The issue was the seal was streched af. loose as Mia Khalifa. The small connector seal was tight.
It went smooth without seal. I got it in the end first from the bottom... somehow (seal is on). All assembled except the SB fuse power i was to drained(tired)... the ecu connector got me. Tried to put it back like 30 times. Forcing to much no no that lever would break.
Board computer works ok.
One thing i dont like i can hear the g85 like plastic on plastic sound grinding.
I think i will use a add a circuit fuse. ( that extender thingy) The to many wires to splice into them not sure how the fuse box will fit ( i did take it off but returned it..)
Counted like 9 times to make sure it 64 (9-th pin from the start)
- IMG_20250516_124724.jpg (2.35 MiB) Viewed 1563 times
- PXL_20250516_111847567.jpg (1.86 MiB) Viewed 1552 times
white-green pin 64
- PXL_20250516_111850624.jpg (1.68 MiB) Viewed 1549 times
I put extra heatshring over the wire, and zip tied everything.
The ecu part was simple, just the connector seal was awful and took the most time.
- IMG_20250516_133821.jpg (1.93 MiB) Viewed 1563 times
- Snapchat-624186402.jpg (895.65 KiB) Viewed 1563 times
Sorry, can you confirm what im thinking.
I have made a loom like this.
T41 ( pin 28) splits to SB11 and to BCM 73A pin (44).
Since the connector 73A allready had pin 44 populated.
I just isolated my pin 73A (44) in my loom, and will be conecting just the SB11 part and ofc t41-28 i inserted.
