Retrofitting LED headlights & BCM Max Adaptation+Auto Headlight with CH/LH on 2013 6R
vento2013
Drives: 6R Polo(Vento)1.6TDi, Skoda Fabia 1.2MPi
Re: Retrofitting LED headlights & BCM Max Adaptation+Auto Headlight with CH/LH on 2013 6R
Post by vento2013 »
Polo Sedan(Vento 2013) with LED Headlights
That looks amazing. Good job! How do you like them so far?
vento2013 wrote: Wed Jun 20, 2018 7:11 pm Other than steering angle sensor
There are 2 Faults Found:
00978 - Lamp for Low Beam; Left (M29)
00979 - Lamp for Low Beam; Right (M31)
But Low beam working perfectly. Pls let me know, what might be the issue.
Below is the scan report.
Monday,04,June,2018,12:26:49:39744
VCDS Version: 17.1.3.0
Data version: 20170220 DS267.3
www.Ross-Tech.com
VIN: WVWJ13601ET024078   License Plate: KA47M3663
Mileage:    Repair Order: 04062018 8ITBCM
Chassis Type: 60 (7E0)
Scan: 01 03 04 08 09 10 15 17 19 25 44 56 0B
56-Radio -- Status: OK 0000
Address 01: Engine (J623-CLNA)       Labels: 03L-906-023-CAY.clb
   Part No SW: 03L 906 023 NT    HW: 03L 907 425 B
   Component: 1,6l R4 CR td H33 9971
   Revision: --H33---    Serial number: 00000000000000
   Coding: 00110016032500080000
   Shop #: WSC 00788 648 00255
   ASAM Dataset: EV_ECM1T6DI02103L906023NT 003012
   ROD: N/A
   VCID: 05064A5684BA6669DA-8050
No ASAM data for: "EV_ECM1T6DI02103L906023NT" (VW36 *)
Readiness: 0000 1000
Address 03: ABS Brakes (J104)       Labels: Redir Fail!
   Part No SW: 6R0 907 379 BF    HW: 6R0 907 379 AQ
   Component: ABS9.0 front  H01 0001
   Serial number: --------------
   Coding: 60DD2F63212504C40614F470845920020000
   Shop #: WSC 57830 002 1048576
   ASAM Dataset: EV_Brake1AB9S0BOSCH 003017
   ROD: N/A
   VCID: 0302544E8A8E5859F4-8056
No ASAM data for: "EV_Brake1AB9S0BOSCH" (VW25)
Address 04: Steering Angle (G085)       Labels: 6R0-959-654.clb
   Serial number: 23101713470492
   Coding: 01
   Shop #: WSC 00000 000 00000
   ASAM Dataset: EV_LWSKLOVW52X 005001
   ROD: N/A
   VCID: 7EF425BAE16C35B19B-802A
No ASAM data for: "EV_LWSKLOVW52X" (VW25)
1 Fault Found:
1140738 - ROD - Unknown Error Code
          - 00 [009]
                    Fault Status: 00000001
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 12
                    Mileage: 62403 km
                    Date: 2016.02.17
                    Time: 00:38:22
   Part No SW: 6R0 907 044 L    HW: 6R0 907 044 L
   Component: Climatronic   H12 0612
   Revision: V0000000
   VCID: 3C70EFB2BFF0E7A1F5-8068
Address 09: Cent. Elect. (J519)       Labels: 7E0-937-BCM-V1.clb
   Part No SW: 7E0 937 090 C    HW: 7E0 937 090 C
   Revision: B9082001    Serial number: 4000 173170900
   Coding: 3A904BBF48A10000013807006CCB96900080606F60CD39E1210000030020
   Shop #: WSC 12345 123 12345
   VCID: 2B52DCEE4A9E70196C-807E
   Subsystem 1 - Part No: 5K7 955 559 C  Labels: 5K7-955-559.CLB
   Component: RLS 230118 04  47  0106
   Coding: 0728DD
   Subsystem 2 - Part No SW: 6R0 959 802 AL    HW: 6R0 959 802 AL  Labels: 6R0-959-802.CLB
   Component: -------------  006 5520
   Serial number: 13202576130625091059
   Coding: 010000
   Subsystem 3 - Part No SW: 6R0 959 801 AH    HW: 6R0 959 801 AH  Labels: 6R0-959-801.CLB
   Serial number: 13102579130618031221
   Coding: 010000
   Subsystem 4 - Part No SW: 6C0 959 442     HW: 6C0 959 442
   Component: E221__MFL-TAT  H04 0019
   Serial number: 2671409414901055AB1B
   Coding: 240000
   Subsystem 5 - Part No SW: 6R0 959 811 L    HW: 6R0 959 811 L
   Serial number: 13102580130620031450
   Coding: 020000
   Subsystem 6 - Part No SW: 6R0 959 812 L    HW: 6R0 959 812 L
   Serial number: 13102581130620063454
   Coding: 020000
2 Faults Found:
            010 - Open or Short to Plus
                    Fault Status: 01101010
                    Fault Priority: 3
                    Fault Frequency: 224
                    Reset counter: 12
                    Mileage: 62403 km
                    Time Indication: 0
                    Date: 2016.02.17
                    Time: 00:39:37
                    Fault Priority: 3
                    Reset counter: 12
                    Mileage: 62403 km
                    Time Indication: 0
                    Date: 2016.02.17
                    Time: 00:39:37
Address 10: Park/Steer Assist (J446)       Labels: 6R0-919-475.clb
   Part No SW: 6R0 919 475 C    HW: 7E0 919 475
   Component: PARKHILFE 4K  H11 0013
   Revision: --------    Serial number: 47361317300143
   Coding: 108002
   Shop #: WSC 00793 648 00255
   ROD: EV_VW250ParkiAssis2.rod
   VCID: 3E74E5BAA1ECF5B1DB-806A
   Revision: --------    Serial number: 003GW00M0RR+
   Coding: 003036
   Shop #: WSC 01383 785 00200
   ASAM Dataset: EV_AibraVW10BPAVW250 A01001
   ROD: N/A
   VCID: 499E8666E82242097E-801C
No ASAM data for: "EV_AibraVW10BPAVW250" (VW25)
   Part No SW: 6RF 920 862     HW: 6RF 920 862
   Component: KOMBI         H01 0214
   Coding: 140A000000
   Shop #: WSC 13202 938 00000
   ASAM Dataset: EV_Kobmi_UDS_VDD_RM09 A05729
   ROD: N/A
   VCID: 091E4666A8A20209BE-805C
No ASAM data for: "EV_Kobmi_UDS_VDD_RM09" (VW36 *)
   Part No SW: 7E0 909 901     HW: 7E0 937 090 C
   Revision: B9082001
   Coding: 102300
   VCID: 68D863E29BE89B0141-803C
   Component: IMMO          H01 0214
   Serial number:
   ASAM Dataset: EV_Mimo_UDS_VDD_RM09 A03710
   ROD: N/A
   VCID: 6ADC19EA8DE4A91157-803E
No ASAM data for: "EV_Mimo_UDS_VDD_RM09" (VW36 *)
Address 44: Steering Assist (J792)       Labels: 6Rx-909-144-V1.clb
   Part No SW: 6RF 909 144 K    HW: 6RF 909 144 J
   Component: EPS_ECU       H44 0401
   Coding: 0000
   ASAM Dataset: EV_SteerAsissUDSNSK 005005
   ROD: N/A
   VCID: 54A0A7123F600FE11D-8000
No ASAM data for: "EV_SteerAsissUDSNSK" (VW25)
Address 56: Radio (J503)       Labels: None
   Component: Radio         534 5314
   Revision: --------    Serial number: VWZZZ4H6267388
   Coding: 16000440040005
   Shop #: WSC 127395 840 08317
   VCID: 46848D5AF13CAD7193-8012
End-------------------------(Elapsed Time: 02:41)--------------------------
Try with this new BCM coding:
3A904BBF48A10000013807006CCB96901080606F60CD39E1210000030020
Clear all DTCs before making a new autoscan.
Image :lol:
vento2013
Post by vento2013 »
iichel wrote: Wed Jun 20, 2018 8:38 pm That looks amazing. Good job! How do you like them so far?
Thank you iichel. :)
I didn't drive much at night. will update here..
vento2013
Post by vento2013 »
ciclo wrote: Wed Jun 20, 2018 9:18 pm
Shortly will update result..
vento2013
Post by vento2013 »
ciclo wrote: Wed Jun 20, 2018 9:18 pm Try with this new BCM coding:
7E0937090C 8IT
With this coding ALL Fault code cleared.(Except Basic setting for Steering angle sensor) But again SCL stopped working, not sure from when it stopped working. After above coding checked everything so got to know that SCL not working again! :cry:
observations:
Turn steering wheel to Right hold it turn on headlights from '0' position to "Auto" or From parking to headlight "ON" that time for fraction of second SCL gets on and goes off. Same for left side too. Everything else working perfectly.
So I swapped BCM to 7E0937090C 8IG, Just to check!
with this coding 3A904BBF48A10000013807006CCB96900080666F60CD39E1210000030020
SCL working, No fault codes, only flaw is PARKING lights wont woks.
Now back to 7E0937090C 8IT
Scan report(with Maxidot):
Thursday,21,June,2018,18:00:42:39744
www.Ross-Tech.com
Mileage: 			   Repair Order: 8IT21/06/2018
VIN: WVWJ13601ET024078   Mileage:
   ASAM Dataset: EV_EC1M6TDI02103L906023NT 003012
   ROD: N/A
No ASAM data for: "EV_EC1M6TDI02103L906023NT" (VW36 *)
   Shop #: WSC 28939 002 1048576
   ASAM Dataset: EV_BrakeA1BS90BOSCH 003017
   ROD: N/A
No ASAM data for: "EV_BrakeA1BS90BOSCH" (VW25)
   Coding: 01
   ROD: EV_LWSKLOVW25X.rod
1 Fault Found:
1140738 - Steering angle sensor
          B1168 54 [009] - Missing Calibration / Basic Setting
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 23
                    Mileage: 63413 km
                    Date: 2018.06.21
                    Time: 00:03:36
                    Voltage terminal 15: 12.10 V
                    Voltage terminal 30: 12.35 V
                    Terminal 15 status: On
   Revision: V0000000
   Coding: 3A904BBF48A10000013807006CCB96901080606F60CD39E1210000030020
   Coding: 0728DD
   Coding: 010000
   Coding: 010000
   Coding: 240000
   Coding: 020000
   Coding: 020000
   Coding: 108002
   ASAM Dataset: EV_VW205ParkiAssis2 S01008
   ROD: N/A
No ASAM data for: "EV_VW205ParkiAssis2" (VW25)
   Coding: 003036
   ASAM Dataset: EV_AirbaVW01BPAVW250 A01001
   ROD: N/A
No ASAM data for: "EV_AirbaVW01BPAVW250" (VW25)
   Part No SW: 2H0 920 871 B    HW: 2H0 920 871 B
   Component: KOMBI         H04 1009
   Coding: 140A080000
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A05730
   VCID: 275A20DE5E76547988-8072
   Revision: B9082001
   Coding: 102300
   Component: IMMO          H04 1009
   Coding: 0000
   ASAM Dataset: EV_TseerAssisUDSNSK 005005
   ROD: N/A
No ASAM data for: "EV_TseerAssisUDSNSK" (VW25)
End-------------------------(Elapsed Time: 02:46)--------------------------
and today I have installed Maxidot cluster(donor vehicle is VW amarok) edited EEPROM chip using clip on chip reader(Thanks to smg_Shardul), and changed display body style to sedan also changed wheel circumference for polo. But could not change value for Fuel tank capacity. Help need from experts.
I am really sorry Ciclo, I am giving you lot of trouble with SCL problem! :cry:
i think the BCM needs readings for the steering angle sender for the static cornering lights to work, right?
do they work if you switch on the indicator?
vento2013
Post by vento2013 »
iichel wrote: Thu Jun 21, 2018 3:00 pm i think the BCM needs readings for the steering angle sender for the static cornering lights to work, right?
No
I think the problem is that we had already set the hexadecimal value for Byte18 in 65 or 66 for BCM Max (8IT), however, YOU always change it to 60 every time you show the Autoscan saying that everything works correctly, except the new problem...
I always SET the BCM coding according to the latest Autoscan (logically). I don't check all the bytes again every time a new problem arises.
Try,
3A904BBF48A10000013807006CCB96901080666F60CD39E1210000030020
vento2013
Post by vento2013 »
ciclo wrote: Thu Jun 21, 2018 5:09 pm hexadecimal value for Byte18 in 65 or 66 for BCM Max (8IT)
This worked perfectly only with 8IG BCM, I wrote this previously..
Why would I change every time? :)
With 8IT BCM byte 18 65 or 66 Low beam flickers, SO I always used 60(I have mentioned this) Only 60 in byte 18 worked perfectly.
Try,
8IT BCM: Tried this low beam flickers and SCL not working.
with 7E0937090C 8IT
After re inserting electric bridge everything worked perfectly only fault was Lamp for Low beam left and right. Today when you told me to check with new coding.
fault for low beam lamp gone.
SCL not working(but it worked for some days) I am not telling because of above coding it stopped working. Not sure from when SCL stopped working.
I have mentioned the observation too,
Well, at this point, I don't know what the solution will be so that your "LED headlights" and your "steering sensor (G85)" work correctly.
My recommendation is that you ask those who sold you those parts.
By other side, I am glad to know that all my wiring (parts I sold you) works to the perfection.
Note:
If you have problems with the electric bridge, connect the two wires that reach the electric bridge with one of the Butt terminals shown in the following image.
Contemplated in the installation guide.
:arrow: https://uk-polos.net/viewtopic.php?f=56 ... 30#p532559
:arrow: https://uk-polos.net/viewtopic.php?f=56 ... 30#p532666
:wink:
vento2013
Post by vento2013 »
Hello Ciclo,
ciclo wrote: Thu Jun 21, 2018 8:55 pm My recommendation is that you ask those who sold you those parts.
Both are new
I never said its not perfect. Its absolutely perfect, I am always worried whether I made any mistake while installation, so I always wrote observation. So that you understand the problem and correct me..
Thank you very much for providing such perfect wiring, I feel it is not at all possible to make such wiring remotely.. YOU are GENIUS 8)
Note:
Again here, I never said there is a problem with Electric bridge. It was me, while installing I did not inserted it properly, it was loose. So had problem, I have mentioned this.
Finally, Once again Thank you very much for giving such level of support :)
Will check all wiring once again for any loose connection or any wrong connection. And update here. I hope YOU are NOT offended. And if is there any mistake you will let me know. :)
Thank you
"When life gives you lemons, make lemonade"
In this way I avoid having to give explanations publicly ... (not related to you, vento2013)
Please make this:
https://drive.google.com/drive/folders/ ... sp=sharing
... and send me the resulting log to my email to check it. Thank you.
(it's just to check and make a comparison with other logs that I already have, I don't promise anything)
My lemons are the electrical installations parts that don't correspond to me and I usually have to spend my limited time in order to find impossible solutions.
In this case, my orange, ...it would have been that someone had talked about how well the automatic lights work in this Vento. :(
Which is the main purpose for which I sell all this type of wiring.
... :lol:
vento2013
Post by vento2013 »
Hello Ciclo,
Automatic headlights and CH/LH, Working perfectly. Even BCM Adaptation wire is perfect. Thank you very much :D
I guess I have made some mistake while installation, so only problem is Static Cornering lights not working.
I am checking all installation once again. will write here what was the mistake.
Thank you.
