BCM Max Transporter 2013
zzm202000
Drives: Caravelle
Re: BCM Max Transporter 2013
Post by zzm202000 »
https://drive.google.com/file/d/1u0vIjk ... drive_link
This is the steering wheel I installed. Currently all buttons and DSG paddles are invalid.
zzm202000
Drives: Caravelle
Post by zzm202000 »
Shadow 109
I would like to ask if you have encountered any initial problems with this engine control computer?
I installed the cruise control switch and connected the circuit, but there was a problem of no initialization when turning on the ECU.
How should I solve the problem?
zzm202000
Drives: Caravelle
Post by zzm202000 »
Shadow 109
zzm202000 wrote: Wed Feb 12, 2025 1:28 am https://drive.google.com/file/d/1u0vIjk ... drive_link
I guess it doesn't make sense that someone has to ask you for permission to see the information in the link if you want to receive help... from other users.🤷‍♂️ (for some, time is gold)
As usually is said, Good luck! 👍😊
zzm202000
Drives: Caravelle
Post by zzm202000 »
Hi Ciclo
OK I will resend this image, this photo only shows the photo of my assembly!
Have you tried to code the buttons on that steering wheel? It's a subsystem of the BCM. What coding did you use?
You must post an autoscan. Host it on a server or in the free space offered by your email account and post the link here.
Direct posting of an autoscan on the forum requires having at least 10 posts on the forum.
It's not the same steering wheel as Shadow109, his is from a POLO 6C* --> T6 and yours seems to be from a Golf 7 or similar.
The CCS via the rocker buttons on the left stalk must be activated in the BCM and ECU, you should not have coding problems if you did the wiring installation correctly.
ECU coding must be, ing ON eng OFF.
Address 01: Engine (J623-CFCA) Labels:. 03L-906-022-CFC.clb
Part No SW: 03L 906 022 JD
(not knowing how to use a diagnostic tool has been and often is the real problem)🤷‍♂️
WSC? = YES
Image👌😄
I'm sure you and I will get along very well.
At first I thought it was a sheep...😅
zzm202000
Drives: Caravelle
Post by zzm202000 »
Hi Ciclo,
Can I send you a private message to ask some questions? I'm afraid I'm taking up too much space on this topic.
Or do you have communication software for other mobile phones?
zzm202000
Drives: Caravelle
Post by zzm202000 »
Hi Ciclo,
Can I PM you to ask some questions? I'm afraid I've taken up too much space on this topic.
It's a doll I found that looks very similar to my dog.
Maarten
Post by Maarten »
zzm202000 wrote: Fri Feb 14, 2025 6:52 am Hi Ciclo,
Ciclo usually want to discuss car related issues on forum.
That way the info is accessible to everyone :)
Everything I do here should be shared with everyone, it's the essence of a forum.
A couple more posts and you'll be able to PM anyone and post auto scans. You can also open a new thread (recommended) and use it as a personal space, so it's easier for anyone who wants to help you. It doesn't matter if you use this personal space temporarily, a little, a lot, if you delete it later or whatever you prefer.
Cute pet 😀 (thanks for sharing), one of my sisters has one just like it in white.
SKIBON
Drives: Rapid
Post by SKIBON »
Здравствуйте 🤝
Столкнулся с такой проблемой как параметрии с давлением колес . Я на прошлой неделе установил на свой автомобиль Škoda Rapid 2014 года выпуска . Мой блок BCM. PQ25. 6R0937087H . антенну 3AA 907 273F и датчики давления в шинах 3AA 907 275B. (Поставил везде где можно галочки в блоке 65 . Давление шин )
На прошлой неделе решил установить датчики давления и антенну, и через программное обеспечение зашел в программу «Вася диагност» и убедился сопрядились антенна с датчиками, они отображаются, система работает, но на приборной панели никаких данных почему то не видно.(((
Прошу Вас подсказать, что нужно сделать дальше: Возможно, требуется прошивка ? или параметрия . Если нужна прошивка, то куда именно её нужно прописывать в какой блок ?Прошу прощения я просто не силен в этом деле на счет прошивок . Но если разъяснить то я обязательно смогу по маленьком шагам сделать.
Буду благодарен за помощь
til3tsio
Drives: Seat Toledo KG
Post by til3tsio »
You need 7H0937090D or 7E0937090B etc...
You are not going to make it work with the 6R0 BCM.
All the information is already on the forum, but if you are not familiar with English you can try to search on drive2.ru
Shadow109
Drives: Vw t5.1 2013
Post by Shadow109 »
New sacn :-
Sunday,24,August,2025,20:05:39:22797
VCDS Version: 25.3.1.2  HEX-NET2 CB: 0.4671.5
Data version: 20250604 DS365.0
www.Ross-Tech.com
VIN: WV1ZZZ7HZDH036544   License Plate:
Chassis Type: 7H-VN75 (7E0)
Scan: 01 03 04 05 08 09 10 13 14 15 17 19 20 25 2B 3C 44 47 55 5F
          61 65 6C 6D A5 0B
VIN: WV1ZZZ7HZDH036544   Mileage: 387070km-240514miles
05-Acc/Start Auth. -- Status: OK 0000
14-Susp. Elect. -- Status: OK 0000
2B-Steer. Col. Lock -- Status: OK 0000
47-Sound System -- Status: Malfunction 0010
6D-Trunk Elect. -- Status: OK 0000
A5-Frt Sens. Drv. Assist -- Status: OK 0000
Address 01: Engine (J623-CAAC)       Labels:. 03L-906-022-CAA.clb
   Part No SW: 03L 906 019 GQ    HW: 03L 907 309 L
   Component: R4 2.0l TDI   H34 9977
   Revision: 22H34---    Serial number: 00000000000000 CVN: 29387363
   Coding: 01114012234401080000
   Shop #: WSC 43690 085 00000
   ASAM Dataset: EV_ECM20TDI01103L906019GQ 004006
   ROD: EV_ECM20TDI01103L906019FH_003.rod
   VCID: 80526D179A8613DA0F9-80D4
   VINID: 9E606AAAA1D8A946000C6144105E5FB8A3
Readiness: 0 0 0 0 1
Address 03: ABS Brakes (J104)       Labels: 7E0-907-37x-MK100ESC.clb
   Part No SW: 7E0 907 379 Q    HW: 7E0 907 379 N
   Component: ESC           H06 0133
   Revision: 00000000    Serial number: 62787000000113
   Coding: 307E4098256586840C7A027AA486612F38F555
   Shop #: WSC 02739 790 50316
   ASAM Dataset: EV_Brake1ESCCONTIVN75XGP2 011001
   ROD: EV_Brake1ESCCONTIVN75XGP2_011.rod
   VCID: C0D2AD17DA06D3DA4F9-8094
Address 05: Acc/Start Auth. (J518)       Labels:. User\5K0-959-434.clb
   Part No SW: 5K0 959 434 H    HW: 5K0 959 434
   Component: VWKESSYPQ35GP 093 1305
   Revision: 00093000    Serial number: 0467921560
   Coding: 032C1C
   Shop #: WSC 12345 123 12345
   ASAM Dataset: EV_KESSYPQ35G A02720
   ROD: N/A
   VCID: BA26DFFFBCDA890A01D-80EE
No ASAM data for: "EV_KESSYPQ35G" (VN75)
   Part No SW: 7E5 907 047 AK    HW: 7E5 907 047 AK
   Component: Climatic-T5   H11 0203
   Revision: 00001005
   Coding: 0000000002
   Shop #: WSC 02737 790 50316
   ROD: EV_ClimaT5Basis_VN75.rod
   VCID: F8A205F7C2565B1A379-80AC
   Revision: B9084001    Serial number: 2502 306190145
   Coding: 32F23D384EFF208281280F817EEB9FDDFF86660F608D79C073E4503F0860
   Shop #: WSC 12345 123 61029
   VCID: AD0CE4A37D142EB294F-80F8
   Subsystem 1 - Part No: 5K7 955 559 B  Labels: 5K7-955-559.CLB
   Component: RLS 230916 03  37  0059
   Coding: 0228EE
   Subsystem 2 - Part No SW: 7E0 959 801     HW: 7E0 959 801   Labels: 7E0-959-80X-V1.CLB
   Component: J386__TSG_FT  002 3313
   Subsystem 3 - Part No SW: 7E0 959 802     HW: 7E0 959 802   Labels: 7E0-959-80X-V1.CLB
   Component: J387__TSG_BT  002 3313
   Subsystem 4 - Part No: 1K0 951 605 F
   Component: LIN BACKUP HO  H01 0009
   Subsystem 5 - Part No SW: 7E0 959 442 A    HW: 7E0 959 442 A
   Component: E221__MFL-DC1  H02 0103
   Serial number: 39180000000570018056
   Coding: B4FFFF
Address 10: Park/Steer Assist (J446)       Labels:| 5Q0-919-294.clb
   Part No SW: 1K8 919 472 C    HW: 5Q0 919 294 A
   Component: PARKHILFE 8K  H03 0480
   Revision: --------    Serial number: 39331817601496
   Coding: 0041155041
   Shop #: WSC 21890 003 104857
   ASAM Dataset: EV_EPHVA18VW364GP00 001007
   ROD: EV_EPHVA18VW364GP00_VW32.rod
   VCID: B720C6CB8FC89462FE3-80E2
1 Fault Found:
12718592 - Databus
          U1121 00 [00001001] - Missing Message
          [Steuergerät für Lenksäulenelektronik-J527/BCM - mZAS_1 - kein Signal/keine Kommunikation]
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 17
                    Mileage: 387079 km
                    Date: 2025.08.24.
                    Time: 04:21:05
Address 13: Auto Dist. Reg (J428)       Labels:| 7N0-907-572.clb
   Part No SW: 7N0 907 572 C    HW: 7E0 907 572
   Component: ACC Bosch PQx H03 0211
   Serial number: 1909180453A6EF Dataset Number: ACC_MRRevo1 0001
   Coding: 00004000FE0779
   Shop #: WSC 01383 790 50316
   ASAM Dataset: EV_ACCBEGVW361 001006
   ROD: EV_ACCBEGVW361.rod
   VCID: B63ECBCF88C26D6AE55-80E2
Address 14: Susp. Elect. (J250)       Labels:. 3C0-907-376.clb
   Part No SW: 3C0 907 376 A    HW: 3C0 907 376
   Component: DAEMPFUNGS-SG H07 0071
   Revision: 00000000    Serial number: 12030906320002
   Coding: 030180
   Shop #: WSC 00046 000 00000
   VCID: A700168B5FE804E26E3-80F2
   Part No SW: 7E0 959 655 D    HW: 7E0 959 655 D
   Component: VW10Airbag00G 008 0016
   Revision: --------    Serial number: 003PH0013MB$ Dataset Number: 7E0003V____ 0735
   Coding: 000000000000000000000000000000003047
   Shop #: WSC 02734 790 50316
   ASAM Dataset: EV_AirbaVW10BPAVW12X 001028
   ROD: EV_AirbaVW10BPAVN750.rod
   Part No SW: 7E0 920 980 S    HW: 7E0 920 980 S
   Component: KOMBI         H04 1109
   Coding: 140E230B00
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A05733
   ROD: EV_Kombi_UDS_VDD_RM09_005_VW32.rod
   VCID: BB28DAFBB3E0B0021AB-80EE
   Revision: B9084001
   Coding: 04220F
   VCID: E88255B79276CB9AA79-80BC
   Revision: AA001001
   Coding: 010100E200000100000000
   ROD: EV_HighBeamAssisAU316_VW32.rod
   VCID: AE0EE3AF709255AAAD5-80FA
   Component: IMMO          H04 1109
   Serial number:
   Coding: 000007
   ROD: EV_Immo_UDS_VDD_RM09_VW32.rod
   VCID: EA862FBF8CFAF98AB1D-80BE
Address 2B: Steer. Col. Lock (J764)       Labels:* 5K0-905-861.clb
   Part No SW: 5K0 905 861 C    HW: 5K0 905 861 C
   Component: ELV-PQ35      H21 0240
   Revision: 00000000    Serial number: 14000305204001
   Coding: 4100000000000000
   Shop #: WSC 00066 790 50316
   ASAM Dataset: EV_ELVMarquMPVW36X A01001
   ROD: EV_ELVMarquMPVW36X_VW32.rod
   VCID: B032FDD76AA6435ABF9-80E4
Address 3C: Lane Change (J1086)       Labels: Redir Fail!
   Part No SW: 2Q0 907 686 B    HW: 2Q0 907 686 B
   Component: HRE3_Kl15_Mst H06 0150
   Serial number: 14520003983159  Dataset Number: V03935303MB 0001
   Coding: 529524A0
   ROD: N/A
   VCID: B924C0F3B9DC8212087-80EC
   Subsystem 1 - Part No SW: 2Q0 907 685 B    HW: 2Q0 907 685 B
   Component: HRE3_Kl15_Slv  H06 0150
   Serial number: 14520003959660
No ASAM data for: "EV_HREntryHellaGen3Kl15" (VN75)
Address 44: Steering Assist (J792)       Labels:| 2Qx-909-144-V2.clb
   Part No SW: 2Q1 909 144 T    HW: 2Q1 909 144 F
   Component: TRW_G4L_MQBA0 611 6213
   Serial number: 01478032CP3L073
   Coding: 000000000100000000000200010001000000010001
   ASAM Dataset: EV_SteerAssisZFGen1PQ12PA 002002
   ROD: EV_SteerAssisZFGen1PQ12PA.rod
   VCID: C3D8A21BCB10C8C252B-8096
Address 47: Sound System (R184)       Labels: 5K0-035-456.clb
   Part No SW: 3AA 035 466 B    HW: 3AA 035 466
   Component: KonzernAmp12K H03 6951
   Revision: --------    Serial number: A1108A00007925 Dataset Number: V03935268UE 0001
   ASAM Dataset: EV_AudioVerst12KanalSTT3 001001
   ROD: EV_AudioVerst12KanalSTT3.rod
   VCID: AF30FEAB77985CA2A63-80FA
3 Faults Found:
9463315 - Rear Left Treble Speaker
          B1066 13 [00001001] - Open Circuit
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 17
                    Mileage: 387079 km
                    Date: 2025.08.24.
                    Time: 04:21:06
9463827 - Rear Right Treble Speaker
          B1068 13 [00001001] - Open Circuit
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 17
                    Mileage: 387079 km
                    Date: 2025.08.24.
                    Time: 04:21:06
9464083 - Center speaker
          B1069 13 [00001001] - Open Circuit
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 17
                    Mileage: 387079 km
                    Date: 2025.08.24.
                    Time: 04:21:06
   Part No SW: 6R0 907 357 C    HW: 6R0 907 357 B
   Component: AFS-ECU       005 0050
   Revision: --------    Serial number: -------------- Dataset Number: V03600097E0 0001
   Coding: 0FC6020001000000
   Shop #: WSC 02748 790 50316
   ROD: EV_HeadlRegulVWLWRCC_VW46.rod
   Component: MU-S--ER      H41 0480
   Serial number: VWZAZ2U1668085 Dataset Number: V00000000VW 0001
   Coding: 0645000FBE00000011110006010908001F0103C401200100CE
   Shop #: WSC 00046 123 12345
   ROD: EV_MUStd4CTSAT_VW32.rod
   VCID: A51C1C83256416F25CF-80F0
1 Fault Found:
1543 - Control Module Incorrectly Coded
          U1014 00 [00001001] - -
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 17
                    Mileage: 387079 km
                    Date: 2025.08.24.
                    Time: 04:21:04
                    Voltage terminal 30: 12.0 V
                    Byte_Coding_Condition-byte_0_condition: ERROR
                    Byte_Coding_Condition-byte_1_condition: OK
                    Byte_Coding_Condition-byte_10_condition: ERROR
                    Byte_Coding_Condition-byte_11_condition: ERROR
                    Byte_Coding_Condition-byte_12_condition: ERROR
                    Byte_Coding_Condition-byte_13_condition: ERROR
                    Byte_Coding_Condition-byte_14_condition: ERROR
                    Byte_Coding_Condition-byte_15_condition: ERROR
                    Byte_Coding_Condition-byte_16_condition: ERROR
                    Byte_Coding_Condition-byte_17_condition: ERROR
                    Byte_Coding_Condition-byte_18_condition: ERROR
                    Byte_Coding_Condition-byte_19_condition: ERROR
                    Byte_Coding_Condition-byte_2_condition: OK
                    Byte_Coding_Condition-byte_20_condition: ERROR
                    Byte_Coding_Condition-byte_21_condition: ERROR
                    Byte_Coding_Condition-byte_22_condition: ERROR
                    Byte_Coding_Condition-byte_23_condition: ERROR
                    Byte_Coding_Condition-byte_24_condition: ERROR
                    Byte_Coding_Condition-byte_25_condition: ERROR
                    Byte_Coding_Condition-byte_26_condition: ERROR
                    Byte_Coding_Condition-byte_27_condition: ERROR
                    Byte_Coding_Condition-byte_3_condition: ERROR
                    Byte_Coding_Condition-byte_4_condition: OK
                    Byte_Coding_Condition-byte_5_condition: OK
                    Byte_Coding_Condition-byte_6_condition: OK
                    Byte_Coding_Condition-byte_7_condition: OK
                    Byte_Coding_Condition-byte_8_condition: OK
                    Byte_Coding_Condition-byte_9_condition: OK
   Part No SW: 7E0 907 534     HW: 7E0 937 090 E
   Component: Batt.regelung H84 0772
   Coding: 330B1A73
   Subsystem 1 - Part No SW: 7E0 915 181 G    HW: 7E0 915 181 G
   Component: J367-BDM  H08 0223
   Serial number: 62309D31111261021812
   Serial number: 30000000047437
   ROD: EV_RDKBERU30_005.rod
Address 6C: Back-up Cam. (J772)       Labels:| 5Q0-980-556.clb
   Part No SW: 5Q0 980 556 B    HW: 5Q0 980 556 B
   Component: RVC Compact   H18 0231
   Dataset Number: V03935257YE 0001
   Coding: 047300010600041F000040
   ASAM Dataset: EV_CamSysRVRVCPANAMQBAB 006009
   ROD: EV_CamSysRVRVCPANAMQBAB.rod
1 Fault Found:
10489856 - No Basic Setting
          B2010 00 [00001001] - -
          [RearView system not calibrated]
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 250
                    Mileage: 150182 km
                    Date: 2024.01.14
                    Time: 14:07:40
                    passive
Address 6D: Trunk Elect. (J605)       Labels:| 7N0-959-107.clb
   Part No SW: 7E0 959 107 A    HW: 7E0 959 107
   Component: HDSG-Modul    H02 0653
   Revision: 31002001    Serial number: 307702205 Dataset Number: 7E0959107A  D109
   Coding: 1973018002
   ASAM Dataset: EV_HDSGVN46T 203001
   ROD: EV_HDSGVN46T.rod
   VCID: AC0AE9A7468E27BA831-80F8
Address A5: Frt Sens. Drv. Assist (R242)       Labels:| 3Q0-980-65X-A5.clb
   Part No SW: 3Q0 980 654 P    HW: 3Q0 980 654 A
   Component: MQB_B_MFK     H14 0821
   Serial number: 04112012P13717 Dataset Number: A00000000DP 0001
   Coding: 000207010000040101221256C1D30500DB000E10002000
   Shop #: WSC 31414 137 00001
   ASAM Dataset: EV_MFKBoschMQBB 002041
   ROD: EV_MFKBoschMQBB_002.rod
   VCID: C4DAA107CE1ECFFA6B1-8090
End----------(Elapsed Time: 02:13, VBatt start/end: 12.0V/12.0V)-----------
------------------------------6 Faults Found-------------------------------
I have removed CP fault in 5f and other several faults but I am stuck with one last fault
