I've been needing to replace my DPF sensor as my car has gone into limp mode and I have the part (https://www.autodoc.es/bosch/665279?gsh ... tsQAvD_BwE) but I have no idea where it's located on the car.
Anyone have an idea of where it is?
DPF Sensor
Re: DPF Sensor
mounted on the fuel filter in the engine bay behind right hand side headlight
Re: DPF Sensor
Doesn’t seem to be there
- 300154D1-1F44-4F6D-B931-AA301780E48D.jpeg (3.31 MiB) Viewed 1969 times
Re: DPF Sensor
Ah I see, your steering wheel is on the wrong side.
look on the other side, on the firewall between the engine and the cabin
would be nice if you could post some pictures of its actual location, thanks
Re: DPF Sensor
Wooo thank you!
Finally found it.
Now, should I be concerned that one of the hoses ends right there?
- 6B25577E-4B8A-45A1-B379-5FFD076282DF.jpeg (2.3 MiB) Viewed 1948 times
Re: DPF Sensor
Looks pretty acceptable to me
