I suppose even you installed BCM from donor, the coding and all adaptations were changed to the same values as was in your old BCM.
As I wrote I don't know the exact parameters to change so you need to find them yourself by comparing codings and all adaptations in 09Centr.elect your and Polo6C with factory LED headlights
Polo LED headlights
- Drives: 6R 1,6MPI(CFNA) sedan
Re: Polo LED headlights
I am not really an expert on doing mods on bcm...that’s why i am hoping to find some support from the ones who have already done that...
Iceman can you tell me please which bcm give you the donnor because i have the same prpblems
You will need a bcm from a t6 or from Indian 6R (both with factory led headlights, or 8IT) or a different 7e0 937 090 /a/b/c/d that will need to be parametrised to the correct settings for LED headlights with i.e. vcp
Hello guys. Is there anyone available to assist me in coding the led headlights? The guy that configured them up to this point is no longer available and me alone cannot manage to figure it out.
I have the vcds...Could it be fixed remote? Thanks
Can you show an autoscan please?
I currently have on me the obdeleven but on monday I will do a proper scan with vcds
I made a full scan and these are the faults on the headlights...sorry for the low photo quality
