iichels VW Passat 2.0 TSI DSG 4-Motion 2017
Posted: Wed Dec 14, 2022 10:07 pm
In other news, the Polo (finally) has its MQB brother, the VW Passat B8 2.0 TSI DSG 4-motion from 2017 (MY2018)
https://imgur.com/a/Kxgf148
Exterior:
- R-Line exterior package
- LED high headlights with DLA and AFS
- LED high tail lights and licence plate lights
- Oryx White paint
- Panoramic sunroof
- Folding mirrors
- Electric tailgate
- Electric folding towbar
- Puddle lights
- Heated windscreen washers
Interior:
- Active Info Display
- Electric folding mirrors
- R-line interior with black roof liner and R-Line door sill trim
- Full electric leather R-Line with memory and massage function
- Keyless entry and start system 'Kessy' with front and rear door keyless locking
- Climatronic 3 zones with auxiliary heater
- Rain and light sensor with automatic lights with CH/LH
- Adaptive cruise control
- Driving mode selection
- Ambient lighting RGB "plus" (RGB in doors, dash; white in ceiling and center console)
- Front and rear seat heating
- Alarm system
- Lane assist
- Lane change assist
- 230V connection in the armrest
Infotainment and assistance systems:
- MIB2.5 9.2 Discover Pro system
- 12K PDC/OPS with PLA3.0 and TJA
- Reversing camera high
- Dynaudio sound system
Running gear:
- DCC with front and rear independent suspension
- Progressive steering rack PR-1N7
- Front 340mm disc brakes with single piston caliper
- Rear 310mm disc brakes with single piston caliper
- Electronic parking brake with auto hold
- 19 inch Verona alloy wheels 3G0601025R 19x8 ET44 with 235/40R19 tires
- Direct TPMS
0x01 Engine:
- Factory fitted CJXA 2.0 TSI EA888 3rd generation engine (280hp/206kW, 350Nm) SIMOS 18
- Chiptuning 415 bhp and 525 Nm --> info
- OEM IHI IS38 turbocharger --> Garrett GTX2867R turbocharger
- OEM Facelift EA888 gen4 engine cover --> info
- Modifications to the OEM air intake --> info
- Later changed to --> R600 intake
- Wagner Competition intercooler --> info
- OEM steel oil sump --> info
- GFB DV+ T9359 diverter valve spacer --> info
- Racingline turbo inlet elbow
- Forge turbo muffler delete
- Audi RS3 LPFP 8V0919087A + controller 4M0906093K + adapter
- Autotech HPFP upgrade
- OEM Audi RS3 coil packs 06H905110P
- OEM Audi RS7 spark plugs 06K905601B
- OEM divertger valve 06H145710D
- OEM EA888 gen 4 06Q boosted PCV (06Q103495B + 06K103210D)
- G12 Evo coolant with 5Q0121407AA 5WA121407F expansion tank without silicate --> info on G12 Evo, info on 5WA tank
0x02 DSG:
- Factory fitted SYP 6-speed DSG gearbox 'DQ250'
- Upgrade OEM DSG oil cooler 02E409061C --> info (later removed due to DQ500 conversion)
- DQ250 SYP --> 7-speed DSG gearbox DQ500 SDM --> info
- VW Tiguan 5NB LED DSG lever 5NB713203K + 3G1711113G --> photo
- How to do a DSG oil service --> info
0x03 ABS:
- Factory fitted MK100 ESC with IPB (integrated parking brake)
- Factory fitted 340mm front discs with single sliding piston calipers and 310mm vented rear discs with single piston sliding calipers and EPB
- Upgraded SW 5Q0614517CH 0743 to 5Q0614517FM 0755
- Audi RS3 8V brake coolers info
- Front 340mm disc brakes --> Audi TTS 4-piston brakes with 338mm discs info --> Audi RS6 400mm ceramic discs with 6-piston Audi RS6 callipers info
- Rear 310mm vented disc brakes with single piston callipers with electronic parking brake --> Audi RS6 370mm vented ceramic brake discs with single-piston calliper and EPB
- ABS later upgraded to HW 5Q0614517BP SW 5Q0614517GS 0993 for experiments with the rear torque splitter differential
0x05 Kessy
- Factory fitted Kessy
- Retrofitted boot sensor 3G0962243 to facilitate easy open 'kick to open' --> info
- 3G0959893C "R" logo on the keys
- Upgraded to HW/SW 3Q0959435Q 1400 in an attempt to gain mirror fold via easy close (and successful)
0x06 Seat memory passenger
- Factory fitted non-memory full electric passenger seat
- Retrofitted passenger seat massage --> info
- Upgraded to Arteon front seats and added memory, massage, ventilation and easy entry --> info
- Updated SW to 3Q0959760D 0024
0x08 Climatronic
- Factory fitted climatronic with front and rear seat heating, Webasto and three-zone control
- Retrofitted facelift front and rear touch climatronic --> info
- Upgraded front touch panel from 3G8907044R to 3G8907044T for seat ventilation
- Retrofitted heated windshield --> info
0x09 Central Electrics
- Factory fitted BCM High (Seat heating, RGB ambient lighting)
- Upgraded to HW/SW 5Q1937084B
- Retrofitted headlight washer electrics to the 5Q1 BCM PCB --> info
- Added RGB ambient lights to the front and rear footwells, door handles and panoramic sunroof --> photo of front and rear door and roof
- Rear DRL stripes in the tail lights --> info
- Coded 30 colour ambient RGB lights --> info
- Upgraded light switch to 3G8941633 ICX for all weather lights
- Upgraded interior lights to touch lights (front 3GB947105, rears 3GB947291 3GB947292)
0x10 Park Steer assist
- Factory fitted 12K PDC/OPS with PLA3.0 and TJA
- Updated SW to 5QA919298L 0074
0x13 Adaptive Cruise Control
- Factory fitted ACC 5Q0 'Bosch' radar (behind the front logo, with the little mirror for calibration)
- Retrofitted 3QF ACC radar --> info
- Added pACC SWaP
0x14 Suspension and wheels
- Factory fitted electronically adjustable dampers with FPA
- Upgraded SW 5Q0907376B 0121 to 5Q0907376C 0130 for DCC slider
- Eibach lowering springs --> info
0x15 Airbags
- Factory fitted front and rear curtain airbags PR-4X4, with front passenger deactivation and driver knee airbag PR-4UN
- Upgraded to HW/SW 3Q0959655CP 0721
0x16 Steering Column electronics
- Added steering column combination switch without assistance button --> 3Q0953521P
- Changed to 5Q0953569B for heated MFSW
- Updated SW 5Q0953521KT from 0245 to 0265 to remove 291104 - Temperature Sensor for Heated Steering Wheel B1455 01 [008] - Electrical Failure
0x17 Instruments
- Factory installed Active Info Display
- Upgraded SW to 3G0920791C 4191 to activate VIEW button
0x18 Auxiliary heating
- Factory fitted auxiliary heater, so it has the battery in the boot and a funny washer reservoir.
- Upgraded SW to 5Q0963272K 0080
- Added second remote 3G0963511C --> info
0x19 CAN Gateway
- Factory fitted 3Q0 Conti High gateway SW train 5xxx
- Flashed SW to 3Q0907530AR 5502
- Modified dataset with DCC slider and R-button controls
- VW Passat B8 facelift MFSW + heating info
0x22 AWD
- Factory fitted Haldex gen 5
- VCDS modifications with RS3 clamping behaviour
- Upgraded to SW 0CQ907554J 7084
- Removed in favour of the Magna torque splitter
0x23 Electromechanical brake booster
- Factory fitted vacuum powered booster
- Retrofitted OEM 3Q1 eBKV in combination with the ceramic brake upgrade --> info
- HW: 3Q0909059A HW: 3Q0909059AA 0074
0x2B Steering Column Lock
- Factory installed ELV
- One of few untouched modules on my car
0x36 Seat memory driver
- Factory fitted with a full electric driver seat with memory, massage and easy entry
- Upgraded to Arteon seats and added ventilation --> info
- Retrofitted Passat B8 rear child seat --> info
0x3C Lane Change
- Factory fitted BSD with Side Assist during parking
- Upgraded 3Q0 based system (3C + CF) to 2Q0 due to incompatibility with AR GW SW
- Upgraded to HW/SW 2Q0907685B + 2Q0907686B 0150 --> info
0x42 Driver door
- Factory fitted central locking with folding mirrors
- Upgraded to HW 5Q0959593F SW 5Q0959593L 0350 due to errors in PDC module
- Retrofitted electronic rear child locks --> info
- Retrofitted double glazing --> info
0x44 Power Steering
- Factory fitted dynamic steering PR-1N7
- Updated SW to 3Q0909144M 5082 with Audi RS3 dataset
0x47 Sound System
- Factory installed Dynaudio
0x4B Multifunctional Module
- Factory installed LED High headlights with AFS and DLA
- Replaced with version F, in combination with my Matrix headlight retrofit.
0x52 Passenger door
- Upgraded to HW 5Q0959592F SW 5Q0959592L 0350 due to errors in PDC module
- Retrofitted auto dimming passenger mirror --> info
0x5F Information Electrics
- Factory fitted Discover Pro 9.2 inch MIB 2.5
- Upgraded to HW 5NA035022 SW 5NA035022B 1367 for DAB+ reception
- DAB+ antenna 3G9035577B
- Apple Carplay and Android Auto from factory
- Retrofitted wireless QI charger 3G0980611 + 3G1864263A
- AAWireless
- Installed MIB toolbox for activation of navigation in AID while using Google Maps
0x65 Tire Pressure
- Factory installed TPMS high with sensors in wheels
- Updated SW to 5Q0907273F 0011
- TinyQ dataset
0x69 Trailer
- Everyone loves 69
- Factory installed electrically swivelling towbar
0x6C Backup Camera
- Factory fitted RVC Compact 'Highline' with dynamic lines
- Retrofitted 360 area view camera --> info
- Dynaudio cover for the 360 cam module --> info
0x6D Trunk Electronics
- Factory installed electrical trunk
- Upgraded to HW 5Q0959107C / SW 5Q0959107Q 0265 for easy close
0xA5 Front Camera
- Factory fitted 3Q0 camera with Lane Assist and DLA
- Flashed SW 3Q0980654L 0610 + 60 second mod --> info
- Upgraded to HW 2Q0980653 SW 2Q0980653J 1423 with VZE swap and 600 seconds hands-free
0xA9 Structure Borne Sound
- Retrofitted Sound Actuator --> info
- Flashed Audi TTRS file for 5-cylinder sound.
0xBB Rear door driver side
- Upgraded to HW 8W1959595D SW 5Q0959595L 0350 due to errors in PDC module
0xBC Rear door passenger side
0xCA Sunroof
0xD6 Light Ctrl Left 2
- Replaced with the 992 modules for my Matrix headlight retrofit
0xD7 Light Ctrl Right 2
0x8126 Trq distrib RearL axle
- Retrofitted Magna Torque splitter from Arteon R
- Active rear diff for more sporty performance
- It was easier than thought after getting the correct MQB classic modules --> info
0x8127 Trq distrib RearR axle
Interior upgrades, mods and retrofits:
- Audi Homelink system --> info and operation via center console button
- VW Passat B8 boot management system --> info
- Skoda Superb USB-C charge port in the interior mirror --> info
- Rear USB port (charge only) --> info
- Passat B8 rear luggage curtain 3G9867871
- Passat B8 all weather floormats + boot mat 3G1061500A + 3G9061161
- Passat B8 rear privacy shades 3G9064365 --> info
- Skoda thrash can 5JA061107
- Lights in rear lid 6Q0947291 + 8KD947411 --> info
Exterior upgrades, mods and retrofits:
- Passat B8 alltrack kevlar skid plate --> info
- Wrapped the front fog light 'C' sections --> info
- Passat B8 / Mk7 /Mk8 golf Aero parts --> info
- Passat B8 facelift front logo with camera 3G7853600 --> info
- Tiguan 5NA "R" side emblems --> info
- Passat B8 facelift rear 'Passat' logo 3G9853687C
- Passat B8 facelift rear 'VW' logo 5H0898633
- Passat B8 black mirror caps
- Passat B8 R-Line tail lights with dual rear fog light
- Showroom dealer license plates 3G9071801
- Skoda washer reservoir cap 6V0955485
Wheels upgrades, mods and retrofits:
- Added VW Dynamic hub caps 000071213D
- Added VW wheel covers 000073900
- T-Roc 2GA 19 inch Estoril alloy wheels 2GA601025AQ 19x8 ET44 with 235/40R19 Michelin Pilot Sport 4 tires --> info
- Michelin Pilot Alpin 5 winter tires on the Verona wheels
Accessories:
- OEM VW bike carrier 3C0071105B
- OEM VW band aid kit 00093114
- OEM VW cool box 1T0065400 'Fritz the fridge' info
First:
Exterior:
- Oryx White paint
- Panoramic sunroof
- Folding mirrors
- Electric tailgate
- Puddle lights
Interior:
- Alarm system
- Lane assist
Running gear:
- Direct TPMS
0x01 Engine:
0x02 DSG:
0x03 ABS:
0x05 Kessy
0x08 Climatronic
- Added pACC SWaP
0x15 Airbags
0x17 Instruments
0x19 CAN Gateway
0x22 AWD
0x3C Lane Change
0x42 Driver door
0x44 Power Steering
0x47 Sound System
0x52 Passenger door
- AAWireless
0x65 Tire Pressure
- TinyQ dataset
0x69 Trailer
- Everyone loves 69
0x6C Backup Camera
0xA5 Front Camera
0xCA Sunroof
Accessories:
First:
Wednesday,14,December,2022,19:00:45:11868
VCDS Version: 22.9.0.0 (x64) HEX-V2 CB: 0.4623.4
Data version: 20220830 DS341.0
www.Ross-Tech.com
Workshop Code: 123 30389 056831
VIN: WVWZZZ3CZJEiichel License Plate:
Mileage: 131667km-81814mi Repair Order:
Chassis Type: 3C-VW48 (3Q0)
Scan: 01 02 03 05 08 09 10 13 14 15 16 17 18 19 22 2B 36 3C 42 44
47 4B 52 5F 65 69 6C 6D A5 BB BC CA CF D6 D7
VIN: WVWZZZ3CZJEiichel Mileage: 131667km-81814miles
05-Acc/Start Auth. -- Status: OK 0000
14-Susp. Elect. -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
18-Aux. Heat -- Status: OK 0000
22-AWD -- Status: OK 0000
2B-Steer. Col. Lock -- Status: OK 0000
36-Seat Mem. Drvr -- Status: OK 0000
47-Sound System -- Status: OK 0000
4B-Multifunc. Module -- Status: OK 0000
69-Trailer -- Status: OK 0000
6D-Trunk Elect. -- Status: OK 0000
A5-Frt Sens. Drv. Assist -- Status: OK 0000
BB-Door Rear Drv -- Status: OK 0000
BC-Door Rear Pass -- Status: OK 0000
CA-Sunroof -- Status: OK 0000
CF-Lane Chge Asst 2 -- Status: OK 0000
D6-Light Ctrl Left 2 -- Status: OK 0000
D7-Light Ctrl Right 2 -- Status: OK 0000
Address 01: Engine (J623-CJXA) Labels:. 06K-907-425-V1.clb
Part No SW: 3G0 906 259 B HW: 06K 907 425 B
Component: 2.0l R4 TFSI H13 0002
Revision: --H13--- CVN: 73B77959
Coding: 091D003A2476050B3004
Shop #: WSC 05311 115 00319
ASAM Dataset: EV_ECM20TFS0203G0906259B 001003
ROD: EV_ECM20TFS0203G0906259B.rod
VCID: 2B03FAEDB387D593621-807E
VINID: 9E69EAAAA0D3A9A54008518520274044B7
Readiness: 1110 0001
Address 02: Auto Trans (J743) Labels: 0D9-927-770.clb
Part No SW: 0D9 300 018 C HW: 02E 927 770 AS
Component: DQ250-6A MQB H54 5201
Revision: 06454104 Serial number: TFK01706160335 CVN: 0000580D
Coding: 0014
Shop #: WSC 05311 115 00065
ASAM Dataset: EV_TCMDQ250021 001001
ROD: EV_TCMDQ250021.rod
VCID: 1C612931E629222B1BB-8048
Address 03: ABS Brakes (J104) Labels: 5Q0-907-379-IPB-V1.clb
Part No SW: 5Q0 614 517 CH HW: 5Q0 614 517 AH
Component: ESC H62 0743
Revision: 00000000 Serial number: 61907000000236
Coding: 0FEC6B8F54222371477D070540CB69F0D62AC4E2E00296753842508842A9420000000012121212B835351919323200
Shop #: WSC 00015 115 00001
ASAM Dataset: EV_Brake1UDSContiMK100IPB 036010
ROD: EV_Brake1UDSContiMK100IPB_036_VW48.rod
VCID: 79AF10A5095BB703A0D-802C
Address 05: Acc/Start Auth. (J518) Labels:| 5Q0-959-435.clb
Part No SW: 3Q0 959 435 G HW: 3Q0 959 435 G
Component: VWKESSYMQB 037 0906
Revision: 00037000 Serial number: 0448732144
Coding: 1F20000723
ASAM Dataset: EV_KessyHellaMQBAB 004041
ROD: EV_KessyHellaMQBAB.rod
VCID: 3E25C3B950F5503BD5F-806A
Rear lid opener control module:
Address 08: Auto HVAC (J255) Labels:| 5G0-907-044.clb
Part No SW: 5G0 907 044 DQ HW: 5G0 907 044 DQ
Component: Climatronic H04 2001
Revision: 00001K10
Coding: 1202002420411101111550000010192A
ASAM Dataset: EV_ACClimaBHBVW37X 006146
ROD: EV_ACClimaBHBVW37X_006_VW37.rod
Fresh air blower control module (front):
A/C pressure/coolant temperature sensor:
Air quality sensor:
Humidity sensor: exterior:
Address 09: Cent. Elect. (J519) Labels:. 5Q0-937-08X-V2.clb
Part No SW: 5Q0 937 086 BM HW: 5Q0 937 086 BH
Component: BCM PQ37BOSCH 034 0242
Revision: -------- Serial number: 865829061700DO
ASAM Dataset: EV_BodyContrModul1UDSBosc 018001
ROD: EV_BCMBOSCH_018.rod
VCID: 06556B5948A5C8FBDDF-8052
Wiper motor control module:
Subsystem 1 - Part No SW: 3G1 955 119 A HW: 3G1 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS 170615 042 0607
Serial number: 170629234856
Coding: 0E4DDD
Rain/Light Recognition Sensor:
Subsystem 2 - Part No SW: 5Q0 955 547 B HW: 5Q0 955 547 B Labels: 5Q0-955-547.CLB
Component: RLHS 042 0105
Serial number: S4Y17M06D29H19M25S21
Coding: 00A8DD
Light switch:
Subsystem 3 - Part No SW: 3G0 941 633 H HW: 3G0 941 633 H
Component: E1 - LDS MQB H01 0032
Serial number: 14 04 2017 10001690
Anti-theft alarm system sensor:
Subsystem 4 - Part No SW: 5Q0 951 172 HW: 5Q0 951 172
Component: Sensor, DWA 005 0316
Serial number: 000000000ZY1714382PB
Alarm horn:
Subsystem 5 - Part No SW: 5Q0 951 605 A HW: 5Q0 951 605 A
Component: Sirene, DWA 005 0314
Serial number: 00000000000070188699
Humidity sensor: interior:
Address 10: Park/Steer Assist (J791) Labels:| 5Q0-919-298.clb
Part No SW: 5QA 919 298 C HW: 5QA 919 298 A
Component: PLA 3.0 12KH07 0045
Serial number: 000308417617172
Coding: 0271167951
ASAM Dataset: EV_EPHVA2CAU3700000 009037
ROD: EV_EPHVA2CAU3700000.rod
VCID: 50F98D01FA61D64B373-8004
Address 13: Auto Dist. Reg (J428) Labels:| 3Q0-907-572.clb
Part No SW: 3Q0 907 572 C HW: 3Q0 907 572 C
Component: ACC BOSCH MQB H04 0195
Coding: 320467DB59FFC428949C8045
ASAM Dataset: EV_ACCBOSCHVW48X 001009
ROD: EV_ACCBOSCHVW48X.rod
VCID: 3537DC9565C39363045-8060
Address 14: Susp. Elect. (J250) Labels: 5Q0-907-376.clb
Part No SW: 5Q0 907 376 B HW: 5Q0 907 376 A
Component: DAEMPFUNGS-SG H17 0121
Serial number: 25061741350001
ASAM Dataset: EV_DRCONTITEMIC 001019
ROD: EV_DRCONTITEMIC_001_VW48.rod
VCID: 3829D5A172D16E0B1F3-806C
Address 15: Airbags (J234) Labels:| 5Q0-959-655.clb
Part No SW: 3Q0 959 655 BK HW: 3Q0 959 655 BK
Component: Airbag VW21 006 0703
Revision: -------- Serial number: 003W6PCG5P2/
Coding: 98FCC0C0008000005C5400CF000800000065
Shop #: WSC 05314 000 00001
ASAM Dataset: EV_AirbaVW21TS6VW48X 001014
ROD: EV_AirbaVW21TS6VW48X_VW37.rod
VCID: 0849656142B1DE8BAF3-805C
Left seat belt tensioner:
Subsystem 1 - Part No SW: 4M0 980 945 A HW: 4M0 980 945 A
Component: BeltPretRevFL 106 1040
Serial number: 3G0857705 0031T01500
Coding: 80000D
Right seat belt tensioner:
Subsystem 2 - Part No SW: 4M0 980 946 A HW: 4M0 980 946 A
Component: BeltPretRevFR 106 1032
Serial number: 3G1857706G0185R01460
Coding: 80000D
Subsystem 3 - Part No SW: ----------- HW: 454 001 606 17
Component: SideSensor_Df 008 0887
Serial number: 357000000000507D3628
Coding: 2D2D2D
Subsystem 4 - Part No SW: ----------- HW: 454 001 806 17
Component: SideSensor_Pf 008 0887
Serial number: 358000000008D140C62J
Coding: 2D2D2D
Subsystem 5 - Part No SW: ----------- HW: 454 801 106 17
Component: SideSensor_Dr 301 0148
Serial number: 3510091305210000000U
Coding: 2D2D2D
Subsystem 6 - Part No SW: ----------- HW: 454 801 106 17
Component: SideSensor_Pr 301 0148
Serial number: 352002F2F52100000009
Coding: 2D2D2D
Subsystem 7 - Part No SW: ----------- HW: 454 801 406 17
Component: FrontSensor_D 304 0149
Serial number: 3550040279610000000%
Coding: 2D2D2D
Address 16: Steering wheel (J524) Labels:| 5Q0-953-549.clb
Part No SW: 5Q0 953 521 BB HW: 5Q0 953 569 A
Component: Lenks.Modul 075 0235
Revision: FF033033 Serial number: 20170627200018
Coding: 0C10
ASAM Dataset: EV_SMLSVALEOMQB 001016
ROD: EV_SMLSVALEOMQB.rod
VCID: 73B3228D2B37CD53EA1-8026
Address 17: Instruments (J285) Labels:| 5G0-920-XXX-17.clb-SRI3
Part No SW: 3G0 920 791 C HW: 3G0 920 791 C
Component: KOMBI 406 3193
Coding: 07A40898FE8C000801886B0F1001000080000000
ASAM Dataset: EV_DashBoardVDDMQBAB 009058
ROD: EV_DashBoardVDDMQBAB_009_VW26.rod
VCID: 290F00E5B97BC78390D-807C
Address 18: Aux. Heat (J364) Labels:| 5Q0-963-272.clb
Part No SW: 5Q0 963 272 H HW: 5Q0 963 272 H
Component: STH-MQB 008 0075
Coding: 9309
ASAM Dataset: EV_AuxilParkiHeateWOS 002018
ROD: EV_AuxilParkiHeateWOS.rod
VCID: 3B23CAAD43E74513F21-806E
Auxiliary heating remote control:
Subsystem 1 - Part No SW: 3Q0 963 513 HW: 3Q0 963 513
Component: R64 D208L 004 0401
Serial number: 00000000000000276932
Address 19: CAN Gateway (J533) Labels:| 3Q0-907-530-V1.clb
Part No SW: 3Q0 907 530 G HW: 3Q0 907 530 C
Component: GW MQB High 518 5304
Serial number: 06071710802132
Coding: 0B0300347F015900FB00025E9C0F00010001070000000000000000000000
GVL: 01DE3C0008000600C0DC80000006CC0010040000000200000000000000000000
ASAM Dataset: EV_GatewNF 013023
ROD: EV_GatewNF_VW37.rod
VCID: 3333E28D6BB78D532A1-8066
Generator:
Multifunction steering wheel control module:
Subsystem 2 - Part No SW: 5G0 959 442 N HW: 5G0 959 442 N Labels: 3C8-959-537.CLB
Component: E221__MFL-DC1 H11 0040
Serial number: 29170001407150107262
Coding: 2DFFFF
Subsystem 3 - Part No SW: 3Q0 915 181 B HW: 3Q0 915 181 B
Component: J367-BDMHella H10 9070
Serial number: 5131394104
Inverter for electrical outlet:
Subsystem 4 - Part No SW: 5Q0 907 155 C HW: 5Q0 907 155 C
Component: U13DCAC H26 0780
Serial number: 0066181
Analog clock:
Subsystem 5 - Part No SW: 3G0 919 204 C HW: 3G0 919 204 C
Component: Analoguhr 111 1004
Serial number: 3003201700010095
Address 22: AWD (J492) Labels:* 0CQ-907-554.clb
Part No SW: 0CQ 907 554 H HW: 0CQ 525 130
Component: Haldex4Motion H52 7083
Serial number: HA1-00017.05.17
Coding: 0301
ASAM Dataset: EV_AllWheelContrHA1VW37X 004013
ROD: EV_AllWheelContrHA1VW37X_004.rod
VCID: 4ACD9F691C3DEC9B797-801E
Address 2B: Steer. Col. Lock (J764) Labels:* 5Q0-905-861.clb
Part No SW: 3Q0 905 861 HW: 3Q0 905 861
Component: ELV-MQBB H05 0032
Serial number: 17000160250002
Coding: 0800000000000000
ASAM Dataset: EV_ELVMarquMQBB 001007
ROD: EV_ELVMarquMQBB.rod
VCID: 71BF2885512BFF4318D-8024
Address 36: Seat Mem. Drvr (J810) Labels:* None
Part No SW: 3Q0 959 760 B HW: 3Q0 959 760 B
Component: Sitzmemory H05 0022
Serial number: Y0006QFD15173
Coding: 001000020000050081C280808080000000008181000000F400
ASAM Dataset: EV_SeatMemorDriveSide 002021
ROD: EV_SeatMemorDriveSide.rod
VCID: 3A2DCFA94CDD7C1BE97-806E
Address 3C: Lane Change (J769) Labels:| 3Q0-907-566.clb
Part No SW: 3Q0 907 566 E HW: 3Q0 907 566
Component: MRR1Rear H20 0510
Revision: --------
Coding: 14C002
ASAM Dataset: EV_RearRadarS1BoschVW48X 001007
ROD: EV_RearRadarS1BoschVW48X_VW37.rod
Address 42: Door Elect, Driver (J386) Labels:| 5QX-959-X93-42.clb
Part No SW: 5Q0 959 593 E HW: 5Q0 959 593 B
Component: TSG FS 020 0041
Serial number: 190417EDJ1110A
Coding: 003F1A20D200028000001000
ASAM Dataset: EV_DCUDriveSideEWMAXKLO 006003
ROD: EV_DCUDriveSideEWMAXCONT.rod
VCID: 43D3B24D3B173DD3BA1-8016
Address 44: Steering Assist (J500) Labels:| 5Q0-909-144.clb
Part No SW: 3Q0 909 144 K HW: 3Q0 909 144 H
Component: EPS_MQB_ZFLS 506 5072
Coding: 9307
Shop #: WSC 00015 115 00319
ASAM Dataset: EV_SteerAssisMQB 013144
ROD: EV_SteerAssisMQB_013.rod
Address 47: Sound System (J525) Labels:| 3Q0-035-466.clb
Part No SW: 3Q0 035 465 HW: 3Q0 035 465
Component: MIB2_amp_P_VW H60 0440
Revision: 00000001 Serial number: VWZ8Z1HJD00RUVL
Coding: 1284020001AA0A2AAA0000000000
ASAM Dataset: EV_AMPMst16C3Gen2ALPI 001016
ROD: EV_AMPMst16C3Gen2ALPI_VW37.rod
VCID: 6B833AED73071593221-803E
Address 4B: Multifunc. Module (J745) Labels:| 3Q0-907-338-V1.clb
Part No SW: 3Q0 907 338 HW: 3Q0 907 338
Component: FCM MQB Low 002 0286
Serial number: 01071710801233
Coding: 000000060100035207004F01020000000000000000000000000000000000
Shop #: WSC 05311 000 00001
ASAM Dataset: EV_MultiModulContiVW48X 001010
ROD: EV_MultiModulContiVW48X_001.rod
VCID: 72BD2789542DC45BE17-8026
Left Headlamp Power Output Stage:
Subsystem 1 - Part No SW: 3G0 941 329 _ HW: 3G0 941 329 _
Component: Leimo links H02 0003
Coding: E02400
Right Headlamp Power Output Stage:
Subsystem 2 - Part No SW: 3G0 941 329 _ HW: 3G0 941 329 _
Component: Leimo rechts H02 0003
Coding: E02400
Address 52: Door Elect, Pass. (J387) Labels:| 5QX-959-X92-52.clb
Part No SW: 5Q0 959 592 E HW: 5Q0 959 592 B
Component: TSG BFS 020 0041
Serial number: 170617EFH29274
Coding: 003F1020DE00028200001000
ASAM Dataset: EV_DCUPasseSideEWMAXKLO 006003
ROD: EV_DCUPasseSideEWMAXCONT.rod
VCID: 42DDB749240D34DBB17-8016
Address 5F: Information Electr. (J794) Labels:| 5G0-035-MIB-HGH2.clb
Part No SW: 5NA 035 042 A HW: 5NA 035 042
Component: MU-H-LN-EU H54 1121
Serial number: A847G0HB006263
Coding: 02840201000000005111000200080A101F0106E4012004009F
ASAM Dataset: EV_MUHig4CGen2HBAS 001001
ROD: EV_MUHig4CGen2HBAS_VW37.rod
Display and control head 1 for information electronics:
Subsystem 1 - Part No SW: 5G6 919 606 HW: 5G6 919 606
Component: ABT_High-2 H50 9130
Serial number: VWZ6ZJT1915518
Data carrier:
Subsystem 2 - Part No SW: V03 959 809 PA HW: -----------
Component: ECE 2022 --- 0195
Compact disc data bank:
Subsystem 3 - Part No SW: V03 959 800 EG HW: -----------
Component: Gracenote2 --- 1016
Address 65: Tire Pressure (J502) Labels: 3AA-907-273.clb
Part No SW: 5Q0 907 273 B HW: 5Q0 907 273
Component: RDKBERU30 H04 0009
Serial number: 40000000081630
ROD: EV_RDKBERU30_006_VW37.rod
VCID: 3431E1916EB98A6B33B-8060
Address 69: Trailer (J345) Labels:| 5Q0-907-383.clb
Part No SW: 5Q0 907 383 N HW: 5Q0 907 383 N
Component: Anhaenger H27 0264
Revision: 8A001003 Serial number: 0446947174
Coding: 0100000202000000
ASAM Dataset: EV_TrailFunctGener2Hella 001008
ROD: EV_TrailFunctGener2Hella_VW26.rod
Address 6C: Back-up Cam. (J772) Labels:| 5Q0-980-556.clb
Part No SW: 5Q0 980 556 B HW: 5Q0 980 556 B
Component: RVC Compact H12 0231
Coding: 0184020163002017000040
ASAM Dataset: EV_CamSysRVRVCPANAMQBAB 006009
ROD: EV_CamSysRVRVCPANAMQBAB_006_VW37.rod
VCID: 392FD0A549DB7703E0D-806C
Address 6D: Trunk Elect. (J605) Labels:| 5Q0-959-107.clb
Part No SW: 5Q0 959 107 L HW: 5Q0 959 107 J
Component: HDSG-Modul H13 0261
Revision: -------- Serial number: 31433445900000
Coding: 0288
ASAM Dataset: EV_DeckLidCONTIAU736 001014
ROD: EV_DeckLidCONTIAU736_VW41.rod
VCID: 41DFB845210B2FC3A8D-8014
Address A5: Frt Sens. Drv. Assist (R242) Labels:| 3Q0-980-65X-A5.clb
Part No SW: 3Q0 980 654 H HW: 3Q0 980 654 A
Component: MQB_B_MFK H07 0272
Serial number: 14061711P11354
Coding: 000408020000040100222347C150A90094000E300040
ASAM Dataset: EV_MFKBoschMQBB 001001
ROD: EV_MFKBoschMQBB_001_VW36.rod
VCID: 3C21C9B146E9422BFBB-8068
Address BB: Door Rear Drv (J388) Labels:* None
Part No SW: 5Q0 959 595 E HW: 5Q0 959 595 B
Component: TSG HFS 020 0041
Serial number: 070617EF614855
Coding: 000E10200100028000001000
ASAM Dataset: EV_DCURearDriveMAXKLO 006003
ROD: EV_DCURearDriveMAXCONT.rod
VCID: 45D7AC55352303E3945-8010
Address BC: Door Rear Pass (J389) Labels:* None
Component: TSG HBFS 020 0041
Serial number: 070617EF613546
ASAM Dataset: EV_DCURearPasseMAXKLO 006003
ROD: EV_DCURearPasseMAXCONT.rod
Address CA: Sunroof (J245) Labels:| 4M0-907-594.clb
Part No SW: 4M0 907 594 J HW: 4M0 907 594
Component: SAD_STG_1 014 0005
Coding: 208040748202
ASAM Dataset: EV_SunRoofCONTIAU736 006008
ROD: EV_SunRoofCONTIAU736_006.rod
VCID: 3D27C4B55DF34B23CC5-8068
Address CF: Lane Chge Asst 2 (J770) Labels:. 3Q0-907-566.clb
Part No SW: 3Q0 907 590 E HW: 3Q0 907 590
Revision: --------
Coding: 14C002
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_RearRadarS2BoschVW48X 001007
ROD: EV_RearRadarS2BoschVW48X_VW37.rod
VCID: 372BD69D7FCF6173169-8062
Address D6: Light Ctrl Left 2 (A31) Labels: 7PP-941-572.clb
Part No SW: 7PP 941 572 AB HW: 7PP 941 572 A
Component: LED1L H09 0003
ASAM Dataset: EV_LEDModLeftMELCOAU736 001004
ROD: EV_LEDModLeftMELCOAU736_VW37.rod
VCID: 16753B191805787B2DF-8042
Address D7: Light Ctrl Right 2 (A27) Labels: 7PP-941-572.clb
Component: LED1R H09 0003
ASAM Dataset: EV_LEDModRightMELCOAU736 001004
End----(Elapsed Time: 02:50, VBatt start/end: 12.0V/11.9V. VIgn 11.9V)-----
