Re: ciclo's Polo. R-line 1.2 TSI 90hp 119gr.🤝
Small task. Factory 140A Alternator Conversion
Previously (READ): :arrow: viewtopic.php?p=610290#p610290
Replacement of the voltage regulator for PWM and DF signals with a voltage regulator for the LIN signal.
ℹ- I haven't tested it, but it should work perfectly. I'm keeping it in the garage storage room in case I need it in the future.🤗
Some notes before replacing the brakes, brake fluid and rear shock absorbers.
Previously: :arrow: viewtopic.php?p=610353#p610353
Use the right lubricants in the right places. The misuse of lubricating greases in modern brake systems is widespread.🤦‍♂️ There are even places where lubricating greases should not be used.
Don't overuse lubricating greases, more isn't better. the layer should be thin, 'TRANSPARENT', not like you're spreading butter on toast.😄
Read installation manuals to learn about the big mistakes you're making... workshops, etc.
Example of brake fluid bleeding/replacement in our Golf with one-way valve.💎
The key is to prevent air from entering the system and not to use those rubber couplings (expensive or cheap) that attach to the bleeder valve, or by opening the bleeder valve too much.
POLO 6R. 1JS rear shock absorbers and rear discs and pads installed.
- According to erWin. Torques, etc...
Highlights.
Related :arrow: https://www.youtube.com/watch?v=Md8MhKuA3-w :arrow: viewtopic.php?p=603171#p603171
PTFE (Teflon) and Silicone Lubricants.
The factory 1JP shock absorbers showed their age. They were still functional and capable of reaching their full travel when compressed, but they were too easy to compress.
Regarding the rear brakes, nothing to add, it's an overdone, recurring topic on YouTube/internet.
The old parts went to the recycling point. During the drive, I did some gentle braking to allow the new pads and discs to bed in.
At the recycling point, I noticed that the UV coating on the Brembo discs looks very nice.
https://www.youtube.com/watch?v=FfnVHF1gdBo
POLO 6R. Front brake pads and discs installed.
A good video tutorial: :arrow: https://www.youtube.com/watch?v=TQKMp6AQJYg
Note:
Before pressing the piston back into the cylinder with a piston resetting tool (e.g, prying with screwdriver), draw off brake fluid from the brake fluid reservoir. Otherwise, especially if the reservoir has been topped up, fluid will overflow and cause damage.
I had to remove 60 ml of brake fluid because the brake fluid was changed and set to max level at a VW dealership years ago when the brake pads were only half worn.
I'll be replacing the brake fluid in a few days...
Installation. Highlights.
Caution! New ATE brake discs have a protective coating that must be worn down by the pads during the first few kilometers. Once this coating is worn down, braking performance will improve. The new ATE ceramic brake pads then leave a transfer layer on the disc for proper operation.
I took the used parts to the recycling point, but this time I did a longer test drive to properly bed in the front and rear brake pads and discs, transfer layers, etc. Naturally, the improvement is total in terms of braking, and especially in the new behavior of the rear shock absorbers. Now, cornering in roundabouts and tight turns feels like a brand new car. The handling is also excellent in normal or sporty driving on any type of road, without sacrificing comfort.😎
On one of the next summer days I will be replacing the brake and clutch fluid to complete the unscheduled tasks.😊
Happy weekend to everyone... without exception!
https://www.youtube.com/watch?v=wKo251x4pzE
Some additional notes before replacing the hydraulic brake and clutch fluid.
Is your bleeding system (pumps, VAS) capable of not contaminating the new DOT4 hydraulic fluid after doing a couple of bleeds?😄
approx... +/- 0.5mm
I prefer not to take the risk with a 14-year-old piece of plastic and have the vehicle become immobilized in the middle of nowhere.
Trying to avoid inaccuracies in brittle plastic nut/bolt/bleeder subjected to 14 years of constant thermal changes.🤔
The brake fluid will be extracted/replaced by pressure/pumping using the one-way valve method, and the clutch slave cylinder fluid will be extracted/replaced using a vacuum system.
I leave you here a video that shows how to bleed the clutch in less than 10 seconds. Quick & Easy Method Explained!
:arrow: https://www.youtube.com/watch?v=DINu_uOrr5E
I would choose the optional part, cleaning is essential, as well as the final test.🤭
https://www.youtube.com/watch?v=RDsTeEiFFp4
POLO 6R. Brake fluid replacement/bleed.
No comment.
Question for VOLKSWAGEN:
How old do you think this brake fluid is?
Possible scenarios:
- The brake fluid was contaminated by the VAS pressure testing machine at the VW dealership where I ordered and paid for the replacement.
- The brake fluid used by the VW dealership is not the recommended type.
- They didn't change the brake fluid but charged me for it.
Any other scenario is IMPOSSIBLE.
...you already know, the future is for those who deserve it...
RL
FL
FR
RR
Test:
It's essential to activate the ABS regulation two or three times. Do this on a track/road with loose sand/gravel to avoid unnecessarily stressing the tires and brakes.
Bleeding the brake fluid for the clutch slave cylinder will have to wait for a cooler day (below 35ºC 💦), or maybe I'll do it in the garage.
Have a good weekend everyone... without exception!
https://www.youtube.com/watch?v=lSBPL2uwkbE
POLO 6R. Clutch slave cylinder. Hydraulic fluid replacement and bleeding (ciclo method).
A wonderful new day begins with extremely pleasant temperatures...
...it's possible some jerk will show up and ruin it.😁
Remove the air filter box according to instructions in a previous post.
Note: Plastic permeation, so that a native English speaker can understand it... without going into detail about the potentially super vague terms they use.👨‍⚖️
:lol:
The magic happens when you release the clutch, so pay attention!
No more efforts are necessary... ...
Now the clutch pedal feels like new, very smooth and pleasant.😎
https://www.youtube.com/watch?v=dPaYdRnAHZQ
This morning, when the streets of the world still do not exist, while I was looking in the garage storage room for the tools to bleed the clutch, the 6R Automatic Lights (LH 30s) and the garage light (1,5min🤷‍♂️) finished their illumination time, fortunately the F-TRON and the Audi ENTRY Lights (previous improvements), with a super ridiculous/low consumption, illuminated my way.
By the way, it's not the same having the tools in your workshop as it is preparing them to do any job in the middle of nowhere. You can't forget any of the ones you might need.
As you can see from this thread, the only thing you don't need is the workshop itself.
https://www.youtube.com/watch?v=d9s96fDzqfM
To close the loop on the unscheduled tasks:
- Replacement of front shock absorbers, control arms/suspension links, anti-roll bar links/coupling links, and swivel joints.
Images of the front shock absorbers and springs ('Sport', not GTI) of my 6R 1.2 TSI R-line from the factory:
It seems that the shock absorber protection bellows came loose from the plastic fastening adapter.
With 100,000 km / 14 years, they still feel in very good condition. During the brake replacement, I verified that there are no signs of play in the suspension components or cracks in the rubbers.
I estimate that we will enjoy another 100,000km with our 6R, so it would not make sense to change these parts at 150,000km when the rubber parts and other elements have high wear.
These are the parts from the VW supplying manufacturers that I am going to change:
I don't know the best time to install these parts. I have other jobs going on with vehicles that aren't mine. Family members and 'associates' are taking advantage of my vacation to use me as a simple mechanic.
I'll install them following erWin's instructions and take pictures of the key moments, that is, pictures of how not to use hammers or forks to remove ball joints during these tasks. :lol:
https://www.youtube.com/watch?v=416lCDxz5kE
VCDS Autoscan
Wednesday,24,June,2026,09:08:10:32438
VCDS Version: 26.3.0.0 (x64)  HEX-V2 CB: 0.4701.4
Data version: 20260320 DS375.1
www.Ross-Tech.com
VIN: WVWZZZ6RZDY0CICLO   License Plate: AFTER FLASHING STANISLAV 7E0C BCM TO 7E0E OK!
Mileage: 102710km-63821mi   Repair Order:
Chassis Type: 6R-VW25 (7E0)
Scan: 01 03 04 08 09 10 15 17 19 20 25 2E 3C 44 55 5F 61 65 6C
VIN: WVWZZZ6RZDY0CICLO   Mileage: 102710km-63821miles
Address 01: Engine (J623-CBZC)       Labels:. 03F-906-070-CBZ.clb
   Part No SW: 03F 906 070 GD    HW: 03F 907 309 AJ
   Component: SIMOS10.22AH10 5466
   Revision: --H10---    Serial number: 00000000000000 CVN: 9A6217E3
   Coding: 001100F6202400080000
   Shop #: WSC 00788 648 00255
   ASAM Dataset: EV_ECM12TFS02103F906070GD 004007
   VCID: 6A8D3FD44CF8023A717-803E
   VINID: 9E69EAAAA1A2A94A400030C808A8E303EA
Readiness: 0110 0101
Address 03: ABS Brakes (J104)       Labels:. User\6R0-907-37x-ESP82.lbl
   Part No SW: 6R0 907 379 BE    HW: 6R0 907 379 AF
   Revision: --------
   Coding: 210228E3216D00B5842814EA84D30040D700
   Shop #: WSC 40308 002 104857
   VCID: 025D77745448FA7AD97-8056
   Serial number: 08021613470174
   Coding: 01
   ROD: EV_LWSKLOVW25X.rod
   VCID: 7EA5038420709E9ABDF-802A
   Part No SW: 6R0 907 044 H    HW: 6R0 907 044 H
   Component: Climatronic   H11 0812
   Revision: V0000000
   VCID: 3829D59C425460AA373-806C
   Revision: B9084001    Serial number: 2502 179190157
   Coding: 3CB02FBF48E12400B3380F317CEB9FD05AC8670E600D39D0200400030800
   Shop #: WSC 00046 123 12345
   VCID: 2D07F4C8BD16D502545-8078
   Component: RLHS 220816 0  42  0106
   Coding: 0228DD
   Subsystem 2 - Part No SW: 6R0 959 801 BD    HW: 6R0 959 801 BD  Labels: 6R0-959-801.CLB
   Component: J386__TSG_FT  003 8612
   Coding: 0200A3
   Subsystem 3 - Part No SW: 6R0 959 802 BF    HW: 6R0 959 802 BF  Labels: 6R0-959-802.CLB
   Component: J387__TSG_BT  003 8612
   Coding: 1000A3
   Subsystem 5 - Part No: 1K8 951 605 B
   Component: LIN BACKUP HO  H11 9005
   Subsystem 8 - Part No SW: 6R0 959 811 N    HW: 6R0 959 811 N
   Component: J388__TSG_HL  003 8611
   Serial number: KU0KU006051551268991
   Coding: 0200A3
   Subsystem 9 - Part No SW: 6R0 959 812 N    HW: 6R0 959 812 N
   Component: J389__TSG_HR  003 8611
   Serial number: KU0KU022041551127896
   Coding: 1000A3
Address 10: Park/Steer Assist (J791)       Labels:. 5Q0-919-298.clb
   Part No SW: 1K8 919 475 D    HW: 5Q0 919 298
   Component: PARKHILFE PLA H12 0480
   Revision: --------    Serial number: 39491531301709 Dataset Number: 2KC800t____ 0003
   Coding: 0031167001
   ASAM Dataset: EV_EPHVA2CVW364GP00 001010
   ROD: N/A
   VCID: 3B23CA9073E24BB2DA1-806E
No ASAM data for: "EV_EPHVA2CVW364GP00" (VW37 *)
1 Fault Found:
12718592 - ROD - Unknown Error Code
          - 00 [00001000]
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 51
                    Mileage: 102713 km
                    Date: 2026.06.24.
                    Time: 09:01:27
   Component: VW10Airbag01M H10 0020
   Revision: --------    Serial number: 003GX01JKVVP Dataset Number: v00305696R0 0001
   Coding: 00314D
   Shop #: WSC 01383 785 00200
   ROD: EV_AirbaVW10BPAVW250.rod
   VCID: 4ACD9F542C38E23A517-801E
   Serial number: 3575HRB405N1C4LI7929
   Crash sensor for side airbag: passenger side:
   Serial number: 3585HRB405B1D5MS8GS2
   Crash sensor for side airbag: driver side rear:
   Serial number: 3515RRB405B17ABS901.
   Crash sensor for side airbag: passenger side rear:
   Serial number: 3525RRB405B181TUDPKC
   Part No SW: 6RD 920 870 A    HW: 6RD 920 870 A
   Component: KOMBI         H04 0805
   Coding: 140E01
   Shop #: WSC 00233 572 00255
   VCID: 47CBA6603F2A1F524E9-8012
   Revision: B9084001
   Coding: 002207
   VCID: 688945DC5274302A673-803C
   Revision: AA001001
   Coding: 0404000000000000000000
   Shop #: WSC 03607 002 104857
   ROD: EV_HighBeamAssisAU316_VW32.rod
   VCID: 2E05F3C4B090AE1A6DF-807A
   Component: IMMO          H04 0805
   Shop #: WSC 12345 123 12345
   Part No SW: 5N0 035 342 F    HW: 5N0 035 342 F
   Component: SG EXT.PLAYER H18 0530
   Revision: A1001003    Serial number: 7662584630
   Coding: 020100
   VCID: 2A0DFFD48CF8C23AB17-807E
Address 3C: Lane Change (J1086)       Labels:. 2Qx-907-686-V2.clb
   Part No SW: 2Q0 907 686 B    HW: 2QD 907 686 A
   Component: HRE3_Kl15_Mst H06 0150
   Serial number: 00006273342269  Dataset Number: V03935359EX 0001
   Coding: 529524A0
   ROD: N/A
   VCID: 392FD09879DE79A2C8D-806C
   Subsystem 1 - Part No SW: 2Q0 907 685 B    HW: 2QD 907 685 A
   Component: HRE3_Kl15_Slv  H06 0150
   Serial number: 00006273536997
No ASAM data for: "EV_HREntryHellaGen3Kl15" (VW25)
   Part No: 6R0 423 156 B
   Coding: 11250
   Shop #: WSC 00788
   VCID: 2F3BEEC0BE5AA712669-807A
   Revision: --------    Serial number: -------------- Dataset Number: 6R0036v____ 0005
   Coding: 0112000001000000
   VCID: 77AB16A00F4AAFD2FE9-8022
   Component: MU-S-ND-ER    H41 0480
   Serial number: VWZAZ2W1480534 Dataset Number: V03935270BD 0001
   Coding: 02620001FF00000051110101C0890A801F0106C400A00100CF
   Shop #: WSC 34480 348 34480
   ROD: EV_MUStd4CTSAT_VW37.rod
   VCID: 25170CE8E566ED429C5-8070
   Data carrier:
   Subsystem 1 - Part No SW: V03 959 822 MM    HW: -----------
   Component: ECE AS 25/26  --- 2410
Address 61: Battery Regul. (J840)       Labels:. User\1K0-907-534.lbl
   Part No SW: 7E0 907 534     HW: 7E0 937 090 E
   Component: Batt.regelung H84 0772
   Coding: 032A1A64
   Subsystem 1 - Part No SW: 6C0 915 181 D    HW: 6C0 915 181 D
   Component: J367-BDMHella  H10 9070
   Serial number: 5943827204
   Serial number: 40000000050821
   ROD: EV_RDKBERU30_005.rod
   VCID: 372BD6A04FCA6FD23E9-8062
Address 6C: Back-up Cam. (J772)       Labels:| 5Q0-980-556.clb
   Part No SW: 5Q0 980 556 B    HW: 4M0 980 556 A
   Component: RVC Compact   H19 0231
   Dataset Number: V03935314JY 0001
   Coding: 010402014600201F000060
   ASAM Dataset: EV_CamSysRVRVCPANAMQBAB 006009
   ROD: EV_CamSysRVRVCPANAMQBAB.rod
End----------(Elapsed Time: 02:12, VBatt start/end: 12.8V/12.8V)-----------
-------------------------------1 Fault Found-------------------------------
"Unlock your mind."
https://www.youtube.com/watch?v=gLUuQWy84Jk
Burn with me 🤭 ... 🔥 AWSM!
Locked
