BCM Max Transporter 2013
Maarten
Re: BCM Max Transporter 2013
Post by Maarten »
Dashcam startsound in the vid lol : :lol:
Good work!
Hi Shadow109, sorry again for my intrusion 🙏, please, when possible, can you share with me the hexadecimal values ​​of the following addresses from the EEPROM of your 3D Instrument Cluster (sw1109)?
02DB
02F6
0454
All three addresses fit in one screenshot, to be sure and not make mistakes when copying them manually.
I'm struggling with the EEPROM of my non-3D IC (sw805) for something that maybe/I think doesn't make sense, but I have to rule out all possible options for RTA beep on IC.🤷‍♂️
Thanks a lot!!!
Hopefully you will achieve your future goals with that new 'special steering rack', lane Assist is an important project.👍
Shadow109
Drives: Vw t5.1 2013
Post by Shadow109 »
02DB : A7
02F6 : 98
0454 : 14
But from my experience with 3D clusters
Values may be different between 3D and normal clusters
I have suffered to fined the correct values for front assist and side assist
Perfect, thanks a lot.🤗
Here are the values ​​for:
- Non-3D clusters Amarok_SW1009 (6R0920870B, 6R0920870E).
02DB : AE
02F6 : 98
0454 : 13
- Non-3D cluster POLO6R_SW805 (6RD920870A). My 6R:
Ori:
02DB : 80
02F6 : 18
0454 : 10
After vagmm007 update for Side Assist (guided function):
02DB : AF
02F6 : 98
0454 : 13
With the original 805 sw of my non-3D IC, the BSD and RTA menus are present when connecting the radars for Lane Change... and they work perfectly if the other parts/codings allow it. Also after the update.
PQ25:
TR_1109/AM_1009/6R_805OE/6R_805mm
02DB... A7AE80AF
02F6... 98981898
0454... 14131013
To compare the binary (easily with NE-tech). :lol:
Shadow109
Post by Shadow109 »
Congrats Fernando
I think I don’t have this menu here
Do you know what is the exact eeropm coding for it ?
Thank you very much! 🤗 Side Assist is a very good assistant.
At first I thought it was even unnecessary or that it didn't add much to driving, now I miss it every time I drive a vehicle that doesn't have it.
I'm really happy to have done this project on my 6R.💪
With the original sw 805 of my IC the BSD activation in the Settings menu is present from the factory, as well as in the Assistants menu.
(see my previous post here for the values ​​of the known eeprom addresses).
There is some eeprom address related to Side Assist that we all miss (I refer to the study in the Excel file that is on the net).
However, if you have the VAGmm007 (or similar -Iscancar-) you can do this :arrow: viewtopic.php?p=604597#p604597
I did this and 'everything' continued to work just as well as with the previous eeprom values.
Many more eeprom addresses are modified than those already known, so first do a reading/backup of the IC eeprom with the current values, but you already knew that. :wink:
Hi Abdullah.
Today I had a session editing the EEPROM of my IC...
... and thinking about your concerns, I also tried the hexadecimal values ​​of the EEPROM addresses of your IC on my IC...
02DB : A7
02F6 : 98
0454 : 14
... and the Assistants/BSD function/option in the SETTINGS menu was always there, as well as in the ASSISTANTS menu.
So you can safely ignore these addresses if you go looking for it.
I was thinking that maybe this option/function is not shown in your IC because you currently have the 2Q0 radars installed instead of 5Q0 and the HMI MIB... :?:
However, the really important thing is that the BSD is shown in the ASSISTANTS menu so you can access it at any time.
I wouldn't worry too much about not having it in the SETTINGS menu.🤷‍♂️
Shadow109
Post by Shadow109 »
Thank you for checking, yes maybe, anyway I have also the menu in 5f activated for lane assist
Shadow109
Post by Shadow109 »
New retrofit : T6.1 LED taillights ....
https://youtu.be/8b7QXltOi_4
https://youtube.com/shorts/iTqjvpRbDIE?feature=share
and renewing the led front fog lights :-
WhatsApp Image 2024-09-18 at 19.27.28_a781b059.jpg (213.13 KiB) Viewed 5069 times
WhatsApp Image 2024-09-18 at 19.27.28_7feb75db.jpg (203.55 KiB) Viewed 5069 times
WhatsApp Image 2024-09-18 at 19.27.28_6b2f9539.jpg (255.02 KiB) Viewed 5069 times
WhatsApp Image 2024-09-18 at 19.27.28_6a4111d4.jpg (203.54 KiB) Viewed 5069 times
the new version won't trigger any fault codes
also the new taillights didn't trigger any faults in 09
They look great, ...and no faults in diagnosis!!
Thanks for sharing.👍
Shadow109
Post by Shadow109 »
New mood :-
Start-stop & mood buttons on MFSW
MFSW feed line should be changed from 15.kl to 30.kl (logically)
https://youtu.be/0WOrTZGFDb8?si=InKsANVZBvMbQvfi
Shadow109
Post by Shadow109 »
Hello all, So it have been a while since I finished retrofitting Kessy, and the only thing that wasn't in place was the ELV, it simply doesn't fit on my T5 steering column, I knew this from the beginning,
In that time I was intending to swap my steering column with the vw up electric steering, my old steering switch won't fit in the wv up steering column, but the ELV was perfect alternative
so I decided to put off the steering retrofit until I finish Kessy retrofit
this time the wire modification was the easy part, the hard part was to place the steering column itself in my T5
WhatsApp Image 2024-10-20 at 18.57.26_5334211d.jpg (232.92 KiB) Viewed 4640 times
WhatsApp Image 2024-10-20 at 18.57.26_8ca676fa.jpg (434.81 KiB) Viewed 4640 times
WhatsApp Image 2024-10-20 at 18.57.26_a220dd50.jpg (456.39 KiB) Viewed 4640 times
nothing was plug and play, I had to swap the coupling from my t5 to the new steering column, also the steering holder,
the steering column should be placed in the same angle was the old one,
unfortunately I didnt remember to take a pic after I have done the modification to the steering wheel, maybe later I will add them
WhatsApp Image 2024-10-20 at 19.06.36_01508ce5.jpg (279.99 KiB) Viewed 4640 times
this was the final result after 3 modifications
the second big issue and question, will the electric steering work with the power steering together, or do I have to figger out a way to disconnect the power steering
as I tried to do basic settings the electric steering started to work for a 10 seconds, but after that it stops and I had A new fualt (crash fault)
Address 44: Steering Assist (J792)       Labels:| 2Qx-909-144-V2.clb
   Part No SW: 2Q1 909 144 T    HW: 2Q1 909 144 F
   Component: TRW_G4L_MQBA0 611 6213
   Serial number: 01213118CP3K155
   Coding: 000000000000000000000201010001010000010001
   ASAM Dataset: EV_SteerAssisZFGen1PQ12PA 002002
   ROD: EV_SteerAssisZFGen1PQ12PA.rod
   VCID: C3D8A21BCB10C8C2829-8096
5 Faults Found:
10531840 - Steering angle sensor
          B1168 54 [10001001] - Missing Calibration / Basic Setting
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 106
                    Mileage: 346576 km
                    Date: 2024.10.05.
                    Time: 23:49:32
                    Engine RPM: 2367 /min
                    Vehicle speed: 31 km/h
                    System status: Malfunction
                    Terminal 15 status: On
                    Voltage terminal 30: 13.86 V
                    Power steering current consumption: 0.5 A
                    max.value: 63.3 A
                    End stage temperature: 31  C
                    Steering assistance: engine output: 100 %
                    Engine angle: 65535
                    Electric motor speed: 45535 /min
                    Steering assistance: target engine torque: 0.0 Nm
                    Steering torque: -1.6 Nm
15793152 - Crash Shut-Down Activated
          P1609 00 [10001001] - -
          [DEM_FRONT_CRASH_STEERING_RANGE_FAULT]
                    Fault Priority: 4
                    Fault Frequency: 1
                    Mileage: 346576 km
                    Date: 2024.10.05.
                    Time: 23:47:20
                    Engine RPM: 863 /min
                    Vehicle speed: 0 km/h
                    max.value: 63.3 A
                    Engine angle: 65535
                    Steering torque: 0.0 Nm
10620672 - Databus
          U1123 00 [00001001] - Received Error Message
          [DEM_CAN_LONG_ACCEL_QBIT_INVALID_FAULT]
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 106
                    Mileage: 346576 km
                    Date: 2024.10.05.
                    Time: 23:47:21
                    Engine RPM: 856 /min
                    Voltage terminal 30: 13.82 V
                    max.value: 63.3 A
                    Engine angle: 65535
10620928 - Databus
          [DEM_CAN_YAW_RATE_QBIT_INVALID_FAULT]
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 106
                    Mileage: 346576 km
                    Date: 2024.10.05.
                    Time: 23:47:21
                    max.value: 63.3 A
                    Engine angle: 65535
10512640 - Steering End Stops Not Learned
          C10AC F0 [10001001] - Unknown Error Elaboration
          [DEM_BOTH_ENDSTOP_NOT_KNOWN]
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 106
                    Mileage: 346576 km
                    Date: 2024.10.05.
                    Time: 23:47:20
                    max.value: 63.3 A
                    Engine angle: 65535
in the beginig I suspected that the electric steering was faulty, so I must try another one before I do anything..
after trying another steering I had the same faults, so my last hope was to disconnect the power steering belt (temporarily) and try to do basic settings..
the Suprise was that it did work finally, every thing it ok, even after returning the power belt, the electric steering still works,
I still have one fault that appeared after basic setting that I have to figger out how to solve it
Saturday,19,October,2024,17:37:00:22797
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 11 x64
VCDS Version: 24.7.1.0 (x64)  HEX-NET2 CB: 0.4643.5
Data version: 20240919 DS356.3
www.Ross-Tech.com
VIN: WV1ZZZ7HZDH036544   License Plate:
Chassis Type: 7H-VN75 (7E0)
Scan: 01 03 04 05 08 09 10 13 14 15 17 19 20 25 2B 3C 44 47 55 5F
          61 65 6C 0B
VIN: WV1ZZZ7HZDH036544   Mileage: 348440km-216510miles
05-Acc/Start Auth. -- Status: OK 0000
14-Susp. Elect. -- Status: Malfunction 0010
2B-Steer. Col. Lock -- Status: OK 0000
47-Sound System -- Status: OK 0000
Address 01: Engine (J623-CAAC)       Labels:. 03L-906-022-CAA.clb
   Part No SW: 03L 906 019 GQ    HW: 03L 907 309 L
   Component: R4 2.0l TDI   H34 9977
   Revision: 22H34---    Serial number: 00000000000000 CVN: 714DC616
   Coding: 01114012234401080000
   Shop #: WSC 43690 085 12345
   ASAM Dataset: EV_ECM20TDI01103L906019GQ 004006
   ROD: EV_ECM20TDI01103L906019FH_003.rod
   VCID: 80526D179A8613DADFB-80D4
   VINID: 9E606AAAA1D8A946000C6144105E5FB8A3
2 Faults Found:
16703 - Gear Reconition Sensor
          P181C 00 [00100111] - Implausbile Signal
                    Fault Priority: 2
                    Fault Frequency: 1
                    Mileage: 348443 km
                    Date: 2024.10.19.
                    Time: 06:01:28
                    Engine RPM: 830.50 /min
                    Normed load value: 30.2 %
                    Coolant temperature: 81  C
                    Intake air temperature: 43  C
                    Ambient air pressure: 920 mbar
                    Voltage terminal 30: 11.960 V
                    Neutral position sensor: current transmission angle: 20.00
                    Neutral position sensor: adapted transmission angle: 0.00
                    Adaptation status of neutral position sensor-Bits 0-7: 4
                    Transmission neutral position sensor voltage: 0 mV
                    Neutral position sensor: upper adaptation value: 0 mV
                    Neutral position sensor: lower adaptation value: 0 mV
10092 - Neutral Gear Sensor
          P15A0 00 [00100111] - Electrical Malfunction
                    Fault Priority: 2
                    Fault Frequency: 1
                    Mileage: 348443 km
                    Date: 2024.10.19.
                    Time: 06:01:29
                    Engine RPM: 891.00 /min
                    Normed load value: 10.6 %
                    Voltage terminal 30: 11.940 V
Readiness: 0 0 0 0 1
Address 03: ABS Brakes (J104)       Labels: 7E0-907-37x-MK100ESC.clb
   Part No SW: 7E0 907 379 Q    HW: 7E0 907 379 N
   Component: ESC           H06 0133
   Revision: 00000000    Serial number: 62787000000113
   Coding: 307E4098256586840C7A027AA486612F38F555
   Shop #: WSC 02739 790 50316
   ASAM Dataset: EV_Brake1ESCCONTIVN75XGP2 011001
   ROD: EV_Brake1ESCCONTIVN75XGP2_011.rod
   VCID: C0D2AD17DA06D3DA9FB-8094
Address 05: Acc/Start Auth. (J518)       Labels:. 5K0-959-434.clb
   Part No SW: 5K0 959 434 H    HW: 5K0 959 434
   Component: VWKESSYPQ35GP 093 1305
   Revision: 00093000    Serial number: 0467921560
   Coding: 032C1C
   Shop #: WSC 12345 123 12345
   ASAM Dataset: EV_KESSYPQ35G A02720
   ROD: N/A
   VCID: BA26DFFFBCDA890AD1F-80EE
No ASAM data for: "EV_KESSYPQ35G" (VN75)
   Part No SW: 7E5 907 047 AK    HW: 7E5 907 047 AK
   Component: Climatic-T5   H11 0203
   Revision: 00001005
   Coding: 0000000002
   Shop #: WSC 02737 790 50316
   ROD: EV_ClimaT5Basis_VN75.rod
   VCID: F8A205F7C2565B1AE7B-80AC
   Revision: B9084001    Serial number: 2502 306190145
   Coding: 22B03D3E4EFF201281280F817EEB9FDDFF86660F608D79C073E4503F0860
   Shop #: WSC 12345 123 61029
   VCID: AD0CE4A37D142EB244D-80F8
   Subsystem 1 - Part No: 5K7 955 559 B  Labels: 5K7-955-559.CLB
   Component: RLS 230916 03  37  0059
   Coding: 0228EE
   Subsystem 2 - Part No SW: 7E0 959 801     HW: 7E0 959 801   Labels: 7E0-959-80X-V1.CLB
   Component: J386__TSG_FT  002 3313
   Subsystem 3 - Part No SW: 7E0 959 802     HW: 7E0 959 802   Labels: 7E0-959-80X-V1.CLB
   Component: J387__TSG_BT  002 3313
   Subsystem 4 - Part No: 1K0 951 605 C
   Subsystem 5 - Part No SW: 7E0 959 442 A    HW: 7E0 959 442 A
   Component: E221__MFL-DC1  H02 0103
   Serial number: 39180000000570018056
   Coding: B4FFFF
Address 10: Park/Steer Assist (J446)       Labels:| 5Q0-919-294.clb
   Part No SW: 1K8 919 472 C    HW: 5Q0 919 294 A
   Component: PARKHILFE 8K  H03 0480
   Revision: --------    Serial number: 39331817601496
   Coding: 0041155041
   Shop #: WSC 21890 003 104857
   ASAM Dataset: EV_EPHVA18VW364GP00 001007
   ROD: EV_EPHVA18VW364GP00_VW32.rod
   VCID: B720C6CB8FC894622E1-80E2
1 Fault Found:
12718592 - Databus
          U1121 00 [00001001] - Missing Message
          [Steuerger t f r Lenks ulenelektronik-J527/BCM - mZAS_1 - kein Signal/keine Kommunikation]
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 148
                    Mileage: 348443 km
                    Date: 2024.10.19.
                    Time: 06:01:24
Address 13: Auto Dist. Reg (J428)       Labels:| 7N0-907-572.clb
   Part No SW: 7N0 907 572 C    HW: 7E0 907 572
   Component: ACC Bosch PQx H03 0211
   Serial number: 1909180453A6EF Dataset Number: ACC_MRRevo1 0001
   Coding: 00004000FE0779
   Shop #: WSC 01383 790 50316
   ASAM Dataset: EV_ACCBEGVW361 001006
   ROD: EV_ACCBEGVW361.rod
   VCID: B63ECBCF88C26D6A357-80E2
Address 14: Susp. Elect. (J250)       Labels:. 3C0-907-376.clb
   Part No SW: 3C0 907 376 A    HW: 3C0 907 376
   Component: DAEMPFUNGS-SG H07 0071
   Revision: 00000000    Serial number: 12030906320002
   Coding: 030180
   Shop #: WSC 00046 000 00000
   VCID: A700168B5FE804E2BE1-80F2
2 Faults Found:
03262 - Comfort Restriction
            000 - -
                    Fault Status: 01100000
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 148
                    Mileage: 348443 km
                    Time Indication: 0
                    Date: 2024.10.19.
                    Time: 06:01:22
                    Error Code: 2
                    Bin. Bits: 00000000
01769 - Sensor for Vehicle Leveling; Front Right (G289)
            010 - Open or Short to Plus
                    Fault Status: 01101010
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 148
                    Mileage: 348443 km
                    Time Indication: 0
                    Date: 2024.10.19.
                    Time: 06:01:22
   Part No SW: 7E0 959 655 D    HW: 7E0 959 655 D
   Component: VW10Airbag00G 008 0016
   Revision: --------    Serial number: 003PH0013MB$ Dataset Number: 7E0003V____ 0735
   Coding: 000000000000000000000000000000003047
   Shop #: WSC 02734 790 50316
   ASAM Dataset: EV_AirbaVW10BPAVW12X 001028
   ROD: EV_AirbaVW10BPAVN750.rod
   Part No SW: 7E0 920 980 S    HW: 7E0 920 980 S
   Component: KOMBI         H04 1109
   Coding: 140E230B00
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A05733
   VCID: BB28DAFBB3E0B002CA9-80EE
   Revision: B9084001
   Coding: 04220F
   VCID: E88255B79276CB9A77B-80BC
   Revision: AA001001
   Coding: 010100E200000100000000
   ROD: EV_HighBeamAssisAU316_VW32.rod
   VCID: AE0EE3AF709255AA7D7-80FA
   Component: IMMO          H04 1109
   Serial number:
   Coding: 000007
   VCID: EA862FBF8CFAF98A61F-80BE
Address 2B: Steer. Col. Lock (J764)       Labels:* 5K0-905-861.clb
   Part No SW: 5K0 905 861 C    HW: 5K0 905 861 C
   Component: ELV-PQ35      H21 0240
   Revision: 00000000    Serial number: 14000305204001
   Coding: 4100000000000000
   Shop #: WSC 00066 790 50316
   ASAM Dataset: EV_ELVMarquMPVW36X A01001
   ROD: EV_ELVMarquMPVW36X_VW32.rod
   VCID: B032FDD76AA6435A6FB-80E4
Address 3C: Lane Change (J1086)       Labels: Redir Fail!
   Part No SW: 2Q0 907 686 B    HW: 2Q0 907 686 B
   Component: HRE3_Kl15_Mst H06 0150
   Serial number: 14520003983159  Dataset Number: V03935303MB 0001
   Coding: 529524A0
   ROD: N/A
   VCID: B924C0F3B9DC8212D85-80EC
   Subsystem 1 - Part No SW: 2Q0 907 685 B    HW: 2Q0 907 685 B
   Component: HRE3_Kl15_Slv  H06 0150
   Serial number: 14520003959660
No ASAM data for: "EV_HREntryHellaGen3Kl15" (VN75)
   Serial number: 01478032CP3L073
   Coding: 000000000100000000000200010001000000010001
1 Fault Found:
10530304 - Databus
          [DEM_HCA_MSG_ABSENT_FAULT]
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 148
                    Mileage: 348443 km
                    Date: 2024.10.19.
                    Time: 06:01:25
                    Engine RPM: 855 /min
                    System status: Driving mode
                    Voltage terminal 30: 12.08 V
                    max.value: 29.7 A
                    End stage temperature: 38  C
                    Engine angle: 132
                    Electric motor speed: 0 /min
Address 47: Sound System (R184)       Labels: 5K0-035-456.clb
   Part No SW: 3AA 035 466     HW: 3AA 035 466
   Component: KonzernAmp12K H03 6904
   Revision: --------    Serial number: A1108A00007925 Dataset Number: 360050v____ 0004
   ASAM Dataset: EV_AudioVerst12KanalSTT1 001001
   ROD: EV_AudioVerst12KanalSTT1_VW36.rod
   VCID: ED8C24A3BD14EEB204D-80B8
   Part No SW: 6R0 907 357 C    HW: 6R0 907 357 B
   Component: AFS-ECU       005 0050
   Revision: --------    Serial number: -------------- Dataset Number: V03600097E0 0001
   Coding: 0FC6020001000000
   Shop #: WSC 02748 790 50316
   ROD: EV_HeadlRegulVWLWRCC.rod
   Component: MU-S-ND-ER    H41 0480
   Serial number: VWZAZ2U1668085 Dataset Number: V00000000VW 0001
   Coding: 0645000FBE00000011110006010D08001F0103C401200100CE
   Shop #: WSC 00046 123 12345
   ROD: EV_MUStd4CTSAT_VW32.rod
   VCID: A51C1C83256416F28CD-80F0
   Data carrier:
   Subsystem 1 - Part No SW: V03 959 820 DC    HW: -----------
   Component: MRM DL2 23/24  --- 2010
2 Faults Found:
1555 - Check Software Version Management
          B201A 00 [00001001] - -
          [Check software version management]
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 148
                    Mileage: 348443 km
                    Date: 2024.10.19.
                    Time: 06:01:24
                    Voltage terminal 30: 12.0 V
                    Status_Software_Version_Management-module_name:
          U1101 00 [00001001] - Active
          [Anti-theft protection - component protection active (0xEA6300)]
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 148
                    Mileage: 348443 km
                    Date: 2024.10.19.
                    Time: 06:01:24
   Part No SW: 7E0 907 534     HW: 7E0 937 090 E
   Component: Batt.regelung H84 0772
   Coding: 330B1A73
   Subsystem 1 - Part No SW: 7E0 915 181 G    HW: 7E0 915 181 G
   Component: J367-BDM  H08 0223
   Serial number: 62309D31111261021812
   Serial number: 30000000047437
   ROD: EV_RDKBERU30_005.rod
Address 6C: Back-up Cam. (J772)       Labels:| 5Q0-980-556.clb
   Part No SW: 5Q0 980 556 B    HW: 5Q0 980 556 B
   Component: RVC Compact   H18 0231
   Dataset Number: V03935257YE 0001
   Coding: 047300010600041F000040
   ASAM Dataset: EV_CamSysRVRVCPANAMQBAB 006009
   ROD: EV_CamSysRVRVCPANAMQBAB_006_VW37.rod
1 Fault Found:
10489856 - No Basic Setting
          B2010 00 [00001001] - -
          [RearView system not calibrated]
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 250
                    Mileage: 150182 km
                    Date: 2024.01.14
                    Time: 14:07:40
                    passive
End----(Elapsed Time: 02:29, VBatt start/end: 12.0V/11.9V. VIgn 12.0V)-----
Next step it to connect A5 and try to activate lane assist and sign assist, I know it won't be easy..
my A5 is alredy in place, I had to replace my windshield a couple months ago, so I took the chance and made my magic
I have a new toy that I was putting on the shelf long time ago, I feel its a perfect time to install it :
WhatsApp Image 2024-10-20 at 19.34.08_669f481e.jpg (255.89 KiB) Viewed 4640 times
I have tried it before, but it seems not happy with my pq acc buttons, According to Egor, it likes MQB ACC buttons..
thats all for today :D
Shadow109
Post by Shadow109 »
the fault in 44 just simply disappeared :shock:
I have connected A5
next step :
1) basic settings for A5
2) replacing 7E0 BCM with 1S0,coding, readding the keys, and replacing MFSW buttons
Tuesday,22,October,2024,21:26:49:22797
www.Ross-Tech.com
          61 65 6C A5 0B
VIN: WV1ZZZ7HZDH036544   Mileage: 348870km-216777miles
14-Susp. Elect. -- Status: OK 0000
A5-Frt Sens. Drv. Assist -- Status: Malfunction 0010
2 Faults Found:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Mileage: 348871 km
                    Date: 2024.10.22.
                    Time: 11:48:26
                    Engine RPM: 857.00 /min
                    Normed load value: 15.3 %
                    Coolant temperature: 87  C
                    Intake air temperature: 45  C
                    Voltage terminal 30: 12.940 V
                    Fault Priority: 2
                    Fault Frequency: 1
                    Mileage: 348871 km
                    Date: 2024.10.22.
                    Time: 11:48:26
                    Engine RPM: 865.50 /min
                    Normed load value: 14.5 %
                    Voltage terminal 30: 12.980 V
Readiness: 0 0 0 0 0
   Coding: 032C1C
   ROD: N/A
   Revision: 00001005
   Coding: 0000000002
   Coding: 0228EE
   Coding: B4FFFF
   Coding: 0041155041
1 Fault Found:
12718592 - Databus
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 155
                    Mileage: 348871 km
                    Date: 2024.10.22.
                    Time: 11:48:24
   Coding: 030180
   Coding: 140E230B00
   Revision: B9084001
   Coding: 04220F
   Revision: AA001001
   Serial number:
   Coding: 000007
   Coding: 529524A0
   ROD: N/A
   Data carrier:
2 Faults Found:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 155
                    Mileage: 348871 km
                    Date: 2024.10.22.
                    Time: 11:48:24
                    Voltage terminal 30: 12.9 V
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 155
                    Mileage: 348871 km
                    Date: 2024.10.22.
                    Time: 11:48:24
                    Voltage terminal 30: 13.0 V
   Coding: 330B1A73
1 Fault Found:
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 250
                    Mileage: 150182 km
                    Date: 2024.01.14
                    Time: 14:07:40
                    passive
Address A5: Frt Sens. Drv. Assist (R242)       Labels:| 3Q0-980-65X-A5.clb
   Part No SW: 3Q0 980 654 P    HW: 3Q0 980 654 A
   Component: MQB_B_MFK     H14 0821
   Serial number: 04112012P13717 Dataset Number: V03935308DF 0001
   Coding: 01020706020004010002105481D6840084000E01002000
   Shop #: WSC 31414 137 00001
   ASAM Dataset: EV_MFKBoschMQBB 002041
   ROD: EV_MFKBoschMQBB_002.rod
   VCID: C4DAA107CE1ECFFABB3-8090
1 Fault Found:
0660 - No Basic Setting
          [Initial_calibration_missing]
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 155
                    Mileage: 348871 km
                    Date: 2024.10.22.
                    Time: 11:48:24
                    Control Module temperature: 37  C
                    Outside temperature: 17.5  C
                    Vehicle speed: 0.00 km/h
                    System run time: 3859.0 s
                    Voltage terminal 15: 13.0 V
                    mid: 00 1E
                    Status of camera: operational
                    Engine_Running_Info: 1
                    Software_Info_4: 1
                    Software_Info_3: 2
                    Software_Info_2: 8
                    Software_Info_1: 0
End----------(Elapsed Time: 02:09, VBatt start/end: 13.0V/13.0V)-----------
til3tsio
Drives: Seat Toledo KG
Post by til3tsio »
The fault was about lane assist and a missing message from the camera.
Is it really required to change bcm ?
Shadow109
Post by Shadow109 »
til3tsio wrote: Tue Oct 22, 2024 8:36 pm The fault was about lane assist and a missing message from the camera.
That sounds logical, regarding BCM change, I am not 100% sure its required, but according to Egor, he flashed his bcm to 1S0 but lane assist didn’t work after bsic settings, and there was not faults at all, But after he tried to connect the A5 to power train can-bus, lane assist started to work, but this will cause that the getaway won’t see A5 at all
This will lead us to a question, what is missing from vw up that we don’t have?
It probably could be a parameter in the can getaway it self, and maybe something in the cluster, but sense the bcm have the getaway in it, and its the responsible for transferring can massages
I would highly suspect it to be the missing part
