Retrofitting LED headlights & BCM Max Adaptation+Auto Headlight with CH/LH on 2013 6R
- Drives: 6R Polo(Vento)1.6TDi, Skoda Fabia 1.2MPi
Re: Retrofitting LED headlights & BCM Max Adaptation+Auto Headlight with CH/LH on 2013 6R
Polo Sedan(Vento 2013) with LED Headlights
That looks amazing. Good job! How do you like them so far?
Try with this new BCM coding:vento2013 wrote: ↑Wed Jun 20, 2018 7:11 pm Other than steering angle sensor
There are 2 Faults Found:
00978 - Lamp for Low Beam; Left (M29)
00979 - Lamp for Low Beam; Right (M31)
But Low beam working perfectly. Pls let me know, what might be the issue.
Below is the scan report.Code: Select all
Monday,04,June,2018,12:26:49:39744 VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x86 VCDS Version: 17.1.3.0 Data version: 20170220 DS267.3 www.Ross-Tech.com VIN: WVWJ13601ET024078 License Plate: KA47M3663 Mileage: Repair Order: 04062018 8ITBCM -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Chassis Type: 60 (7E0) Scan: 01 03 04 08 09 10 15 17 19 25 44 56 0B VIN: WVWJ13601ET024078 01-Engine -- Status: OK 0000 03-ABS Brakes -- Status: OK 0000 04-Steering Angle -- Status: OK 0000 08-Auto HVAC -- Status: OK 0000 09-Cent. Elect. -- Status: Malfunction 0010 10-Park/Steer Assist -- Status: OK 0000 15-Airbags -- Status: OK 0000 17-Instruments -- Status: OK 0000 19-CAN Gateway -- Status: OK 0000 25-Immobilizer -- Status: OK 0000 44-Steering Assist -- Status: OK 0000 56-Radio -- Status: OK 0000 ------------------------------------------------------------------------------- Address 01: Engine (J623-CLNA) Labels: 03L-906-023-CAY.clb Part No SW: 03L 906 023 NT HW: 03L 907 425 B Component: 1,6l R4 CR td H33 9971 Revision: --H33--- Serial number: 00000000000000 Coding: 00110016032500080000 Shop #: WSC 00788 648 00255 ASAM Dataset: EV_ECM1T6DI02103L906023NT 003012 ROD: N/A VCID: 05064A5684BA6669DA-8050 No ASAM data for: "EV_ECM1T6DI02103L906023NT" (VW36 *) No fault code found. Readiness: 0000 1000 ------------------------------------------------------------------------------- Address 03: ABS Brakes (J104) Labels: Redir Fail! Part No SW: 6R0 907 379 BF HW: 6R0 907 379 AQ Component: ABS9.0 front H01 0001 Serial number: -------------- Coding: 60DD2F63212504C40614F470845920020000 Shop #: WSC 57830 002 1048576 ASAM Dataset: EV_Brake1AB9S0BOSCH 003017 ROD: N/A VCID: 0302544E8A8E5859F4-8056 No ASAM data for: "EV_Brake1AB9S0BOSCH" (VW25) No fault code found. ------------------------------------------------------------------------------- Address 04: Steering Angle (G085) Labels: 6R0-959-654.clb Part No SW: 6R0 959 654 HW: 6R0 959 654 Component: LENKW.SENSOR H07 0070 Serial number: 23101713470492 Coding: 01 Shop #: WSC 00000 000 00000 ASAM Dataset: EV_LWSKLOVW52X 005001 ROD: N/A VCID: 7EF425BAE16C35B19B-802A No ASAM data for: "EV_LWSKLOVW52X" (VW25) 1 Fault Found: 1140738 - ROD - Unknown Error Code - 00 [009] Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 2 Fault Frequency: 1 Reset counter: 12 Mileage: 62403 km Date: 2016.02.17 Time: 00:38:22 ------------------------------------------------------------------------------- Address 08: Auto HVAC (J255) Labels: 6R0-907-044.clb Part No SW: 6R0 907 044 L HW: 6R0 907 044 L Component: Climatronic H12 0612 Revision: V0000000 VCID: 3C70EFB2BFF0E7A1F5-8068 No fault code found. ------------------------------------------------------------------------------- Address 09: Cent. Elect. (J519) Labels: 7E0-937-BCM-V1.clb Part No SW: 7E0 937 090 C HW: 7E0 937 090 C Component: BCM PQ25 Max4 H82 0752 Revision: B9082001 Serial number: 4000 173170900 Coding: 3A904BBF48A10000013807006CCB96900080606F60CD39E1210000030020 Shop #: WSC 12345 123 12345 VCID: 2B52DCEE4A9E70196C-807E Subsystem 1 - Part No: 5K7 955 559 C Labels: 5K7-955-559.CLB Component: RLS 230118 04 47 0106 Coding: 0728DD Subsystem 2 - Part No SW: 6R0 959 802 AL HW: 6R0 959 802 AL Labels: 6R0-959-802.CLB Component: ------------- 006 5520 Serial number: 13202576130625091059 Coding: 010000 Subsystem 3 - Part No SW: 6R0 959 801 AH HW: 6R0 959 801 AH Labels: 6R0-959-801.CLB Component: ------------- 006 5520 Serial number: 13102579130618031221 Coding: 010000 Subsystem 4 - Part No SW: 6C0 959 442 HW: 6C0 959 442 Component: E221__MFL-TAT H04 0019 Serial number: 2671409414901055AB1B Coding: 240000 Subsystem 5 - Part No SW: 6R0 959 811 L HW: 6R0 959 811 L Component: ------------- 006 5520 Serial number: 13102580130620031450 Coding: 020000 Subsystem 6 - Part No SW: 6R0 959 812 L HW: 6R0 959 812 L Component: ------------- 006 5520 Serial number: 13102581130620063454 Coding: 020000 2 Faults Found: 00978 - Lamp for Low Beam; Left (M29) 010 - Open or Short to Plus Freeze Frame: Fault Status: 01101010 Fault Priority: 3 Fault Frequency: 224 Reset counter: 12 Mileage: 62403 km Time Indication: 0 Date: 2016.02.17 Time: 00:39:37 00979 - Lamp for Low Beam; Right (M31) 010 - Open or Short to Plus Freeze Frame: Fault Status: 01101010 Fault Priority: 3 Fault Frequency: 224 Reset counter: 12 Mileage: 62403 km Time Indication: 0 Date: 2016.02.17 Time: 00:39:37 ------------------------------------------------------------------------------- Address 10: Park/Steer Assist (J446) Labels: 6R0-919-475.clb Part No SW: 6R0 919 475 C HW: 7E0 919 475 Component: PARKHILFE 4K H11 0013 Revision: -------- Serial number: 47361317300143 Coding: 108002 Shop #: WSC 00793 648 00255 ASAM Dataset: EV_VW250ParkiAssis2 S01008 ROD: EV_VW250ParkiAssis2.rod VCID: 3E74E5BAA1ECF5B1DB-806A No fault code found. ------------------------------------------------------------------------------- Address 15: Airbags (J234) Labels: 5K0-959-655.clb Part No SW: 6R0 959 655 J HW: 6R0 959 655 J Component: VW10AirbagU06 H10 0020 Revision: -------- Serial number: 003GW00M0RR+ Coding: 003036 Shop #: WSC 01383 785 00200 ASAM Dataset: EV_AibraVW10BPAVW250 A01001 ROD: N/A VCID: 499E8666E82242097E-801C No ASAM data for: "EV_AibraVW10BPAVW250" (VW25) No fault code found. ------------------------------------------------------------------------------- Address 17: Instruments (J285) Labels: 5K0-920-xxx-17.clb Part No SW: 6RF 920 862 HW: 6RF 920 862 Component: KOMBI H01 0214 Serial number: 00000000000000 Coding: 140A000000 Shop #: WSC 13202 938 00000 ASAM Dataset: EV_Kobmi_UDS_VDD_RM09 A05729 ROD: N/A VCID: 091E4666A8A20209BE-805C No ASAM data for: "EV_Kobmi_UDS_VDD_RM09" (VW36 *) No fault code found. ------------------------------------------------------------------------------- Address 19: CAN Gateway (J533) Labels: None Part No SW: 7E0 909 901 HW: 7E0 937 090 C Component: GW-K-CAN TP20 H82 0752 Revision: B9082001 Coding: 102300 Shop #: WSC 12345 123 12345 VCID: 68D863E29BE89B0141-803C No fault code found. ------------------------------------------------------------------------------- Address 25: Immobilizer (J334) Labels: 5K0-920-xxx-25.clb Part No SW: 5K0 953 234 HW: 5K0 953 234 Component: IMMO H01 0214 Serial number: Coding: 000000 Shop #: WSC 00000 000 00000 ASAM Dataset: EV_Mimo_UDS_VDD_RM09 A03710 ROD: N/A VCID: 6ADC19EA8DE4A91157-803E No ASAM data for: "EV_Mimo_UDS_VDD_RM09" (VW36 *) No fault code found. ------------------------------------------------------------------------------- Address 44: Steering Assist (J792) Labels: 6Rx-909-144-V1.clb Part No SW: 6RF 909 144 K HW: 6RF 909 144 J Component: EPS_ECU H44 0401 Coding: 0000 Shop #: WSC 00000 000 00000 ASAM Dataset: EV_SteerAsissUDSNSK 005005 ROD: N/A VCID: 54A0A7123F600FE11D-8000 No ASAM data for: "EV_SteerAsissUDSNSK" (VW25) No fault code found. ------------------------------------------------------------------------------- Address 56: Radio (J503) Labels: None Part No SW: 6RD 035 187 B HW: 6RD 035 187 B Component: Radio 534 5314 Revision: -------- Serial number: VWZZZ4H6267388 Coding: 16000440040005 Shop #: WSC 127395 840 08317 VCID: 46848D5AF13CAD7193-8012 No fault code found. End-------------------------(Elapsed Time: 02:41)--------------------------
3A904BBF48A10000013807006CCB96901080606F60CD39E1210000030020
Clear all DTCs before making a new autoscan.
7E0937090C 8IT
With this coding ALL Fault code cleared.(Except Basic setting for Steering angle sensor) But again SCL stopped working, not sure from when it stopped working. After above coding checked everything so got to know that SCL not working again!
observations:
Turn steering wheel to Right hold it turn on headlights from '0' position to "Auto" or From parking to headlight "ON" that time for fraction of second SCL gets on and goes off. Same for left side too. Everything else working perfectly.
So I swapped BCM to 7E0937090C 8IG, Just to check!
with this coding 3A904BBF48A10000013807006CCB96900080666F60CD39E1210000030020
SCL working, No fault codes, only flaw is PARKING lights wont woks.
Now back to 7E0937090C 8IT
Scan report(with Maxidot):
Thursday,21,June,2018,18:00:42:39744
www.Ross-Tech.com
Mileage: Repair Order: 8IT21/06/2018
VIN: WVWJ13601ET024078 Mileage:
ASAM Dataset: EV_EC1M6TDI02103L906023NT 003012
ROD: N/A
No ASAM data for: "EV_EC1M6TDI02103L906023NT" (VW36 *)
Shop #: WSC 28939 002 1048576
ASAM Dataset: EV_BrakeA1BS90BOSCH 003017
ROD: N/A
No ASAM data for: "EV_BrakeA1BS90BOSCH" (VW25)
Coding: 01
ROD: EV_LWSKLOVW25X.rod
1 Fault Found:
1140738 - Steering angle sensor
B1168 54 [009] - Missing Calibration / Basic Setting
Fault Priority: 2
Fault Frequency: 1
Reset counter: 23
Mileage: 63413 km
Date: 2018.06.21
Time: 00:03:36
Voltage terminal 15: 12.10 V
Voltage terminal 30: 12.35 V
Terminal 15 status: On
Revision: V0000000
Coding: 3A904BBF48A10000013807006CCB96901080606F60CD39E1210000030020
Coding: 0728DD
Coding: 010000
Coding: 010000
Coding: 240000
Coding: 020000
Coding: 020000
Coding: 108002
ASAM Dataset: EV_VW205ParkiAssis2 S01008
ROD: N/A
No ASAM data for: "EV_VW205ParkiAssis2" (VW25)
Coding: 003036
ASAM Dataset: EV_AirbaVW01BPAVW250 A01001
ROD: N/A
No ASAM data for: "EV_AirbaVW01BPAVW250" (VW25)
Part No SW: 2H0 920 871 B HW: 2H0 920 871 B
Component: KOMBI H04 1009
Coding: 140A080000
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A05730
VCID: 275A20DE5E76547988-8072
Revision: B9082001
Coding: 102300
Component: IMMO H04 1009
Coding: 0000
ASAM Dataset: EV_TseerAssisUDSNSK 005005
ROD: N/A
No ASAM data for: "EV_TseerAssisUDSNSK" (VW25)
End-------------------------(Elapsed Time: 02:46)--------------------------
I am really sorry Ciclo, I am giving you lot of trouble with SCL problem!
i think the BCM needs readings for the steering angle sender for the static cornering lights to work, right?
do they work if you switch on the indicator?
I think the problem is that we had already set the hexadecimal value for Byte18 in 65 or 66 for BCM Max (8IT), however, YOU always change it to 60 every time you show the Autoscan saying that everything works correctly, except the new problem...
I always SET the BCM coding according to the latest Autoscan (logically). I don't check all the bytes again every time a new problem arises.
Try,
3A904BBF48A10000013807006CCB96901080666F60CD39E1210000030020
Try,
This worked perfectly only with 8IG BCM, I wrote this previously..
Why would I change every time?YOU always change it to 60 every time you show the Autoscan saying that everything works correctly, except the new problem...
With 8IT BCM byte 18 65 or 66 Low beam flickers, SO I always used 60(I have mentioned this) Only 60 in byte 18 worked perfectly.
8IT BCM: Tried this low beam flickers and SCL not working.Try,
with 7E0937090C 8IT
After re inserting electric bridge everything worked perfectly only fault was Lamp for Low beam left and right. Today when you told me to check with new coding.
fault for low beam lamp gone.
SCL not working(but it worked for some days) I am not telling because of above coding it stopped working. Not sure from when SCL stopped working.
I have mentioned the observation too,
Well, at this point, I don't know what the solution will be so that your "LED headlights" and your "steering sensor (G85)" work correctly.
My recommendation is that you ask those who sold you those parts.
By other side, I am glad to know that all my wiring (parts I sold you) works to the perfection.
Note:
If you have problems with the electric bridge, connect the two wires that reach the electric bridge with one of the Butt terminals shown in the following image.
Contemplated in the installation guide.
https://uk-polos.net/viewtopic.php?f=56 ... 30#p532559
https://uk-polos.net/viewtopic.php?f=56 ... 30#p532666
Note:
Hello Ciclo,
Thank you very much for providing such perfect wiring, I feel it is not at all possible to make such wiring remotely.. YOU are GENIUS
Finally, Once again Thank you very much for giving such level of support
Will check all wiring once again for any loose connection or any wrong connection. And update here. I hope YOU are NOT offended. And if is there any mistake you will let me know.
Thank you
Both are new
I never said its not perfect. Its absolutely perfect, I am always worried whether I made any mistake while installation, so I always wrote observation. So that you understand the problem and correct me..By other side, I am glad to know that all my wiring (parts I sold you) works to the perfection.
Again here, I never said there is a problem with Electric bridge. It was me, while installing I did not inserted it properly, it was loose. So had problem, I have mentioned this.Note:
Thank you
"When life gives you lemons, make lemonade"
In this way I avoid having to give explanations publicly ... (not related to you, vento2013)
Please make this:
https://drive.google.com/drive/folders/ ... sp=sharing
... and send me the resulting log to my email to check it. Thank you.
(it's just to check and make a comparison with other logs that I already have, I don't promise anything)
My lemons are the electrical installations parts that don't correspond to me and I usually have to spend my limited time in order to find impossible solutions.
In this case, my orange, ...it would have been that someone had talked about how well the automatic lights work in this Vento.
Which is the main purpose for which I sell all this type of wiring.
Hello Ciclo,
Automatic headlights and CH/LH, Working perfectly. Even BCM Adaptation wire is perfect. Thank you very much
I guess I have made some mistake while installation, so only problem is Static Cornering lights not working.
I am checking all installation once again. will write here what was the mistake.
Thank you.
Thank you.
