Log # 26, 27, and 28.
#26 OEM wireless charging pad in storage compartment.
# 27 OEM Led DSG gear knob China version.
#28 OEM touch climatronic unit China version.
I got some free time out of my hectic work schedule. So decided to do all the above 3 retrofits at the same time, as they involve almost the same area/trims involved of the central console.
Log #26 OEM wireless charging pad(5NA980611, rated 5w).
Previous information with wiring scheme here
viewtopic.php?p=598872#p598872
How to dismantle central console trim in T-roc is here( applicable to all 3 mentioned retrofits)
viewtopic.php?p=597689#p597689
Pictures/details of installation:
1. 12v +30 from the additional fuse box I made
2. GND to near by GND point
3. 5F control unit quadlock grey connector 12pin t12/5 &11
4. BCM
t73a/14 "C" connector( optional) - I connected it, this connection has a specific function, I found out by doing tests. This connection allows the phone to continue charging even when ignition is turned off. The charging stops only when the driver door is opened/ car is locked.
5. Coding: Enable
Byte15, bit5 in 5F using experimental yellow screen.
Bought a new charging rubber mat for
RHD 2GB863328B9B9. For
LHD 2GA863328C9B9
Charging also works with stock mat, but the mat for wireless charging is designed thoughtfully. The new mat has a wide central deeper recess for correct alignment of the phone over the charging pad. On the back side, new honeycomb pattern of the mat allows heat dissipation more efficiently
I have observed a noticeable reduction of phone heating with the new mat.
# 27 ?OEM Led DSG gear knob China version.
I bought this from a reputed AliExpress seller. She assured me that it is OEM China version and not cheap replicas sold everywhere on AliExpress. I took her words with a pinch of salt and purchased it. For the price of 70$, the quality, the fit and finish is very good, I have no complaints.
I prefer to have a dual display of gears selection both in knob and base panel. The Chinese version doesn't have the problem of electronic conflict when you install a LED gear knob while retaining the base gear indicator panel. The Original EU version LED knob will not work correctly if the knob is installed while retaining the base gear indicator panel. Some letters on both the led knob and base panel don't illuminate correctly.
I have solved this problem with OEM led gear knob in Polo. Details here
viewtopic.php?p=589334#p589334
The fonts are slightly thinner in Chinese version compared to OE version. But the colour rendering is perfect and works well. No errors in scan
#28 OEM touch climatronic unit China version ( 17G907044AN)
A previous attempt to install touch climatronic with a frame bought from AliExpress was unsuccessful. The touch climatronic frames for T-roc sold in AliExpress are for LHD only. Details here
viewtopic.php?p=602253#p602253
As I mentioned previously, for RHD T-roc we need a frame with part number
2GB863099B. Unfortunately, this part is not sold separately! It's a part of a larger ridiculously expensive central console trim
2GB863042B.
Fortunately, I found the RHD central console trim with frame for touch climatronic unit on EBay UK for a fraction of the price. But the seller wasn't willing to ship to India. I tormented dear iichel to get it.
The trim made a long and arduous journey from UK-NL-IND.
Finally got it undamaged and in perfect condition like brand new.. glossy
I liked the glossy black trim so much so that, for a change, I decided to install the trim as is rather than transferring the climatronic frame to my stock limestone grey trim
The climatronic frame is plastic welded to central console trim, but with gentle hands and correct tools it is possible to dismantle the frame without damaging it.
Basic settings and coding/adaptations transfer:
1. Transferred the 08 HVAC coding from old to new unit
2. Basic settings of flap motors went on fine.
3. Basic settings of AC compressor didn't start, got an error
I had to follow the steps provided by Ross -tech shared by dear master Ciclo in his post here
viewtopic.php?p=575072#p575072 http://wiki.ross-tech.com/wiki/index.ph ... 9_Climatic
On 3rd attempt, it was successful!
I did all the checks on new unit and everything is working correctly
Though I felt it wasn't necessary, I did transfer all the adaptations of old unit. Everything was ok.
Old unit:
New unit:
Autoscan:
Saturday,19,October,2024,20:49:13:09269
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 11 x64
VCDS Version: 24.7.0.0 (x64) HEX-V2 CB: 0.4643.4
Data version: 20240715 DS356.3
www.Ross-Tech.com
VIN: WVGZZZA1ZLVtriple-roc License Plate:
Chassis Type: A1-VW27 (3Q0)
Scan: 01 02 03 05 08 09 10 13 15 17 19 2B 3C 42 44 4B 52 5F 65 6D
75 A5 BB BC CA D6 D7
VIN: WVGZZZA1ZLVtriple-roc Mileage: 59681km-37084miles
05-Acc/Start Auth. -- Status: OK 0000
2B-Steer. Col. Lock -- Status: OK 0000
4B-Multifunc. Module -- Status: OK 0000
6D-Trunk Elect. -- Status: OK 0000
75-Telematics -- Status: OK 0000
A5-Frt Sens. Drv. Assist -- Status: OK 0000
BB-Door Rear Drv -- Status: OK 0000
BC-Door Rear Pass -- Status: OK 0000
CA-Sunroof -- Status: OK 0000
D6-Light Ctrl Left 2 -- Status: OK 0000
D7-Light Ctrl Right 2 -- Status: OK 0000
Address 01: Engine (J623-DPCA) Labels:. 04E-907-309-V1.clb
Part No SW: 05E 906 018 AT HW: 05E 907 309 H
Component: R4 1.5l TFS H20 9640
Revision: 8AH20000 CVN: 5E8A0C2D
Coding: 0125003223641D0830000000000000000000000000000000
Shop #: WSC 00020 043 00000
ASAM Dataset: EV_ECM15TFS01105E906018AT 003003
ROD: EV_ECM15TFS01105E906018AT_003_VW27.rod
VCID: 77A8E2A6DF4F07E26E9-8022
VINID: 9E65EAAAA441A9C9801C720314E84F2DE4
Readiness: 1010 0001
Address 02: Auto Trans (J743) Labels: 0CW-927-769.clb
Part No SW: 0CW 300 050 J HW: 0AM 927 769 E
Component: GSG DQ200G2_M H05 1911
Revision: 00005009 Serial number: CU501911185682 CVN: ABB5E1C0
Coding: 0014
Shop #: WSC 17734 418 534600
ASAM Dataset: EV_TCMDQ200021 001001
ROD: EV_TCMDQ200021.rod
VCID: 3C223D8AA6E9E4BA43B-8068
Address 03: ABS Brakes (J104) Labels: 5Q0-907-379-IPB-V1.clb
Part No SW: 5Q0 614 517 DK HW: 5Q0 614 517 BN
Component: ESC H35 0113
Revision: 00000000 Serial number: 63139000003538
Coding: 46FA8A7D90272473477F060362C82562510924E26046A4733822F00A52A24B0B00000523525212121035351919323200
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_Brake1UDSContiMK100IPB 049012
ROD: EV_Brake1UDSContiMK100IPB_049_VW27.rod
VCID: 7DA4F08EFD732DB2345-8028
Address 05: Acc/Start Auth. (J518) Labels:| User\5Q0-959-435.lbl
Part No SW: 3Q0 959 435 N HW: 3Q0 959 435 N
Component: VWKESSYMQB 037 1307
Revision: 00037000 Serial number: 0534174099 Dataset Number: V03935301VA 0001
Coding: 1F20200723
Shop #: WSC 00046 000 00000
ASAM Dataset: EV_KessyHellaMQBAB 004052
ROD: EV_KessyHellaMQBAB.rod
VCID: 45D4586ED523A5722C5-8010
Rear lid opener control module:
Subsystem 1 - Part No SW: 3GD 962 243 D HW: 3GD 962 243 D
Component: GEB.F.Heckoef H17 0908
Serial number: 05086671
Address 08: Auto HVAC (E87) Labels:. 5G0-907-044.clb
Part No SW: 17G 907 044 AN HW: 17G 907 044 AN
Component: AC Automat H11 1501
Revision: 20K07000 Serial number: 00000A00811480
Coding: 061200242001100D1105004012101836
Shop #: WSC 12345 123 12345
ASAM Dataset: EV_ACTouchPrehVW37X 001010
ROD: N/A
VCID: 76B6EFA2D8457EEA75F-8022
No ASAM data for: "EV_ACTouchPrehVW37X" (VW27)
Address 09: Cent. Elect. (J519) Labels:. 5Q0-937-08X-V2.clb
Part No SW: 5Q0 937 084 EC HW: 5Q0 937 084 EC
Component: BCM MQBAB H H44 0511
Serial number: B2701012207200 Dataset Number: V03935394NB 0001
ASAM Dataset: EV_BCMMQB 022001
ROD: EV_BCMBOSCH_022_VW26.rod
Rain/Light Recognition Sensor:
Subsystem 1 - Part No SW: 5Q0 955 547 C HW: 5Q0 955 547 C Labels: 5Q0-955-547.CLB
Component: RLHS 051 0206
Serial number: S6Y19M10D15H05M19S28
Coding: 0018DD
Anti-theft alarm system sensor:
Subsystem 2 - Part No SW: 5Q0 951 172 HW: 5Q0 951 172
Component: Sensor, DWA 005 0316
Serial number: 000000000ZY192950M1T
Alarm horn:
Subsystem 3 - Part No SW: 5Q0 951 605 B HW: 5Q0 951 605 B
Component: Sirene, DWA 004 0007
Serial number: 00000000000000754028
Steering Column Switch:
Subsystem 4 - Part No SW: 5Q1 953 521 Q HW: 5Q1 953 569
Component: Lenks.Modul H03 0170
Serial number: 0100221120190C400340
Address 10: Park/Steer Assist (J791) Labels:| 5Q0-919-298.clb
Part No SW: 5QA 919 298 K HW: 5QA 919 298 A
Component: PLA 3.0 12K H08 0073
Serial number: 000150057322125 Dataset Number: V03935342EN 0001
Coding: 8379167851
ASAM Dataset: EV_EPHVA2CAU3700000 009055
ROD: EV_EPHVA2CAU3700000_010_VW37.rod
VCID: 58EA811A3291289A473-800C
Address 13: Auto Dist. Reg (J428) Labels:| 2Q0-907-572.clb
Part No SW: 2Q0 907 572 AB HW: 2Q0 907 572 B
Component: ACCCONTIMQB H03 0397
Dataset Number: V03935376DS 0001
Coding: 300C47435CFF8748949C812483578700000000000000000004
Shop #: WSC 00046 123 12345
ASAM Dataset: EV_ACCMRRCONTIVW376 003018
ROD: EV_ACCMRRCONTIVW376_003_VW27.rod
VCID: 74B2D5AACE396CFA4BB-8020
Address 15: Airbags (J234) Labels:| 5Q0-959-655.clb
Part No SW: 3Q0 959 655 CM HW: 3Q0 959 655 CM
Component: Airbag VW21 006 0720
Revision: -------- Serial number: 003Z2PPMRKF2 Dataset Number: V03935298UN 0001
Coding: 88CCC0C0000000005C5400CF008840000065
Shop #: WSC 00020 999 00000
ASAM Dataset: EV_AirbaVW21TS6VW48X 001014
ROD: EV_AirbaVW21TS6VW48X_VW27.rod
VCID: 0B40AE56B3C713023A1-805E
Subsystem 1 - Part No SW: ----------- HW: 454 002 910 19
Component: SideSensor_Df 008 0887
Serial number: 357000000004A1316142
Coding: 2D2D2D
Subsystem 2 - Part No SW: ----------- HW: 454 002 810 19
Component: SideSensor_Pf 008 0887
Serial number: 35800000000C98B8424V
Coding: 2D2D2D
Subsystem 3 - Part No SW: ----------- HW: 454 802 210 19
Component: SideSensor_Dr 301 0148
Serial number: 35100A0CB121A000000D
Coding: 2D2D2D
Subsystem 4 - Part No SW: ----------- HW: 454 802 510 19
Component: SideSensor_Pr 301 0148
Serial number: 35200E4A8381A000000P
Coding: 2D2D2D
Subsystem 5 - Part No SW: ----------- HW: 454 802 310 19
Component: FrontSensor_D 304 0149
Serial number: 35500964D2C1A000000R
Coding: 2D2D2D
Address 17: Instruments (J285) Labels:| 5G0-920-XXX-17.clb-SRI3
Part No SW: 17A 920 790 B HW: 17A 920 790 B
Component: KOMBI 503 4310
Coding: 65FC00986E88080C0188770F1801000000000906
ASAM Dataset: EV_DashBoardVDDMQBA0 001042
ROD: EV_DashBoardVDDMQBA0_001_VW27.rod
VCID: 2616FFE248654E6A05F-8072
Address 19: CAN Gateway (J533) Labels:| 3Q0-907-530-V1.clb
Part No SW: 3Q0 907 530 AC HW: 3Q0 907 530 C
Component: GW MQB High 442 4388
Revision: -------- Serial number: 0000427114 Dataset Number: V03935301GP 0001
Coding: 030100046F08560003100258180F00010001070000000000000000000000
GVL: 014E3C000800060040CC80008000C80010000000000200000000000000000000
ASAM Dataset: EV_GatewNF 013026
ROD: EV_GatewNF_VW27.rod
VCID: 70BAD9BABA2150DAAF3-8024
Generator:
Component: 5-01-14-01-04
Multifunction steering wheel control module:
Subsystem 2 - Part No SW: 1EA 959 442 D HW: 1EA 959 442 D
Component: MFL H03 0219
Serial number: 17038312100192202040
Coding: 2D0900
Subsystem 3 - Part No SW: 5Q0 915 181 K HW: 5Q0 915 181 K
Component: J367-BDMHella H10 9070
Serial number: 3250843205
Address 2B: Steer. Col. Lock (J764) Labels:| 1EA-905-861.clb
Part No SW: 2Q0 905 861 A HW: 2Q0 905 861 A
Component: ELV-MQBB H08 0021
Serial number: 19000332474005
Coding: 0800000000000000
ASAM Dataset: EV_ELVMarqMQBA0 002002
ROD: EV_ELVMarqMQBA0_VW27.rod
VCID: 313C1CBE71AB19D2E0D-8064
Address 3C: Lane Change (J1086) Labels:* Redir Fail!
Part No SW: 2Q0 907 686 B HW: 2Q0 907 686 B
Component: HRE3_Kl15_Mst H06 0150
Serial number: 14520011985865 Dataset Number: V03935308HF 0001
Coding: 92A54640
ROD: EV_HREntryHellaGen3Kl15_002_VW27.rod
VCID: 392C249EA9DBD19258D-806C
Lane change assistance control module 2:
Subsystem 1 - Part No SW: 2Q0 907 685 B HW: 2Q0 907 685 B
Component: HRE3_Kl15_Slv H06 0150
Serial number: 14520011913860
Address 42: Door Elect, Driver (J386) Labels:| 5QX-959-X93-42.clb
Part No SW: 5Q4 959 593 K HW: 5Q4 959 593 K
Component: TSG FS 007 0485
Serial number: 0000397175085 Dataset Number: V03935313VT 0001
Coding: 00151A20D001028000001000
ROD: EV_DCU2DriveSideMAXHCONT_VW27.rod
VCID: 4DC4604E0D535D32E45-8018
Subsystem 1 - Part No SW: 5Q0 959 408 HW: 5Q0 959 164 Labels: 5QX-959-81X-V1.CLB
Component: FOND_FHSG_DRV 007 0010
Serial number: 00000000000036110727
Coding: 1D0000
Address 44: Steering Assist (J500) Labels:| 5Q0-909-144.clb
Part No SW: 5Q0 909 144 AB HW: 5Q0 909 144 AA
Component: EPS_MQB_ZFLS 131 1082
Dataset Number: V03935312TK 0001
Coding: 171F0000
Shop #: WSC 00020 999 12345
ROD: EV_SteerAssisMQB_015.rod
Address 4B: Multifunc. Module (J745) Labels:| 3Q0-907-338-V2.clb
Part No SW: 3Q0 907 338 E HW: 3Q0 907 338 E
Component: FCM MQB Low 003 0367
Serial number: 17111910522941 Dataset Number: V03935304ZR 0001
Coding: 000000070900204600000900000000000000000000000000000000000000
ASAM Dataset: EV_MultiModulContiVW48X 003003
ROD: EV_MultiModulContiVW48X_003.rod
VCID: 372822A69FCFC7E2AE9-8062
Address 52: Door Elect, Pass. (J387) Labels:| 5QX-959-X92-52.clb
Part No SW: 5Q4 959 592 K HW: 5Q4 959 592 K
Component: TSG BFS 007 0485
Serial number: 0000396858048 Dataset Number: V03935313WJ 0001
Coding: 00151020DC01028000001000
ROD: EV_DCU2PasseSideMAXHCONT_VW27.rod
VCID: 4CC26D4AF649543AF3B-8018
Subsystem 1 - Part No SW: 5Q0 959 407 HW: 5Q0 959 163 Labels: 5QX-959-81X-V1.CLB
Component: FOND_FHSG_PSG 007 0010
Serial number: 00000000000036011483
Coding: 050000
Address 5F: Information Electr. (J794) Labels:| 5G0-035-MIB-STD2.clb
Part No SW: 3Q0 035 864 C HW: 3Q0 035 864 C
Component: MU-S-N-ER 854 0879
Serial number: Dataset Number: 5G0CV1v____ 0001
Coding: 02720601BE0000004111000100080A201F0500F601200000C6
ROD: EV_MUStd4CDELP_VW27.rod
Display and control head 1 for information electronics:
Subsystem 1 - Part No SW: 5G6 919 605 B HW: 5G6 919 605 B
Component: ABT_Std-2_Nav 361 8214
Serial number: VWZ6ZHX1471458
Data carrier:
Subsystem 2 - Part No SW: 5NA 919 866 FH HW: -----------
Component: MRM2 2024/25 --- 2210
Address 65: Tire Pressure (J502) Labels: 3AA-907-273.clb
Part No SW: 5Q0 907 273 B HW: 5Q0 907 273
Component: RDKBERU30 H04 0009
Serial number: 30000000255241 Dataset Number: RDKS_TinyQ_ 1017
ROD: EV_RDKBERU30_005.rod
VCID: 343215AA8EB92CFA8BB-8060
Address 6D: Trunk Elect. (J605) Labels:| 5Q0-959-107.clb
Part No SW: 5Q0 959 107 T HW: 5Q0 959 107 C
Component: HDSG-Modul H12 0271
Revision: -------- Serial number: PLG01908160021 Dataset Number: V03935301SX 0001
Coding: 1C28
ASAM Dataset: EV_DeckLidCONTIAU736 001017
ROD: EV_DeckLidCONTIAU736_VW27.rod
VCID: 49CC545EF93B4112C8D-801C
Address 75: Telematics (J949) Labels:| 5QE-035-285.clb
Part No SW: 5NA 035 284 C HW: 5NA 035 284 C
Component: OCULowMQBLGE H19 0825
Revision: -------- Dataset Number: V03935298KU 0001
Coding: 02720601EA16380D3F1CBE000045400382E608
ASAM Dataset: EV_OCULowMQBLGE 004049
ROD: EV_OCULowMQBLGE_004_VW27.rod
VCID: 3D24308EBDF3EDB2745-8068
Address A5: Frt Sens. Drv. Assist (R242) Labels:| 3Q0-980-65X-A5.clb
Part No SW: 3Q0 980 654 L HW: 3Q0 980 654 A
Component: MQB_B_MFK H12 0610
Serial number: 15111915K10993 Dataset Number: V03935315JQ 0001
Coding: 000207060000040100021356C156890088000E20002000
ASAM Dataset: EV_MFKBoschMQBB 002041
ROD: EV_MFKBoschMQBB_002.rod
VCID: 40DA497ACA01805A1F3-8014
Address CA: Sunroof (J245) Labels:| 4M0-907-594.clb
Part No SW: 4K0 907 594 AC HW: 4K0 907 594
Component: SAD_STG_1 006 0002
Dataset Number: V03935280ME 0001
Coding: 508040727602
ASAM Dataset: EV_SunRoofCONTIAU736 009011
ROD: EV_SunRoofCONTIAU736_009_VW27.rod
VCID: 75B4E8AEC54375F27C5-8020
Address D6: Light Ctrl Left 2 (A31) Labels: 7P5-941-591.clb
Part No SW: 7P5 941 591 AH HW: 7P5 941 591 A
Component: LED1L H07 0009
ASAM Dataset: EV_LED_PLUS_L_KEBODAVW416 001003
ROD: EV_LED_PLUS_L_KEBODAVW416.rod
VCID: 025E8372848D524A497-8056
Address D7: Light Ctrl Right 2 (A27) Labels: 7P5-941-591.clb
Component: LED1R H07 0009
ASAM Dataset: EV_LED_PLUS_R_KEBODAVW416 001003
ROD: EV_LED_PLUS_R_KEBODAVW416_VW27.rod
End----(Elapsed Time: 01:43, VBatt start/end: 11.9V/11.9V. VIgn 11.9V)-----
My observations:
The new touch panel looks modern and adds premiumness to cabin. Touch buttons sensitivity is sharp and works well. The sensitivity of touch can be adjusted in adaptations. I rarely touch the climatronic unit once set at desired temperatures, so the new touch panel shouldn't be of distraction to me.
I also found few deficiencies in the new unit. The Max AC button is missing on the new unit, it is very useful in hot countries like mine to get instant full AC on the push of a button. Sync button is also missing, instead a clean air option is available. Sync is now available in the AC menu display of MIB, though I don't use it much ( EU version has sync instead of clean air) . Another bug I found was when you press Menu option in touch display, AC menu appears in MIB, and press menu again, AC menu doesn't close on MIB and goes back to the previous display. This wasn't the case with the old unit, I found it slightly annoying in the new unit.
Overall I am very satisfied with the results of all three retrofits.
Another beautiful, ambitious and challenging project is taking shape in the background with divine enlightenment from the top
