BCM Max Transporter 2013
MrCollayder
Drives: Polo 614 sedan (cczb+dq250 awd+pq35)
Re: BCM Max Transporter 2013
Post by MrCollayder »
EPS is the same, A5 camera is the same. So the question is gateway or dashboard? Or both of them at all? We'll find out soon =)
Shadow109
Drives: Vw t5.1 2013
Post by Shadow109 »
Hello all, yesterday I have a free time, so have started to try to calibrate A5, the light in my work shop was too bright so I had to dim it
After a couple of try's I got this faul :-
when I saw it I double checked the glass transparency in front of the camera
I could say its not 100% clear, Saw I have decided to change my front windshield to T6.1 with Camera bracket, then modify the bracket to fit 3Q0 Camera
This will take some time :|
Shadow109
Post by Shadow109 »
Regrading Adapting 1S0 BCM :-
this is a scan after coding and adapting key to the new BCM :-
Thursday,24,October,2024,21:59:31:22797
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 11 x64
VCDS Version: 24.7.1.0 (x64)  HEX-NET2 CB: 0.4643.5
Data version: 20240919 DS356.3
www.Ross-Tech.com
VIN: WV1ZZZ7HZDH036544   License Plate:
Chassis Type: 7H-VN75 (1S0)
Scan: 01 03 05 08 09 10 13 14 15 17 19 20 25 2B 37 3C 44 47 55 56
          5F 61 65 6C 77 A5
VIN: WV1ZZZ7HZDH036544   Mileage: 349330km-217063miles
05-Acc/Start Auth. -- Status: Malfunction 0010
14-Susp. Elect. -- Status: Malfunction 0010
2B-Steer. Col. Lock -- Status: OK 0000
47-Sound System -- Status: OK 0000
56-Radio -- Status: OK 0000
A5-Frt Sens. Drv. Assist -- Status: Malfunction 0010
Address 01: Engine (J623-CAAC)       Labels:. 03L-906-022-CAA.clb
   Part No SW: 03L 906 019 GQ    HW: 03L 907 309 L
   Component: R4 2.0l TDI   H34 9977
   Revision: 22H34---    Serial number: 00000000000000 CVN: 714DC616
   Coding: 01114012234401080000
   Shop #: WSC 43690 085 12345
   ASAM Dataset: EV_ECM20TDI01103L906019GQ 004006
   ROD: EV_ECM20TDI01103L906019FH_003.rod
   VCID: 80526D179A8613DADFB-80D4
   VINID: 9E606AAAA1D8A946000C6144105E5FB8A3
4 Faults Found:
7144 - Please Check DTC Memory in CAN Gateway (J533)
          U1008 00 [00100111] - -
          [Diagnostic interface for data busRead out DTC]
                    Fault Priority: 2
                    Fault Frequency: 1
                    Mileage: 349323 km
                    Date: 2024.10.24.
                    Time: 04:47:13
                    Engine RPM: 858.00 /min
                    Normed load value: 54.1 %
                    Vehicle speed: 0 km/h
                    Coolant temperature: 70  C
                    Intake air temperature: 31  C
                    Ambient air pressure: 930 mbar
                    Voltage terminal 30: 14.040 V
                    ACC specified acceleration: 0.000 m/s
                    ACC control module: received status-Bits 0-7: 7
                    Active brake system error status-Bits 0-7: 0
                    Status of ACC/CCS acceleration interface-Bits 0-7: 3
                    Acceleration: 0.000 m/s
                    Engine status: COENG_RUNNING
                    Engine status-Test_Program_Co Eng st COMPU VERB UBYTE: 3
16703 - Gear Reconition Sensor
          P181C 00 [00100111] - Implausbile Signal
                    Fault Priority: 2
                    Fault Frequency: 1
                    Mileage: 349323 km
                    Date: 2024.10.24.
                    Time: 04:00:39
                    Engine RPM: 0.00 /min
                    Normed load value: 0.0 %
                    Coolant temperature: 95  C
                    Intake air temperature: 36  C
                    Voltage terminal 30: 12.200 V
                    Neutral position sensor: current transmission angle: 20.00
                    Neutral position sensor: adapted transmission angle: 0.00
                    Adaptation status of neutral position sensor-Bits 0-7: 4
                    Transmission neutral position sensor voltage: 0 mV
                    Neutral position sensor: upper adaptation value: 0 mV
                    Neutral position sensor: lower adaptation value: 0 mV
4483 - Function Restriction due to Faults in Other Modules
          U1113 00 [00100111] - -
                    Fault Priority: 6
                    Fault Frequency: 1
                    Mileage: 349323 km
                    Date: 2024.10.24.
                    Time: 04:00:38
                    Cruise Control System (CCS): switch position-Bits 0-7: 64
                    Cruise Control System (CCS): status-Bits 0-7: 208
                    Cruise control switch-off: irreversible-Bits 0-7: 255
                    Cruise control switch-off: reversible-Bits 0-7: 255
                    Cruise Control System: specified speed: 0.00 km/h
                    Engine control module reset status-Bits 0-7: 0
                    Engine control module reset status-Bits 0-7: 2
                    Cruise control switch-off: irreversible w. brake intervention-Bits 0-7: 0
10092 - Neutral Gear Sensor
          P15A0 00 [00100111] - Electrical Malfunction
                    Fault Priority: 2
                    Fault Frequency: 1
                    Mileage: 349323 km
                    Date: 2024.10.24.
                    Time: 04:00:39
Readiness: 0 0 0 0 0
Address 03: ABS Brakes (J104)       Labels: 7E0-907-37x-MK100ESC.clb
   Part No SW: 7E0 907 379 Q    HW: 7E0 907 379 N
   Component: ESC           H06 0133
   Revision: 00000000    Serial number: 62787000000113
   Coding: 307E4098256586840C7A027AA486612F38F555
   Shop #: WSC 02739 790 50316
   ASAM Dataset: EV_Brake1ESCCONTIVN75XGP2 011001
   ROD: EV_Brake1ESCCONTIVN75XGP2_011.rod
   VCID: C0D2AD17DA06D3DA9FB-8094
Address 05: Acc/Start Auth. (J518)       Labels:. 5K0-959-434.clb
   Part No SW: 5K0 959 434 H    HW: 5K0 959 434
   Component: VWKESSYPQ35GP 093 1305
   Revision: 00093000    Serial number: 0467921560
   Coding: 032C1C
   Shop #: WSC 12345 123 12345
   ASAM Dataset: EV_KESSYPQ35G A02720
   ROD: N/A
   VCID: BA26DFFFBCDA890AD1F-80EE
No ASAM data for: "EV_KESSYPQ35G" (VN75)
1 Fault Found:
1069319 - ROD - Unknown Error Code
          - 00 [00001001]
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 190
                    Mileage: 349323 km
                    Date: 2024.10.24.
                    Time: 04:01:34
   Part No SW: 7E5 907 047 AK    HW: 7E5 907 047 AK
   Component: Climatic-T5   H11 0203
   Revision: 00001005
   Coding: 0000000002
   Shop #: WSC 02737 790 50316
   ROD: EV_ClimaT5Basis_VN75.rod
   VCID: F8A205F7C2565B1AE7B-80AC
Address 09: Cent. Elect. (J519)       Labels:. 1S0-937-09x-V2.clb
   Part No SW: 1S0 937 090 M    HW: 1S0 937 090 M
   Component: BCM PQ25 1MX4 H84 0780
   Revision: BW084001    Serial number: 5200 260200622
   Coding: 22B03D3E4EFF201001280F816EEB9FDDFF86660F608D79C03304503F0801
   Shop #: WSC 31414 133 00001
   VCID: BD2CD4E3AD74BE32F4D-80E8
   Subsystem 1 - Part No: 5K7 955 559 B  Labels: 5K7-955-559.CLB
   Component: RLS 230916 03  37  0059
   Coding: 0228EE
   Subsystem 2 - Part No SW: 7E0 959 801     HW: 7E0 959 801   Labels: 7E0-959-80X-V1.CLB
   Component: J386__TSG_FT  002 3313
   Subsystem 3 - Part No SW: 7E0 959 802     HW: 7E0 959 802   Labels: 7E0-959-80X-V1.CLB
   Component: J387__TSG_BT  002 3313
1 Fault Found:
01326 - Control Module for Multi-Function Steering Wheel (J453)
            004 - No Signal/Communication
                    Fault Status: 01100100
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 190
                    Mileage: 349323 km
                    Time Indication: 0
                    Date: 2024.10.24.
                    Time: 04:00:39
Address 10: Park/Steer Assist (J446)       Labels:| 5Q0-919-294.clb
   Part No SW: 1K8 919 472 C    HW: 5Q0 919 294 A
   Component: PARKHILFE 8K  H03 0480
   Revision: --------    Serial number: 39331817601496
   Coding: 0041155041
   Shop #: WSC 21890 003 104857
   ASAM Dataset: EV_EPHVA18VW364GP00 001007
   ROD: EV_EPHVA18VW364GP00_VW32.rod
   VCID: B720C6CB8FC894622E1-80E2
1 Fault Found:
12718592 - Databus
          U1121 00 [00001000] - Missing Message
          [Steuerger t f r Lenks ulenelektronik-J527/BCM - mZAS_1 - kein Signal/keine Kommunikation]
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 190
                    Mileage: 349323 km
                    Date: 2024.10.24.
                    Time: 04:00:37
Address 13: Auto Dist. Reg (J428)       Labels:| 7N0-907-572.clb
   Part No SW: 7N0 907 572 C    HW: 7E0 907 572
   Component: ACC Bosch PQx H03 0211
   Serial number: 1909180453A6EF Dataset Number: ACC_MRRevo1 0001
   Coding: 00004000FE0779
   Shop #: WSC 01383 790 50316
   ASAM Dataset: EV_ACCBEGVW361 001006
   ROD: EV_ACCBEGVW361.rod
   VCID: B63ECBCF88C26D6A357-80E2
4 Faults Found:
0101 - Steering Column Control Module
          B105D F0 [00001001] - Incorrectly Coded
          [FAULT_CIS_GRA_CODE]
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 190
                    Mileage: 349323 km
                    Date: 2024.10.24.
                    Time: 04:00:37
                    Control Module temperature: 30  C
                    Voltage terminal 15: 12.1 V
                    Vehicle speed: 0.00 m/s
                    Acceleration: 0.00 m/s
0100 - Steering Column Control Module
          B105D 00 [00001001] - -
          [FAULT_CIS_GRA_TYPE]
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 190
                    Mileage: 349323 km
                    Date: 2024.10.24.
                    Time: 04:00:37
1090 - Databus
          U1123 00 [00001001] - Received Error Message
          [FAULT_CIS_OP_FAIL]
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 190
                    Mileage: 349323 km
                    Date: 2024.10.24.
                    Time: 04:00:39
1043 - Automatic Distance Control
          B10E7 F0 [00001001] - Disconnected
          [FAULT_CIS_TSK_IRREV_FAIL]
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 190
                    Mileage: 349323 km
                    Date: 2024.10.24.
                    Time: 04:00:37
Address 14: Susp. Elect. (J250)       Labels:. 3C0-907-376.clb
   Part No SW: 3C0 907 376 A    HW: 3C0 907 376
   Component: DAEMPFUNGS-SG H07 0071
   Revision: 00000000    Serial number: 12030906320002
   Coding: 030180
   Shop #: WSC 00046 000 00000
   VCID: A700168B5FE804E2BE1-80F2
3 Faults Found:
01319 - Control Module for Distance Control (J428)
            013 - Check DTC Memory
                    Fault Status: 01101101
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 190
                    Mileage: 349323 km
                    Time Indication: 0
                    Date: 2024.10.24.
                    Time: 04:00:34
                    Bin. Bits: 00000000 00000001
03262 - Comfort Restriction
            000 - -
                    Fault Status: 01100000
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 190
                    Mileage: 349323 km
                    Time Indication: 0
                    Date: 2024.10.24.
                    Time: 04:00:35
                    Error Code: 2
                    Bin. Bits: 00000000
01769 - Sensor for Vehicle Leveling; Front Right (G289)
            010 - Open or Short to Plus
                    Fault Status: 01101010
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 190
                    Mileage: 349323 km
                    Time Indication: 0
                    Date: 2024.10.24.
                    Time: 04:00:34
   Part No SW: 7E0 959 655 D    HW: 7E0 959 655 D
   Component: VW10Airbag00G 008 0016
   Revision: --------    Serial number: 003PH0013MB$ Dataset Number: 7E0003V____ 0735
   Coding: 000000000000000000000000000000003047
   Shop #: WSC 02734 790 50316
   ASAM Dataset: EV_AirbaVW10BPAVW12X 001028
   ROD: EV_AirbaVW10BPAVN750.rod
   Part No SW: 7E0 920 980 S    HW: 7E0 920 980 S
   Component: KOMBI         H04 1109
   Coding: 140E230B00
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A05733
   VCID: BB28DAFBB3E0B002CA9-80EE
   Part No SW: 1S0 909 901     HW: 1S0 937 090 M
   Component: GW-K-CAN TP20 H84 0780
   Revision: BW084001
   Coding: 04220F
   VCID: F0B23DD7AAA6035A2FB-80A4
1 Fault Found:
03389 - Data Set Implausible
            000 - -
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 190
                    Mileage: 349323 km
                    Time Indication: 0
                    Date: 2024.10.24.
                    Time: 04:05:23
   Revision: AA001001
   Coding: 010100E200000100000000
   ROD: EV_HighBeamAssisAU316_VW32.rod
   VCID: AE0EE3AF709255AA7D7-80FA
   Component: IMMO          H04 1109
   Serial number:
   Coding: 000007
   VCID: EA862FBF8CFAF98A61F-80BE
Address 2B: Steer. Col. Lock (J764)       Labels:* 5K0-905-861.clb
   Part No SW: 5K0 905 861 C    HW: 5K0 905 861 C
   Component: ELV-PQ35      H21 0240
   Revision: 00000000    Serial number: 14000305204001
   Coding: 4100000000000000
   Shop #: WSC 00066 790 50316
   ASAM Dataset: EV_ELVMarquMPVW36X A01001
   ROD: EV_ELVMarquMPVW36X_VW32.rod
   VCID: B032FDD76AA6435A6FB-80E4
Address 37: Navigation
Cannot be reached
Address 3C: Lane Change (J1086)       Labels: Redir Fail!
   Part No SW: 2Q0 907 686 B    HW: 2Q0 907 686 B
   Component: HRE3_Kl15_Mst H06 0150
   Serial number: 14520003983159  Dataset Number: V03935303MB 0001
   Coding: 529524A0
   ROD: N/A
   VCID: B924C0F3B9DC8212D85-80EC
   Subsystem 1 - Part No SW: 2Q0 907 685 B    HW: 2Q0 907 685 B
   Component: HRE3_Kl15_Slv  H06 0150
   Serial number: 14520003959660
No ASAM data for: "EV_HREntryHellaGen3Kl15" (VN75)
Address 44: Steering Assist (J792)       Labels:| 2Qx-909-144-V2.clb
   Part No SW: 2Q1 909 144 T    HW: 2Q1 909 144 F
   Component: TRW_G4L_MQBA0 611 6213
   Serial number: 01478032CP3L073
   Coding: 000000000100000000000200010001000000010001
   ASAM Dataset: EV_SteerAssisZFGen1PQ12PA 002002
   ROD: EV_SteerAssisZFGen1PQ12PA.rod
   VCID: C3D8A21BCB10C8C2829-8096
Address 47: Sound System (R184)       Labels: 5K0-035-456.clb
   Part No SW: 3AA 035 466     HW: 3AA 035 466
   Component: KonzernAmp12K H03 6904
   Revision: --------    Serial number: A1108A00007925 Dataset Number: 360050v____ 0004
   ASAM Dataset: EV_AudioVerst12KanalSTT1 001001
   ROD: EV_AudioVerst12KanalSTT1_VW36.rod
   VCID: ED8C24A3BD14EEB204D-80B8
   Part No SW: 6R0 907 357 C    HW: 6R0 907 357 B
   Component: AFS-ECU       005 0050
   Revision: --------    Serial number: -------------- Dataset Number: V03600097E0 0001
   Coding: 0FC6020001000000
   Shop #: WSC 02748 790 50316
   ROD: EV_HeadlRegulVWLWRCC.rod
Address 56: Radio
Cannot be reached
   Component: MU-S-ND-ER    H41 0480
   Serial number: VWZAZ2U1668085 Dataset Number: V00000000VW 0001
   Coding: 0645000FBE00000011110006010D08001F0103C401200100CE
   Shop #: WSC 00046 123 12345
   ROD: EV_MUStd4CTSAT_VW32.rod
   VCID: A51C1C83256416F28CD-80F0
   Data carrier:
   Subsystem 1 - Part No SW: V03 959 820 DC    HW: -----------
   Component: MRM DL2 23/24  --- 2010
5 Faults Found:
1553 - Function Restriction
          B200D F0 [00001001] - due to Internal Communcations Error
          [Function restriction due to internal communication error: optical drive (fitted)]
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 190
                    Mileage: 349323 km
                    Date: 2024.10.24.
                    Time: 04:29:43
                    Voltage terminal 30: 12.4 V
1555 - Check Software Version Management
          B201A 00 [00001001] - -
          [Check software version management]
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 190
                    Mileage: 349323 km
                    Date: 2024.10.24.
                    Time: 04:00:36
                    Voltage terminal 30: 12.1 V
                    Status_Software_Version_Management-module_name:
1556 - Internal Control Module Memory Check Sum Error
          B2000 87 [00001001] - Missing Message
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 190
                    Mileage: 349323 km
                    Date: 2024.10.24.
                    Time: 04:45:31
                    System_Software_Error-SW_Status_Consistency: 04 01 01
                    System_Software_Error-SW_Status_Device: o
          U1101 00 [00001001] - Active
          [Anti-theft protection - component protection active (0xEA6300)]
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 190
                    Mileage: 349323 km
                    Date: 2024.10.24.
                    Time: 04:00:36
2562 - Navigation System
          B126C F0 [00001001] - Navigation Database Faulty
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 190
                    Mileage: 349323 km
                    Date: 2024.10.24.
                    Time: 04:29:40
   Part No SW: 1S0 907 534     HW: 1S0 937 090 M
   Component: Batt.regelung H84 0780
   Coding: 17820873
   Shop #: WSC 31414 790 00001
   Subsystem 1 - Part No SW: 7E0 915 181 G    HW: 7E0 915 181 G
   Component: J367-BDM  H08 0223
   Serial number: 62309D31111261021812
   Serial number: 30000000047437
   ROD: EV_RDKBERU30_005.rod
Address 6C: Back-up Cam. (J772)       Labels:| 5Q0-980-556.clb
   Part No SW: 5Q0 980 556 B    HW: 5Q0 980 556 B
   Component: RVC Compact   H18 0231
   Dataset Number: V03935257YE 0001
   Coding: 047300010600041F000040
   ASAM Dataset: EV_CamSysRVRVCPANAMQBAB 006009
   ROD: EV_CamSysRVRVCPANAMQBAB_006_VW37.rod
1 Fault Found:
10489856 - No Basic Setting
          B2010 00 [00001001] - -
          [RearView system not calibrated]
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 250
                    Mileage: 150182 km
                    Date: 2024.01.14
                    Time: 14:07:40
                    passive
Address 77: Telephone
Cannot be reached
Address A5: Frt Sens. Drv. Assist (R242)       Labels:| 3Q0-980-65X-A5.clb
   Part No SW: 3Q0 980 654 P    HW: 3Q0 980 654 A
   Component: MQB_B_MFK     H14 0821
   Serial number: 04112012P13717 Dataset Number: V03935308DF 0001
   Coding: 01020706020004010002105481D6840084000E01002000
   Shop #: WSC 31414 137 00001
   ASAM Dataset: EV_MFKBoschMQBB 002041
   ROD: EV_MFKBoschMQBB_002.rod
   VCID: C4DAA107CE1ECFFABB3-8090
2 Faults Found:
0663 - Control Module For Camera
          C110A 76 [00001001] - Incorrect Mounting Position
          [Initial_calibration_out_of_range]
                    Fault Priority: 4
                    Fault Frequency: 2
                    Reset counter: 190
                    Mileage: 349323 km
                    Date: 2024.10.24.
                    Time: 04:10:32
                    Control Module temperature: 37  C
                    Outside temperature: 19.0  C
                    Vehicle speed: 0.00 km/h
                    System run time: 974.8 s
                    mid: 00 1C
                    Status of camera: System malfunction
                    Engine_Running_Info: 0
                    Software_Info_4: 1
                    Software_Info_3: 2
                    Software_Info_2: 8
                    Software_Info_1: 0
0660 - No Basic Setting
          [Initial_calibration_missing]
                    Fault Priority: 4
                    Fault Frequency: 2
                    Reset counter: 190
                    Mileage: 349323 km
                    Date: 2024.10.24.
                    Time: 04:10:32
                    mid: 00 1E
                    Software_Info_4: 1
                    Software_Info_3: 2
                    Software_Info_2: 8
                    Software_Info_1: 0
End----------(Elapsed Time: 02:02, VBatt start/end: 12.7V/12.7V)-----------
this First two things that I had immediately noticed that the MFSW is not working at all, According to egor LC 29,06 needed to be checked in coding for mfsw to work
after some try's it seems impossible to activate it
the second thing kessy had a fualt with kessy wake-up line (short to ground)
the only thing that maybe a good sign was the fault the can getaway, it seems that this BCM had a totally different Eeprom
at this moment I decided to Compare the Pins On both 7E0..H84 and 1S0..H84
I was chocked :shock:
WhatsApp Image 2024-10-25 at 09.49.16_9e498843.jpg (242.37 KiB) Viewed 6282 times
Screenshot 2024-10-25 084251.png (62.04 KiB) Viewed 6283 times
A lot of missing pins..
I think this is a dead end for this BCM, 7E0 is way alot better to stick with
Shadow109
Post by Shadow109 »
A new Trim for steering column :-
this trim is from VW Ateron PR: 3G0858559D
the reason why I choose this trim is because it had palce for the adjustment handle (similar to T5) as the handle in my current steeing column will disturb the dash lower cover
WhatsApp Image 2024-10-30 at 21.06.21_fe1ba9f4.jpg (67.91 KiB) Viewed 5562 times
WhatsApp Image 2024-10-30 at 21.06.21_ca398729.jpg (80.57 KiB) Viewed 5562 times
I hope is will fit perfectly or I will have to make my own handle
Shadow109
Post by Shadow109 »
Sine MFSW via Lin horn had worked with Egor after he flashed 7E0 BCM to 1S0, this means that the flash itself is not missing the data only the physical pins, So I am thinking maybe we should try flashing 7E0 with 1S0 SW then copying EEPROM from the original 1S0 BCM to the new one..
Anyone had experience with reading full EEPROM from a PQ25 BCM??
I know VCP or odis-E could help
This video explains how to read EEPROM from pq35 bcm, unfortunately it doesn’t work for pq25 :-
https://youtu.be/rYAKHxwtZVM?si=4lCKRwdyBDHribtC
til3tsio
Drives: Seat Toledo KG
Post by til3tsio »
I have original vcp.
It has a PQ25 parameters editor.
But I dont have access to 1S0...M bcm to see the parameters
Shadow109
Post by Shadow109 »
replacing the front windshield :-
WhatsApp Image 2024-11-17 at 09.19.20_ecadbd6e.jpg (410.84 KiB) Viewed 5272 times
WhatsApp Image 2024-11-17 at 09.19.20_fe6ebcef.jpg (309.55 KiB) Viewed 5272 times
WhatsApp Image 2024-11-17 at 09.19.20_19906f7f.jpg (111.98 KiB) Viewed 5272 times
after replacing the windshield I had modified the camera parameters in adaptions, the basic settings fault had disappeared
the Suprise was that the lana assist started to work on the dashboard CAnbus, but sadly there is no notification on the dashboard about lane assist at all
https://youtube.com/shorts/gFeS2VHeYW8? ... aRnIIXqqBl
still need more digging to try to display it on the dashboard :D
til3tsio
Post by til3tsio »
That's great !
Can you clarify :
1. with what bcm / software combination did you manage to succeed
2. How do you control the assistant, I suppose you wired a button to act as the assistant button on UP!
3. Do you have the appropriate indicators soldered in your cluster ? Is your eeprom activated for the assistant as on pq35 ?
Shadow109
Post by Shadow109 »
1. I have used my usual BCM without Any changes
BCM : 7E0937090E H84 0772
Cluster: 7E0920980S H04 1109
2. I didn't installed the button yet
3. I have modified the eeprom for lane assist as pq35 but still no lane assist or sign assist menu, and sadly the T6 hadn't lane assist indicators in its dashboard
I have no fault for missing indicators, I don't get a worning on the dash when I remove my hands from the steering wheel
you can say that the cluster doesn't communicate with A5 at all
here is my last scan :-
Sunday,17,November,2024,17:02:58:22797
www.Ross-Tech.com
Chassis Type: 7H-VN75 (7E0)
Scan: 01 03 04 05 08 09 10 13 14 15 17 19 20 25 2B 3C 44 47 55 5F
          61 65 6C 6D A5 0B
VIN: WV1ZZZ7HZDH036544   Mileage: 352290km-218902miles
05-Acc/Start Auth. -- Status: OK 0000
14-Susp. Elect. -- Status: OK 0000
A5-Frt Sens. Drv. Assist -- Status: OK 0000
   Revision: 22H34---    Serial number: 00000000000000 CVN: 29387363
   Shop #: WSC 43690 085 00000
Readiness: 0 0 0 0 1
Address 05: Acc/Start Auth. (J518)       Labels:. User\5K0-959-434.clb
   Coding: 032C1C
   ROD: N/A
   Revision: 00001005
   Coding: 0000000002
   Revision: B9084001    Serial number: 2502 306190145
   Coding: 22B03D3E4EFF201281280F817EEB9FDDFF86660F608D79C073E4503F0860
   Shop #: WSC 12345 123 61029
   VCID: AD0CE4A37D142EB244D-80F8
   Coding: 0228EE
   Subsystem 4 - Part No: 1K0 951 605 C
   Subsystem 5 - Part No SW: 7E0 959 442 A    HW: 7E0 959 442 A
   Component: E221__MFL-DC1  H02 0103
   Serial number: 39180000000570018056
   Coding: B4FFFF
   Coding: 0041155041
1 Fault Found:
12718592 - Databus
          U1121 00 [00001001] - Missing Message
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 229
                    Mileage: 352297 km
                    Date: 2024.11.17.
                    Time: 03:14:58
   Coding: 030180
   Coding: 140E230B00
   Revision: B9084001
   Coding: 04220F
   VCID: E88255B79276CB9A77B-80BC
   Revision: AA001001
   Serial number:
   Coding: 000007
   Coding: 529524A0
   ROD: N/A
   Coding: 000000000100000000000200010001000100010001
   Data carrier:
2 Faults Found:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 229
                    Mileage: 352297 km
                    Date: 2024.11.17.
                    Time: 03:14:58
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 229
                    Mileage: 352297 km
                    Date: 2024.11.17.
                    Time: 03:14:58
   Part No SW: 7E0 907 534     HW: 7E0 937 090 E
   Component: Batt.regelung H84 0772
   Coding: 330B1A73
1 Fault Found:
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 250
                    Mileage: 150182 km
                    Date: 2024.01.14
                    Time: 14:07:40
                    passive
   Coding: 01020706020004010002105481D6850087000E01002000
End----------(Elapsed Time: 01:58, VBatt start/end: 12.1V/12.1V)-----------
til3tsio
Post by til3tsio »
Thanks for the details,
I see that you have an HBA mirror, do you know if it is possible to use HBA from the A5 camera instead of the mirror?
I am asking because I am exploring mounting possibilities for the A5 camera in my Toledo,
unfortunately, there is no windscreen for my car with a camera mount and I do not know if something else fits, so I will I have to improvise.
I got a "universal" mount from Ali that I can stick lower than the mirror but, in this way, my HBA’s mirror camera view would be blocked and I would have to replace it with a non-HBA one.
RobertVW
Drives: T6
Post by RobertVW »
You could consider extracting the camera lens module out if the whole assembly and extending the ribbon tape.
Example below.
https://mqb.pl/en/tutorial-retrofiting- ... 5q0980653/
til3tsio
Post by til3tsio »
RobertVW wrote: Fri Jan 10, 2025 10:35 am You could consider extracting the camera lens module out if the whole assembly and extending the ribbon tape.
Example below.
I have seen this solution but when I asked some "experts" the answer that I got was that this trick does not work on the 3q0 cameras because of the long ribbon so I haven't tried it.
do you know any working examples ?
zzm202000
Drives: Caravelle
Post by zzm202000 »
Shadow109 wrote: Tue Dec 29, 2020 5:42 pm So finally I’ve got the new slip ring and the stalk
I have make all the additional wiring like Adams digram, no faults on vcds, but still no high beam, and the high beam light on the cluster is always on
Shadow 109
Can I ask you about the wiring of the control buttons on this steering wheel?
I also installed the same steering wheel as yours on my 2014 T5 Caravelle.
The difference is that mine is a DSG gearbox. Can you help me set it up?
zzm202000
Drives: Caravelle
Post by zzm202000 »
Shadow 109
Shadow109
Post by Shadow109 »
Did you had an oem mfsw before?
An autoscan will help
