BCM Max Transporter 2013
Re: BCM Max Transporter 2013
https://drive.google.com/file/d/1u0vIjk ... drive_link
This is the steering wheel I installed. Currently all buttons and DSG paddles are invalid.
Shadow 109
I would like to ask if you have encountered any initial problems with this engine control computer?
I installed the cruise control switch and connected the circuit, but there was a problem of no initialization when turning on the ECU.
How should I solve the problem?
Shadow 109
I guess it doesn't make sense that someone has to ask you for permission to see the information in the link if you want to receive help... from other users.zzm202000 wrote: Wed Feb 12, 2025 1:28 am https://drive.google.com/file/d/1u0vIjk ... drive_link
As usually is said, Good luck!
Hi Ciclo
OK I will resend this image, this photo only shows the photo of my assembly!
- IMG_0013.jpg (295.56 KiB) Viewed 8164 times
Have you tried to code the buttons on that steering wheel? It's a subsystem of the BCM. What coding did you use?
You must post an autoscan. Host it on a server or in the free space offered by your email account and post the link here.
Direct posting of an autoscan on the forum requires having at least 10 posts on the forum.
It's not the same steering wheel as Shadow109, his is from a POLO 6C* --> T6 and yours seems to be from a Golf 7 or similar.
The CCS via the rocker buttons on the left stalk must be activated in the BCM and ECU, you should not have coding problems if you did the wiring installation correctly.
ECU coding must be, ing ON eng OFF.
Address 01: Engine (J623-CFCA) Labels:. 03L-906-022-CFC.clb
Part No SW: 03L 906 022 JD
(not knowing how to use a diagnostic tool has been and often is the real problem)
WSC? = YES
WSC? = YES
I'm sure you and I will get along very well.
At first I thought it was a sheep...
Hi Ciclo,
Can I send you a private message to ask some questions? I'm afraid I'm taking up too much space on this topic.
Or do you have communication software for other mobile phones?
Hi Ciclo,
Can I PM you to ask some questions? I'm afraid I've taken up too much space on this topic.
It's a doll I found that looks very similar to my dog.
- Maarten
Ciclo usually want to discuss car related issues on forum.zzm202000 wrote: Fri Feb 14, 2025 6:52 am Hi Ciclo,
That way the info is accessible to everyone
Everything I do here should be shared with everyone, it's the essence of a forum.
A couple more posts and you'll be able to PM anyone and post auto scans. You can also open a new thread (recommended) and use it as a personal space, so it's easier for anyone who wants to help you. It doesn't matter if you use this personal space temporarily, a little, a lot, if you delete it later or whatever you prefer.
Cute pet
(thanks for sharing), one of my sisters has one just like it in white.
Cute pet
Здравствуйте
Столкнулся с такой проблемой как параметрии с давлением колес . Я на прошлой неделе установил на свой автомобиль Škoda Rapid 2014 года выпуска . Мой блок BCM. PQ25. 6R0937087H . антенну 3AA 907 273F и датчики давления в шинах 3AA 907 275B. (Поставил везде где можно галочки в блоке 65 . Давление шин )
На прошлой неделе решил установить датчики давления и антенну, и через программное обеспечение зашел в программу «Вася диагност» и убедился сопрядились антенна с датчиками, они отображаются, система работает, но на приборной панели никаких данных почему то не видно.(((
Прошу Вас подсказать, что нужно сделать дальше: Возможно, требуется прошивка ? или параметрия . Если нужна прошивка, то куда именно её нужно прописывать в какой блок ?Прошу прощения я просто не силен в этом деле на счет прошивок . Но если разъяснить то я обязательно смогу по маленьком шагам сделать.
Буду благодарен за помощь
- til3tsio
- Drives: Seat Toledo KG
You need 7H0937090D or 7E0937090B etc...
You are not going to make it work with the 6R0 BCM.
All the information is already on the forum, but if you are not familiar with English you can try to search on drive2.ru
- Shadow109
- Drives: Vw t5.1 2013
New sacn :-
I have removed CP fault in 5f and other several faults but I am stuck with one last fault
Sunday,24,August,2025,20:05:39:22797
VCDS Version: 25.3.1.2 HEX-NET2 CB: 0.4671.5
Data version: 20250604 DS365.0
www.Ross-Tech.com
VIN: WV1ZZZ7HZDH036544 License Plate:
Chassis Type: 7H-VN75 (7E0)
Scan: 01 03 04 05 08 09 10 13 14 15 17 19 20 25 2B 3C 44 47 55 5F
61 65 6C 6D A5 0B
VIN: WV1ZZZ7HZDH036544 Mileage: 387070km-240514miles
05-Acc/Start Auth. -- Status: OK 0000
14-Susp. Elect. -- Status: OK 0000
2B-Steer. Col. Lock -- Status: OK 0000
47-Sound System -- Status: Malfunction 0010
6D-Trunk Elect. -- Status: OK 0000
A5-Frt Sens. Drv. Assist -- Status: OK 0000
Address 01: Engine (J623-CAAC) Labels:. 03L-906-022-CAA.clb
Part No SW: 03L 906 019 GQ HW: 03L 907 309 L
Component: R4 2.0l TDI H34 9977
Revision: 22H34--- Serial number: 00000000000000 CVN: 29387363
Coding: 01114012234401080000
Shop #: WSC 43690 085 00000
ASAM Dataset: EV_ECM20TDI01103L906019GQ 004006
ROD: EV_ECM20TDI01103L906019FH_003.rod
VCID: 80526D179A8613DA0F9-80D4
VINID: 9E606AAAA1D8A946000C6144105E5FB8A3
Readiness: 0 0 0 0 1
Address 03: ABS Brakes (J104) Labels: 7E0-907-37x-MK100ESC.clb
Part No SW: 7E0 907 379 Q HW: 7E0 907 379 N
Component: ESC H06 0133
Revision: 00000000 Serial number: 62787000000113
Coding: 307E4098256586840C7A027AA486612F38F555
Shop #: WSC 02739 790 50316
ASAM Dataset: EV_Brake1ESCCONTIVN75XGP2 011001
ROD: EV_Brake1ESCCONTIVN75XGP2_011.rod
VCID: C0D2AD17DA06D3DA4F9-8094
Address 05: Acc/Start Auth. (J518) Labels:. User\5K0-959-434.clb
Part No SW: 5K0 959 434 H HW: 5K0 959 434
Component: VWKESSYPQ35GP 093 1305
Revision: 00093000 Serial number: 0467921560
Coding: 032C1C
Shop #: WSC 12345 123 12345
ASAM Dataset: EV_KESSYPQ35G A02720
ROD: N/A
VCID: BA26DFFFBCDA890A01D-80EE
No ASAM data for: "EV_KESSYPQ35G" (VN75)
Address 08: Auto HVAC (J301) Labels:| 7E5-907-047.clb
Part No SW: 7E5 907 047 AK HW: 7E5 907 047 AK
Component: Climatic-T5 H11 0203
Revision: 00001005
Coding: 0000000002
Shop #: WSC 02737 790 50316
ROD: EV_ClimaT5Basis_VN75.rod
VCID: F8A205F7C2565B1A379-80AC
Part No SW: 7E0 937 090 E HW: 7E0 937 090 E
Revision: B9084001 Serial number: 2502 306190145
Coding: 32F23D384EFF208281280F817EEB9FDDFF86660F608D79C073E4503F0860
Shop #: WSC 12345 123 61029
VCID: AD0CE4A37D142EB294F-80F8
Subsystem 1 - Part No: 5K7 955 559 B Labels: 5K7-955-559.CLB
Component: RLS 230916 03 37 0059
Coding: 0228EE
Subsystem 2 - Part No SW: 7E0 959 801 HW: 7E0 959 801 Labels: 7E0-959-80X-V1.CLB
Component: J386__TSG_FT 002 3313
Subsystem 3 - Part No SW: 7E0 959 802 HW: 7E0 959 802 Labels: 7E0-959-80X-V1.CLB
Component: J387__TSG_BT 002 3313
Subsystem 4 - Part No: 1K0 951 605 F
Component: LIN BACKUP HO H01 0009
Subsystem 5 - Part No SW: 7E0 959 442 A HW: 7E0 959 442 A
Component: E221__MFL-DC1 H02 0103
Serial number: 39180000000570018056
Coding: B4FFFF
Address 10: Park/Steer Assist (J446) Labels:| 5Q0-919-294.clb
Part No SW: 1K8 919 472 C HW: 5Q0 919 294 A
Component: PARKHILFE 8K H03 0480
Revision: -------- Serial number: 39331817601496
Coding: 0041155041
Shop #: WSC 21890 003 104857
ASAM Dataset: EV_EPHVA18VW364GP00 001007
ROD: EV_EPHVA18VW364GP00_VW32.rod
VCID: B720C6CB8FC89462FE3-80E2
1 Fault Found:
12718592 - Databus
U1121 00 [00001001] - Missing Message
[Steuergerät für Lenksäulenelektronik-J527/BCM - mZAS_1 - kein Signal/keine Kommunikation]
Fault Priority: 6
Fault Frequency: 1
Reset counter: 17
Mileage: 387079 km
Date: 2025.08.24.
Time: 04:21:05
Address 13: Auto Dist. Reg (J428) Labels:| 7N0-907-572.clb
Part No SW: 7N0 907 572 C HW: 7E0 907 572
Component: ACC Bosch PQx H03 0211
Serial number: 1909180453A6EF Dataset Number: ACC_MRRevo1 0001
Coding: 00004000FE0779
Shop #: WSC 01383 790 50316
ASAM Dataset: EV_ACCBEGVW361 001006
ROD: EV_ACCBEGVW361.rod
VCID: B63ECBCF88C26D6AE55-80E2
Address 14: Susp. Elect. (J250) Labels:. 3C0-907-376.clb
Part No SW: 3C0 907 376 A HW: 3C0 907 376
Component: DAEMPFUNGS-SG H07 0071
Revision: 00000000 Serial number: 12030906320002
Coding: 030180
Shop #: WSC 00046 000 00000
VCID: A700168B5FE804E26E3-80F2
Part No SW: 7E0 959 655 D HW: 7E0 959 655 D
Component: VW10Airbag00G 008 0016
Revision: -------- Serial number: 003PH0013MB$ Dataset Number: 7E0003V____ 0735
Coding: 000000000000000000000000000000003047
Shop #: WSC 02734 790 50316
ASAM Dataset: EV_AirbaVW10BPAVW12X 001028
ROD: EV_AirbaVW10BPAVN750.rod
Part No SW: 7E0 920 980 S HW: 7E0 920 980 S
Component: KOMBI H04 1109
Coding: 140E230B00
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A05733
ROD: EV_Kombi_UDS_VDD_RM09_005_VW32.rod
VCID: BB28DAFBB3E0B0021AB-80EE
Part No SW: 7E0 909 901 HW: 7E0 937 090 E
Revision: B9084001
Coding: 04220F
VCID: E88255B79276CB9AA79-80BC
Address 20: High Beam Assist. (J844) Labels:| 8S0-857-511.clb
Part No SW: 7E0 857 511 G HW: 7E0 857 511 E
Component: FLA H10 0003
Revision: AA001001
Coding: 010100E200000100000000
ROD: EV_HighBeamAssisAU316_VW32.rod
VCID: AE0EE3AF709255AAAD5-80FA
Component: IMMO H04 1109
Serial number:
Coding: 000007
ROD: EV_Immo_UDS_VDD_RM09_VW32.rod
VCID: EA862FBF8CFAF98AB1D-80BE
Address 2B: Steer. Col. Lock (J764) Labels:* 5K0-905-861.clb
Part No SW: 5K0 905 861 C HW: 5K0 905 861 C
Component: ELV-PQ35 H21 0240
Revision: 00000000 Serial number: 14000305204001
Coding: 4100000000000000
Shop #: WSC 00066 790 50316
ASAM Dataset: EV_ELVMarquMPVW36X A01001
ROD: EV_ELVMarquMPVW36X_VW32.rod
VCID: B032FDD76AA6435ABF9-80E4
Address 3C: Lane Change (J1086) Labels: Redir Fail!
Part No SW: 2Q0 907 686 B HW: 2Q0 907 686 B
Component: HRE3_Kl15_Mst H06 0150
Serial number: 14520003983159 Dataset Number: V03935303MB 0001
Coding: 529524A0
ROD: N/A
VCID: B924C0F3B9DC8212087-80EC
Subsystem 1 - Part No SW: 2Q0 907 685 B HW: 2Q0 907 685 B
Component: HRE3_Kl15_Slv H06 0150
Serial number: 14520003959660
No ASAM data for: "EV_HREntryHellaGen3Kl15" (VN75)
Address 44: Steering Assist (J792) Labels:| 2Qx-909-144-V2.clb
Part No SW: 2Q1 909 144 T HW: 2Q1 909 144 F
Component: TRW_G4L_MQBA0 611 6213
Serial number: 01478032CP3L073
Coding: 000000000100000000000200010001000000010001
ASAM Dataset: EV_SteerAssisZFGen1PQ12PA 002002
ROD: EV_SteerAssisZFGen1PQ12PA.rod
VCID: C3D8A21BCB10C8C252B-8096
Address 47: Sound System (R184) Labels: 5K0-035-456.clb
Part No SW: 3AA 035 466 B HW: 3AA 035 466
Component: KonzernAmp12K H03 6951
Revision: -------- Serial number: A1108A00007925 Dataset Number: V03935268UE 0001
ASAM Dataset: EV_AudioVerst12KanalSTT3 001001
ROD: EV_AudioVerst12KanalSTT3.rod
VCID: AF30FEAB77985CA2A63-80FA
3 Faults Found:
9463315 - Rear Left Treble Speaker
B1066 13 [00001001] - Open Circuit
Fault Priority: 5
Fault Frequency: 1
Reset counter: 17
Mileage: 387079 km
Date: 2025.08.24.
Time: 04:21:06
9463827 - Rear Right Treble Speaker
B1068 13 [00001001] - Open Circuit
Fault Priority: 5
Fault Frequency: 1
Reset counter: 17
Mileage: 387079 km
Date: 2025.08.24.
Time: 04:21:06
9464083 - Center speaker
B1069 13 [00001001] - Open Circuit
Fault Priority: 4
Fault Frequency: 1
Reset counter: 17
Mileage: 387079 km
Date: 2025.08.24.
Time: 04:21:06
Address 55: Headlight Range (J431) Labels:. 6R0-907-357.clb
Part No SW: 6R0 907 357 C HW: 6R0 907 357 B
Component: AFS-ECU 005 0050
Revision: -------- Serial number: -------------- Dataset Number: V03600097E0 0001
Coding: 0FC6020001000000
Shop #: WSC 02748 790 50316
ROD: EV_HeadlRegulVWLWRCC_VW46.rod
Address 5F: Information Electr. (J794) Labels:| 5G0-035-MIB-STD2.clb
Part No SW: 5C0 035 680 G HW: 5C0 035 680 G
Component: MU-S--ER H41 0480
Serial number: VWZAZ2U1668085 Dataset Number: V00000000VW 0001
Coding: 0645000FBE00000011110006010908001F0103C401200100CE
Shop #: WSC 00046 123 12345
ROD: EV_MUStd4CTSAT_VW32.rod
VCID: A51C1C83256416F25CF-80F0
1 Fault Found:
1543 - Control Module Incorrectly Coded
U1014 00 [00001001] - -
Fault Priority: 4
Fault Frequency: 1
Reset counter: 17
Mileage: 387079 km
Date: 2025.08.24.
Time: 04:21:04
Voltage terminal 30: 12.0 V
Byte_Coding_Condition-byte_0_condition: ERROR
Byte_Coding_Condition-byte_1_condition: OK
Byte_Coding_Condition-byte_10_condition: ERROR
Byte_Coding_Condition-byte_11_condition: ERROR
Byte_Coding_Condition-byte_12_condition: ERROR
Byte_Coding_Condition-byte_13_condition: ERROR
Byte_Coding_Condition-byte_14_condition: ERROR
Byte_Coding_Condition-byte_15_condition: ERROR
Byte_Coding_Condition-byte_16_condition: ERROR
Byte_Coding_Condition-byte_17_condition: ERROR
Byte_Coding_Condition-byte_18_condition: ERROR
Byte_Coding_Condition-byte_19_condition: ERROR
Byte_Coding_Condition-byte_2_condition: OK
Byte_Coding_Condition-byte_20_condition: ERROR
Byte_Coding_Condition-byte_21_condition: ERROR
Byte_Coding_Condition-byte_22_condition: ERROR
Byte_Coding_Condition-byte_23_condition: ERROR
Byte_Coding_Condition-byte_24_condition: ERROR
Byte_Coding_Condition-byte_25_condition: ERROR
Byte_Coding_Condition-byte_26_condition: ERROR
Byte_Coding_Condition-byte_27_condition: ERROR
Byte_Coding_Condition-byte_3_condition: ERROR
Byte_Coding_Condition-byte_4_condition: OK
Byte_Coding_Condition-byte_5_condition: OK
Byte_Coding_Condition-byte_6_condition: OK
Byte_Coding_Condition-byte_7_condition: OK
Byte_Coding_Condition-byte_8_condition: OK
Byte_Coding_Condition-byte_9_condition: OK
Address 61: Battery Regul. (J840) Labels:. 1K0-907-534.clb
Part No SW: 7E0 907 534 HW: 7E0 937 090 E
Component: Batt.regelung H84 0772
Coding: 330B1A73
Subsystem 1 - Part No SW: 7E0 915 181 G HW: 7E0 915 181 G
Component: J367-BDM H08 0223
Serial number: 62309D31111261021812
Address 65: Tire Pressure (J502) Labels: 3AA-907-273.clb
Part No SW: 3AA 907 273 F HW: 5Q0 907 273
Component: RDKBERU30 H04 0011
Serial number: 30000000047437
ROD: EV_RDKBERU30_005.rod
Address 6C: Back-up Cam. (J772) Labels:| 5Q0-980-556.clb
Part No SW: 5Q0 980 556 B HW: 5Q0 980 556 B
Component: RVC Compact H18 0231
Dataset Number: V03935257YE 0001
Coding: 047300010600041F000040
ASAM Dataset: EV_CamSysRVRVCPANAMQBAB 006009
ROD: EV_CamSysRVRVCPANAMQBAB.rod
1 Fault Found:
10489856 - No Basic Setting
B2010 00 [00001001] - -
[RearView system not calibrated]
Fault Priority: 5
Fault Frequency: 1
Reset counter: 250
Mileage: 150182 km
Date: 2024.01.14
Time: 14:07:40
passive
Address 6D: Trunk Elect. (J605) Labels:| 7N0-959-107.clb
Part No SW: 7E0 959 107 A HW: 7E0 959 107
Component: HDSG-Modul H02 0653
Revision: 31002001 Serial number: 307702205 Dataset Number: 7E0959107A D109
Coding: 1973018002
ASAM Dataset: EV_HDSGVN46T 203001
ROD: EV_HDSGVN46T.rod
VCID: AC0AE9A7468E27BA831-80F8
Address A5: Frt Sens. Drv. Assist (R242) Labels:| 3Q0-980-65X-A5.clb
Part No SW: 3Q0 980 654 P HW: 3Q0 980 654 A
Component: MQB_B_MFK H14 0821
Serial number: 04112012P13717 Dataset Number: A00000000DP 0001
Coding: 000207010000040101221256C1D30500DB000E10002000
Shop #: WSC 31414 137 00001
ASAM Dataset: EV_MFKBoschMQBB 002041
ROD: EV_MFKBoschMQBB_002.rod
VCID: C4DAA107CE1ECFFA6B1-8090
End----------(Elapsed Time: 02:13, VBatt start/end: 12.0V/12.0V)-----------
------------------------------6 Faults Found-------------------------------
