Good morning
new wire t16/9>SB27(5a)
no drl,no Lo no Hi, hand react to movement and i see blue indicator of Hibeam on cluster but nothing happen ,i do first and second code for test.
first test)
6C980F2000210400000808303F480CC00F406607600308C0060000024000
second test)
6C980F2000210400000808303F480CC00F404007600308C0060000024000
Nothing.
I back to my default one :!:
6C980F2000210400000808303F480CC00F406607600308C0060000024800
where is Lo working+ Hi if lo on,+ i can do short and long Hi with hand, but only if lo on.
oh god i forgot to scan :oops: if it matters. Car scanner show me same 3 light error
In principle with this change t16/9>SB27 everything works as before with my default code.
T17/7 as I understand no need anymore?
in my opinion with all these improvements with the new BCM and new wire, even before communicating with you, turning on the high beam was accompanied by a strange sound from the headlights :|
that normal?
We are progressing.
Yes, T17/7 is no longer necessary.
Have you installed the wires for the front parking lights?
Left ...T73b/5 ---0.5mm2 wire--> T10/10
Right ... T73b/6 ---0.5mm2 wire--> T10/10
Remove and Insulate the original wire from the headlight connector. Isolate the original wire correctly because this wire is still live.
It is essential for the LED strip module to work correctly, and so that it makes sense to parameterize with VCP or ODIS the values of TFL and POS.
New BCM coding: (fourth test)
6C980F2000210400000808303E4B0CC00F40730F600338C0060000164800
Two tests with this BCM coding; You must test it with the BCM 54 channel at 0, and then with 1.
Report the results. Autoscan/s.
Rapid
Drives: Rapid 2013
Post by Rapid »
58 channel with 0
After start engine, drl work stable no winks;)but only as drl.
No lo no hi, hi no short no long. Cluster blue indicator hi beam working no stop, but not on zero switch.
58 channel with 1
Drl as drl ok, Lo winks 2-3 seconds and turned off, but after i save the channel it start works, Hi short+ long but only if Lo active only.
Hand switch work strange, when i try to of Hi long it continues work, until i kick hand to short position.
cluster blue indicator hi beam working no stop, but not on zero switch
i don't mention the taillights but this time they turned off after ignition, i hope is just edit one bit later :mrgreen:
Although now I went for food and the Lo did not turn on at all , I switch back to zero and to Lo again and it wink as drl in first video, they turn on and off or wink and off
https://youtu.be/0DkB3iB7Hsg
inside block
before and after clean
5 Faults Found:
            011 - Open Circuit - Intermittent
                    Fault Status: 00101011
                    Fault Priority: 2
                    Fault Frequency: 3
                    Reset counter: 97
                    Time Indication: 0
03432 - Activation of Right Parking Light
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 96
                    Mileage: 195642 km
                    Time Indication: 0
                    Date: 2049.14.23
                    Time: 15:48:59
00532 - Supply Voltage B+
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 96
                    Mileage: 0 km
                    Time Indication: 0
                    Date: 2049.14.23
                    Time: 16:35:15
01495 - Bulb for High-Beams; Left (M30)
            010 - Open or Short to Plus
                    Fault Status: 01101010
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 56
                    Mileage: 195642 km
                    Time Indication: 0
                    Date: 2049.14.23
                    Time: 17:56:39
01499 - Bulb for High-Beams; Right (M32)
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 56
                    Mileage: 195642 km
                    Time Indication: 0
                    Date: 2049.14.23
                    Time: 17:56:39
after clear
Sunday,21,May,2023,18:52:11
3 Faults Found:
            011 - Open Circuit
                    Fault Status: 01101011
                    Fault Priority: 2
                    Fault Frequency: 3
                    Reset counter: 57
                    Mileage: 195643 km
                    Time Indication: 0
                    Date: 2049.14.23
                    Time: 18:48:11
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 57
                    Mileage: 195643 km
                    Time Indication: 0
                    Date: 2049.14.23
                    Time: 18:48:41
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 57
                    Mileage: 195643 km
                    Time Indication: 0
                    Date: 2049.14.23
                    Time: 18:48:41
Full
Sunday,21,May,2023,18:55:27
56-Radio -- Status: Malfunction 1010
Address 01: Engine (J623-CAXA)       Labels:. 03C-906-016-CAX2.clb
   Part No SW: 03C 906 016 CR    HW: 03C 906 016 CR
   Component: 1.4l R4 TSI   H02 4874
   Revision: LJH02---    Serial number:                CVN: 761A8B19
   Coding: 00250012000400000000
   Shop #: WSC 73430 031 00125
   ASAM Dataset: EV_ECM14TFS01103C906016CR 001004
   ROD: EV_ECM14TFS01103C906016CR.rod
   VCID: 71E960C3A0A913057D-8024
   VINID: 91D4919067981D41000C51C9086C1421BB
Readiness: 0000 0000
Address 02: Auto Trans        Labels: 0AM-927-769.clb
   Part No SW: 0AM 300 060 E    HW: 0AM 927 769 D
   Component: GSG DSG AG7     431 6203
   Revision: 00043014    Serial number: CU501601216604
   Coding: 0000020
   Shop #: WSC 08643 002 1048576
   VCID: 2C57B1B78F0B3EED0E-8078
Address 03: ABS Brakes (J104)       Labels: 6R0-614-517-TRW460.clb
   Part No SW: 6R0 614 517 BK    HW: 6R0 614 517 BK
   Component: EBC 460 ESP   H08 0004
   Serial number: A00AWQ1
   Coding: 4129481409B400B9824E12DB90A200404B0800
   ASAM Dataset: EV_Brake1ESPAEntryTRW 002011
   ROD: EV_Brake1ESPAEntryTRW.rod
   VCID: 7DF14CF3ECF16765E9-8028
   Part No SW: 6RA 959 654     HW: 6RA 959 654
   Component: LENKW.SENSOR  H02 0020
   Serial number: 28051304210234
   Coding: 01
   Shop #: WSC 00000 000 00000
   ASAM Dataset: EV_LWSKLOVW25X 005002
   ROD: EV_LWSKLOVW25X.rod
   VCID: 0F2D063BD65D65F50B-805A
Address 08: Auto HVAC (J301)       Labels: 6R0-820-045-9AB.clb
   Part No SW: 5JA 820 045     HW: 5JA 820 045
   Component: Man AC        H06 0101
   Revision: 2013SH06
   VCID: 73E56ACBD2B521158F-8026
   Revision: B9080001    Serial number: 0771 003200040
   Coding: 6C980F2000210400000808303E4B0CC00F40730F600338C0060000164800
   Shop #: WSC 18752 008 00032
   VCID: 68DF0DA79B73D2CD2A-803C
   Subsystem 1 - Part No SW: 5E0 919 719 C    HW: 5E0 919 719 C  Labels: 3C8-959-537.CLB
   Component: E221__MFL-PR6  H03 0120
   Serial number: 000000000A0184150513
3 Faults Found:
            011 - Open Circuit
                    Fault Priority: 2
                    Fault Frequency: 3
                    Reset counter: 57
                    Mileage: 195643 km
                    Time Indication: 0
                    Date: 2017.10.11
                    Time: 18:48:11
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 57
                    Mileage: 195643 km
                    Time Indication: 0
                    Date: 2017.10.11
                    Time: 18:48:41
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 57
                    Mileage: 195643 km
                    Time Indication: 0
                    Date: 2017.10.11
                    Time: 18:48:41
Address 15: Airbags (J234)       Labels:| 5Q0-959-655.clb
   Part No SW: 34D 959 655 B    HW: 34D 959 655 B
   Component: AirbagVW20    004 0365
   Serial number: 003K7R016UMU
   Coding: 88CCC00000000000540000C8000000000045
   Shop #: WSC 73430 790 00125
   ASAM Dataset: EV_AirbaVW20SMEVW253 001108
   ROD: EV_AirbaVW20SMEVW253.rod
   VCID: 3467A9D79F3B662D56-8060
   Subsystem 1 - Part No SW: -----------    HW: 480 411 805 13
   Component: SideSensor_Df  003 0148
   Serial number: 349650A25E62A7233EDW
   Coding: 2D2D2D
   Subsystem 2 - Part No SW: -----------    HW: 480 411 805 13
   Component: SideSensor_Pf  003 0148
   Serial number: 350650A25E6C6F22AF6
   Coding: 2D2D2D
   Subsystem 3 - Part No SW: -----------    HW: 480 411 805 13
   Component: SideSensor_Dr  003 0148
   Serial number: 351650A25E62ADF2AF1$
   Coding: 2D2D2D
   Subsystem 4 - Part No SW: -----------    HW: 480 411 805 13
   Component: SideSensor_Pr  003 0148
   Serial number: 352650A25E62A2F4EC4Z
   Coding: 2D2D2D
   Part No SW: 5JA 920 810 B    HW: 5JA 920 810 B
   Component: KOMBI         H04 0709
   Coding: 110A01
   ROD: EV_Kombi_UDS_VDD_RM09_004_SK25.rod
   VCID: 366393DF8947743D68-8062
   Revision: B9080001
   Coding: 332200
2 Faults Found:
            000 - - - Intermittent
                    Fault Status: 00100000
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 0 km
                    Time Indication: 0
                    Date: 2017.10.11
                    Time: 16:35:15
01304 - Radio
                    Fault Status: 00100100
                    Fault Priority: 2
                    Fault Frequency: 16
                    Reset counter: 97
                    Mileage: 195625 km
                    Time Indication: 0
                    Date: 2017.10.10
                    Time: 21:01:32
   Component: IMMO          H04 0709
   VCID: 6ADB77AF8D7FE0DD3C-803E
   Part No: 6R0 423 156 C
   Component: LenkhilfeTRW        V278
   Coding: 11230
   Shop #: WSC 73430
   VCID: 306FA5C7F7235A0D32-8064
Address 56: Radio
Cannot be reached
End-------------------------(Elapsed Time: 02:17)--------------------------
