Page 8 of 8
Re: Polo 6r GTI - Bi-Xenon installation Issues
Posted: Wed May 28, 2025 8:50 am
by lvu89
iichel wrote: Wed May 28, 2025 8:34 am I don't think your BCM is capable of powering the LED for the bixenon headlights. You'll need 7H0 937 089 minimum (best is 7E0 090)
Hello iichel, I know. If you take a look at what I explained a little higher in the first post to which I added pictures, you will understand. There are two situations. Theoretically, the second situation (BCM MAX) should have worked.
Posted: Fri May 30, 2025 4:53 pm
by ciclo
lvu89 wrote: Wed May 28, 2025 7:53 am
ciclo wrote: Wed May 28, 2025 5:48 am ... from here to the weekend I will take a look carefully, ... as soon as possible.
I'm waiting with interest. I'm also attaching a scan for the first situation (present - with BCM OEM 6R0937087F) it might help you. If necessary I can reconnect the new BCM MAX and the cables related to the second situation to do a new scan. Thanks in advance!
Wednesday,28,May,2025,08:17:25:53651
VCDS Version: 17.1.0.0
Data version: 20170106 DS267.0
VIN: WVWBS51K5DK000019 License Plate:
Mileage: 200500km-124584mi Repair Order:
blah, blah, blah...😁
Hello 2501/2500 :) -lvu89-, homework for the weekend or whenever you want.
Concept:
As iichel mentioned, the BCM 6R0 cannot control the 6R bi-xenon headlights. Proceed with making a campfire with it or sell it for a very reasonable price (its advantages are that it manages the CCS and central locking for remote controls).
Procedure:
- Install the BCM 7E0 and install the wiring harnesses according to the KUFATEC guide... it will be necessary to install some more wires, but not at this time.
- New provisional BCM 7E0 coding, based on the Autoscan you posted.
3CB02DBF28A10000002800C17C0F9CD17AC847BB60071040200000020000
There's a methodology to this new coding because I won't be asking questions about lights other than the bi-xenon headlights. I can imagine what's going on, but a new autoscan will tell us what we need to know.
- With VCDS go to Autosan, click GW Installation List, click in clear all DTCs (whatever can be erased).
- Important: Verify that this BCM 7E0 has adaptation channels 53 and 54 set to '0'. Proceed to set them if not.
- Perform a functional test of all the lights without exception, that is, in addition to the 'normal lights' 😁, don't forget the reverse light, rear fog light, and license plate lights.
- You can repeat the same functional test after disconnecting and reconnecting the negative battery terminal for at least 10 seconds. Do this if any lights aren't working properly (at this point, this is still normal).
- Report the results with a new VCDS autoscan to debug errors due to missing wiring or coding (small and simple tasks). Don't panic just yet.
Note:
This BCM 7E0 may (or may not) have to be parameterized for the position/side/parking light values. According to results.
By the way, what is this on your Autoscan:
Subsystem 3 - Part No SW: KU 0-K U02 7. HW: KU0 -KU 027 .0
7.10
Serial number: KU0-KU027.07.10130
Coding: 333036
Take it easy, we'll be here to see what happens.
BTW2: cheer our eyes with a couple of photos of that 2501/2500 with that engine.
Posted: Sat Jun 07, 2025 10:03 am
by lvu89
ciclo wrote: Fri May 30, 2025 4:53 pm
Concept:
Procedure:
Note:
7.10
Coding: 333036
Hello, I finally managed to solve what you sent me. I did everything you said and it works with one exception. The fog lights in the headlights. I want to clarify that I had the OEM bar with the fog lights positioned at the bottom. Now the wiring is there, but it is not connected to any bulb because of the WRC front bumper. I still connected a bulb and when I put "Fog lights" light switch on = the bulb lights up on the old OEM installation but not in the headlight. Shouldn't the fog lights on both the headlight and the projector?
The result for the above configuration:
1) Light switch 0 = LEDs and high beam work (shutters and lights).
2) Light switch "position lights" = LEDs and high beam work.
3) Light switch "on" = LEDs still on, xenon headlight comes on, high beam works fine with lights (Bi-Xenon) and fog turn signals work if I signal.
4) Light switch "fog lights" = LEDs still on, fog lights in headlight do not work, high beam works fine with lights (Bi-Xenon).
I am attaching the scan after this installation as you asked and some pictures of the beast. :))
Posted: Sat Jun 07, 2025 10:08 am
by lvu89
Mileage: 200620km-124659mi Repair Order:
Chassis Type: 1K (7E0)
Scan: 01 02 03 04 08 09 15 17 19 25 37 44 56 77 0B
VIN: WVWBS51K5DK000019 Mileage: 200620km-124659miles
56-Radio -- Status: OK 0000
Address 01: Engine (CCZ) Labels: 06J-907-115-CCZ.clb
Part No SW: 5K7 907 115 HW: 1K0 907 115 AA
Component: 2.0l R4/4V TFSI 0010
Revision: AAH18--- Serial number:
Coding: 041B000C1C070160
Shop #: WSC 00040 040 00001
VCID: 6ED3A89D794696312D-803A
Readiness: 0010 0001
Address 02: Auto Trans Labels: 02E-927-770.clb
Part No SW: 02E 300 053 N HW: 02E 927 770 AL
Component: GSG DSG AG6 512 2207
Revision: 05551213 Serial number: 00001112050015
Coding: 0000020
Shop #: WSC 04940 001 00001
VCID: 204F86A5F3127041EF-8074
Address 03: ABS Brakes (J104) Labels: 6R0-907-37x-ESP82.clb
Part No SW: 6R0 907 379 AJ HW: 6R0 907 379 AF
Revision: --------
Coding: 210228E3417400B4842C14EA82D100401100
Shop #: WSC 12345 123 56789
VCID: 0603F03DB5F6BE71F5-8052
Address 08: Auto HVAC (J301) Labels: 6R0-820-045-9AP.clb
Part No SW: 6R0 820 045 J HW: 6R0 820 045 J
Component: Climatic 25 0660
Revision: 00 11 25
VCID: 356147F19C90E5E92C-8060
1 Fault Found:
00819 - High Pressure Sensor (G65)
002 - Lower Limit Exceeded
Fault Status: 01100010
Fault Priority: 2
Fault Frequency: 1
Reset counter: 137
Mileage: 200625 km
Time Indication: 0
Date: 2019.10.22
Time: 04:11:30
Address 09: Cent. Elect. (J519) Labels: 7E0-937-BCM-V1.clb
Part No SW: 7E0 937 090 C HW: 7E0 937 090 C
Revision: B9082001 Serial number: 4000 186180363
Coding: 3CB02DBF28A10000002800C17C0F9CD17AC847BB60071040200000020000
Shop #: WSC 50823 003 104857
VCID: 2B5561894AD4A3194A-807E
Subsystem 1 - Part No SW: 6R0 959 801 R HW: 6R0 959 801 R Labels: 6R0-959-801.CLB
Component: J386__TSG_FT 006 0912
Serial number: KU0-KU026.07.1013309
Coding: 08BC30
Subsystem 2 - Part No SW: 6R0 959 802 T HW: 6R0 959 802 T Labels: 6R0-959-802.CLB
Component: J387__TSG_BT 006 0912
Serial number: KU0-KU027.07.1013069
Coding: 08BC30
7.10
Coding: 333036
1 Fault Found:
01504 - Bulb for License-Plate Light (X)
010 - Open or Short to Plus
Fault Status: 01101010
Fault Priority: 3
Fault Frequency: 1
Reset counter: 137
Mileage: 200625 km
Time Indication: 0
Date: 2019.10.22
Time: 04:11:31
Component: VW10Airbag004 H09 0020
Revision: -------- Serial number: 003GX005PUP8
Coding: 003034
Shop #: WSC 00788 648 00255
ROD: N/A
VCID: 4A9B040DED6E9A1151-801E
Subsystem 1 - Serial number: 3572SRB40000C7E462BE
Subsystem 2 - Serial number: 3582SRB40000C7909A9F
Subsystem 3 - Serial number: 3515RRB405R6T8MIHG2I
Subsystem 4 - Serial number: 3525RRB40616T8MIF0AR
No ASAM data for: "EV_AirbaVW10BPAVW250" (VW36)
Part No SW: 6R0 920 860 F HW: 6R0 920 860 F
Component: KOMBI H04 0304
Coding: 140800
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04086
VCID: 377D4DF98E9C17F93E-8062
Address 19: CAN Gateway (J533) Labels: None
Part No SW: 7E0 909 901 HW: 7E0 937 090 C
Revision: B9082001
Coding: 002000
VCID: 68DFDE859BA2480167-803C
Component: IMMO H04 0304
Serial number:
Shop #: WSC 00000 000 00000
VCID: 6ADBA48D8DAE7A1171-803E
Address 37: Navigation (J0506) Labels: 1T0-035-680.clb
Part No SW: 1T0 035 680 L HW: 1T0 035 680 B
Component: RNS-MID H11 5238
Revision: AB001001 Serial number: VWZ6Z7J9045036
Coding: 04000400040000A10020
Shop #: WSC 05314 123 12345
VCID: 377D4DF9869C17F93E-8062
Part No: 6R0 423 156 B
Component: LenkhilfeTRW V277
Coding: 11250
Shop #: WSC 00788
VCID: 2F6D7599EACCDF3966-807A
Address 56: Radio (J0506) Labels: 1T0-035-680.clb
Address 77: Telephone (J412) Labels: 7P6-035-730.clb
Part No SW: 7P6 035 730 L HW: 7P6 035 730 L
Component: TELEFON H15 3200
Revision: 1B001001 Serial number: 00007664892951
Coding: 0010000100010110
ASAM Dataset: EV_UHVNA 002720
ROD: EV_UHVNA_002.rod
VCID: 3B7551C9B2B43399DA-806E
End-------------------------(Elapsed Time: 02:31)--------------------------
Posted: Sat Jun 07, 2025 10:16 am
by lvu89
8) Image
Posted: Sat Jun 07, 2025 10:20 am
by lvu89
Posted: Sat Jun 07, 2025 12:01 pm
by ciclo
Thanks for showing us the beast. 8)
Everything's great, except for the SCLs (static cornering lights) and the license plate lights... as expected.
The lights you're referring to as fog lights in the headlights are called SCLs. Info: :arrow: viewtopic.php?p=493598#p493598
Easy to fix...
SCLs:
Since your original installation had SCLs in the fog lights via fuse SB57 -according to your fuse box-, all you need to do is transfer the positive wires from your old fog lights connectors to the 14 terminal in T14 connector on your bi-xenon headlights (T14/14).
Example image (cornering lights only - blue lines). https://drive.google.com/file/d/0B2nv91 ... -One-hbY_Q
LPLs:
To fix the license plate lights problem, you need to run a NEW wire from T73b/7 to the positive terminal of both license plate lights. Cut the original wires for the license plate light supply (be careful, it's still live and must remain that way, and must be carefully insulated) and connect the new wire to both license plate lights. It's not necessary to remove the bumper, it can be done in the trunk area by removing the rear trim.
Example image:
Do these two simple tasks with the negative battery terminal removed!!
Please tell us the results. Thank you.
Posted: Sat Jun 07, 2025 12:15 pm
by lvu89
oops! Something is wrong. Now, checking the SB57 7.5A fuse I noticed this:
It seems to have heated up/melted. Why?
Posted: Sat Jun 07, 2025 12:29 pm
by ciclo
This may be due to having both bulbs/lights powered by the same line/wire, both the old fog lights and the new SCLs.
How they work is defined in the BCM coding... If bi-xenon headlights are installed, it should be coded as 'front fog lights with SCLs not installed' (I coded that way).
Posted: Sat Jun 07, 2025 4:24 pm
by lvu89
ciclo wrote: Sat Jun 07, 2025 12:29 pm This may be due to having both bulbs/lights powered by the same line/wire, both the old fog lights and the new SCLs.
Well the old fog lights are connected to the SB54 fuse according to this diagram.
So I don't think that's the reason. I'm afraid it will get worse. What should I do?
Posted: Sat Jun 07, 2025 6:10 pm
by ciclo
Obviously, I don't know what "real" modifications you've made to your 6R's wiring; that's something only you can know.
In this image you showed of your SB fusebox :arrow: https://uk-polos.net/viewtopic.php?p=608311#p608311 , fuse SB54 is missing!, but fuse SB57 is present... and then you show a picture of the SB fusebox with the SB54 fuse installed and the SB57 slot with superficial burns :arrow: https://uk-polos.net/viewtopic.php?p=608382#p608382 .... :lol:
I have some fortune-telling skills, but I didn't think they were necessary here. :mrgreen:
Because of the front R bumper, you currently don't have front fog lights, so the original wiring or wiring them through fuse SB54 doesn't make sense under any circumstances. This wiring is through the light switch, without BCM control and, of course, without SCLs.
The wiring for the SCLs in the bi-xenon headlights must be done with three wires.
- one wire for the BCM power supply from fuse SB57.
- and two wires from the BCM to the bi-xenon headlights.
And in your particular case (front R bumper) you must remove the T17/8 wire from the light switch connector and insulate it appropriately.
The following diagrams will make it clear.
L
R
+30 (15A fuse)
Do it this way, and your SCLs will be operational.
