Again brilliant, I followed the procedure again, this time no faults other that terminal 30 left and right open circuit, I know why that is
thanks,
Darren
Ciclo,ciclo wrote: Wed Jul 25, 2018 3:15 am
By other side, right now I'm on vacation. (Meditation time ...,
Wednesday,08,August,2018,11:27:16:00006
VCDS Version: 17.8.0.1
Data version: 20170721 DS276.2
www.Ross-Tech.com
VIN: *** License Plate:
Mileage: 129900km-80716mi Repair Order:
Chassis Type: 7H-VN75 (7E0)
Scan: 01 03 04 08 09 10 15 17 19 25 56 0B
VIN: *** Mileage: 129900km-80716miles
56-Radio -- Status: OK 0000
Address 01: Engine (J623-CFCA) Labels:. 03L-906-022-CFC.clb
Part No SW: 03L 906 019 GN HW: 03L 907 309 L
Component: R4 2,0L EDC H38 5606
Revision: 22H38--- Serial number: 00000000000000
Coding: 01194012232400080000
Shop #: WSC 02736 790 50316
ASAM Dataset: EV_ECM20BTD01103L906019GN 003004
ROD: EV_ECM20BTD01103L906019GK_003.rod
VCID: 7DF14FF6ECF168AEE1-8028
Readiness: 0 0 0 0 1
Address 03: ABS Brakes (-----) Labels:. 7E0-907-37x-MK25AXT.clb
Part No SW: 7E0 907 379 K HW: 7E0 907 379 E
Component: ESP MK25A XT H43 0110
Revision: 00H43001
Coding: 508724AD89A50A9824AA9177A96210
Shop #: WSC 02736 790 49152
VCID: 3A7B84EAB55F9F9684-806E
Address 08: Auto HVAC (J301) Labels:| 7E5-907-047.clb
Part No SW: 7E5 907 047 BN HW: 7E5 907 047 BN
Component: Climatic-T5 H20 0506
Revision: 00001012
Coding: 0000000002
ROD: EV_ClimaT5Basis.rod
VCID: 7CF742F2F7EB61A6D6-8028
Part No SW: 7E0 937 090 HW: 7E0 937 090
Revision: B9080001 Serial number: 0771 092160713
Coding: B8A030BA4A73243193284EF06EEB9E54F28063FF608C64C1320000030000
Shop #: WSC 18752 008 00032
VCID: 68DF0EA29B73DD0622-803C
Subsystem 1 - Part No: 1K0 955 559 AF Labels: 1K0-955-559-AF.CLB
Component: RLS 020608 04 46 0204
Coding: 0F30AD
Subsystem 2 - Part No SW: 7E0 959 801 B HW: 7E0 959 801 B Labels: 7E0-959-80X-V1.CLB
Component: J386__TSG_FT 002 3313
Coding: 010000
Subsystem 3 - Part No SW: 7E0 959 802 B HW: 7E0 959 802 B Labels: 7E0-959-80X-V1.CLB
Component: J387__TSG_BT 002 3313
Subsystem 4 - Part No: 7E1 951 172
Component: DWA-Sensor 00 001 0104
Component: LIN BACKUP HO H05 1501
Subsystem 6 - Part No: 7E1 951 172
Address 10: Park/Steer Assist (J446) Labels:| 7E0-919-475.clb
Part No SW: 7E0 919 475 K HW: 1Q0 919 475
Component: PARKHILFE 4K H03 0106
Revision: -------- Serial number: 32931312600211
Coding: 108001
ASAM Dataset: EV_VW75XParkAssis4K 001004
ROD: EV_VW75XParkAssis4K_001.rod
VCID: 3A7B84EABD5F9F9684-806E
Part No SW: 7E0 959 655 B HW: 7E0 959 655 B
Component: VW10Airbag009 H07 0013
Revision: -------- Serial number: 003HL00J7H86
Coding: 000000000000000000000000000000003039
Shop #: WSC 02734 790 50316
ROD: EV_AirbaVW10BPAVN750.rod
VCID: 356197D6944170EE69-8060
Address 17: Instruments (J285) Labels:| 5K0-920-xxx-17.clb
Part No SW: 7E0 920 970 J HW: 7E0 920 970 J
Component: KOMBI H04 0710
Coding: 160A01
ROD: EV_Kombi_UDS_VDD_RM09_004_VN35.rod
VCID: 3169A3C660295CCE35-8064
Part No SW: 7E0 909 901 HW: 7E0 937 090
Revision: B9080001
Coding: 002300
Component: IMMO H04 0710
Serial number:
Shop #: WSC 00000 000 00000
VCID: 6ADB74AA8D7FEF1634-803E
Part No SW: 6RD 035 187 B HW: 6RD 035 187 B
Component: Radio 541 5314
Revision: -------- Serial number: VWZZZ4J6228373
Coding: 16000200020014
Shop #: WSC 127395 840 08317
VCID: 4683E01AF1A7EB76F0-8012
End-------------------------(Elapsed Time: 03:04)--------------------------Hello to every one.Dazzyboy81 wrote: Thu Aug 02, 2018 5:31 pm Ciclo!
Again brilliant, I followed the procedure again, this time no faults other that terminal 30 left and right open circuit, I know why that isso once I completely finish this part and I'm back I will post saying where I'm up to with an up to date scan,
thanks,
Darren![]()
Sorry just saw this!ciclo wrote: Thu Aug 09, 2018 6:01 am Thank you very much for the final report. This is what everyone should do (autoscan).
Please, check again that all the lights work correctly in all positions of the light switch, stalks, buttons, etc ...
Sincerely, Fernando.
Thanks to you!
Hi bizmo, are you using oem vw lights swich or aliexpress rubbish? I hade the same issue 5weeks ago with my gti.Bizmo wrote: Sun Sep 02, 2018 6:45 pmSorry just saw this!ciclo wrote: Thu Aug 09, 2018 6:01 am Thank you very much for the final report. This is what everyone should do (autoscan).
Thanks to you!
See bellow the photos, just need to get the better light switch you had now as this one looks a bit rubbish but will do for now, I also want to get some better headlights but again will wait a while!
Please excuse how dirty the van is!
Hey bizmo on my t5 and gti when i put on 0 it lightning red. But on your t5 not. Are you sure thate wiring is correct??? Juist asking.
I’ve used Ciclos wiring so should be, everything seems to work. Maybe one of our switches has a function the other doesn’t?El Boss wrote: Wed Sep 05, 2018 7:51 pm
Adam i was by vw and they told me some of the vw cars are oem. I have done nothing. Only retrofited c.c and mfsw. In november i will paint my t5 and i will take my dash out. And in one time i will upgrade my rls and xenon and pdc. With help of ciclo and bizmo. I hope so.Bizmo wrote: Thu Sep 13, 2018 6:50 pm Without the auto switch that does the DRL so maybe it’s because of the power going to the lights?
