Polo LED headlights
firegrafik
Drives: 6R 1,6MPI(CFNA) sedan
Re: Polo LED headlights
Post by firegrafik »
I suppose even you installed BCM from donor, the coding and all adaptations were changed to the same values as was in your old BCM.
As I wrote I don't know the exact parameters to change so you need to find them yourself by comparing codings and all adaptations in 09Centr.elect your and Polo6C with factory LED headlights
iceman86
Drives: 6C 1.2 TSI DSG
Post by iceman86 »
I am not really an expert on doing mods on bcm...that’s why i am hoping to find some support from the ones who have already done that...:)
dimblue
Drives: polo 6r tdi dsg
Post by dimblue »
Iceman can you tell me please which bcm give you the donnor because i have the same prpblems
You will need a bcm from a t6 or from Indian 6R (both with factory led headlights, or 8IT) or a different 7e0 937 090 /a/b/c/d that will need to be parametrised to the correct settings for LED headlights with i.e. vcp
iceman86
Post by iceman86 »
Hello guys. Is there anyone available to assist me in coding the led headlights? The guy that configured them up to this point is no longer available and me alone cannot manage to figure it out.
I have the vcds...Could it be fixed remote? Thanks
Can you show an autoscan please?
iceman86
Post by iceman86 »
I currently have on me the obdeleven but on monday I will do a proper scan with vcds
obdeleven scan
obdeleven scan
iceman86
Post by iceman86 »
I made a full scan and these are the faults on the headlights...sorry for the low photo quality
Muckman
Drives: 6c GTI
Post by Muckman »
iceman86 wrote: Thu May 23, 2019 8:27 pm I made a full scan and these are the faults on the headlights...sorry for the low photo quality
Did you end up fixing this problem? or is it a fact that if your car does not have a range control module your always going to have this fault?
