ciclo. Wife's Golf MK7.5 Ready2Go 1.0 TSI 6MT 200Nm/l 115HP. 🧙‍♂️
Re: ciclo. Wife's Golf MK7.5 Ready2Go 1.0 TSI 6MT 200Nm/l 115HP. 🧙‍♂️
Golf 7.5. DCC Suspension. Fine-tuning for dataset V03935317XE. Spring-to-Dataset Frequency Matching.
As far as I am aware, the dataset V03935317XE belongs to the 'Arteon Elegance, R-line' versions... (without going into infinite variables and technical details).
This is the dataset I intentionally chose for the DCC unit '5Q0907376C' of my Golf 7.5 with 'factory standard suspension' when I installed the DCC suspension.
Address 14: Susp. Elect. (J250) Labels: 5Q0-907-376.clb
Part No SW: 5Q0 907 376 C HW: 5Q0 907 376 A
Component: DAEMPFUNGS-SG H17 0130
Serial number: 31051841350252 Dataset Number: V03935317XE 0001
ASAM Dataset: EV_DRCONTITEMIC 001019
ROD: EV_DRCONTITEMIC_VW37.rod
VCID: 392FD09879DE79A289D-806C
They are excellent dataset for making 'my' Golf feel like it's on a magic carpet at all adjustment levels (1-15 on the slider - Individual MODE-).
Since then, enough time has passed to accurately understand and test all these suspension settings on all types of roads.
But, in Slider position 1, for 'extra' maximum comfort, and when driving over a very specific speed bump, and only on this particular bump with a very high hump, the rear suspension bottoms out. This doesn't happen in Slider position 2 or higher. It's a very, very specific issue.
Since I have to drive over this speed bump every day, I'm going to correct this small 'deviation'.
To prevent the rear suspension from bottoming out in Slider position 1 when going over this bump, I am going to opt for a mechanical solution: 'Original' Sport springs to lower the ride height by 15mm (not GTI, not R). This will allow me to maintain the same comfort across all 15 levels but within the range expected by this dataset V03935317XE... I might even get a slight improvement at the maximum sport setting.
Note:
In no case is my intention to reduce the height of the body, only to try to correct this slight 'deviation'. The small 15mm suspension lowering is just an addition to ensure that everything is in 'harmonic frequency'.
After collating a lot of data regarding the factory configuration of my Golf 1.0 TSI, manual gearbox, to choose the appropriate original sport springs (-15mm), I come to the following conclusion:
-Front springs.
From factory 5Q0411105GH (PR codes: G05 2UA) to 5Q0411105HA (PR codes: G06 2UC).
-Rear springs.
From factory 5Q0511121AC (Pr codes: 1JA 0YC) to 5Q0511121CC (Pr code: 1JC or 1JD + 0YC).
Eibach is perhaps the world's best manufacturer of springs, so the cross-references Eibach ERL for these original springs are:
Front: 5Q0411105HA ... R13936
Rear: 5Q0511121CC ... R11078
In Eibach, ERL stands for Eibach Replacement Line. This series is specifically designed as an Original Equipment (OE) quality replacement alternative.
Technically speaking, getting this exceptional Arteon dataset to work perfectly or align with the configuration of 'my' Golf and my retrofitted DCC suspension is a real labyrinth. I suppose I'd need a specific program for all sorts of calculations based on weights and inertias, but since all I have is my car and my senses, I'm going to try this new configuration.
My logic tells me I'm on the right track...😅
I will install these new springs according to erWin, just as I did when installing the DCC suspension, plus the basic settings of the units involved with ODIS S.
Looking at the new bolts I'm going to replace, you can probably guess how to do an efficient installation of springs. The remaining six small new nuts and bolts are in the garage, I had them left over from when I installed the DCC shocks.
I will do the installation when the environmental and surrounding conditions are most favorable. 🌄
I will report the results.
In any case, with the standard springs and this dataset, everything works really well, so this small adjustment wouldn't be necessary at all.
Finding the solution to this specific issue is purely a personal matter.👽
https://www.youtube.com/watch?v=LvWVTpG_Riw
A few small details to keep in mind when installing new springs on a Golf 7/7.5
From least to most important:
1- Remember that the rubber stop has its housing...
... for some, this point doesn't seem entirely clear.
2- A great idea for holding the parts while releasing the spring compressor.
...and avoiding having to struggle with them. :arrow: https://youtu.be/LGgka_ytHH4?t=173 👍
3- Torque update for bolt WHT005437A according to erWin:
e2018
Related: :arrow: viewtopic.php?p=603218#p603218
IMHO, it's best to apply full torque with the car jacked up (to protect the wheel bearing).
e2023
I don't know if this is due to the bolt's Property Class/Grade or the lateral preload applied to the wheel bearing.
Which engineer is responsible for this new torque on this bolt that also applies to the Golf 8? :mrgreen:
Remember not to use an impact wrench, or the bearing will be damaged, and in a few thousand kilometers/milles you'll have to replace it...
When summer temperatures are more favorable, I'll install the Eibach ERL sport springs, it's still too hot.💦
https://www.youtube.com/watch?v=2zJx2R7TuDY
Test on the front shock absorber springs:
"Dual-Wall Adhesive-Lined FR Polyethylene Tubing".
Retraction ratio: 3:1. Diameter used: 15.4 mm. Final wall thickness: 1 mm.
This is an additional measure to avoid possible noise, oxidation/corrosion, and the use of inappropriate lubricating greases in metal-to-metal spring contact areas (especially copper grease).
To avoid arguments, this is an AI recommendation.😁
It might not be necessary on the front spring of the Golf 7.5, but it's the additional measure that I'm also going to apply to the springs of our Polo 6R in all areas where the springs are in metal-to-metal contact, which they are all, except at the top of the rear 6R springs.
https://www.youtube.com/watch?v=lL0srxY5NOA
😲...Fascinating, Supreme...😍
Since I'll be working on the rear axle sometime in the next few days :) , I'm going to replace the rear ABS speed sensors. It's something I've been thinking about and looked into for a while now.
The currently installed ones, version B, work perfectly for all the systems involved, but the new version C seems to be more accurate and effective.
Explanation from AI after some discussion :lol: and sharing my knowledge:
- Rear ABS Sensor Evolution MQB, etc... (1X0): WHT003864B vs WHT003864C (ETKA Supersession)
Quick technical breakdown regarding the evolution of the rear wheel speed sensors (ABS/ESC) for MQB platforms (etc.), specifically the supersession from version B to version C in ETKA.
Even though ETKA states it is a direct replacement, there is a clear geometric redesign of the sensing tip: version B looks like a "golf club", while version C features a "cricket bat/paddle" shape.
Here is the engineering rationale behind this hardware revision:
1. Sensing Window Optimization (Active Hall-Effect).
-Version B ("Golf Club"): Focused the sensor element on a very narrow area. Highly sensitive to air gap fluctuations (distance between the sensor tip and the wheel hub's magnetic ring).
-Version C ("Cricket Bat"): Broadens the magnetic flux capture area. By widening the reading surface, the sensor becomes significantly more resilient to wheel bearing axial play or hub vibrations under heavy cornering/rough roads, preventing signal dropouts.
2. Electromagnetic Noise Immunity & Hysteresis. The internal circuitry of version C was upgraded to enhance magnetic noise filtering. Modern driver-assist features (ACC Stop&Go, Front Assist, Park Assist) demand an ultra-clean square wave signal. Version C minimizes signal "noise" that typically triggers intermittent dashboard Christmas trees.
3. Debris & Brake Dust Deflection. The flat, streamlined profile of the C-version tip alters the micro-airflow inside the hub cavity. This prevents brake dust (ferodo) and metallic rust flakes from accumulating on the sensor face—a common issue on the older B-version that caused sensor blindness over time.
🛠️ Installation Pro-Tips for Enthusiasts.
Compatibility: 100% Plug & Play. No coding or adaptation via VCDS/OBDeleven required.
Proper Fitment: Clean the knuckle bore thoroughly using a nylon brush and brake cleaner. NEVER use copper grease (suspended metal particles will magnetize, attracting debris and disrupting the Hall-effect readings). Install it completely dry or apply a micro-layer of 100% metal-free/dielectric ceramic grease only on the plastic body to prevent galvanic corrosion and future seizing inside the knuckle.
In my humble opinion, and I'm sorry to say, the best thing you can do right now is throw the copper grease away and use new lubricating greases.
Copper grease was very useful and effective for brainless iron cars 🤭, but nowadays it can be the cause of many problems.
Additional note:
The 'front ABS speed sensors' were also updated (to version B, WHT 003 860B, WHT 003 861B -> "cricket bat/paddle" shape), but those were already included in the new steering knuckles I bought for my DCC project.
🦉 :lol:
https://www.youtube.com/watch?v=73-yVb3wYwY
I've already removed the plenum chamber covers in the engine bay for 'easy access' to the upper shock absorber bolts (3 min), so replacing the suspension springs is now a must...
Note the 'free' wiper repositioning marks. V6 sound
Step by step...💦😄
https://www.youtube.com/watch?v=_7ycfSVn6Cw
...while the temperatures gradually improve, which will allow me to work 'enthusiastically' on replacing the sport springs for the DCC electronic suspension, etc... I'm also thinking about improve the heated seats to ventilated seats too, just like Slavik did :arrow: https://www.drive2.ru/l/735946289375612745/
It's easy, although a very fun process. 😄
Hmm... so, let's try out these ventilated seats and see if they're worth it.
The ventilated seats are wonderful in my climate zone... that with/along the air suspension and other little things (full package) of this Porsche Panamera ST, it feels like you're living on Mount Olympus/Heaven... of the Gods.
In reality, I'm still doing some diagnostics/codings 💨 on family vehicles with the PIWIS -'Spectrum 82'- 😁 before starting with the Golf 7.5 springs replacement.
This V6 sounds delicious (just the way you like it... ...VROOOOOOOAMMMMMM...STUTUTU...BANG...POP...CRACKLE...BANG...FLAME-POW...PATA-PATA-PATA...TUTUTUTU-TATATA...BURBLE...😂) without any fantastic Soundaktor. 🤭
https://www.youtube.com/watch?v=l7mnTGVYY9Q
Golf 7.5. DCC Fine-Tuning - 'OEM' Sport Springs Installation. Result. Absolute Success!
Update on my Golf MK7.5 (1.0 TSI DKRF 6MT) DCC fine-tuning journey.
Previous info: :arrow: viewtopic.php?p=610536#p610536 (read this page).
Following up on my last post regarding the minor bottoming-out issue with the Arteon dataset (V03935317XE) on extreme speed bumps in Slider Position 1 (maximum comfort), I finally pulled the trigger on the mechanical solution: fitting the OEM-equivalent sport springs (-15mm).
For those interested, I went with the Eibach Replacement Line (ERL) Sport range:
- Front: 5Q0411105HA (Eibach ref: R13936)
- Rear: 5Q0511121CC (Eibach ref: R11078)
Installation. 'Highlights'.
Simply showing an easy and efficient way to proceed without damaging the parts.🤭
Front.
If you need more information you can consult erWin, the posts dedicated to installing DCC suspension in this thread, or 'some' video tutorials on YouTube.
Rear.
After letting the springs settle for a brief period, I hooked up the car to ODIS Service to perform the basic adaptation for both the DCC and the Matrix LED headlights.
As expected, the DCC basic calibration went flawlessly with all four wheels completely off the ground (unloaded suspension).
Since this process reads the maximum extension voltage —which is dictated by the dampers' full travel and not the springs— the car drove just as beautifully before and after the ODIS reset. :arrow: viewtopic.php?p=603950#p603950
However, the Matrix headlights calibration was absolutely necessary due to the geometry change. :arrow: viewtopic.php?p=582892#p582892 , viewtopic.php?p=582906#p582906
Driving Impressions: Absolute Success!
To put it bluntly, this has been an absolute triumph. The speed bump where the rear torsion beam used to clunk/bottom out at 50 km/h in Slider Position 1 (max comfort) I can now smoothly glide over it at up to 70 km/h 😄 with zero drama. The damper valves are now operating perfectly within their optimal hardware window, the overall driving dynamics have been completely transformed without sacrificing a single bit of comfort.
-Slider Position 1 (Max Comfort): Incredibly plush, but now with a perfectly controlled rebound.
-The 15 Slider Steps: The entire adjustment range now feels crisp, refined, and exquisite.
-Slider Position 15 (Max Sport): It was already fun before, but now the car feels 'brand new', the highway lane changes and steering feedback are ultra-precise and direct.
It is incredibly fun to drive.🤸‍♂️
IYRC...
The R button is definitely the perfect match for the DCC, way easier to operate than the center console MODE button.
Aesthetics & Ride Height.
Even though these springs are technically rated for a -15mm drop, on my lightweight 1.0 TSI manual setup, they yielded closer to a -20mm drop. They will likely settle a tiny bit more over the coming kilometers, but the current stance is absolutely perfect. It doesn't look slammed or impractically low, it sits beautifully, looking much closer to a factory R-Line. Overall, I couldn't be happier with how this retrofit turned out.
Mechanical harmony achieved! 🎉💪🤗
Luxferre vs. Lucifer. ⚖️
One final recommendation:
Even if your Golf doesn't have the DCC system and you are running the standard factory suspension, I highly recommend upgrading to the Eibach ERL Sport range.
The mechanical improvement in body control, reduced body roll, and steering precision —all while maintaining excellent daily comfort— is absolutely worth it. Just keep in mind that you need to look up the exact part numbers for your specific configuration, depending on your engine, gearbox, and whether you have a torsion beam or a multilink rear axle.
I might edit this post with some new images, data... and, for the time being, I decided not to install the new rear ABS sensors 'C' during the DCC fine-tuning tests and not to mix concepts.
https://www.youtube.com/watch?v=t13htKovSvM
Yesterday, Sunday, I took a ride along one of those winding, twisty mid-mountain roads that you and I love. The plan was to test Comfort mode on broken asphalt (small handling details), but I was surprised to find that the road surface had been exquisitely resurfaced (brand new!), so the ride was a delight in Sport mode without reaching lightning speed.
ImageThree fingers.👌 8)
BTW, the ABS pump sensors are fully aware of the new geometry so the ABS system can apply the appropriate/perfect brake pressure, both for the ACC system and the DCC driving modes. It's great! Kudos to the developers.🤗
VCDS Autoscan.
Sunday,06,September,2026,10:27:06:32438
VCDS Version: 26.9.0.3 (x64)  HEX-V2 CB: 0.4713.4
Data version: 20260828 DS378.0
www.Ross-Tech.com
VIN: WVWZZZAUZKPCICLOW   License Plate: SPORT SPRING TESTS. OK!
Mileage: 68468km-42544mi   Repair Order:
Chassis Type: AU-VW37 (3Q0)
Scan: 01 03 08 09 10 13 14 15 17 19 29 39 3C 42 44 4B 52 5F 65 6C
          A5 A9 D6 D7
VIN: WVWZZZAUZKPCICLOw   Mileage: 68468km-42544miles
14-Susp. Elect. -- Status: OK 0000
29-Left Light -- Status: OK 0000
39-Right Light -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
4B-Multifunc. Module -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
A5-Frt Sens. Drv. Assist -- Status: OK 0000
A9-Struct. Borne Sound -- Status: OK 0000
D6-Light Ctrl Left 2 -- Status: OK 0000
D7-Light Ctrl Right 2 -- Status: OK 0000
Address 01: Engine (J623-DKRF)       Labels:. 04C-907-309-V1.clb
   Part No SW: 04C 906 025 L    HW: 04C 907 309 BB
   Component: R3 1.0l TFS   H20 6198
   Revision: D7H20000    CVN: 92B19492
   Coding: 01190032234415082000
   Shop #: WSC 00046 123 12345
   ASAM Dataset: EV_ECM10TFS01104C906025L 002003
   ROD: EV_ECM10TFS01104C906025L_002_VW37.rod
   VCID: 290F00D8897EC92290E-807C
   VINID: 9E69EAAAA465A9B8000041051C011774D2
Readiness: 0100 0000
Address 03: ABS Brakes (J104)       Labels:. User\5Q0-907-379-IPB-V1.lbl
   Part No SW: 5Q0 614 517 DD    HW: 5Q0 614 517 AC
   Component: ESC           H25 0424
   Revision: 00000000    Serial number: 51998000000173
   Coding: 01FA6AA134202170477B060560CA2580562C84E26006A4733420F08A40AA430B00000012121212B835351919323200
   ASAM Dataset: EV_Brake1UDSContiMK100IPB 037009
   ROD: EV_Brake1UDSContiMK100IPB_037_VW37.rod
   VCID: 76B51BA40840D6DACDC-8022
Address 08: Auto HVAC (E87)       Labels:| 5G0-907-044.clb
   Part No SW: 5NA 907 044 AJ    HW: 5NA 907 044 AJ
   Component: AC Automat    H50 1301
   Revision: 20K03000    Serial number: 00000A00202735
   Coding: 000100032001100D1115004C0018542A
   Shop #: WSC 12345 123 12345
   ASAM Dataset: EV_ACTouchPrehVW37X 001010
   ROD: EV_ACTouchPrehVW37X_VW37.rod
   VCID: 074B66607FAADF52A6A-8052
   Air quality sensor:
   Humidity sensor: exterior:
   Subsystem 2 - Part No SW: 4H0 907 658 D    HW: 4H0 907 658 D
   Component: G935 MuFu  H05 0010
   Serial number: AAE88B8400PAG0MUFU05
Address 09: Cent. Elect. (J519)       Labels:. 5Q0-937-08X-V2.clb
   Part No SW: 5Q0 937 084 EC    HW: 5Q0 937 084 EC
   Component: BCM MQBAB H   H44 1513
   Serial number: B2701012406040 Dataset Number: V03935315NT 0001
   Coding: 000000000000000000000000000000000000000000000000000000000000
   Shop #: WSC 00000 000 00000
   ASAM Dataset: EV_BCMMQB 022001
   ROD: EV_BCMBOSCH_022_VW27.rod
   VCID: 7DA704882D7685828C6-8028
   Wiper motor control module:
   Subsystem 1 - Part No SW: 5G1 955 119 A    HW: 5G1 955 119 A  Labels: 5QX-955-119-V1.CLB
   Component: WWS    180621  043 0551
   Serial number:         180705074106
   Coding: 0F4DFD
   Rain/Light Recognition Sensor:
   Subsystem 2 - Part No SW: 5Q0 955 547 C    HW: 5Q0 955 547 C  Labels: 5Q0-955-547.CLB
   Component: RLHS  054 0206
   Serial number: SBY22M01D06H23M07S44
   Coding: 00A8DD
   Anti-theft alarm system sensor:
   Subsystem 3 - Part No SW: 5Q0 951 172     HW: 5Q0 951 172
   Component: Sensor, DWA  005 0316
   Serial number: 000000000ZY191251XZQ
   Alarm horn:
   Subsystem 4 - Part No SW: 5QD 951 605     HW: 5QD 951 605
   Component: Sirene, DWA  005 0313
   Serial number: 00002854456462182207
   Steering Column Switch:
   Subsystem 5 - Part No SW: 5Q1 953 507 GB    HW: 5Q1 953 549 F
   Component: J527 SMLS MQB  005 0080
   Serial number: 00000023032104400679
Address 10: Park/Steer Assist (J791)       Labels:| 5Q0-919-298.clb
   Part No SW: 5QA 919 298 K    HW: 5QA 919 298 A
   Component: PLA 3.0 12K   H07 0073
   Serial number: 000308417318277 Dataset Number: V03935313MC 0001
   Coding: 8271567841
   Shop #: WSC 00046 000 00000
   ASAM Dataset: EV_EPHVA2CAU3700000 009055
   ROD: EV_EPHVA2CAU3700000_009_VW37.rod
   VCID: 58E9751CE29480AAFF0-800C
Address 13: Auto Dist. Reg (J428)       Labels:| 5Q0-907-572-V2.clb
   Part No SW: 5Q0 907 572 S    HW: 3QF 907 572 A
   Component: ACC BOSCH MQB H11 0780
   Dataset Number: V12345678AA V310
   Coding: 2B0D67E35DFFC728979C81A4614006800000000000B9C00024
   ASAM Dataset: EV_ACCBOSCHVW416 003015
   ROD: EV_ACCBOSCHVW416_003_VW37.rod
   VCID: 47CBA6603F2A1F5266A-8012
   VCID: 392FD09879DE79A2E0E-806C
Address 15: Airbags (J234)       Labels:| 5Q0-959-655.clb
   Part No SW: 5Q0 959 655 BJ    HW: 5Q0 959 655 BJ
   Component: AirbagVW21    006 0339
   Serial number: 003VWR4F1CUQ Dataset Number: V03935272MG 0001
   Coding: 98CCC000000000005C0000CF000800000065
   Shop #: WSC 00028 028 00064
   ASAM Dataset: EV_AirbaVW20SMEVW37X 002160
   ROD: EV_AirbaVW20SMEVW37X_VW37.rod
   VCID: 094F605869BEA922B0E-805C
   Left seat belt tensioner:
   Subsystem 1 - Part No SW: 5G0 980 945 B    HW: 5G0 980 945 B
   Component: BeltPretRevFL  H37 0350
   Serial number: 34169667E30071820325
   Coding: 333135
   Right seat belt tensioner:
   Subsystem 2 - Part No SW: 5G0 980 946 B    HW: 5G0 980 946 B
   Component: BeltPretRevFR  H37 0350
   Serial number: 34169668E31071830145
   Coding: 333135
   Subsystem 3 - Part No SW: -----------    HW: 480 002 307 18
   Component: SideSensor_Df  001 0887
   Serial number: 35700000000F8745C23S
   Coding: 2D2D2D
   Crash sensor for side airbag: passenger side:
   Subsystem 4 - Part No SW: -----------    HW: 480 002 807 18
   Component: SideSensor_Pf  001 0887
   Serial number: 358000000000EC18233G
   Coding: 2D2D2D
   Crash sensor for side airbag: driver side rear:
   Subsystem 5 - Part No SW: -----------    HW: 480 403 107 18
   Component: SideSensor_Dr  003 6149
   Serial number: 3510001A729FD154210-
   Coding: 2D2D2D
   Crash sensor for side airbag: passenger side rear:
   Subsystem 6 - Part No SW: -----------    HW: 480 403 107 18
   Component: SideSensor_Pr  003 6149
   Serial number: 3520001A929FD1515577
   Coding: 2D2D2D
   Subsystem 7 - Part No SW: -----------    HW: 480 402 306 18
   Component: FrontSensor_D  003 6149
   Serial number: 3550001A326704A3C63.
   Coding: 2D2D2D
Address 17: Instruments (J285)       Labels:| 5G0-920-XXX-17.clb-SRI3
   Part No SW: 5G1 920 791 B    HW: 5G1 920 791 B
   Component: KOMBI         404 4191
   Coding: 07A532807E8C000801887A0F5401000080000000
   ASAM Dataset: EV_DashBoardVDDMQBAB 009058
   ROD: EV_DashBoardVDDMQBAB_009_VW37.rod
   VCID: 2B03FAD08382DB32622-807E
Address 19: CAN Gateway (J533)       Labels:| 3Q0-907-530-V1.clb
   Part No SW: 3Q0 907 530 AR    HW: 3Q0 907 530 C
   Component: GW MQB High   521 5502
   Serial number: 09012020001767 Dataset Number: FPA_SL_ME_R 0001
   Coding: 030900047F085700DB0002FE881F00010001070000000000000000000000
   GVL: 014E3C100000000040CC800000024C0000000000000200000000000000000000
   ASAM Dataset: EV_GatewNF 013026
   ROD: EV_GatewNF_VW37.rod
   VCID: 7F5BFE80277A97929EA-802A
   Generator:
   Component: 5-01-14-01-04
   Multi-function steering wheel control module:
   Subsystem 2 - Part No SW: 1EA 959 442 F    HW: 1EA 959 442 F
   Component: MFL  H50 0420
   Serial number: 17044958021162102894
   Coding: AE2B00
   Subsystem 3 - Part No SW: 5Q0 915 181 K    HW: 5Q0 915 181 K
   Component: J367-BDMHella  H10 9070
   Serial number: 9353818504
Address 29: Left Light (J1018)       Labels: 8V0-907-399.clb
   Part No SW: 8V0 907 399 D    HW: 8V0 907 399 D
   Component: LCM_MLBevoH08 0014
   ASAM Dataset: EV_LCMLeftHELLAAU736 001012
   ROD: EV_LCMLeftHELLAAU736_VW37.rod
Address 39: Right Light (J1023)       Labels: 8V0-907-399.clb
   ASAM Dataset: EV_LCMRightHELLAAU736 001012
Address 3C: Lane Change (J1086)       Labels:| 2Qx-907-686-V2.clb
   Part No SW: 2Q0 907 686 B    HW: 2Q0 907 686 B
   Component: HRE3_Kl15_Mst H07 0150
   Serial number: 00000587514012
   Coding: 52A54640
   ASAM Dataset: EV_HREntryHellaGen3Kl15 002001
   ROD: EV_HREntryHellaGen3Kl15_002_VW27.rod
   Lane change assistance control module 2:
   Subsystem 1 - Part No SW: 2Q0 907 685 B    HW: 2Q0 907 685 B
   Component: HRE3_Kl15_Slv  H07 0150
   Serial number: 00000587481913
Address 42: Door Elect, Driver (J386)       Labels:* Redir Fail!
   Part No SW: 5Q4 959 593 P    HW: 5Q4 959 593 P
   Component: TSG FS        011 0912
   Serial number: 0000417322781  Dataset Number: V03935341UB 0001
   Coding: 00150220D000048000001000
   Shop #: WSC 00030 935 00052
   ASAM Dataset: EV_DCU2DriveSideMAXHCONT 001005
   ROD: EV_DCU2DriveSideMAXHCONT_VW37.rod
   VCID: 52FD8734C468AAFA014-8006
   Left rear door control module:
   Subsystem 1 - Part No SW: 5Q4 959 811 F    HW: 5Q4 959 811 F  Labels: 5QX-959-81X-V1.CLB
   Component: Fond FHSG DRV  010 0004
   Serial number: 00000000000009798407
   Coding: 010000
Address 44: Steering Assist (J500)       Labels:| 5Q0-909-144.clb
   Part No SW: 5Q0 909 144 AB    HW: 5Q0 909 144 AA
   Component: EPS_MQB_ZFLS  131 1082
   Dataset Number: V03935287HR 0001
   Coding: 931F0000
   ASAM Dataset: EV_SteerAssisMQB 015157
   ROD: EV_SteerAssisMQB_015.rod
   VCID: 74B121AC1E3CC4CAF38-8020
Address 4B: Multifunc. Module (J745)       Labels:| 3Q0-907-338-V2.clb
   Part No SW: 3Q0 907 338 E    HW: 3Q0 907 338 E
   Component: FCM MQB Low   003 0371
   Serial number: 01081930001280 Dataset Number: V03935292JZ 0001
   Coding: 00000005090016C206207F07620000000000000000000000000000000000
   ASAM Dataset: EV_MultiModulContiVW48X 003003
   ROD: EV_MultiModulContiVW48X_003_VW27.rod
   VCID: 372BD6A04FCA6FD216A-8062
Address 52: Door Elect, Pass. (J387)       Labels:| 5QX-959-X92-52.clb
   Part No SW: 5Q4 959 592 P    HW: 5Q4 959 592 P
   Component: TSG BFS       011 0912
   Serial number: 0000423015792  Dataset Number: V03935341UE 0001
   Coding: 00150220DE00048000001000
   Shop #: WSC 00030 935 00034
   ASAM Dataset: EV_DCU2PasseSideMAXHCONT 001005
   ROD: EV_DCU2PasseSideMAXHCONT_VW37.rod
   VCID: 51FF8838C16ED1E238E-8004
   Right rear door control module:
   Subsystem 1 - Part No SW: 5Q4 959 812 F    HW: 5Q4 959 812 F  Labels: 5QX-959-81X-V1.CLB
   Component: Fond FHSG PSG  010 0004
   Serial number: 00000000000009846262
   Coding: 090000
   Part No SW: 3Q0 035 874 C    HW: 3Q0 035 874 C
   Component: MU-S-ND-ER    853 0879
   Serial number:                Dataset Number: 5G0CV1v____ 0001
   Coding: 02731001FF0000005111010100890AA31F0507E401200400CF
   ASAM Dataset: EV_MUStd4CDELP 001001
   ROD: EV_MUStd4CDELP_VW37.rod
   VCID: 323DE7B4A4A88AFA214-8066
   Display and control head 1 for information electronics:
   Subsystem 1 - Part No SW: 5G6 919 605 B    HW: 5G6 919 605 B
   Component: ABT_Std-2_Nav  H52 8130
   Serial number: VWZ6ZHV2691212
   Data carrier:
   Subsystem 2 - Part No SW: V03 959 822 MM    HW: -----------
   Component: ECE AS 25/26  --- 2410
   Part No SW: 5Q0 907 273 F    HW: 5Q0 907 273
   Serial number: 30000000250801 Dataset Number: RDKS_TinyQ_ 1017
   ASAM Dataset: EV_RDKBERU30 006001
   ROD: EV_RDKBERU30_006_VW37.rod
   VCID: 3829D59C42D460AA1F0-806C
Address 6C: Back-up Cam. (J772)       Labels:| 5Q0-980-556.clb
   Part No SW: 5Q0 980 556 B    HW: 5Q0 980 556 B
   Component: RVC Compact   H18 0231
   Dataset Number: V03935246NT 0001
   Coding: 01040201C600201F000060
   ASAM Dataset: EV_CamSysRVRVCPANAMQBAB 006009
   ROD: EV_CamSysRVRVCPANAMQBAB.rod
Address A5: Frt Sens. Drv. Assist (R242)       Labels:| 2Q0-980-653.clb
   Part No SW: 2Q0 980 653 J    HW: 2Q0 980 653
   Component: MQB MFK 3.0   H16 1423
   Serial number: E80320004213340 Dataset Number: V03935436AM 0001
   Coding: 0000018811EEC028889F2C801030004400438000000000000000000000000000
   ASAM Dataset: EV_MFK3ValeoMQB 007042
   ROD: EV_MFK3ValeoMQB_007_VW27.rod
   VCID: 3C21C98C76EC4C8AFB8-8068
Address A9: Struct. Borne Sound (J869)       Labels: 4H0-907-159.clb
   Part No SW: 5F0 907 159     HW: 4H0 907 159 A
   Component: SAS-GEN 2     H07 Z001
   Serial number: 181027201414
   ASAM Dataset: EV_SoundActuaGen2AU64X 003010
   ROD: EV_SoundActuaGen2AU64X_003_VW37.rod
   VCID: 6A8D3FD44CF8023A594-803E
Address D6: Light Ctrl Left 2 (A31)       Labels: 7PP-941-572.clb
   Part No SW: 7P5 941 572 A    HW: 7P5 941 572 A
   Component: LED1L         H06 0002
   ASAM Dataset: EV_LEDMinMaxL_KEBODAVW481 001003
   ROD: EV_LEDMinMaxL_KEBODAVW481_VW37.rod
Address D7: Light Ctrl Right 2 (A27)       Labels: 7PP-941-572.clb
   Component: LED1R         H06 0002
   ASAM Dataset: EV_LEDMinMaxR_KEBODAVW481 001003
End----------(Elapsed Time: 01:53, VBatt start/end: 12.8V/12.8V)-----------
---------------------------No fault code found.----------------------------
https://www.youtube.com/watch?v=HcZFPG3hrIA
Golf 7.5. Upgrade of rear ABS speed sensors from WHT003864B to WHT003864C.
Previous information: :arrow: viewtopic.php?p=610593#p610593 (READ).
Clear accumulation of debris -small particles- that forms a homogeneous layer around the ABS speed sensor tip.
C
Conclusion:
In my opinion, it is recommended to upgrade to the new version WHT003864C and/or clean the four ABS speed sensors every 60,000 km.
Same behavior as in the video. :arrow: https://www.youtube.com/watch?v=LabJhzGuRI8
https://www.youtube.com/watch?v=COOOoLO5WlQ
Golf 7.5. 8IU Led Headlights. NEW LIGHT SETUP. OK!
Highway lights and predictive route data disabled.
Why? Because it's annoying and tiring on long trips along the Highway.
With the 8IU LED headlights (LHD in this case, driving on the right) 'featuring variable light distribution', the right headlight casts a perfect beam—rising/turning slightly—to perfectly illuminate the shoulder, while the left headlight casts a shorter beam—dipping down—to avoid "potential" glare for oncoming traffic in Highway/Motorway.
This asymmetry instinctively compels me to constantly scan the shadowed area on the left side, which becomes tired on long journeys.👎
Once disabled, the performance of these 8IU LED headlights is fantastic, restoring the lighting to a logical, natural symmetry. The Dynamic Light Assist (DLA) -permanent high beams- works exactly as it should. In 99,9% of situations, it won't dazzle oncoming traffic, barring rare exceptions caused by the terrain, something that would happen regardless of the headlight type and road type
-Improvement: Better overall lighting. 'Guide Lights' permanently.
-Trade-off: The predictive Intersection Lights are lost. They're nice but not essential. The gap is filled by the static cornering lights (SCLs) that activate a second later when turning the steering wheel at intersections... I have SCLs enabled on both the main headlights -using the dedicated LED intersection light elements- and the/my LED fog lights. 💪 :arrow: viewtopic.php?p=582843#p582843
It is possible that some terms may not be understood due to lack of knowledge of the functions of these headlights.
The 8IU headlights -maximum headlights for Golf 7.5- are a marvel of science... 'if all their functions are well coded'. 🤭
Sunday,27,September,2026,07:26:12:32438
www.Ross-Tech.com
VIN: WVWZZZAUZKPCICLOW   License Plate: NEW LIGHT SETUP. OK!
Mileage: 68955km-42846mi   Repair Order:
          A5 A9 D6 D7
VIN: WVWZZZAUZKPCICLOW   Mileage: 68955km-42846miles
Readiness: 1110 0001
   Air quality sensor:
   Coding: 0F4DFD
   Coding: 00A8DD
   Alarm horn:
   Coding: 8271567841
   Coding: 333135
   Coding: 333135
   Coding: 2D2D2D
   Coding: 2D2D2D
   Coding: 2D2D2D
   Coding: 2D2D2D
   Coding: 2D2D2D
   Generator:
   Coding: AE2B00
   Coding: 52A54640
   Coding: 010000
   Coding: 931F0000
   Coding: 00000005090016C206207702220000000000000000000000000000000000
   Coding: 090000
   Data carrier:
End----------(Elapsed Time: 01:53, VBatt start/end: 13.3V/13.4V)-----------
Remember that every time 4B is coded, you must perform the Basic Setting procedure. :arrow: viewtopic.php?p=582892#p582892
Not related.
Warning:
I may be the first human to make AI vengeful. 🥇😈
https://www.youtube.com/watch?v=CgWcGAsn-Z0
Scheduled vehicle technical inspection (ITV, MOT, TÜV, etc.). 8 years-October 2026.
Successfully completed. PASSED, APPROVED. -FAVORABLE.
Online appointment.
Fifteen minutes. The engineers were very kind and friendly.🤗
Perfect!
https://www.youtube.com/watch?v=3a25ZzgS3Zk
Locked
